library ieee; use ieee.std_logic_1164.all; entity tb_AD7960_conversion_freq is end tb_AD7960_conversion_freq; architecture tb of tb_AD7960_conversion_freq is component AD7960_conversion_freq port (DINp : in std_logic; DCOp : out std_logic; DCIp : in std_logic; CNVp : out std_logic; clk : in std_logic; sync_clk : in std_logic; aresetn : in std_logic; conv : in std_logic; data : out std_logic_vector (16-1 downto 0); dvalid : out std_logic); end component; signal DINp : std_logic; signal DCOp : std_logic; signal DCIp : std_logic; signal CNVp : std_logic; signal clk : std_logic; signal sync_clk : std_logic; signal aresetn : std_logic; signal conv : std_logic; signal data : std_logic_vector (16-1 downto 0); signal dvalid : std_logic; constant TbPeriod : time := 10 ns; -- EDIT Put right period here constant CNVPeriod : time := 333 ns; -- EDIT Put right period here constant SYNCPeriod : time := 5 ns; -- EDIT Put right period here signal TbClock : std_logic := '0'; signal TbSimEnded : std_logic := '0'; signal ConvClock : std_logic := '0'; signal SyncClock : std_logic := '0'; procedure send_data( d : std_logic_vector; -- data to send -- Signal interface signal DC : in std_logic; signal Data : out std_logic ) is begin for i in d'range loop --wait for 18 ns; Data <= d(i); wait until falling_edge(DC); end loop; wait until rising_edge(DC); end procedure send_data; begin dut : AD7960_conversion_freq port map (DINp => DINp, DCOp => DCOp, DCIp => DCIp, CNVp => CNVp, clk => clk, sync_clk => sync_clk, aresetn => aresetn, conv => conv, data => data, dvalid => dvalid); -- Clock generation TbClock <= not TbClock after TbPeriod/2 when TbSimEnded /= '1' else '0'; ConvClock <= not ConvClock after CNVPeriod/2 when TbSimEnded /= '1' else '0'; SyncClock <=not SyncClock after SYNCPeriod/2 when TbSimEnded /= '1' else '0'; -- EDIT: Check that clk is really your main clock signal clk <= TbClock; conv <= ConvClock; DCIp <= DCOp;-- after 3ns; sync_clk <= SyncClock; stimuli : process begin -- EDIT Adapt initialization as needed --DINp <= '0'; --DCIp <= '0'; --conv <= '0'; -- Reset generation -- EDIT: Check that aresetn is really your reset signal aresetn <= '0'; wait for 100 ns; aresetn <= '1'; wait for 100 ns; --conv <= ConvClock; -- EDIT Add stimuli here --wait for 10 * TbPeriod; --DCIp <= DCOp;-- after 3ns; wait until rising_edge(DCOp); send_data(x"F3A0", DCOp, DINp); wait until rising_edge(DCOp); send_data(x"F3A0", DCOp, DINp); wait until rising_edge(DCOp); send_data(x"1234", DCOp, DINp); wait until rising_edge(DCOp); send_data(x"F0F0", DCOp, DINp); wait for 100 ns; -- Stop the clock and hence terminate the simulation TbSimEnded <= '1'; wait; end process; end tb; -- Configuration block below is required by some simulators. Usually no need to edit. configuration cfg_tb_AD7960_conversion_freq of tb_AD7960_conversion_freq is for tb end for; end cfg_tb_AD7960_conversion_freq;
