root@home2l:/ # avrdude -c stk500v2 -p t85 -P /dev/cuau1 -t -v -i 10 avrdude: Version 6.4 Copyright (c) Brian Dean, http://www.bdmicro.com/ Copyright (c) Joerg Wunsch System wide configuration file is "/usr/local/etc/avrdude.conf" User configuration file is "/root/.avrduderc" User configuration file does not exist or is not a regular file, skipping Using Port : /dev/cuau1 Using Programmer : stk500v2 Setting isp clock delay : 10 avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_getsync(): timeout communicating with programmer AVR Part : ATtiny85 Chip Erase delay : 4500 us PAGEL : P00 BS2 : P00 RESET disposition : possible i/o RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 65 6 4 0 no 512 4 0 4000 4500 0xff 0xff flash 65 6 32 0 yes 8192 64 128 4500 4500 0xff 0xff signature 0 0 0 0 no 3 1 0 0 0 0x00 0x00 lock 0 0 0 0 no 1 1 0 9000 9000 0x00 0x00 lfuse 0 0 0 0 no 1 1 0 9000 9000 0x00 0x00 hfuse 0 0 0 0 no 1 1 0 9000 9000 0x00 0x00 efuse 0 0 0 0 no 1 1 0 9000 9000 0x00 0x00 calibration 0 0 0 0 no 1 1 0 0 0 0x00 0x00 Programmer Type : STK500V2 Description : Atmel STK500 Version 2.x firmware Programmer Model: Unknown avrdude: stk500v2_ReceiveMessage(): timeout . . . avrdude: stk500v2_getsync(): timeout communicating with programmer avrdude: stk500v2_command(): failed miserably to execute command 0x11 avrdude: stk500v2_disable(): failed to leave programming mode root@home2l:/ # usbconfig ugen0.1: <0x8086 XHCI root HUB> at usbus0, cfg=0 md=HOST spd=SUPER (5.0Gbps) pwr=SAVE (0mA) ugen0.2: at usbus0, cfg=0 md=HOST spd=LOW (1.5Mbps) pwr=ON (100mA) ugen0.3: at usbus0, cfg=0 md=HOST spd=LOW (1.5Mbps) pwr=ON (100mA) ugen0.4: at usbus0, cfg=0 md=HOST spd=FULL (12Mbps) pwr=ON (500mA) root@home2l:/ # usbconfig -d ugen0.4 dump_device_desc ugen0.4: at usbus0, cfg=0 md=HOST spd=FULL (12Mbps) pwr=ON (500mA) bLength = 0x0012 bDescriptorType = 0x0001 bcdUSB = 0x0200 bDeviceClass = 0x0002 bDeviceSubClass = 0x0000 bDeviceProtocol = 0x0000 bMaxPacketSize0 = 0x0040 idVendor = 0x16c0 idProduct = 0x2a9b bcdDevice = 0x4340 iManufacturer = 0x0001 iProduct = 0x0002 iSerialNumber = 0x0003 <19331-49101-552> bNumConfigurations = 0x0001 - - -
