// avr_f64.c // Original Code by Detlef_a (Nickname in the www.mikrocontroller.net forum). // Extensions (trigonometric functions et al.) und changes by Florian Königstein, mail@virgusta.eu . // The following copyright information refers to the code developed by Florian Königstein. //***********************************************************************************************************// //***********************************************************************************************************// // // // avr_f64.c and avr_f64.h : Contains ANSI C Funktions for handling of 64 bit IEEE 754 double precision // // floating point numbers. // // float64_t represents an IEEE 64 bit double precision floating point number. // // // // Compiler: avr-gcc // // // // Copyright: // // You may use this program free of charge for any purpose you wish provided you agree to the following // // License: // // Warranty of Provenance and Disclaimer of Warranty. Licensor warrants that the copyright // // in and to the Original Work and the patent rights granted herein by Licensor are owned by the // // Licensor or are sublicensed to You under the terms of this License with the permission of the // // contributor(s) of those copyrights and patent rights. Except as expressly stated in the immediately // // preceding sentence, the Original Work is provided under this License on an "AS IS" BASIS and WITHOUT // // WARRANTY, either express or implied, including, without limitation, the warranties of // // non-infringement, merchantability or fitness for a particular purpose. THE ENTIRE RISK AS TO THE // // QUALITY OF THE ORIGINAL WORK IS WITH YOU. This DISCLAIMER OF WARRANTY constitutes an essential part // // of this License. No license to the Original Work is granted by this License except under this // // disclaimer. // // // // Limitation of Liability. Under no circumstances and under no legal theory, whether in tort // // (including negligence), contract, or otherwise, shall the Licensor be liable to anyone for any // // indirect, special, incidental, or consequential damages of any character arising as a result of // // this License or the use of the Original Work including, without limitation, damages for loss of // // goodwill, work stoppage, computer failure or malfunction, or any and all other commercial damages // // or losses. This limitation of liability shall not apply to the extent applicable law prohibits such // // limitation. // // // //***********************************************************************************************************// //***********************************************************************************************************// // IEEE754 denormalized numbers other than zero are not supported. If a denormalized number is passed // to a function, it is interpreted as zero. However, the functions f_sd() and f_ds() support denormalized single // precision floating point numbers. // All kinds of IEEE NaNs (Not a Number) are treated in the same way. If the result of a calculation // is NaN, the IEEE 754 NaN with HEX value 7fffffffffffffff is returned. // +INF and -INF are supported if F_ONLY_NAN_NO_INFINITY is NOT defined. If F_ONLY_NAN_NO_INFINITY is defined, // a function may yield NaN or +/-INF, but a +/-INF as argument for a function is interpreted in the same // way as NaN. Defining F_ONLY_NAN_NO_INFINITY results in a little bit smaller code size. // *** ATTENTION *** : The functions f_to_decimalExp() and f_to_string() return pointers to static memory // containing the decimal representation of the float64 passed to these functions. The string contained // in this memory will become invalid if one of the functions f_to_decimalExp(), f_to_string(), // f_exp(), f_log(), f_sin(), f_cos(), f_tan(), f_arcsin(), f_arccos(), f_arctan() is called as // these functions will overwrite the memory. // If this Library shall be compiled as C++ with avr-gcc (after renaming the file to avr_f64.cpp), // all integer constants larger than 32 Bits must get the ending LLU . #include "avr_f64.h" #ifdef USE_AVR #define LANGEEINS (1ull) #else #define LANGEEINS (1l) #endif static char TemporaryMemory[128]; #ifdef USE_AVR #define FLASHMEM_IF_AVR PROGMEM #else #define FLASHMEM_IF_AVR #endif #if defined(USE_AVR) && ( defined(F_WITH_sin) || defined(F_WITH_cos) || defined(F_WITH_tan) || defined(F_WITH_exp) || defined(F_WITH_log) || defined(F_WITH_arcsin) || defined(F_WITH_arccos) || defined(F_WITH_arctan) ) static void copy_from_flash_to_tempmem(void *address_in_flash, uint8_t nr_bytes) { uint8_t i; for(i=0; i>52) & 2047))) *frac=0; else if(2047!=(*f_ex)) *frac |= 0x10000000000000; *frac <<= lshift; *f_sign = ((*x)>>63) & 1; } #if defined(F_WITH_float64_to_long) || defined(F_WITH_exp) || defined(F_WITH_sin) || defined(F_WITH_cos) || defined(F_WITH_tan) || defined(F_WITH_arcsin) || defined(F_WITH_arccos) || defined(F_WITH_arctan) static void f_split_to_fixpoint(float64_t *x, uint8_t * f_sign, int16_t * f_ex, uint64_t *frac, int16_t point_bitnr) { // Liefert *frac=0, wenn x die Zahl Null darstellt f_split64(x, f_sign, f_ex, frac, 0); if(0!=(*f_ex) && 2047!=(*f_ex)) { point_bitnr=(1023+52)-(*f_ex)-point_bitnr; if(point_bitnr<=-64 || point_bitnr>=64) *frac=0; else if(point_bitnr<0) *frac<<=-point_bitnr; else *frac>>=point_bitnr; } } #endif static void f_combi_from_fixpoint(float64_t * x, uint8_t f_sign, int16_t f_ex, uint64_t *frac) { // Achtung: NaN kann mit dieser Funktion nicht erzeugt werden. // Wenn *frac==0 übergeben wird, wird Null erzeugt, falls f_ex<2047 ist, und sonst +/-INF. uint8_t round=0; uint64_t w=*frac; if(0!=w) { while(0==(w & 0xffffe00000000000)) { w<<=8; f_ex-=8; } while(0==(w & 0xfff0000000000000)) { w<<=1; --f_ex; } while(0!=(w & 0xff00000000000000)) { round = 0!=(w&(1<<3)); w>>=4; f_ex+=4; } while(0!=(w & 0xffe0000000000000)) { round = 0!=(w&1); w>>=1; ++f_ex; } if(round) { ++w; if(0!=(w & 0xffe0000000000000)) { w>>=1; ++f_ex; } } if(f_ex<=0) // Falls f_ex==0: Es werden keine unnormalisierten Zahlen außer Null unterstützt { f_ex=0; w=0; } // +0 oder -0 } else if(f_ex<2047) f_ex=0; if(f_ex>=2047) { f_ex=2047; w=0; } // +INF oder -INF *((uint64_t*)x)=(((uint64_t)f_sign)<<63) | (((uint64_t)f_ex)<<52) | (w & 0xfffffffffffff); } #if defined(F_WITH_fmod) || defined(F_WITH_exp) || defined(F_WITH_sin) || defined(F_WITH_cos) || defined(F_WITH_tan) || defined(F_WITH_to_decimalExp) || defined(F_WITH_to_string) || defined(F_WITH_strtod) || defined(F_WITH_atof) static int8_t f_shift_left_until_bit63_set(uint64_t *w) { // Falls *w=0 ist oder falls das Bit mit der Nummer 63 nicht durch // mehrmaliges Linksschieben von *w gesetzt werden kann, wird *w=0 gesetzt und 64 zurückgeliefert. // Ansonsten wird *w so oft nach links geshiftet, bis das Bit mit der Nummer 63 // gesetzt ist. Die Anzahl der erfolgten Links-Shifts wird zurückgeliefert. register int8_t count=0; register uint64_t mask; for(mask=((uint64_t)255LU)<<(63-7); 0==(mask & (*w)) && count<64; count+=8) (*w) <<= 8; for(mask=((uint64_t)1LU)<<63; 0==(mask & (*w)) && count<64; ++count) (*w) <<= 1; return count; } #endif static uint64_t approx_high_uint64_word_of_uint64_mult_uint64(uint64_t *x, uint64_t *y, uint8_t signed_mult) { // Berechnet eine Näherung von floor(x * y / (2 hoch 64)). Wenn signed_mult==0 übergeben wird, ist // der zurückgegebene Wert ist niemals größer und maximal um 3 kleiner als der tatsächliche Wert. // 0!=signed_mult & 1 : *x ist vorzeichenbehaftet // 0!=signed_mult & 2 : *y ist vorzeichenbehaftet uint64_t r=((*x)>>32)*((*y)>>32) + ((((*x)>>32)*((*y)&0xffffffff))>>32) + ((((*y)>>32)*((*x)&0xffffffff))>>32); if(0!=(signed_mult & 1) && ((int64_t)(*x))<0) r -= (*y); if(0!=(signed_mult & 2) && ((int64_t)(*y))<0) r -= (*x); return r; } static uint64_t approx_high_uint64_word_of_uint64_mult_uint64_pbv_y(uint64_t *x, uint64_t y, uint8_t signed_mult) { return approx_high_uint64_word_of_uint64_mult_uint64(x, &y, signed_mult); } #if defined(F_PREFER_SMALL_BUT_SLOWER_CODE) static uint64_t approx_inverse_of_fixpoint_uint64(uint64_t *y) { // Es muss 0!=*y & 0x8000000000000000 sein ! // Unter dieser Voraussetzung wird (2 hoch 126) / *y berechnet und ggf. auf die nächste // ganze Zahl gerundet. uint64_t zL=0, dH=*y, dL=0, aH=0x4000000000000000, aL=0; uint8_t i=65; while(1) { dL >>= 1; if(dH & 1) dL |= ((uint64_t)1LU) << 63; dH >>= 1; if(0==--i) break; zL<<=1; if(aH>dH || (aH==dH && aL>=dL)) { zL |= 1; aH -= dH; if(dL > aL) --aH; aL -= dL; } } if(aL>=dL) ++zL; return zL; } #else static uint64_t approx_inverse_of_fixpoint_uint64(uint64_t *y) { // Es muss 0!=*y & 0x8000000000000000 sein ! // Unter dieser Voraussetzung wird eine Näherung für (2 hoch 126) / *y berechnet. // Theoretische Überlegungen ergeben, dass nahezu alle 64 Bits des Ergebnisses signifkant sind. // Numerische Experimente lassen vermuten, dass der zurückgegebene Wert um maximal +/- 1 gegenüber dem // auf die nächste ganze Zahl gerundeten Wert von (2 hoch 126) / *y abweicht. uint64_t yv=*y, z8, k5; uint16_t z3; uint32_t z5=(yv>>32), z6, k; uint8_t c; if(0!=(((unsigned long)yv)&0x80000000) && 0==++z5) z6=0; else { z3=(z5>>16); if(0==(z3&0x7fff)) { if(0==(z5&0xffff)) return (0xffffffffffffffff+1)-yv; z6=-((z5&0xffff)<<2); } else if(0xffff==z3) z6=-z5; else { z3=(uint16_t)(1 + (0xffffffff-(z3>>1)) / z3); z6=(((uint32_t)z3)<<17) - (z5 + ((z3*((0x20000+(uint32_t)z3)*(uint64_t)z5))>>32))-1; } } for(k=(uint32_t)(k5=(0x100000000 | ((uint64_t)z6))*z5 + (z5>>1)), c=k5>>32 ; 0!=c ; ) { if(k+z5>1; } #endif #ifdef F_WITH_long_to_float64 float64_t f_long_to_float64(long n) { float64_t r; uint64_t w=((uint64_t)(n<0 ? -n : n))<<20; f_combi_from_fixpoint(&r, n<0 ? 1 : 0, 1023+32, &w); return r; } #endif #if defined(F_WITH_abs) || defined(F_WITH_exp) || defined(F_WITH_sin) || defined(F_WITH_cos) || defined(F_WITH_tan) float64_t f_abs(float64_t x) { return x & 0x7fffffffffffffff; } #endif #ifdef F_WITH_sd /***********************************************************/ float64_t f_sd(float32_t fx) /***********************************************************/ { int32_t * i; uint8_t f_sign; int16_t f_ex; uint64_t w; float64_t f64; //float32_t x; i=&fx; w = ((*i )&0x7fffffl); f_ex = (*i>>23)&0xff; f_sign = (*i>>31)&1; if(0==f_ex && 0!=w) // Denormalisierte float (32 Bits) Zahl f_ex+=29+0x3ff-0x7e; else if(255==f_ex) // +/-INF oder NaN return 0==w ? (f_sign ? float64_MINUS_INFINITY : float64_PLUS_INFINITY) : float64_ONE_POSSIBLE_NAN_REPRESENTATION; else { w |= 0x800000; // Falls KEINE denormalisierte float-Zahl (32 Bits) vorliegt, wird das implizite führende 1-Bit in w ergänzt. if(f_ex) f_ex += 29+0x3ff-0x7f; // Für ==> FLOAT (32 Bits) <== gilt: NICHT ALLE denormalisierten FLOAT-Zahlen werden als Null interpretiert. } f_combi_from_fixpoint(&f64, f_sign, f_ex, &w); return(f64); } #endif #ifdef F_WITH_ds /***********************************************************/ float32_t f_ds(float64_t fx) /***********************************************************/ { int8_t f_sign; int16_t f_ex; uint32_t ui32; float32_t f32; uint64_t w; f_split64(&fx,&f_sign,&f_ex,&w, 0); if(f_ex >= 1023-149) { if(f_ex>1023+127) // +/-INF oder NaN { if(f_ex==2047 && 0!=w) // NaN ui32=0xfffff; else ui32=0; f_ex=255; } else { ui32=(w>>(52-23)) & 0x7fffff; // Es ist 0x10000000000000 | w == w if(f_ex<1023-126) // Es wird eine denormalisierte float-Zahl (32 Bits) erzeugt. { ui32 = (ui32 | 0x800000) >> (1023-126-f_ex); f_ex=0; } else f_ex=(f_ex-0x3ff+0x7f)&0xff; } } else // geändert von Florian Königstein: Alle denormalisierten float64-Zahlen werden als Null interpretiert. ui32=0; ui32 |= ((uint32_t)f_sign<<31)|((uint32_t)f_ex<<23); f32= *((float32_t *)&ui32); return(f32); } #endif /***********************************************************/ static void f_addsub2(float64_t * x, float64_t a, float64_t b, uint8_t flagadd, uint8_t * flagexd ) /***********************************************************/ { // add positive doubles uint8_t sig; int16_t aex,bex; uint64_t wa, wb; f_split64(&a,&sig,&aex,&wa, 10); f_split64(&b,&sig,&bex,&wb, 10); *flagexd=0; #ifdef F_ONLY_NAN_NO_INFINITY if(2047==aex || 2047==bex) { *x=float64_ONE_POSSIBLE_NAN_REPRESENTATION; return; } #else if(2047==aex) // a ist ein NaN oder +INF oder -INF { if(0==wa && (2047!=bex || (0==wb && flagadd))) *x=a; else *x=float64_ONE_POSSIBLE_NAN_REPRESENTATION; return; } else if(2047==bex) { *x=b; return; } #endif if(!aex || aex+64<=bex) {*x=b; *flagexd=1; return;} // Alle denormalisierten Zahlen werden als Null interpretiert. if(!bex || bex+64<=aex) {*x=a; return;} // Alle denormalisierten Zahlen werden als Null interpretiert. if(flagadd) { if(aex>=bex) wa+=wb>>(aex-bex); // aex-bex<64 wurde schon durch die obige Abfrage if(!bex || bex+64<=aex) sichergestellt else { wa=wb+(wa>>(bex-aex)); // bex-aex<64 wurde schon durch die obige Abfrage if(!aex || aex+64<=bex) sichergestellt aex=bex; } } else { if(aex>bex || (aex==bex && wa>=wb)) wa-=wb>>(aex-bex); // aex-bex<64 wurde schon durch die obige Abfrage if(!bex || bex+64<=aex) sichergestellt else { wa=wb-(wa>>(bex-aex)); // bex-aex<64 wurde schon durch die obige Abfrage if(!aex || aex+64<=bex) sichergestellt *flagexd=1; aex=bex; } } f_combi_from_fixpoint(x, 0, aex-10, &wa); } /***********************************************************/ static void f_setsign(float64_t * x, int8_t sign) /***********************************************************/ { if(sign) *x |= 0x8000000000000000; else *x &= 0x7fffffffffffffff; } /***********************************************************/ static uint8_t f_getsign(float64_t x) /***********************************************************/ { uint64_t * px=&x; return ((uint8_t)(((*px)>>63)&1)); } /***********************************************************/ float64_t f_add(float64_t a, float64_t b) /***********************************************************/ {uint8_t signa,signb,signerg; uint8_t flagexd; uint64_t i64; float64_t * x = &i64; signa= f_getsign(a); signb= f_getsign(b); if(signa^signb) { // diff. signs f_addsub2(x,a,b,0,&flagexd); // calc a-b signerg= ((flagexd^signa))&1; }else{ // eq. signs f_addsub2(x,a,b,1,&flagexd); // calc a+b signerg= signa; } f_setsign(x,signerg); return(i64); } /***********************************************************/ float64_t f_sub(float64_t a, float64_t b) /***********************************************************/ {uint8_t signb; float64_t bloc=b; uint64_t i64; signb= f_getsign(bloc); signb ^= 1; f_setsign(&bloc,signb); i64=f_add(a,bloc); return(i64); } /***********************************************************/ float64_t f_mult(float64_t fa, float64_t fb) /***********************************************************/ { //multiply doubles uint8_t asig,bsig; int16_t aex,bex; uint64_t am, bm; f_split64(&fa,&asig,&aex,&am, 11); f_split64(&fb,&bsig,&bex,&bm, 11); #ifdef F_ONLY_NAN_NO_INFINITY if(2047==aex || 2047==bex) return float64_ONE_POSSIBLE_NAN_REPRESENTATION; #else if(2047==aex) // a ist ein NaN oder +INF oder -INF { if(0!=am || (2047==bex && 0!=bm) || 0==bex) return float64_ONE_POSSIBLE_NAN_REPRESENTATION; // Auch +/-INF * Null ergibt NaN // (+/- INF) * (+/- INF) oder (+/- INF) * endliche Zahl außer Null ergibt +/-INF } else if(2047==bex) { if(0!=bm || 0==aex) return float64_ONE_POSSIBLE_NAN_REPRESENTATION; aex=bex; am=bm; } #endif else if(!aex || !bex) // geändert von Florian Königstein: Alle denormalisierten Zahlen werden als Null interpretiert. { // 0 return float64_NUMBER_PLUS_ZERO; }else{ aex=aex+bex-(0x3ff+10); am=approx_high_uint64_word_of_uint64_mult_uint64(&am, &bm, 0); } asig ^= bsig; f_combi_from_fixpoint(&fa, asig, aex, &am); // Hier darf von aex nichts subtrahiert werden, damit // auch aex==2047 (INF, NaN) nicht verfälscht wird. return fa; } /***********************************************************/ float64_t f_div(float64_t x, float64_t y) /***********************************************************/ { uint8_t xsig, ysig; int16_t xex, yex; uint64_t xm, ym, i64; f_split64(&x,&xsig,&xex,&xm, 11); f_split64(&y,&ysig,&yex,&ym, 11); #ifdef F_ONLY_NAN_NO_INFINITY if(2047==xex || 2047==yex || 0==yex) return float64_ONE_POSSIBLE_NAN_REPRESENTATION; #else if(0==yex) { // divide by 0 wont work . Geändert von Florian Königstein: Alle denormalisierten Zahlen werden als Null interpretiert. return float64_ONE_POSSIBLE_NAN_REPRESENTATION; } else if(2047==xex) // x ist ein NaN oder +INF oder -INF { if(0!=xm || 2047==yex) return float64_ONE_POSSIBLE_NAN_REPRESENTATION; // Ansonsten: (+/- INF) / (endliche Zahl außer Null) return (xsig^ysig) ? float64_MINUS_INFINITY : float64_PLUS_INFINITY; } else if(2047==yex) // x ist ein NaN oder +INF oder -INF { if(0==ym) // endliche Zahl / INF = Null return float64_NUMBER_PLUS_ZERO; return float64_ONE_POSSIBLE_NAN_REPRESENTATION; } #endif else { i64=approx_high_uint64_word_of_uint64_mult_uint64_pbv_y(&xm, approx_inverse_of_fixpoint_uint64(&ym), 0); xex += 1023-yex; } f_combi_from_fixpoint(&x, xsig^ysig, xex-10, &i64); return x; } #ifdef F_WITH_cut_noninteger_fraction float64_t f_cut_noninteger_fraction(float64_t x) { int16_t f_ex=(((x)>>52) & 2047); if(0==f_ex || f_ex>=1023+52) // Alle denormalisierten Zahlen werden als Null interpretiert. return x; // schließt auch die Fälle x=NaN, x=+/-INF ein. if(f_ex<1023) return float64_NUMBER_PLUS_ZERO; return x & (0xffffffffffffffff << ((1023+52)-f_ex)); } #endif #if defined(F_WITH_float64_to_long) || defined(F_WITH_exp) long f_float64_to_long(float64_t x) { // Wenn f_abs(x) größer als 1LU<<31 ist, wird Null geliefert. uint8_t f_sign; int16_t f_ex; uint64_t w; f_split_to_fixpoint(&x, &f_sign, &f_ex, &w, 0); return (f_ex>=1023+32) ? 0 : (f_sign ? -((long)w) : ((long)w)); // Hiermit werden auch die Fälle // x=+/-INF und x=NaN abgedeckt (Lieferung von 0). Im Fall x=0 ist w=0. } #endif #ifdef F_WITH_isnan int8_t f_isnan(float64_t x) { // Returns nonzero if x is an IEEE 754 "Not A Number" and otherwise zero. return 0x7ff0000000000000 == (((uint64_t)x) & 0x7ff0000000000000) && 0!=(((uint64_t)x) & 0xfffffffffffff); } #endif #ifdef F_WITH_finite int8_t f_finite(float64_t x) { // Returns nonzero if x represents a real number and zero otherwise i.e. if x is +INF, -INF or NaN. return 0x7ff0000000000000 != (((uint64_t)x) & 0x7ff0000000000000); } #endif #ifdef F_WITH_compare int8_t f_compare(float64_t x, float64_t y) { // If both x and y represent real numbers // (or +/-INF if F_ONLY_NAN_NO_INFINITY is not defined) f_compare returns // zero if x is equal to y, positive nonzero if x > y and negative nonzero if x < y. // If x or y are NaN, f_compare returns zero. uint8_t asig,bsig; int16_t xex,yex; uint64_t wx, wy; f_split64(&x,&asig,&xex,&wx, 0); f_split64(&y,&bsig,&yex,&wy, 0); #ifdef F_ONLY_NAN_NO_INFINITY if(2047==xex || 2047==yex) return 0; #else if((2047==xex && 0!=wx) || (2047==yex && 0!=wy)) // x=NaN oder y=NaN return 0; if(2047==xex) // x = +INF oder -INF (oder NaN, aber schon oben abgefangen) { if(2047==yex) // y = +INF oder -INF return asig==bsig ? 0 : (asig ? -1 : 1); else return asig ? -1 : 1; } if(2047==yex) // y = +INF oder -INF (oder NaN, aber schon oben abgefangen) return bsig ? 1 : -1; // x kann wegen den obigen Abfragen weder +/-INF noch NaN sein #endif if(0==xex) // x = 0 (Alle denormalisierten Zahlen werden als Null interpretiert) return (0==yex && 0==wy) ? 0 : (bsig ? 1 : -1); if(0==yex || asig!=bsig || xex>yex) // Alle denormalisierten Zahlen werden als Null interpretiert return asig ? -1 : 1; if(xexwy && !asig) || (wx Es kann nur 0<=xr<1 übergeben werden // oder aber -1yex || (xex==yex && xm>=(*ymts))) && 0!=--count ; ) { // In vielen Fällen wird diese Schleife kein oder ein Mal durchlaufen. q=approx_high_uint64_word_of_uint64_mult_uint64_pbv_y(&xm, (approx_inverse_of_fixpoint_uint64(ymts)-5)<<1, 0)-5; // approx_inverse_of_fixpoint_uint64(&ym)-5 ist nicht größer als der tatsächliche Wert (ohne Rundungsfehler). // Außerdem ist (2 hoch 62) <= approx_inverse_of_fixpoint_uint64(&ym)-5 < (2 hoch 63). if(xex==yex && 0==(0x8000000000000000 & q)) // Rundungsfehler q=0x8000000000000000; // entspricht der Zahl 1 zex=xex-yex; if(zex<=63) q &= (0xffffffffffffffff << (63-zex)); xm -= approx_high_uint64_word_of_uint64_mult_uint64(&q, ymts, 0)<<1; if(ganz) { f_combi_from_fixpoint(&g, xsig^ysig, (1023-11)+zex, &q); *ganz=f_add(*ganz, g); } xex-=f_shift_left_until_bit63_set(&xm); } f_combi_from_fixpoint(&x, xsig, xex-11, &xm); *ymts=xm; if(0==count) return float64_NUMBER_PLUS_ZERO; // Keine exakte Berechnung erfolgt. Sicherstellen, dass // der Rückgabewert innerhalb des Bereichs von 0 bis ausschließlich y liegt. return x; } #endif #ifdef F_WITH_fmod float64_t f_mod(float64_t x, float64_t y, float64_t *ganz) { // The fmod function calculates the floating-point remainder f of x / y such that x = i * y + f, // where i is an integer, f has the same sign as x, and the absolute value of f is less than the absolute value of y. uint8_t ysig; int16_t yex; uint64_t ym; f_split64(&y,&ysig,&yex,&ym, 11); return f_mod_intern(x, ysig, yex, &ym, ganz); } #endif #if defined(F_WITH_sqrt) || defined(F_WITH_sin) || defined(F_WITH_cos) || defined(F_WITH_tan) || defined(F_WITH_arcsin) || defined(F_WITH_arccos) || defined(F_WITH_arctan) static uint64_t rounded_sqrt_of_integer128(uint64_t x_high, uint64_t x_low) { // Liefert die auf die nächste ganze Zahl gerundete Quadratwurzel aus (2 hoch 64)*x_high + x_low . // Falls die Wurzel nach Rundung gleich (2 hoch 64) sein müsste, wird (2 hoch 64)-1 zurückgegeben. uint64_t rL=0, rH=0, sH, sL; uint8_t i; for(i=2*64; 0!=i; ) { i-=2; sH=rH; sL=rL; if(i>=64) sH += ((uint64_t)1LU) << (i-64); else { if(sL >= (uint64_t)(-(((uint64_t)1LU) << i))) // sL >= (2 hoch 64) - (2 hoch i) sH++; sL += ((uint64_t)1LU) << i; } rL >>= 1; if(rH & 1) rL |= ((uint64_t)1LU) << 63; rH >>= 1; if(sH x_low) --x_high; x_low -= sL; if(i>=64) rH |= ((uint64_t)1LU) << (i-64); else rL |= ((uint64_t)1LU) << i; } } return (0!=x_high || x_low>=rL) && 0xffffffffffffffff!=rL ? rL+1 : rL; } #endif #ifdef F_WITH_sqrt float64_t f_sqrt(float64_t x) { uint8_t xsig; int16_t xex; uint64_t w, wL; f_split64(&x,&xsig,&xex,&w, 11); if(0==xex) // Null return float64_NUMBER_PLUS_ZERO; #ifdef F_ONLY_NAN_NO_INFINITY if(2047==xex || 0!=xsig) return float64_ONE_POSSIBLE_NAN_REPRESENTATION; #else if(2047==xex) // NaN, +INF oder -INF { if(0==w && 0==xsig) // +INF return x; return float64_ONE_POSSIBLE_NAN_REPRESENTATION; } if(xsig) return float64_ONE_POSSIBLE_NAN_REPRESENTATION; #endif wL=0; if(xex & 1) { if(w & 1) wL = ((uint64_t)1LU) << 63; w >>= 1; } w=rounded_sqrt_of_integer128(w, wL); f_combi_from_fixpoint(&x, 0, (xex+1)/2 + 500, &w); return x; } #endif #ifdef F_WITH_exp float64_t f_exp(float64_t x) { uint8_t f_sign, f_sign2; int16_t f_ex; float64_t g, rest; int16_t gi; uint64_t w, w2; static uint64_t interp[] FLASHMEM_IF_AVR = { // Interpolation von exp(x) im Bereich von x=0 ... log(2.0) // Zähler: 12 Koeffizienten, Nenner: 0 Koeffizienten 0x00000025f42ff241, 0x00000112e79387f1, 0x00000ba525a70ff3, 0x000067f7ce0d91cb, 0x0003403a635c5891, 0x0016c16a4128d5ee, 0x00888888e10886ed, 0x02aaaaaaa0251d3e, 0x0aaaaaaaab66a1c0, 0x1ffffffffff9434d, 0x400000000000180b, 0x3ffffffffffffff2 }; f_split64(&x, &f_sign, &f_ex, &w, 0); if(0==f_ex) return float64_NUMBER_ONE; #ifdef F_ONLY_NAN_NO_INFINITY // Ohne die folgende Abfrage würde die unten stehende Funktion f_float64_to_long() einen falschen Wert liefern. // Damit werden auch die Fälle erfasst, dass x=NaN oder x=+/-INF ist. if(f_ex>=1023+10) return (f_sign && f_ex!=2047) ? float64_NUMBER_PLUS_ZERO : float64_ONE_POSSIBLE_NAN_REPRESENTATION; #else if(2047==f_ex) // NaN, +INF oder -INF { if(0!=w || (0==w && 0==f_sign)) // NaN oder +INF return x; return float64_NUMBER_PLUS_ZERO; } if(f_ex>=1023+10) // Ohne diese Abfrage würde die unten stehende Funktion f_float64_to_long() einen falschen Wert liefern. return f_sign ? float64_NUMBER_PLUS_ZERO : float64_PLUS_INFINITY; #endif w=0xb17217f7d1cf79ac; // Mantisse von log(2) rest=f_mod_intern(f_abs(x), 0, 1022, &w, &g); // Modulo log(2) // Von f_mod_intern() wurde an w nun die 64-Bit-Mantisse von x zugewiesen. f_split_to_fixpoint(&rest, &f_sign2, &f_ex, &w2, 64); // w2, nicht w übergeben ! if(f_ex<=1022-64) w=0; else w>>=1022-f_ex; gi=f_float64_to_long(g); if(f_sign2) w=0; else if(f_ex>=1023) // Rundungsfehler bei f_mod w=0xffffffffffffffff; #ifdef USE_AVR copy_from_flash_to_tempmem(&interp[0], 12*8); w=f_eval_function_by_rational_approximation_fixpoint(w, 12, 0, (uint64_t*)(&TemporaryMemory[0]), 0); #else w=f_eval_function_by_rational_approximation_fixpoint(w, 12, 0, interp, 0); #endif if(f_sign) { gi-=f_shift_left_until_bit63_set(&w); w=approx_inverse_of_fixpoint_uint64(&w); } f_combi_from_fixpoint(&g, 0, f_sign ? (1021-10)-gi : (1023-10)+gi, &w); return g; } #endif #ifdef F_WITH_log float64_t f_log(float64_t x) { uint8_t f_sign; int8_t sgnw2=0; // Initialisierung sgnw2=0 wichtig ! int16_t f_ex, f_ex2; uint64_t w, w2; static uint64_t interp[] FLASHMEM_IF_AVR = { // Interpolation von log(1+x)/x im Bereich von x= -0.125 ... 1 // Zähler: 7 Koeffizienten, Nenner: 8 Koeffizienten 0x00020306b29459c0, 0x0059c8a974126d6a, 0x03f628260c2db8e4, 0x11dfa5d2d89584a5, 0x255cf1f4fada2dcc, 0x243348927d4a6bdf, 0x0d22e971210e91e5, 0x00005e30ad9c1880, 0x001a68f2d08c85a8, 0x01b09953e747fe7e, 0x0af24b95490068ee, 0x2215f7d0824727db, 0x365e581f76be278e, 0x2ac4bd4b0dd1b53c, 0x0d22e971210e91e6 }; f_split64(&x, &f_sign, &f_ex, &w, 11); #ifdef F_ONLY_NAN_NO_INFINITY if(2047==f_ex || 0==f_ex || 0!=f_sign) return float64_ONE_POSSIBLE_NAN_REPRESENTATION; #else if(0==f_ex) // Null return float64_MINUS_INFINITY; if(2047==f_ex || 0!=f_sign) // NaN, +INF oder -INF { if(0==w && 0==f_sign) // +INF return x; return float64_ONE_POSSIBLE_NAN_REPRESENTATION; // -INF } #endif if(1022==f_ex && w>=0xe000000000000000) { // Hiermit wird erreicht, dass auch im Fall, dass x kleiner als 1, aber dicht bei 1 liegt, alle // Mantissebits des berechneten Logarithmus signifikant sind (wenn man davon absieht, dass in seltenen // Fällen in die "falsche" Richtung gerundet wird). w=(0xffffffffffffffff+1)-w; // 0xffffffffffffffff+1 ergibt gewollt 0 (warning: integral constant overflow). sgnw2=-1; } else { w2=f_ex-1023; // vor dem Überschreiben von f_ex ! if(f_ex<1023) { w2=-w2; sgnw2=-2; } else if(f_ex>1023) sgnw2=1; w<<=1; // Das höchstwertigste Bit hinausschieben: Entspricht der Subtraktion von 1 von der Mantisse. } f_ex = (1022-9) - f_shift_left_until_bit63_set(&w); #ifdef USE_AVR copy_from_flash_to_tempmem(&interp[0], 15*8); if(0!=w) w=approx_high_uint64_word_of_uint64_mult_uint64_pbv_y(&w, f_eval_function_by_rational_approximation_fixpoint( w >> ((1022-9)-f_ex), 7, 8, (uint64_t*)(&TemporaryMemory[0]), -1==sgnw2 ? 3 : 0), 0); #else if(0!=w) w=approx_high_uint64_word_of_uint64_mult_uint64_pbv_y(&w, f_eval_function_by_rational_approximation_fixpoint(w >> ((1022-9)-f_ex), 7, 8, interp, -1==sgnw2 ? 3 : 0), 0); #endif if(0==sgnw2 || -1==sgnw2) f_ex2=f_ex; else { f_ex2=(1023+63-11)-f_shift_left_until_bit63_set(&w2); w2=approx_high_uint64_word_of_uint64_mult_uint64_pbv_y(&w2, 0xb17217f7d1cf79ac, 0); if(f_ex2>=f_ex) (f_ex2-f_ex>=64) ? (w=0) : (w>>=(f_ex2-f_ex)); else w<<=(f_ex-f_ex2); if(sgnw2>=0) w+=w2; else w=w2-w; } f_combi_from_fixpoint(&x, sgnw2<0 ? 1 : 0, f_ex2, &w); return x; } #endif #if defined(F_WITH_sin) || defined(F_WITH_cos) || defined(F_WITH_tan) float64_t f_berechne_sinus_cosinus_tangens(float64_t x, uint8_t fkt_nr) { // fkt_nr=0 ==> Sinus, fkt_nr=1 ==> Cosinus, fkt_nr=2 ==> Tangens uint8_t f_sign; int16_t f_ex; uint64_t w, w2; uint8_t neg, tneg=0, mir45=(1==fkt_nr) ? 1 : 0; static uint64_t interp[] FLASHMEM_IF_AVR = { // Interpolation von sin(sqrt(x))/sqrt(x) im Bereich von x=0 ... (Pi/4)*(Pi/4) // Zähler: 7 Koeffizienten (vorzeichenbehaftet), Nenner: 0 Koeffizienten 0x000000002bb08115, 0xffffffe51a1d4a39, 0x00000b8ef1a8f972, 0xfffcbfcbfcc8da4a, 0x0088888888879853, 0xf555555555555eb1, 0x3ffffffffffffff0 }; f_split64(&x, &f_sign, &f_ex, &w, 0); if(0==f_ex) // Null return 1==fkt_nr ? float64_NUMBER_ONE : float64_NUMBER_PLUS_ZERO; if(2047==f_ex) // NaN, +INF oder -INF return float64_ONE_POSSIBLE_NAN_REPRESENTATION; tneg=neg=(0!=f_sign && 1!=fkt_nr) ? 1 : 0; w2=0xc90fdaa22168c235; // Mantisse von 2*PI x=f_mod_intern(f_abs(x), 0, 1023+2, &w2, 0); // Modulo 2*PI // Von f_mod_intern() wurde an w2 nun die 64-Bit-Mantisse von x zugewiesen. f_split_to_fixpoint(&x, &f_sign, &f_ex, &w, 61); // &w, nicht &w2 übergeben! w2 hat 64 Bits, w nur 53 Bits Mantisse w=w2; // bleibt im Fall f_ex<1022 unten erhalten if(1025-64>=f_ex) w2=0; else w2>>=1025-f_ex; if(w2 >= 0x6487ed5110b4611a) // x>=PI { neg ^= 1; w2-=0x6487ed5110b4611a; // x -= PI } if(w2 >= 0x3243f6a8885a308d) // x>=PI/2 { tneg ^= 1; if(1==fkt_nr) neg ^= 1; w2=0x6487ed5110b4611a-w2; // x = PI-x } if(w2 >= 0x1921fb54442d1846) // x>=PI/4 { mir45 ^= 1; w2=0x3243f6a8885a308d-w2; // x = PI/2-x } w2<<=3; if(f_ex>=1022) { w=w2; f_ex=0; } else f_ex-=1022; f_ex-=f_shift_left_until_bit63_set(&w); // Im Fall w=0 ist f_ex im Folgenden irrelevant #ifdef USE_AVR copy_from_flash_to_tempmem(&interp[0], 7*8); w=approx_high_uint64_word_of_uint64_mult_uint64_pbv_y(&w, f_eval_function_by_rational_approximation_fixpoint( approx_high_uint64_word_of_uint64_mult_uint64(&w2, &w2, 0), 7, 0, (uint64_t*)(&TemporaryMemory[0]), 1), 0); #else w=approx_high_uint64_word_of_uint64_mult_uint64_pbv_y(&w, f_eval_function_by_rational_approximation_fixpoint( approx_high_uint64_word_of_uint64_mult_uint64(&w2, &w2, 0), 7, 0, interp, 1), 0); #endif if(0!=(0x8000000000000000 & w)) // negativ durch Rundungsfehler w=0; // Durch die vorangehende Abfrage ist sichergestellt, dass durch Rundungsfehler kein negatives w geliefert wird. // Das maximale w an dieser Stelle entspricht der reellen Zahl 1/sqrt(2) als Funktionswert von sin(Pi/4). if(mir45 || 2==fkt_nr) { w2=w; if(f_ex<=-64) w=0; else w>>=(-f_ex); w=rounded_sqrt_of_integer128(0xffffffffffffffff - (approx_high_uint64_word_of_uint64_mult_uint64(&w, &w, 0)<<4), 0xffffffffffffffff); // Hier darf nicht (0xffffffffffffffff+1) statt 0xffffffffffffffff stehen (Integer-Überlauf), weil // die zu subtrahierende Zahl (approx_high_uint64_word_of_uint64_mult_uint64(&w, &w, 0)<<4)) auch Null sein kann. // Es ist sichergestellt, dass nicht durch Rundungsfehler ein w > 2 hoch 32 geliefert wird, welches // einem Funktionswert von sin bzw. cos von betraglich größer als 1 entsprechen würde. if(2==fkt_nr) { uint64_t *ps, *pc; f_ex+=2; if(mir45) { ps=&w; pc=&w2; f_ex=-f_ex; } else { ps=&w2; pc=&w; } if(0==*pc) // z.B. bei tan(PI/2) return float64_ONE_POSSIBLE_NAN_REPRESENTATION; f_ex-=f_shift_left_until_bit63_set(ps); f_ex+=f_shift_left_until_bit63_set(pc); w=approx_high_uint64_word_of_uint64_mult_uint64_pbv_y(ps, approx_inverse_of_fixpoint_uint64(pc), 0); neg=tneg; } else f_ex=-2; } f_combi_from_fixpoint(&x, neg, 1013+f_ex, &w); return x; } #endif #if defined(F_WITH_arcsin) || defined(F_WITH_arccos) || defined(F_WITH_arctan) float64_t f_berechne_arcsin_arccos_arctan(float64_t x, uint8_t fkt_nr) { uint8_t f_sign, mir45=0, nr_shift; int16_t f_ex; uint64_t w, w2; static uint64_t interp[] FLASHMEM_IF_AVR = { // Interpolation von arctan(sqrt(x))/sqrt(x) im Bereich von x=0 ... 1 // Zähler 7 Koeffizienten (alle positiv), Nenner 7 Koeffizienten (alle positiv) 0x000051f590de71e7, 0x00252120c9d0cdc1, 0x0277897981ffc250, 0x0e45a25bb3bfe210, 0x2360ae1e927608ad, 0x26d3fc5ec2d01988, 0x0f7f3182c822dbc8, 0x000347839b4bdad9, 0x0082e7b5e08e6b4d, 0x056b67d2062eb49d, 0x1755b06e64aa19e5, 0x2ef15e8d8e6c5b98, 0x2bfe6235058656ae, 0x0f7f3182c822dbce }; f_split64(&x, &f_sign, &f_ex, &w, 11); if(0==f_ex) // Null return 1==fkt_nr ? ((float64_t)0x3ff921fb54442d18) : 0; #ifdef F_ONLY_NAN_NO_INFINITY if(2047==f_ex) return x; // NaN #else if(2047==f_ex) // NaN, +INF oder -INF { if(0!=w) // NaN return x; if(f_sign) // -INF return 2==fkt_nr ? ((float64_t)0xbff921fb54442d18) : float64_ONE_POSSIBLE_NAN_REPRESENTATION; else return 2==fkt_nr ? ((float64_t)0x3ff921fb54442d18) : float64_ONE_POSSIBLE_NAN_REPRESENTATION; } #endif if(2!=fkt_nr) { if(f_ex>=1023 || (f_ex==1022 && w>=0xb504f333f9de6484-0x0000000100000000)) // fabs(x) >= sqrt(2)/2 - (2 hoch (-32)) { // Es ist wichtig, dass auf w>=0xb504f333f9de6484-0x0000000100000000 statt auf w>=0xb504f333f9de6484 // getestet wird, damit w2 im else-Teil vor Ausführung von w2=approx_inverse_of_fixpoint_uint64(&w2) // mindestens gleich 0x8000000000000000 ist (wie von approx_inverse_of_fixpoint_uint64() gefordert). if(f_ex>1023 || (f_ex==1023 && w>0x8000000000000000)) return float64_ONE_POSSIBLE_NAN_REPRESENTATION; if(f_ex==1023) // fabs(x)=1 . Dieser Fall würde im else-Code nicht korrekt behandelt. { w=0; f_ex=1021; } else { // Die folgende Rechnung entspricht y=sqrt(2*(1-x) - (1-x)*(1-x)) / x . // Theoretisch (wenn ohne Rundungsfehler) liefert y=sqrt(1-x*x) / x das gleiche Ergebnis; aber wenn // x nahe bei 1 ist, muss zur Verringerung von Rundungsfehlern die erste Rechnung benutzt werden. w2=(0xffffffffffffffff+1) - w; // 0xffffffffffffffff+1 ergibt gewollt 0 (warning: integral constant overflow). for(nr_shift=0 ; 0==(0x6000000000000000 & w2) ; ++nr_shift) w2<<=2; w=approx_inverse_of_fixpoint_uint64(&w); w=approx_high_uint64_word_of_uint64_mult_uint64_pbv_y(&w, rounded_sqrt_of_integer128((w2<<1) - (approx_high_uint64_word_of_uint64_mult_uint64(&w2,&w2,0)>>(2*nr_shift)), 0), 0); f_ex=1024-nr_shift; } mir45=(0==fkt_nr) ? 1 : 0; } else // fabs(x) < sqrt(2)/2 - (2 hoch (-32)) { f_split_to_fixpoint(&x, &f_sign, &f_ex, &w2, 64); w2=0xffffffffffffffff - approx_high_uint64_word_of_uint64_mult_uint64(&w2,&w2,0); // Obwohl w2=0 oben abgefangen wird, kann approx_high_uint64_word_of_uint64_mult_uint64(&w2,&w2,0)==0 sein. // Daher darf dieses Produkt nicht von (0xffffffffffffffff+1) abgezogen werden (Integer-Überlauf). // Wegen fabs(x) < sqrt(2)/2 - (2 hoch (-32)) ist an dieser Stelle w2>=0x8000000000000000 w2=approx_inverse_of_fixpoint_uint64(&w2); w2=rounded_sqrt_of_integer128(w2, 0); w=approx_high_uint64_word_of_uint64_mult_uint64(&w, &w2, 0); // Das höchstwertigste Bit kann gesetzt sein ! ++f_ex; mir45=(1==fkt_nr) ? 1 : 0; } } if(0!=w) // Wenn fkt_nr!=2 und x=+1.0 oder x=-1.0 ist, wird oben w=0 gesetzt. f_ex-=f_shift_left_until_bit63_set(&w); --f_ex; if(f_ex>=1022) { w=approx_inverse_of_fixpoint_uint64(&w); f_ex=2044-f_ex-f_shift_left_until_bit63_set(&w); mir45=1; } // Im Folgenden muss der Fall 1022==f_ex gesondert behandelt werden, weil der dem Wert 1 entsprechende Wert nicht // an f_eval_function_by_rational_approximation_fixpoint() übergeben werden kann. Außerdem würden sich sonst negative // Anzahl an Shifts ergeben ( w>>(1021-f_ex) ). Der Fall 1022==f_ex tritt bei arctan(1) und arctan(-1) und bei // bestimmten Werten von arccos und arcsin auf. if(1022==f_ex) w=0x1921fb54442d1847; // ergibt x=Pi/4 oder x=-Pi/4 else { #ifdef USE_AVR copy_from_flash_to_tempmem(&interp[0], 14*8); w=approx_high_uint64_word_of_uint64_mult_uint64_pbv_y(&w, f_eval_function_by_rational_approximation_fixpoint(f_ex<=1021-32 ? 0 : (approx_high_uint64_word_of_uint64_mult_uint64(&w, &w, 0)>>(2*(1021-f_ex))), 7, 7, (uint64_t*)(&TemporaryMemory[0]), 0), 0); #else w=approx_high_uint64_word_of_uint64_mult_uint64_pbv_y(&w, f_eval_function_by_rational_approximation_fixpoint(f_ex<=1021-32 ? 0 : (approx_high_uint64_word_of_uint64_mult_uint64(&w, &w, 0)>>(2*(1021-f_ex))), 7, 7, interp, 0), 0); #endif if(mir45) { w=0x6487ed5110b4611a - (f_ex<=1021-64 ? 0 : (w>>(1021-f_ex))); // entspricht x = PI/2 - x f_ex=1021; } if(1==fkt_nr && f_sign) { w=0xc90fdaa22168c235 - (f_ex<=1021-64 ? 0 : (w>>(1021-f_ex))); // entspricht x = PI - x f_ex=1021; f_sign=0; } } f_combi_from_fixpoint(&x, f_sign, f_ex-8, &w); return x; } #endif #if defined(F_WITH_to_decimalExp) || defined(F_WITH_to_string) || defined(F_WITH_strtod) || defined(F_WITH_atof) static int16_t f_10HochN(int64_t n, uint64_t *res) { uint64_t pot=((uint64_t)10)<<60; int16_t exp2=0, pot_exp2=3; uint8_t neg=0; *res=((uint64_t)1)<<63; if(n<0) { neg=1; n=-n; } while(0 != n) { if(0 != (n & 1)) { *res = approx_high_uint64_word_of_uint64_mult_uint64(res, &pot, 0); exp2+=pot_exp2+1-f_shift_left_until_bit63_set(res); } pot = approx_high_uint64_word_of_uint64_mult_uint64(&pot, &pot, 0); pot_exp2=(pot_exp2<<1)+1-f_shift_left_until_bit63_set(&pot); n >>= 1; } if(neg) { *res = approx_inverse_of_fixpoint_uint64(res); exp2=-exp2-f_shift_left_until_bit63_set(res); } return exp2; } #endif #if defined(F_WITH_to_decimalExp) || defined(F_WITH_to_string) char *f_to_decimalExp(float64_t x, uint8_t anz_dezimal_mantisse, uint8_t MantisseUndExponentGetrennt, int16_t *ExponentBasis10) { // f_to_decimalExp() converts the float64 to the decimal representation of the number x if x is // a real number or to the strings "+INF", "-INF", "NaN". If x is real, f_to_decimalExp() generates // a mantisse-exponent decimal representation of x using anz_dezimal_mantisse decimal digits for // the mantisse. If MantisseUndExponentGetrennt!=0 is passed f_to_decimalExp() will generate different // strings for the mantisse and the exponent. If you assign // char *str=f_to_decimalExp(x, anz_mts, 1, 0) // then str points to the mantisse string and str+strlen(str) points to the exponent string. // If the pointer ExponentBasis10 passed to f_to_decimalExp() is nonzero, the function will // assign the 10-exponent to *ExponentBasis10 ; e.g. if the decimal representation of x // is 1.234E58 then the integer 58 is assigned to *ExponentBasis10. // *** ATTENTION *** : The functions f_to_decimalExp() and f_to_string() return pointers to static memory // containing the decimal representation of the float64 passed to these functions. The string contained // in this memory will become invalid if one of the functions f_to_decimalExp(), f_to_string(), // f_exp(), f_log(), f_sin(), f_cos(), f_tan(), f_arcsin(), f_arccos(), f_arctan() is called as // these functions will overwrite the memory. uint8_t f_sign; uint8_t len, posm, i; int16_t f_ex; uint64_t w, w2; int16_t Exp10; if(anz_dezimal_mantisse>17) anz_dezimal_mantisse=17; if(anz_dezimal_mantisse<1) anz_dezimal_mantisse=1; f_split64(&x, &f_sign, &f_ex, &w, 11); if(0==f_ex) // Alle denormalisierten Zahlen werden als Null interpretiert. { TemporaryMemory[0]='0'; TemporaryMemory[1]=0; return TemporaryMemory; } #ifdef F_ONLY_NAN_NO_INFINITY if(2047==f_ex) { strcpy(TemporaryMemory, "NaN"); return TemporaryMemory; } #else if(2047==f_ex) { if(0!=w) { strcpy(TemporaryMemory, "NaN"); return TemporaryMemory; } TemporaryMemory[0]=f_sign ? '-' : '+'; strcpy(TemporaryMemory+1, "INF"); return TemporaryMemory; } #endif f_ex-=1023; // Nach der Abfrage auf 0==f_ex und 2047==f_ex ! len=0; if(f_sign) TemporaryMemory[len++]='-'; if(f_ex >= 0) Exp10=(uint16_t)((((uint16_t)f_ex)*10+31)>>5); else Exp10=(int16_t)(-((((uint16_t)(-f_ex))*9)>>5)); f_ex+=f_10HochN(-Exp10, &w2); w=approx_high_uint64_word_of_uint64_mult_uint64(&w, &w2, 0); f_ex+=1-f_shift_left_until_bit63_set(&w); while(f_ex<0) { w=approx_high_uint64_word_of_uint64_mult_uint64_pbv_y(&w, ((uint64_t)10)<<60, 0); f_ex+=4-f_shift_left_until_bit63_set(&w); Exp10--; } while(f_ex>=4 || (f_ex==3 && (w & 0xf000000000000000)>=0xa000000000000000)) { w=approx_high_uint64_word_of_uint64_mult_uint64_pbv_y(&w, 0xcccccccccccccccc, 0); f_ex-=3+f_shift_left_until_bit63_set(&w); Exp10++; } posm=len; ++len; // Platz für . while(0!=(anz_dezimal_mantisse--)) { TemporaryMemory[len]='0'; if(f_ex>=0) { TemporaryMemory[len] += (w>>(63-f_ex)); w <<= 1+f_ex; f_ex=-1; } ++len; w=approx_high_uint64_word_of_uint64_mult_uint64_pbv_y(&w, ((uint64_t)10)<<60, 0); f_ex+=4-f_shift_left_until_bit63_set(&w); } if(f_ex>=0 && (w>>(63-f_ex)) >= 5) { for(i=len ; --i>posm ; ) if(TemporaryMemory[i]=='9') TemporaryMemory[i]='0'; else { ++TemporaryMemory[i]; break; } if(i==posm) { ++Exp10; TemporaryMemory[++i]='1'; while(++i0) TemporaryMemory[len++]='+'; itoa(Exp10, &TemporaryMemory[len], 10); if(0!=ExponentBasis10) *ExponentBasis10=Exp10; return TemporaryMemory; } #endif #ifdef F_WITH_to_string char *f_to_string(float64_t x, uint8_t max_nr_chars, uint8_t max_leading_mantisse_zeros) { // f_to_decimalExp() converts the float64 to the decimal representation of the number x if x is // a real number or to the strings "+INF", "-INF", "NaN". If x is real, f_to_decimalExp() generates // a decimal representation without or with mantisse-exponent representation depending on // what in more suitable or possible. If -1 < x < 1 the non-exponent representation is chosen if // there are less than max_leading_mantisse_zeros zeros after the decimal point. // In most cases f_to_string() will generate a string with maximal 'max_nr_chars' chars. If // necessary, f_to_string() reduces the number of decimal digits in the mantisse in order to // get a maximum string width of 'max_nr_chars' chars. If however max_nr_chars is so small that // even a mantisse of one digit and the corresponding exponent doesn't fit into 'max_nr_chars' chars, // the string returned will be longer than 'max_nr_chars' chars. // *** ATTENTION *** : The functions f_to_decimalExp() and f_to_string() return pointers to static memory // containing the decimal representation of the float64 passed to these functions. The string contained // in this memory will become invalid if one of the functions f_to_decimalExp(), f_to_string(), // f_exp(), f_log(), f_sin(), f_cos(), f_tan(), f_arcsin(), f_arccos(), f_arctan() is called as // these functions will overwrite the memory. int16_t exp10; int8_t nrd=(0!=(x & 0x8000000000000000)) ? (max_nr_chars-1) : max_nr_chars; // nrd: Zahl der zu berechnenden dezimalen Mantissestellen. int8_t nrd_vor=nrd+1; char *r=0; uint8_t j, k; for(j=0; j<3 && nrd!=nrd_vor; j++) { if(nrd>nrd_vor) { r=f_to_decimalExp(x, nrd_vor, 1, &exp10); // Nur exp10 berechnen break; } r=f_to_decimalExp(x, nrd, 1, &exp10); // Nur exp10 berechnen if(((x>>52)&2047)==2047 || 0==(x & 0x7ff0000000000000)) return r; if(exp10<-max_leading_mantisse_zeros-1) break; nrd_vor=nrd; nrd=f_getsign(x) ? max_nr_chars-1 : max_nr_chars; // Diese Variable nrd muss sowohl hier als oben vor Beginn der Schleife initialisiert werden. if(exp10<0) nrd += exp10-1; // exp10-1 Zeichen durch 0.00 .... verbraucht. else if(exp10+1=0 . --nrd; // Ein Zeichen durch Dezimalpunkt verbraucht. // Beispiel für den Fall exp10==max_nr_chars-2 : Es sei max_nr_chars=4, exp10=2, Zahl=683.79426 // ==> Es wird 684 dargestellt // (3 statt 4 Zeichen belegt, weil 683.8 zu viele Zeichen belegen würde). } if(0!=(x & 0x7ff0000000000000) && exp10>=-max_leading_mantisse_zeros && nrd>exp10) { // Darstellung ohne 10er-Exponent (E) if(f_getsign(x)) ++r; // - Zeichen if(exp10<0) { for(j=strlen(r) ; (j--)>0 && '0'==r[j] ; ) r[j]=0; r[1]=r[0]; for(++j ; j>0 ; j--) r[j-exp10]=r[j]; r[0]='0'; r[1]='.'; for(j=2; ++exp10<0; ) r[j++]='0'; } else { for(j=1 ; j<=exp10 ; j++) if(0==(r[j]=r[j+1])) { while(j<=exp10) r[j++]='0'; r[j]=0; break; } if(j+10 && '0'==r[j] ; ) r[j]=0; if('.'==r[j]) r[j]=0; } else r[j]=0; // Notwendig für den Fall j+1>=max_nr_chars } if(f_getsign(x)) --r; } else { // Darstellung mit 10er-Exponent (E) j=max_nr_chars-4; if(f_getsign(x)) --j; exp10=(x>>52)&2047; // exp10 wird hier zur Aufnahme des binären Exponenten "missbraucht" if(exp10<1023) --j; if(exp10>1023+34 || exp10<1023-34) --j; if(j<1) j=1; while((r=f_to_decimalExp(x, j, 0, 0)), strlen(r)>(uint8_t)max_nr_chars) if(--j<1) break; for(j=2; 0!=r[j] && 'E'!=r[j] && 'e'!=r[j] ; j++) ; k=j; while((--j>=4 || (!f_getsign(x) && j>=3)) && '0'==r[j]) ; while(0!=(r[++j]=r[k++])) ; } return r; } #endif #if defined(F_WITH_strtod) || defined(F_WITH_atof) float64_t f_strtod(char *str, char **endptr) { char *s=str; uint8_t f_sign=0, point=0; int16_t f_ex; uint64_t w, w2; int16_t Exp10; float64_t x; while(*s && (*s==' ' || *s=='\t')) s++; if((s[0]=='n' || s[0]=='N') && (s[1]=='a' || s[1]=='A') && (s[2]=='n' || s[2]=='N')) { s+=3; goto return_NaN; } if(*s=='-') { f_sign=1; ++s; } else if(*s=='+') ++s; #ifndef F_ONLY_NAN_NO_INFINITY if((s[0]=='i' || s[0]=='I') && (s[1]=='n' || s[1]=='N') && (s[2]=='f' || s[2]=='F')) { if(endptr) *endptr=s+3; return f_sign ? float64_MINUS_INFINITY : float64_PLUS_INFINITY; } #endif Exp10=0; w=0; f_ex=3; while(1) { if(*s=='.') { ++s; if(point) goto return_NaN; point=1; } if(!(*s>='0' && *s<='9')) break; if(f_ex<=63-4) { if(point) --Exp10; w=approx_high_uint64_word_of_uint64_mult_uint64_pbv_y(&w, ((uint64_t)10)<<60, 0); if(w) f_ex+=4; w += (((uint64_t)(*s))-'0')<<(63-f_ex); if(w) f_ex-=f_shift_left_until_bit63_set(&w); } else if(!point) ++Exp10; ++s; } if(*s=='E' || *s=='e') { Exp10+=atoi(++s); if(*s=='-' || *s=='+') ++s; while(*s>='0' && *s<='9') ++s; } f_ex+=1+f_10HochN(Exp10, &w2); w=approx_high_uint64_word_of_uint64_mult_uint64(&w, &w2, 0); f_combi_from_fixpoint(&x, f_sign, 1023-11+f_ex, &w); if(endptr) *endptr=s; return x; return_NaN: if(endptr) *endptr=s; return float64_ONE_POSSIBLE_NAN_REPRESENTATION; } #endif
