.include "m8def.inc" ; ATmega8L .equ XTAL = 8000000 ; 8MHz (Quarz)!!!! .def Timer1 = r16 .def Timer2 = r17 .def Timer3 = r18 .def Timer4 = r19 .def Timer5 = r20 .def temp1 = r21 ; PB0 --> normale LED (L-Aktiv) ; PB1 (OC1A) --> IR-LED (H-Aktiv) ; PB6 (XTAL1/TOSC1) --> Quarz + 15nF -> Masse ; PB7 (XTAL2/TOSC2) --> Quarz + 15nF -> Masse ; PC6 (RESET) --> Taster nach Masse .org 0x0000 Reset: ldi temp1, LOW(RAMEND) ; LOW-Byte der obersten RAM-Adresse out SPL, temp1 ldi temp1, HIGH(RAMEND) ; HIGH-Byte der obersten RAM-Adresse out SPH, temp1 ldi temp1, (1<
