//LCD Functions Developed by electroSome /*#define eS_PORTA0 0 #define eS_PORTA1 1 #define eS_PORTA2 2 #define eS_PORTA3 3 #define eS_PORTA4 4 #define eS_PORTA5 5 #define eS_PORTA6 6 #define eS_PORTA7 7*/ #define eS_PORTB0 10 #define eS_PORTB1 11 #define eS_PORTB2 12 #define eS_PORTB3 13 #define eS_PORTB4 14 #define eS_PORTB5 15 #define eS_PORTB6 16 #define eS_PORTB7 17 #define eS_PORTC0 20 #define eS_PORTC1 21 #define eS_PORTC2 22 #define eS_PORTC3 23 #define eS_PORTC4 24 #define eS_PORTC5 25 #define eS_PORTC6 26 #define eS_PORTD4 34 #define eS_PORTD5 35 #define eS_PORTD6 36 #define eS_PORTD7 37 #include void pinChange(int a, int b) { if(b == 0) { if(a == eS_PORTB0) PORTB &= ~(1< RS = 0 Lcd8_Port(a); //Data transfer pinChange(EN,1); // => E = 1 _delay_ms(1); pinChange(EN,0); // => E = 0 _delay_ms(1); } void Lcd8_Clear() { Lcd8_Cmd(1); } void Lcd8_Set_Cursor(char a, char b) { if(a == 1) Lcd8_Cmd(0x80 + b); else if(a == 2) Lcd8_Cmd(0xC0 + b); } void Lcd8_Init() { pinChange(RS,0); pinChange(EN,0); _delay_ms(20); ///////////// Reset process from datasheet ///////// Lcd8_Cmd(0x30); _delay_ms(5); Lcd8_Cmd(0x30); _delay_ms(1); Lcd8_Cmd(0x30); _delay_ms(10); ///////////////////////////////////////////////////// Lcd8_Cmd(0x38); //function set Lcd8_Cmd(0x0C); //display on,cursor off,blink off Lcd8_Cmd(0x01); //clear display Lcd8_Cmd(0x06); //entry mode, set increment } void Lcd8_Write_Char(char a) { pinChange(RS,1); // => RS = 1 Lcd8_Port(a); //Data transfer pinChange(EN,1); // => E = 1 _delay_ms(1); pinChange(EN,0); // => E = 04 _delay_ms(1); } void Lcd8_Write_String(char *a) { int i; for(i=0;a[i]!='\0';i++) Lcd8_Write_Char(a[i]); } void Lcd8_Shift_Right() { Lcd8_Cmd(0x1C); } void Lcd8_Shift_Left() { Lcd8_Cmd(0x18); } //End LCD 8 Bit Interfacing Functions */ //LCD 4 Bit Interfacing Functions void Lcd4_Port(char a) { if(a & 1) pinChange(D4,1); else pinChange(D4,0); if(a & 2) pinChange(D5,1); else pinChange(D5,0); if(a & 4) pinChange(D6,1); else pinChange(D6,0); if(a & 8) pinChange(D7,1); else pinChange(D7,0); } void Lcd4_Cmd(char a) { pinChange(RS,0); // => RS = 0 Lcd4_Port(a); pinChange(EN,1); // => E = 1 _delay_ms(1); pinChange(EN,0); // => E = 0 _delay_ms(1); } void Lcd4_Clear() { Lcd4_Cmd(0); Lcd4_Cmd(1); } void Lcd4_Set_Cursor(char a, char b) { char temp,z,y; if(a == 1) { temp = 0x80 + b; z = temp>>4; y = (0x80+b) & 0x0F; Lcd4_Cmd(z); Lcd4_Cmd(y); } else if(a == 2) { temp = 0xC0 + b; z = temp>>4; y = (0xC0+b) & 0x0F; Lcd4_Cmd(z); Lcd4_Cmd(y); } } void Lcd4_Init() { Lcd4_Port(0x00); _delay_ms(20); ///////////// Reset process from datasheet ///////// Lcd4_Cmd(0x03); _delay_ms(5); Lcd4_Cmd(0x03); _delay_ms(11); Lcd4_Cmd(0x03); ///////////////////////////////////////////////////// Lcd4_Cmd(0x02); Lcd4_Cmd(0x02); Lcd4_Cmd(0x08); Lcd4_Cmd(0x00); Lcd4_Cmd(0x0C); Lcd4_Cmd(0x00); Lcd4_Cmd(0x06); } void Lcd4_Write_Char(char a) { char temp,y; temp = a&0x0F; y = a&0xF0; pinChange(RS,1); // => RS = 1 Lcd4_Port(y>>4); //Data transfer pinChange(EN,1); _delay_ms(1); pinChange(EN,0); _delay_ms(1); Lcd4_Port(temp); pinChange(EN,1); _delay_ms(1); pinChange(EN,0); _delay_ms(1); } void Lcd4_Write_String(char *a) { int i; for(i=0;a[i]!='\0';i++) Lcd4_Write_Char(a[i]); } void Lcd4_Shift_Right() { Lcd4_Cmd(0x01); Lcd4_Cmd(0x0C); } void Lcd4_Shift_Left() { Lcd4_Cmd(0x01); Lcd4_Cmd(0x08); } //End LCD 4 Bit Interfacing Functions
