'-------------------------------------------------- ' $serialinput.bas ' (c) 1999-2003 MCS Electronics ' demonstrates $SERIALINPUT redirection of serial input '-------------------------------------------------- 'define chip to use $regfile = "8535def.dat" 'define used crystal $crystal = 4000000 'dimension used variables Dim S As String * 10 Dim W As Long 'inform the compiler which routine must be called to get serial characters $serialinput = Myinput 'make a never ending loop Do 'ask for name Input "name " , S Print S 'error is set on time out Print "Error " ; Err Loop End 'custom character handling routine 'instead of saving and restoring only the used registers 'and write full ASM code, we use Pushall and PopAll to save and restore 'all registers so we can use all BASIC statements '$SERIALINPUT requires that the character is passed back in R24 Myinput: Pushall 'save all registers W = 0 'reset counter Myinput1: Incr W 'increase counter Sbis USR, 7 ' Wait for character Rjmp myinput2 'no charac waiting so check again Popall 'we got something Err = 0 'reset error In _temp1, UDR ' Read character from UART Return 'end of routine Myinput2: If W > 1000000 Then 'with 4 MHz ca 10 sec delay rjmp Myinput_exit 'waited too long Else Goto Myinput1 'try again End If Myinput_exit: Popall 'restore registers Err = 1 'set error variable ldi R24, 13 'fake enter so INPUT will end Return
