/* ************************************************************************ * (c) by Karl-Heinz Kuebbeler, Project Transistor Tester * * File: 7x8_vertikal_LSB_1.h * Funktion: table of the bits for the 7x8 character set * - 8 bytes per character * - first byte: first vertical line (left to right) * - bit #0: top / bit #7: bottom (vertically flipped) * * History: Date Sign Kommentar * 2021-01-05 Bohu ISO 8859-2 character added * 2021-01-10 Karl defined added * 2021-01-13 Karl sequence of characters in area 3-15 changed * 2021-01-27 Bohu some special characters changed * 2021-02-13 Karl defines in std_defines.h * 2021-02-16 Karl dual tables for tester and characters * 2022-09-01 FuzzyS corrections & modifications * ************************************************************************ */ #include "std_defines.h" /* use standard defines for special characters */ #if defined(MAIN_C) const unsigned char PROGMEM sfont[9][FONT_WIDTH]= { {0x08,0x3E,0x22,0x22,0x22,0x3E,0x08}, /* 0x00 Resistor3 */ {0x7F,0x7F,0x3E,0x1C,0x08,0x7F,0x08}, /* 0x01 Diode1 */ {0x08,0x7F,0x08,0x1C,0x3E,0x7F,0x7F}, /* 0x02 Diode2 */ {0x08,0x7F,0x7F,0x00,0x00,0x7F,0x7F}, /* 0x03 Capacitor */ {0x7F,0x41,0x41,0x41,0x41,0x41,0x41}, /* 0x04 Resistor2 */ {0x41,0x41,0x41,0x41,0x41,0x41,0x7F}, /* 0x05 Resistor1 */ {0x08,0x08,0x08,0x08,0x08,0x08,0x08}, /* 0x06 Line1 */ {0x38,0x40,0x40,0x30,0x40,0x40,0x30}, /* 0x07 Inductor1 */ {0x40,0x40,0x30,0x40,0x40,0x38,0x08}, /* 0x08 Inductor2 */ }; const unsigned char PROGMEM nfont[(CHAR_COUNT-28)][(FONT_WIDTH-1)]= { {0xC0,0x7E,0x01,0x49,0x49,0x36}, /* 0x1c Beta */ {0x5C,0x62,0x02,0x02,0x62,0x5C}, /* 0x1d Omega */ {0xFE,0x20,0x20,0x10,0x3E,0x40}, /* 0x1e micro */ {0x00,0x02,0x05,0x02,0x00,0x00}, /* 0x1f degree */ /* ----ASCII-0x20-0x79---------------- */ {0x00,0x00,0x00,0x00,0x00,0x00}, /* 0x20 ' ' */ {0x00,0x00,0x6F,0x6F,0x00,0x00}, /* 0x21 '!' */ {0x00,0x07,0x00,0x07,0x00,0x00}, /* 0x22 '"' */ {0x14,0x3E,0x14,0x3E,0x14,0x00}, /* 0x23 '#' */ {0x04,0x2A,0x7F,0x2A,0x10,0x00}, /* 0x24 '$' */ {0x23,0x13,0x08,0x64,0x62,0x00}, /* 0x25 '%' */ {0x36,0x49,0x49,0x55,0x22,0x50}, /* 0x26 '&' */ {0x00,0x00,0x07,0x0B,0x00,0x00}, /* 0x27 ''' */ {0x00,0x1C,0x22,0x41,0x00,0x00}, /* 0x28 '(' */ {0x00,0x00,0x41,0x22,0x1C,0x00}, /* 0x29 ')' */ {0x14,0x08,0x3E,0x08,0x14,0x00}, /* 0x2a '*' */ {0x08,0x08,0x3E,0x08,0x08,0x00}, /* 0x2b '+' */ {0x00,0x00,0xB0,0x70,0x00,0x00}, /* 0x2c ',' */ {0x08,0x08,0x08,0x08,0x08,0x08}, /* 0x2d '-' */ {0x00,0x00,0x60,0x60,0x00,0x00}, /* 0x2e '.' */ {0x40,0x20,0x10,0x08,0x04,0x00}, /* 0x2f '/' */ {0x3E,0x51,0x49,0x45,0x3E,0x00}, /* 0x30 '0' */ {0x00,0x42,0x7F,0x40,0x00,0x00}, /* 0x31 '1' */ {0x42,0x61,0x51,0x49,0x46,0x00}, /* 0x32 '2' */ {0x41,0x41,0x49,0x49,0x36,0x00}, /* 0x33 '3' */ {0x18,0x14,0x12,0x7F,0x10,0x00}, /* 0x34 '4' */ {0x27,0x45,0x45,0x45,0x39,0x00}, /* 0x35 '5' */ {0x3C,0x4A,0x49,0x49,0x30,0x00}, /* 0x36 '6' */ {0x01,0x71,0x09,0x05,0x03,0x00}, /* 0x37 '7' */ {0x36,0x49,0x49,0x49,0x36,0x00}, /* 0x38 '8' */ {0x06,0x49,0x49,0x29,0x1E,0x00}, /* 0x39 '9' */ {0x00,0x00,0x66,0x66,0x00,0x00}, /* 0x3a ':' */ {0x00,0x00,0xA6,0x66,0x00,0x00}, /* 0x3b ';' */ {0x00,0x08,0x14,0x22,0x41,0x00}, /* 0x3c '<' */ {0x14,0x14,0x14,0x14,0x14,0x14}, /* 0x3d '=' */ {0x00,0x41,0x22,0x14,0x08,0x00}, /* 0x3e '>' */ {0x02,0x01,0x51,0x09,0x06,0x00}, /* 0x3f '?' */ {0x3E,0x41,0x5D,0x55,0x5E,0x00}, /* 0x40 '@' */ {0x7E,0x09,0x09,0x09,0x7E,0x00}, /* 0x41 'A' */ {0x7F,0x49,0x49,0x49,0x36,0x00}, /* 0x42 'B' */ {0x3E,0x41,0x41,0x41,0x22,0x00}, /* 0x43 'C' */ {0x7F,0x41,0x41,0x22,0x1C,0x00}, /* 0x44 'D' */ {0x7F,0x49,0x49,0x49,0x41,0x00}, /* 0x45 'E' */ {0x7F,0x09,0x09,0x09,0x01,0x00}, /* 0x46 'F' */ {0x3E,0x41,0x49,0x49,0x79,0x00}, /* 0x47 'G' */ {0x7F,0x08,0x08,0x08,0x7F,0x00}, /* 0x48 'H' */ {0x00,0x41,0x7F,0x41,0x00,0x00}, /* 0x49 'I' */ {0x30,0x40,0x40,0x40,0x3F,0x00}, /* 0x4a 'J' */ {0x7F,0x18,0x14,0x22,0x41,0x00}, /* 0x4b 'K' */ {0x7F,0x40,0x40,0x40,0x40,0x00}, /* 0x4c 'L' */ {0x7F,0x06,0x0C,0x06,0x7F,0x00}, /* 0x4d 'M' */ {0x7F,0x04,0x08,0x10,0x7F,0x00}, /* 0x4e 'N' */ {0x3E,0x41,0x41,0x41,0x3E,0x00}, /* 0x4f 'O' */ {0x7F,0x09,0x09,0x09,0x06,0x00}, /* 0x50 'P' */ {0x3E,0x41,0x51,0x21,0x5E,0x00}, /* 0x51 'Q' */ {0x7F,0x09,0x19,0x29,0x46,0x00}, /* 0x52 'R' */ {0x26,0x49,0x49,0x49,0x32,0x00}, /* 0x53 'S' */ {0x01,0x01,0x7F,0x01,0x01,0x00}, /* 0x54 'T' */ {0x3F,0x40,0x40,0x40,0x3F,0x00}, /* 0x55 'U' */ {0x1F,0x20,0x40,0x20,0x1F,0x00}, /* 0x56 'V' */ {0x3F,0x40,0x38,0x40,0x3F,0x00}, /* 0x57 'W' */ {0x63,0x14,0x08,0x14,0x63,0x00}, /* 0x58 'X' */ {0x07,0x08,0x70,0x08,0x07,0x00}, /* 0x59 'Y' */ {0x61,0x51,0x49,0x45,0x43,0x00}, /* 0x5a 'Z' */ {0x00,0x7F,0x41,0x41,0x00,0x00}, /* 0x5b '[' */ {0x00,0x04,0x08,0x10,0x20,0x40}, /* 0x5c '\' */ {0x00,0x41,0x41,0x7F,0x00,0x00}, /* 0x5d ']' */ {0x04,0x02,0x01,0x02,0x04,0x00}, /* 0x5e '^' */ {0x80,0x80,0x80,0x80,0x80,0x00}, /* 0x5f '_' */ {0x00,0x01,0x02,0x04,0x00,0x00}, /* 0x60 '`' */ {0x20,0x54,0x54,0x54,0x78,0x00}, /* 0x61 'a' */ {0x7F,0x48,0x44,0x44,0x38,0x00}, /* 0x62 'b' */ {0x38,0x44,0x44,0x44,0x44,0x00}, /* 0x63 'c' */ {0x38,0x44,0x44,0x48,0x7F,0x00}, /* 0x64 'd' */ {0x38,0x54,0x54,0x54,0x58,0x00}, /* 0x65 'e' */ {0x08,0x7E,0x09,0x01,0x02,0x00}, /* 0x66 'f' */ {0x18,0xA4,0xA4,0xA4,0x7C,0x00}, /* 0x67 'g' */ {0x7F,0x08,0x08,0x08,0x70,0x00}, /* 0x68 'h' */ {0x00,0x44,0x7D,0x40,0x00,0x00}, /* 0x69 'i' */ {0x40,0x80,0x84,0x7D,0x04,0x00}, /* 0x6a 'j' */ {0x00,0x7F,0x10,0x28,0x44,0x00}, /* 0x6b 'k' */ {0x00,0x01,0x7F,0x40,0x00,0x00}, /* 0x6c 'l' */ {0x7C,0x04,0x38,0x04,0x78,0x00}, /* 0x6d 'm' */ {0x7C,0x08,0x04,0x04,0x78,0x00}, /* 0x6e 'n' */ {0x38,0x44,0x44,0x44,0x38,0x00}, /* 0x6f 'o' */ {0xFC,0x14,0x24,0x24,0x18,0x00}, /* 0x70 'p' */ {0x18,0x24,0x24,0x14,0xFC,0x00}, /* 0x71 'q' */ {0x7C,0x08,0x04,0x04,0x08,0x00}, /* 0x72 'r' */ {0x48,0x54,0x54,0x54,0x20,0x00}, /* 0x73 's' */ {0x04,0x3F,0x44,0x40,0x20,0x00}, /* 0x74 't' */ {0x3C,0x40,0x40,0x20,0x7C,0x00}, /* 0x75 'u' */ {0x1C,0x20,0x40,0x20,0x1C,0x00}, /* 0x76 'v' */ {0x3C,0x40,0x30,0x40,0x3C,0x00}, /* 0x77 'w' */ {0x44,0x28,0x10,0x28,0x44,0x00}, /* 0x78 'x' */ {0x0C,0x50,0x50,0x50,0x3C,0x00}, /* 0x79 'y' */ {0x44,0x64,0x54,0x4C,0x44,0x00}, /* 0x7a 'z' */ {0x08,0x36,0x41,0x41,0x00,0x00}, /* 0x7b '{' */ {0x00,0x00,0x00,0x7F,0x00,0x00}, /* 0x7c '|' */ {0x00,0x41,0x41,0x36,0x08,0x00}, /* 0x7d '}' */ {0x04,0x02,0x04,0x08,0x10,0x08}, /* 0x7e '~' */ {0x1C,0x12,0x11,0x12,0x1C,0x00}, /* 0x7f */ /* All language specific characters are defined below, only the required are added with */ /* #include "language-dependend_characters.h" */ /* Please note, that the position of special characters defined in "std_defines.h" must match to */ /* the sequence in "language-dependend_characters.h" ! */ /* Cyrillic characters are included additionally, if required. */ #define PIX_a_acute {0x20,0x54,0x54,0x56,0x79,0x00}, #define PIX_c_acute {0x38,0x44,0x44,0x46,0x45,0x08}, #define PIX_e_acute {0x38,0x54,0x56,0x55,0x58,0x00}, #define PIX_i_acute {0x40,0x7C,0x40,0x02,0x01,0x00}, #define PIX_l_acute {0x00,0x02,0x3E,0x40,0x02,0x01}, #define PIX_n_acute {0x00,0x78,0x08,0x0A,0x09,0x70}, #define PIX_o_acute {0x30,0x48,0x4A,0x49,0x30,0x00}, #define PIX_r_acute {0x78,0x12,0x09,0x08,0x10,0x00}, #define PIX_s_acute {0x48,0x54,0x56,0x55,0x54,0x20}, #define PIX_u_acute {0x38,0x40,0x42,0x21,0x78,0x00}, #define PIX_y_acute {0x0C,0x10,0x52,0x51,0x3C,0x00}, #define PIX_z_acute {0x44,0x64,0x56,0x4D,0x44,0x00}, #define PIX_A_acute {0x70,0x28,0x26,0x25,0x28,0x70}, #define PIX_C_acute {0x18,0x24,0x43,0x43,0x42,0x24}, #define PIX_E_acute {0x7C,0x54,0x56,0x55,0x44,0x00}, #define PIX_I_acute {0x00,0x00,0x44,0x7E,0x45,0x00}, #define PIX_L_acute {0x7E,0x40,0x42,0x41,0x40,0x00}, #define PIX_N_acute {0x7E,0x04,0x0A,0x11,0x20,0x7E}, #define PIX_O_acute {0x38,0x44,0x46,0x45,0x38,0x00}, #define PIX_R_acute {0x7C,0x14,0x16,0x35,0x48,0x00}, #define PIX_S_acute {0x24,0x4A,0x43,0x53,0x24,0x00}, #define PIX_U_acute {0x3C,0x40,0x42,0x41,0x3C,0x00}, #define PIX_Y_acute {0x04,0x5C,0x70,0x72,0x5D,0x04}, #define PIX_Z_acute {0x44,0x64,0x56,0x4D,0x44,0x00}, #define PIX_a_breve {0x20,0x55,0x56,0x55,0x78,0x00}, #define PIX_A_breve {0x70,0x29,0x2A,0x29,0x70,0x00}, #define PIX_c_caron {0x00,0x30,0x49,0x4A,0x49,0x00}, #define PIX_d_caron {0x30,0x4B,0x48,0x28,0x7F,0x00}, #define PIX_e_caron {0x38,0x55,0x56,0x55,0x58,0x00}, #define PIX_l_caron {0x02,0x3C,0x41,0x02,0x01,0x00}, #define PIX_n_caron {0x78,0x11,0x0A,0x09,0x70,0x00}, #define PIX_r_caron {0x78,0x11,0x0A,0x09,0x10,0x00}, #define PIX_s_caron {0x08,0x55,0x56,0x55,0x20,0x00}, #define PIX_t_caron {0x04,0x3E,0x44,0x40,0x23,0x00}, #define PIX_z_caron {0x44,0x65,0x56,0x4D,0x44,0x00}, #define PIX_C_caron {0x30,0x49,0x4A,0x49,0x48,0x00}, #define PIX_D_caron {0x7C,0x45,0x46,0x45,0x38,0x00}, #define PIX_E_caron {0x7C,0x55,0x56,0x55,0x44,0x00}, #define PIX_L_caron {0x7E,0x40,0x41,0x42,0x41,0x00}, #define PIX_N_caron {0x7C,0x09,0x12,0x21,0x7C,0x00}, #define PIX_R_caron {0x7C,0x15,0x16,0x35,0x48,0x00}, #define PIX_S_caron {0x08,0x55,0x56,0x55,0x20,0x00}, #define PIX_T_caron {0x04,0x05,0x7E,0x05,0x04,0x00}, #define PIX_Z_caron {0x44,0x65,0x56,0x4D,0x44,0x00}, #define PIX_c_cedil {0x1C,0xA2,0xA2,0x62,0x22,0x14}, #define PIX_s_cedil {0x04,0xAA,0xAA,0x6A,0x10,0x00}, #define PIX_t_cedil {0x02,0xBF,0xA2,0x60,0x00,0x00}, #define PIX_C_cedil {0x1E,0xA1,0xA1,0x61,0x12,0x00}, #define PIX_S_cedil {0x06,0xA9,0xA9,0x69,0x10,0x00}, #define PIX_T_cedil {0x01,0x81,0xBF,0x41,0x01,0x00}, #define PIX_a_circ {0x20,0x56,0x55,0x56,0x78,0x00}, #define PIX_e_circ {0x38,0x56,0x55,0x56,0x58,0x00}, #define PIX_i_circ {0x00,0x00,0x4A,0x7D,0x42,0x00}, #define PIX_o_circ {0x38,0x46,0x45,0x46,0x38,0x00}, #define PIX_u_circ {0x38,0x42,0x41,0x22,0x78,0x00}, #define PIX_A_circ {0x70,0x2A,0x25,0x2A,0x70,0x00}, #define PIX_E_circ {0x7C,0x56,0x55,0x56,0x44,0x00}, #define PIX_I_circ {0x00,0x46,0x7D,0x45,0x02,0x00}, #define PIX_O_circ {0x38,0x46,0x45,0x46,0x38,0x00}, #define PIX_U_circ {0x3C,0x42,0x41,0x42,0x3C,0x00}, #define PIX_o_dblac {0x3B,0x44,0x44,0x44,0x3B,0x00}, #define PIX_u_dblac {0x38,0x43,0x40,0x23,0x78,0x00}, #define PIX_O_dblac {0x38,0x47,0x44,0x47,0x38,0x00}, #define PIX_U_dblac {0x3C,0x43,0x40,0x43,0x3C,0x00}, #define PIX_z_dot {0x44,0x65,0x55,0x4C,0x44,0x00}, #define PIX_Z_dot {0x42,0x62,0x53,0x4B,0x46,0x00}, #define PIX_a_elig {0x20,0x54,0x54,0x7C,0x54,0x48}, #define PIX_o_elig {0x10,0x28,0x44,0x7C,0x54,0x48}, #define PIX_A_elig {0x7C,0x0A,0x09,0x7F,0x49,0x41}, #define PIX_O_elig {0x1C,0x22,0x41,0x7F,0x49,0x41}, #define PIX_d_eth {0x38,0x44,0x44,0x58,0x7F,0x04}, #define PIX_D_eth {0x08,0x7F,0x49,0x41,0x22,0x1C}, #define PIX_a_grave {0x20,0x54,0x55,0x56,0x78,0x00}, #define PIX_e_grave {0x38,0x54,0x55,0x56,0x58,0x00}, #define PIX_i_grave {0x00,0x00,0x48,0x7D,0x42,0x00}, #define PIX_o_grave {0x38,0x44,0x45,0x46,0x38,0x00}, #define PIX_u_grave {0x38,0x40,0x41,0x22,0x78,0x00}, #define PIX_A_grave {0x70,0x28,0x25,0x2A,0x70,0x00}, #define PIX_E_grave {0x7C,0x55,0x56,0x54,0x44,0x00}, #define PIX_I_grave {0x00,0x44,0x7D,0x46,0x00,0x00}, #define PIX_O_grave {0x38,0x44,0x45,0x46,0x38,0x00}, #define PIX_U_grave {0x3C,0x41,0x42,0x40,0x3C,0x00}, #define PIX_a_ogon {0x10,0x2A,0x2A,0x6A,0xBC,0x00}, #define PIX_e_ogon {0x1C,0x2A,0x2A,0x6A,0xAC,0x00}, #define PIX_A_ogon {0x7E,0x11,0x11,0x11,0x5E,0xB0}, #define PIX_E_ogon {0x3F,0x25,0x25,0x65,0xA1,0x00}, #define PIX_a_ring {0x20,0x56,0x55,0x56,0x78,0x00}, #define PIX_u_ring {0x38,0x42,0x45,0x22,0x78,0x00}, #define PIX_A_ring {0x70,0x2A,0x2D,0x2A,0x70,0x00}, #define PIX_U_ring {0x38,0x42,0x45,0x22,0x78,0x00}, #define PIX_s_sharp {0xFE,0x4A,0x4A,0x4A,0x34,0x00}, #define PIX_o_slash {0x78,0x64,0x54,0x4C,0x3C,0x02}, #define PIX_O_slash {0x3C,0x32,0x49,0x45,0x22,0x1D}, #define PIX_l_stroke {0x00,0x09,0x3E,0x44,0x00,0x00}, #define PIX_L_stroke {0x10,0x7F,0x44,0x40,0x40,0x40}, #define PIX_a_uml {0x20,0x55,0x54,0x55,0x78,0x00}, #define PIX_e_uml {0x38,0x55,0x54,0x55,0x58,0x00}, #define PIX_i_uml {0x00,0x02,0x48,0x7A,0x40,0x00}, #define PIX_o_uml {0x38,0x45,0x44,0x45,0x38,0x00}, #define PIX_u_uml {0x3C,0x41,0x40,0x21,0x7C,0x00}, #define PIX_y_uml {0x0C,0x11,0x50,0x51,0x3C,0x00}, #define PIX_A_uml {0x79,0x14,0x12,0x14,0x79,0x00}, #define PIX_E_uml {0x7C,0x55,0x54,0x55,0x44,0x00}, #define PIX_I_uml {0x00,0x45,0x7C,0x45,0x00,0x00}, #define PIX_O_uml {0x3D,0x42,0x42,0x42,0x3D,0x00}, #define PIX_U_uml {0x3C,0x41,0x40,0x41,0x3C,0x00}, #define PIX_Y_uml {0x0C,0x11,0x60,0x11,0x0C,0x00}, #include "language-dependent_characters.h" #if defined LCD_CYRILLIC {0x7F,0x49,0x49,0x49,0x30,0x00}, /* 0x80 Cyr_B */ {0x7F,0x01,0x01,0x01,0x01,0x00}, /* 0x81 Cyr_G */ {0x7D,0x55,0x54,0x55,0x45,0x00}, /* 0x82 Cyr_Jo */ {0x77,0x08,0x7F,0x08,0x77,0x00}, /* 0x83 Cyr_Zsch */ {0x22,0x41,0x49,0x49,0x49,0x36}, /* 0x84 Cyr_Z */ {0x7F,0x30,0x18,0x0C,0x06,0x7F}, /* 0x85 Cyr_I */ {0x7C,0x60,0x31,0x19,0x0D,0x7C}, /* 0x86 Cyr_J */ {0x60,0x3C,0x02,0x01,0x01,0x7F}, /* 0x87 Cyr_L */ {0x7F,0x01,0x01,0x01,0x7F,0x00}, /* 0x88 Cyr_P */ {0x07,0x08,0x48,0x48,0x48,0x3F}, /* 0x89 Cyr_U */ {0x1C,0x22,0x7F,0x22,0x1C,0x00}, /* 0x8a Cyr_F */ {0x07,0x08,0x08,0x08,0x08,0x7F}, /* 0x8b Cyr_Tsch */ {0x7F,0x40,0x7F,0x40,0x7F,0x00}, /* 0x8c Cyr_Sch */ {0x03,0x7F,0x48,0x48,0x48,0x30}, /* 0x8d Cyr_HH */ {0x7F,0x48,0x48,0x78,0x30,0x7F}, /* 0x8e Cyr_Y */ {0x22,0x41,0x41,0x49,0x49,0x3E}, /* 0x8f Cyr_E */ {0x7F,0x08,0x3E,0x41,0x41,0x3E}, /* 0x90 Cyr_Ju */ {0x06,0x49,0x29,0x19,0x09,0x7F}, /* 0x91 Cyr_Ja */ {0x3C,0x4A,0x49,0x48,0x48,0x30}, /* 0x92 Cyr_b */ {0x7E,0x4A,0x4A,0x4A,0x4A,0x34}, /* 0x93 Cyr_v */ {0x7E,0x02,0x02,0x02,0x02,0x06}, /* 0x94 Cyr_g */ {0x39,0x55,0x54,0x55,0x55,0x18}, /* 0x95 Cyr_jo */ {0x76,0x08,0x7E,0x08,0x76,0x00}, /* 0x96 Cyr_zsch */ {0x24,0x42,0x42,0x4A,0x4A,0x34}, /* 0x97 Cyr_z */ {0x7E,0x20,0x10,0x08,0x04,0x7E}, /* 0x98 Cyr_i */ {0x7C,0x20,0x11,0x09,0x05,0x7C}, /* 0x99 Cyr_j */ {0x7E,0x08,0x08,0x14,0x22,0x40}, /* 0x9a Cyr_k */ {0x60,0x3C,0x02,0x02,0x02,0x7E}, /* 0x9b Cyr_l */ {0x7E,0x0C,0x18,0x0C,0x7E,0x00}, /* 0x9c Cyr_m */ {0x7E,0x08,0x08,0x08,0x7E,0x00}, /* 0x9d Cyr_n */ {0x7E,0x02,0x02,0x02,0x7E,0x00}, /* 0x9e Cyr_p */ {0x02,0x02,0x7E,0x02,0x02,0x00}, /* 0x9f Cyr_t */ {0x0E,0x10,0x10,0x10,0x7E,0x00}, /* 0xa0 Cyr_tsch */ {0x7E,0x40,0x7E,0x40,0x7E,0x00}, /* 0xa1 Cyr_sch */ {0x06,0x7C,0x48,0x48,0x48,0x30}, /* 0xa2 Cyr_hh */ {0x7E,0x48,0x48,0x30,0x10,0x7E}, /* 0xa3 Cyr_y */ {0x7E,0x48,0x48,0x48,0x30,0x00}, /* 0xa4 Cyr_ww */ {0x24,0x42,0x42,0x4A,0x4A,0x3C}, /* 0xa5 Cyr_e */ {0x7E,0x08,0x3C,0x42,0x42,0x3C}, /* 0xa6 Cyr_ju */ {0x0C,0x52,0x32,0x12,0x12,0x7E}, /* 0xa7 Cyr_ja */ {0xC0,0x70,0x4E,0x41,0x7F,0xC0}, /* 0xa8 Cyr_D */ {0x7F,0x40,0x40,0x40,0xFF,0xC0}, /* 0xa9 Cyr_C */ {0x7F,0x40,0x7F,0x40,0xFF,0xC0}, /* 0xaa Cyr_Schtsch */ {0xC0,0x70,0x4C,0x42,0x7E,0xC0}, /* 0xab Cyr_d */ {0x38,0x44,0xFE,0x44,0x38,0x00}, /* 0xac Cyr_f */ {0x7E,0x40,0x40,0x40,0xFE,0xC0}, /* 0xad Cyr_c */ {0x7E,0x40,0x7E,0x40,0xFE,0x00}, /* 0xae Cyr_schtsch */ #endif }; #else #ifndef __ASSEMBLER__ extern const unsigned char PROGMEM sfont[9][FONT_WIDTH]; extern const unsigned char PROGMEM nfont[(CHAR_COUNT-28)][(FONT_WIDTH-1)]; #endif #endif /* ****************************** EOF *********************** */
