Screen 0: minimum 320 x 200, current 1024 x 768, maximum 4096 x 4096 VGA1 connected 1024x768+0+0 (0x43) normal (normal left inverted right x axis y axis) 360mm x 270mm Identifier: 0x3b Timestamp: 126590 Subpixel: unknown Clones: LVDS1 CRTC: 0 CRTCs: 0 1 Transform: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000 filter: EDID: 00ffffffffffff00410c07e075610300 2c0b010368241bb0e800b8a057499b26 10484cadef803159455961598199a94f d140010101011a4f403062b0324040c0 1300680e1100001e000000ff00204358 20203232313535370a20000000fc0050 48494c495053203130394232000000fd 0032a01e6115000a202020202020001e 1600x1200 (0x3e) 202.5MHz +HSync +VSync h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 93.8KHz v: height 1200 start 1201 end 1204 total 1250 clock 75.0Hz 1280x1024 (0x3f) 135.0MHz +HSync +VSync h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 80.0KHz v: height 1024 start 1025 end 1028 total 1066 clock 75.0Hz 1152x864 (0x40) 108.0MHz +HSync +VSync h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.5KHz v: height 864 start 865 end 868 total 900 clock 75.0Hz 1024x768 (0x41) 78.8MHz +HSync +VSync h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.1KHz v: height 768 start 769 end 772 total 800 clock 75.1Hz 1024x768 (0x42) 75.0MHz -HSync -VSync h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.5KHz v: height 768 start 771 end 777 total 806 clock 70.1Hz 1024x768 (0x43) 65.0MHz -HSync -VSync *current h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.4KHz v: height 768 start 771 end 777 total 806 clock 60.0Hz 832x624 (0x44) 57.3MHz -HSync -VSync h: width 832 start 864 end 928 total 1152 skew 0 clock 49.7KHz v: height 624 start 625 end 628 total 667 clock 74.6Hz 800x600 (0x45) 50.0MHz +HSync +VSync h: width 800 start 856 end 976 total 1040 skew 0 clock 48.1KHz v: height 600 start 637 end 643 total 666 clock 72.2Hz 800x600 (0x46) 49.5MHz +HSync +VSync h: width 800 start 816 end 896 total 1056 skew 0 clock 46.9KHz v: height 600 start 601 end 604 total 625 clock 75.0Hz 800x600 (0x47) 40.0MHz +HSync +VSync h: width 800 start 840 end 968 total 1056 skew 0 clock 37.9KHz v: height 600 start 601 end 605 total 628 clock 60.3Hz 640x480 (0x48) 31.5MHz -HSync -VSync h: width 640 start 664 end 704 total 832 skew 0 clock 37.9KHz v: height 480 start 489 end 491 total 520 clock 72.8Hz 640x480 (0x49) 31.5MHz -HSync -VSync h: width 640 start 656 end 720 total 840 skew 0 clock 37.5KHz v: height 480 start 481 end 484 total 500 clock 75.0Hz 640x480 (0x4a) 25.2MHz -HSync -VSync h: width 640 start 656 end 752 total 800 skew 0 clock 31.5KHz v: height 480 start 490 end 492 total 525 clock 60.0Hz 720x400 (0x4b) 28.3MHz -HSync +VSync h: width 720 start 738 end 846 total 900 skew 0 clock 31.5KHz v: height 400 start 412 end 414 total 449 clock 70.1Hz LVDS1 connected 1024x768+0+0 (0x4c) normal (normal left inverted right x axis y axis) 0mm x 0mm Identifier: 0x3c Timestamp: 126590 Subpixel: horizontal rgb Clones: VGA1 CRTC: 1 CRTCs: 0 1 Transform: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000 filter: 1024x768 (0x4c) 65.0MHz *current +preferred h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.4KHz v: height 768 start 771 end 777 total 806 clock 60.0Hz 1024x768 (0x4d) 94.5MHz +HSync +VSync h: width 1024 start 1072 end 1168 total 1376 skew 0 clock 68.7KHz v: height 768 start 769 end 772 total 808 clock 85.0Hz 1024x768 (0x4e) 78.8MHz +HSync +VSync h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.0KHz v: height 768 start 769 end 772 total 800 clock 75.0Hz 1024x768 (0x42) 75.0MHz -HSync -VSync h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.5KHz v: height 768 start 771 end 777 total 806 clock 70.1Hz 1024x768 (0x43) 65.0MHz -HSync -VSync h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.4KHz v: height 768 start 771 end 777 total 806 clock 60.0Hz 832x624 (0x44) 57.3MHz -HSync -VSync h: width 832 start 864 end 928 total 1152 skew 0 clock 49.7KHz v: height 624 start 625 end 628 total 667 clock 74.6Hz 800x600 (0x4f) 56.3MHz +HSync +VSync h: width 800 start 832 end 896 total 1048 skew 0 clock 53.7KHz v: height 600 start 601 end 604 total 631 clock 85.1Hz 800x600 (0x45) 50.0MHz +HSync +VSync h: width 800 start 856 end 976 total 1040 skew 0 clock 48.1KHz v: height 600 start 637 end 643 total 666 clock 72.2Hz 800x600 (0x46) 49.5MHz +HSync +VSync h: width 800 start 816 end 896 total 1056 skew 0 clock 46.9KHz v: height 600 start 601 end 604 total 625 clock 75.0Hz 800x600 (0x47) 40.0MHz +HSync +VSync h: width 800 start 840 end 968 total 1056 skew 0 clock 37.9KHz v: height 600 start 601 end 605 total 628 clock 60.3Hz 800x600 (0x50) 36.0MHz +HSync +VSync h: width 800 start 824 end 896 total 1024 skew 0 clock 35.2KHz v: height 600 start 601 end 603 total 625 clock 56.2Hz 640x480 (0x51) 36.0MHz -HSync -VSync h: width 640 start 696 end 752 total 832 skew 0 clock 43.3KHz v: height 480 start 481 end 484 total 509 clock 85.0Hz 640x480 (0x52) 31.5MHz -HSync -VSync h: width 640 start 664 end 704 total 832 skew 0 clock 37.9KHz v: height 480 start 489 end 492 total 520 clock 72.8Hz 640x480 (0x49) 31.5MHz -HSync -VSync h: width 640 start 656 end 720 total 840 skew 0 clock 37.5KHz v: height 480 start 481 end 484 total 500 clock 75.0Hz 640x480 (0x53) 25.2MHz -HSync -VSync h: width 640 start 656 end 752 total 800 skew 0 clock 31.5KHz v: height 480 start 490 end 492 total 525 clock 59.9Hz 720x400 (0x54) 35.5MHz -HSync +VSync h: width 720 start 756 end 828 total 936 skew 0 clock 37.9KHz v: height 400 start 401 end 404 total 446 clock 85.0Hz 640x400 (0x55) 31.5MHz -HSync +VSync h: width 640 start 672 end 736 total 832 skew 0 clock 37.9KHz v: height 400 start 401 end 404 total 445 clock 85.1Hz 640x350 (0x56) 31.5MHz +HSync -VSync h: width 640 start 672 end 736 total 832 skew 0 clock 37.9KHz v: height 350 start 382 end 385 total 445 clock 85.1Hz TV1 unknown connection (normal left inverted right x axis y axis) Identifier: 0x3d Timestamp: 126590 Subpixel: unknown Clones: CRTCs: 0 1 Transform: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000 filter: bottom margin: 37 (0x00000025) range: (0,100) right margin: 46 (0x0000002e) range: (0,100) top margin: 36 (0x00000024) range: (0,100) left margin: 54 (0x00000036) range: (0,100) mode: NTSC-M supported: NTSC-M NTSC-443 NTSC-J PAL-M PAL-N PAL 480p@59.94Hz 480p@60Hz 576p 720p@60Hz 720p@59.94Hz 720p@50Hz 1080i@50Hz 1080i@60Hz 1080i@59.94H 1024x768 (0x43) 65.0MHz -HSync -VSync h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.4KHz v: height 768 start 771 end 777 total 806 clock 60.0Hz 800x600 (0x47) 40.0MHz +HSync +VSync h: width 800 start 840 end 968 total 1056 skew 0 clock 37.9KHz v: height 600 start 601 end 605 total 628 clock 60.3Hz 640x480 (0x53) 25.2MHz -HSync -VSync h: width 640 start 656 end 752 total 800 skew 0 clock 31.5KHz v: height 480 start 490 end 492 total 525 clock 59.9Hz
