#include #define DEBUG 0 /* Symbolic names for bit rate of CAN message */ typedef enum {CAN_50KBPS, CAN_100KBPS, CAN_125KBPS, CAN_250KBPS, CAN_500KBPS, CAN_1000KBPS} BITRATE; /* Real speed for bit rate of CAN message */ uint32_t SPEED[6] = {50*1000, 100*1000, 125*1000, 250*1000, 500*1000, 1000*1000}; /* Symbolic names for formats of CAN message */ typedef enum {STANDARD_FORMAT = 0, EXTENDED_FORMAT} CAN_FORMAT; /* Symbolic names for type of CAN message */ typedef enum {DATA_FRAME = 0, REMOTE_FRAME} CAN_FRAME; typedef struct { uint32_t id; /* 29 bit identifier */ uint8_t data[8]; /* Data field */ uint8_t len; /* Length of data field in bytes */ uint8_t ch; /* Object channel(Not use) */ uint8_t format; /* 0 - STANDARD, 1- EXTENDED IDENTIFIER */ uint8_t type; /* 0 - DATA FRAME, 1 - REMOTE FRAME */ } CAN_msg_t; typedef struct { uint16_t baud_rate_prescaler; /// [1 to 1024] uint8_t time_segment_1; /// [1 to 16] uint8_t time_segment_2; /// [1 to 8] uint8_t resynchronization_jump_width; /// [1 to 4] (recommended value is 1) } CAN_bit_timing_config_t; #define CAN_STM32_ERROR_UNSUPPORTED_BIT_RATE 1000 #define CAN_STM32_ERROR_MSR_INAK_NOT_SET 1001 #define CAN_STM32_ERROR_MSR_INAK_NOT_CLEARED 1002 #define CAN_STM32_ERROR_UNSUPPORTED_FRAME_FORMAT 1003 /* * Calculation of bit timing dependent on peripheral clock rate */ int16_t ComputeCANTimings(const uint32_t peripheral_clock_rate, const uint32_t target_bitrate, CAN_bit_timing_config_t* const out_timings) { if (target_bitrate < 1000) { return -CAN_STM32_ERROR_UNSUPPORTED_BIT_RATE; } assert(out_timings != NULL); // NOLINT memset(out_timings, 0, sizeof(*out_timings)); /* * Hardware configuration */ static const uint8_t MaxBS1 = 16; static const uint8_t MaxBS2 = 8; /* * Ref. "Automatic Baudrate Detection in CANopen Networks", U. Koppe, MicroControl GmbH & Co. KG * CAN in Automation, 2003 * * According to the source, optimal quanta per bit are: * Bitrate Optimal Maximum * 1000 kbps 8 10 * 500 kbps 16 17 * 250 kbps 16 17 * 125 kbps 16 17 */ const uint8_t max_quanta_per_bit = (uint8_t)((target_bitrate >= 1000000) ? 10 : 17); // NOLINT assert(max_quanta_per_bit <= (MaxBS1 + MaxBS2)); static const uint16_t MaxSamplePointLocationPermill = 900; /* * Computing (prescaler * BS): * BITRATE = 1 / (PRESCALER * (1 / PCLK) * (1 + BS1 + BS2)) -- See the Reference Manual * BITRATE = PCLK / (PRESCALER * (1 + BS1 + BS2)) -- Simplified * let: * BS = 1 + BS1 + BS2 -- Number of time quanta per bit * PRESCALER_BS = PRESCALER * BS * ==> * PRESCALER_BS = PCLK / BITRATE */ const uint32_t prescaler_bs = peripheral_clock_rate / target_bitrate; /* * Searching for such prescaler value so that the number of quanta per bit is highest. */ uint8_t bs1_bs2_sum = (uint8_t)(max_quanta_per_bit - 1); // NOLINT while ((prescaler_bs % (1U + bs1_bs2_sum)) != 0) { if (bs1_bs2_sum <= 2) { return -CAN_STM32_ERROR_UNSUPPORTED_BIT_RATE; // No solution } bs1_bs2_sum--; } const uint32_t prescaler = prescaler_bs / (1U + bs1_bs2_sum); if ((prescaler < 1U) || (prescaler > 1024U)) { return -CAN_STM32_ERROR_UNSUPPORTED_BIT_RATE; // No solution } /* * Now we have a constraint: (BS1 + BS2) == bs1_bs2_sum. * We need to find such values so that the sample point is as close as possible to the optimal value, * which is 87.5%, which is 7/8. * * Solve[(1 + bs1)/(1 + bs1 + bs2) == 7/8, bs2] (* Where 7/8 is 0.875, the recommended sample point location *) * {{bs2 -> (1 + bs1)/7}} * * Hence: * bs2 = (1 + bs1) / 7 * bs1 = (7 * bs1_bs2_sum - 1) / 8 * * Sample point location can be computed as follows: * Sample point location = (1 + bs1) / (1 + bs1 + bs2) * * Since the optimal solution is so close to the maximum, we prepare two solutions, and then pick the best one: * - With rounding to nearest * - With rounding to zero */ uint8_t bs1 = (uint8_t)(((7 * bs1_bs2_sum - 1) + 4) / 8); // Trying rounding to nearest first // NOLINT uint8_t bs2 = (uint8_t)(bs1_bs2_sum - bs1); // NOLINT assert(bs1_bs2_sum > bs1); { const uint16_t sample_point_permill = (uint16_t)(1000U * (1U + bs1) / (1U + bs1 + bs2)); // NOLINT if (sample_point_permill > MaxSamplePointLocationPermill) // Strictly more! { bs1 = (uint8_t)((7 * bs1_bs2_sum - 1) / 8); // Nope, too far; now rounding to zero bs2 = (uint8_t)(bs1_bs2_sum - bs1); } } const bool valid = (bs1 >= 1) && (bs1 <= MaxBS1) && (bs2 >= 1) && (bs2 <= MaxBS2); /* * Final validation * Helpful Python: * def sample_point_from_btr(x): * assert 0b0011110010000000111111000000000 & x == 0 * ts2,ts1,brp = (x>>20)&7, (x>>16)&15, x&511 * return (1+ts1+1)/(1+ts1+1+ts2+1) */ if ((target_bitrate != (peripheral_clock_rate / (prescaler * (1U + bs1 + bs2)))) || !valid) { // This actually means that the algorithm has a logic error, hence assert(0). assert(0); // NOLINT return -CAN_STM32_ERROR_UNSUPPORTED_BIT_RATE; } out_timings->baud_rate_prescaler = (uint16_t) prescaler; out_timings->resynchronization_jump_width = 1; // One is recommended by UAVCAN, CANOpen, and DeviceNet out_timings->time_segment_1 = bs1; out_timings->time_segment_2 = bs2; if (DEBUG) { Serial.print("target_bitrate="); Serial.println(target_bitrate); Serial.print("peripheral_clock_rate="); Serial.println(peripheral_clock_rate); Serial.print("timings.baud_rate_prescaler="); Serial.println(out_timings->baud_rate_prescaler); Serial.print("timings.time_segment_1="); Serial.println(out_timings->time_segment_1); Serial.print("timings.time_segment_2="); Serial.println(out_timings->time_segment_2); Serial.print("timings.resynchronization_jump_width="); Serial.println(out_timings->resynchronization_jump_width); } return 0; } /** * Print registers. */ void printRegister(const char * buf, uint32_t reg) { if (DEBUG == 0) return; Serial.print(buf); Serial.print(reg, HEX); Serial.println(); } /** * Initializes the CAN filter registers. * * @preconditions - This register can be written only when the filter initialization mode is set (FINIT=1) in the CAN_FMR register. * @params: index - Specified filter index. index 27:14 are available in connectivity line devices only. * @params: scale - Select filter scale. * 0: Dual 16-bit scale configuration * 1: Single 32-bit scale configuration * @params: mode - Select filter mode. * 0: Two 32-bit registers of filter bank x are in Identifier Mask mode * 1: Two 32-bit registers of filter bank x are in Identifier List mode * @params: fifo - Select filter assigned. * 0: Filter assigned to FIFO 0 * 1: Filter assigned to FIFO 1 * @params: bank1 - Filter bank register 1 * @params: bank2 - Filter bank register 2 * */ void CANSetFilter(uint8_t index, uint8_t scale, uint8_t mode, uint8_t fifo, uint32_t bank1, uint32_t bank2) { if (index > 27) return; CAN1->FA1R &= ~(0x1UL<FS1R &= ~(0x1UL<FS1R |= (0x1UL<FM1R &= ~(0x1UL<FM1R |= (0x1UL<FFA1R &= ~(0x1UL<FFA1R |= (0x1UL<sFilterRegister[index].FR1 = bank1; // Set filter bank registers1 CAN1->sFilterRegister[index].FR2 = bank2; // Set filter bank registers2 CAN1->FA1R |= (0x1UL<APB1ENR |= 0x2000000UL; // Enable CAN clock RCC->APB2ENR |= 0x1UL; // Enable AFIO clock AFIO->MAPR &= 0xFFFF9FFF; // reset CAN remap // CAN_RX mapped to PA11, CAN_TX mapped to PA12 if (remap == 0) { RCC->APB2ENR |= 0x4UL; // Enable GPIOA clock GPIOA->CRH &= ~(0xFF000UL); // Configure PA12(0b0000) and PA11(0b0000) // 0b0000 // MODE=00(Input mode) // CNF=00(Analog mode) GPIOA->CRH |= 0xB8FFFUL; // Configure PA12(0b1011) and PA11(0b1000) // 0b1011 // MODE=11(Output mode, max speed 50 MHz) // CNF=10(Alternate function output Push-pull // 0b1000 // MODE=00(Input mode) // CNF=10(Input with pull-up / pull-down) GPIOA->ODR |= 0x1UL << 12; // PA12 Upll-up } if (remap == 2) { AFIO->MAPR |= 0x00004000; // set CAN remap // CAN_RX mapped to PB8, CAN_TX mapped to PB9 (not available on 36-pin package) RCC->APB2ENR |= 0x8UL; // Enable GPIOB clock GPIOB->CRH &= ~(0xFFUL); // Configure PB9(0b0000) and PB8(0b0000) // 0b0000 // MODE=00(Input mode) // CNF=00(Analog mode) GPIOB->CRH |= 0xB8UL; // Configure PB9(0b1011) and PB8(0b1000) // 0b1011 // MODE=11(Output mode, max speed 50 MHz) // CNF=10(Alternate function output Push-pull // 0b1000 // MODE=00(Input mode) // CNF=10(Input with pull-up / pull-down) GPIOB->ODR |= 0x1UL << 8; // PB8 Upll-up } if (remap == 3) { AFIO->MAPR |= 0x00005000; // set CAN remap // CAN_RX mapped to PD0, CAN_TX mapped to PD1 (available on 100-pin and 144-pin package) RCC->APB2ENR |= 0x20UL; // Enable GPIOD clock GPIOD->CRL &= ~(0xFFUL); // Configure PD1(0b0000) and PD0(0b0000) // 0b0000 // MODE=00(Input mode) // CNF=00(Analog mode) GPIOD->CRH |= 0xB8UL; // Configure PD1(0b1011) and PD0(0b1000) // 0b1000 // MODE=00(Input mode) // CNF=10(Input with pull-up / pull-down) // 0b1011 // MODE=11(Output mode, max speed 50 MHz) // CNF=10(Alternate function output Push-pull GPIOD->ODR |= 0x1UL << 0; // PD0 Upll-up } CAN1->MCR |= 0x1UL; // Require CAN1 to Initialization mode while (!(CAN1->MSR & 0x1UL)); // Wait for Initialization mode //CAN1->MCR = 0x51UL; // Hardware initialization(No automatic retransmission) CAN1->MCR = 0x41UL; // Hardware initialization(With automatic retransmission) // Set bit timing register CAN_bit_timing_config_t timings; Serial.print("bitrate="); Serial.println(bitrate); uint32_t target_bitrate = SPEED[bitrate]; Serial.print("target_bitrate="); Serial.println(target_bitrate); int result = ComputeCANTimings(HAL_RCC_GetPCLK1Freq(), target_bitrate, &timings); Serial.print("ComputeCANTimings result="); Serial.println(result); if (result) while(true); CAN1->BTR = (((timings.resynchronization_jump_width - 1U) & 3U) << 24U) | (((timings.time_segment_1 - 1U) & 15U) << 16U) | (((timings.time_segment_2 - 1U) & 7U) << 20U) | ((timings.baud_rate_prescaler - 1U) & 1023U); // Configure Filters to default values CAN1->FMR |= 0x1UL; // Set to filter initialization mode CAN1->FMR &= 0xFFFFC0FF; // Clear CAN2 start bank // bxCAN has 28 filters. // These filters are shared by both CAN1 and CAN2. // STM32F103 has only CAN1, so all 28 are used for CAN1 CAN1->FMR |= 0x1C << 8; // Assign all filters to CAN1 // Set fileter 0 // Single 32-bit scale configuration // Two 32-bit registers of filter bank x are in Identifier Mask mode // Filter assigned to FIFO 0 // Filter bank register to all 0 CANSetFilter(0, 1, 0, 0, 0x0UL, 0x0UL); CAN1->FMR &= ~(0x1UL); // Deactivate initialization mode uint16_t TimeoutMilliseconds = 1000; bool can1 = false; CAN1->MCR &= ~(0x1UL); // Require CAN1 to normal mode // Wait for normal mode // If the connection is not correct, it will not return to normal mode. for (uint16_t wait_ack = 0; wait_ack < TimeoutMilliseconds; wait_ack++) { if ((CAN1->MSR & 0x1UL) == 0) { can1 = true; break; } delayMicroseconds(1000); } //Serial.print("can1="); //Serial.println(can1); if (can1) { Serial.println("CAN1 initialize ok"); } else { Serial.println("CAN1 initialize fail!!"); return false; } return true; } #define STM32_CAN_TIR_TXRQ (1U << 0U) // Bit 0: Transmit Mailbox Request #define STM32_CAN_RIR_RTR (1U << 1U) // Bit 1: Remote Transmission Request #define STM32_CAN_RIR_IDE (1U << 2U) // Bit 2: Identifier Extension #define STM32_CAN_TIR_RTR (1U << 1U) // Bit 1: Remote Transmission Request #define STM32_CAN_TIR_IDE (1U << 2U) // Bit 2: Identifier Extension #define CAN_EXT_ID_MASK 0x1FFFFFFFU #define CAN_STD_ID_MASK 0x000007FFU /** * Decodes CAN messages from the data registers and populates a * CAN message struct with the data fields. * * @preconditions A valid CAN message is received * @params CAN_rx_msg - CAN message structure for reception * */ void CANReceive(CAN_msg_t* CAN_rx_msg) { uint32_t id = CAN1->sFIFOMailBox[0].RIR; if ((id & STM32_CAN_RIR_IDE) == 0) { // Standard frame format CAN_rx_msg->format = STANDARD_FORMAT;; CAN_rx_msg->id = (CAN_STD_ID_MASK & (id >> 21U)); } else { // Extended frame format CAN_rx_msg->format = EXTENDED_FORMAT;; CAN_rx_msg->id = (CAN_EXT_ID_MASK & (id >> 3U)); } if ((id & STM32_CAN_RIR_RTR) == 0) { // Data frame CAN_rx_msg->type = DATA_FRAME; } else { // Remote frame CAN_rx_msg->type = REMOTE_FRAME; } CAN_rx_msg->len = (CAN1->sFIFOMailBox[0].RDTR) & 0xFUL; CAN_rx_msg->data[0] = 0xFFUL & CAN1->sFIFOMailBox[0].RDLR; CAN_rx_msg->data[1] = 0xFFUL & (CAN1->sFIFOMailBox[0].RDLR >> 8); CAN_rx_msg->data[2] = 0xFFUL & (CAN1->sFIFOMailBox[0].RDLR >> 16); CAN_rx_msg->data[3] = 0xFFUL & (CAN1->sFIFOMailBox[0].RDLR >> 24); CAN_rx_msg->data[4] = 0xFFUL & CAN1->sFIFOMailBox[0].RDHR; CAN_rx_msg->data[5] = 0xFFUL & (CAN1->sFIFOMailBox[0].RDHR >> 8); CAN_rx_msg->data[6] = 0xFFUL & (CAN1->sFIFOMailBox[0].RDHR >> 16); CAN_rx_msg->data[7] = 0xFFUL & (CAN1->sFIFOMailBox[0].RDHR >> 24); // Release FIFO 0 output mailbox. // Make the next incoming message available. CAN1->RF0R |= 0x20UL; } /** * Encodes CAN messages using the CAN message struct and populates the * data registers with the sent. * * @params CAN_tx_msg - CAN message structure for transmission * */ void CANSend(CAN_msg_t* CAN_tx_msg) { volatile int count = 0; uint32_t out = 0; if (CAN_tx_msg->format == EXTENDED_FORMAT) { // Extended frame format out = ((CAN_tx_msg->id & CAN_EXT_ID_MASK) << 3U) | STM32_CAN_TIR_IDE; } else { // Standard frame format out = ((CAN_tx_msg->id & CAN_STD_ID_MASK) << 21U); } // Remote frame if (CAN_tx_msg->type == REMOTE_FRAME) { out |= STM32_CAN_TIR_RTR; } CAN1->sTxMailBox[0].TDTR &= ~(0xF); CAN1->sTxMailBox[0].TDTR |= CAN_tx_msg->len & 0xFUL; CAN1->sTxMailBox[0].TDLR = (((uint32_t) CAN_tx_msg->data[3] << 24) | ((uint32_t) CAN_tx_msg->data[2] << 16) | ((uint32_t) CAN_tx_msg->data[1] << 8) | ((uint32_t) CAN_tx_msg->data[0] )); CAN1->sTxMailBox[0].TDHR = (((uint32_t) CAN_tx_msg->data[7] << 24) | ((uint32_t) CAN_tx_msg->data[6] << 16) | ((uint32_t) CAN_tx_msg->data[5] << 8) | ((uint32_t) CAN_tx_msg->data[4] )); // Send Go CAN1->sTxMailBox[0].TIR = out | STM32_CAN_TIR_TXRQ; // Wait until the mailbox is empty while(CAN1->sTxMailBox[0].TIR & 0x1UL && count++ < 1000000); // The mailbox don't becomes empty while loop if (CAN1->sTxMailBox[0].TIR & 0x1UL) { Serial.println("Send Fail"); Serial.println(CAN1->ESR); Serial.println(CAN1->MSR); Serial.println(CAN1->TSR); } } /** * Returns whether there are CAN messages available. * * @returns If pending CAN messages are in the CAN controller * */ uint8_t CANMsgAvail(void) { // Check for pending FIFO 0 messages return CAN1->RF0R & 0x3UL; } uint8_t counter = 0; uint8_t frameLength = 0; unsigned long previousMillis = 0; // stores last time output was updated const long interval = 1000; // transmission interval (milliseconds) void setup() { Serial.begin(115200); //bool ret = CANInit(CAN_500KBPS, 0); // CAN_RX mapped to PA11, CAN_TX mapped to PA12 bool ret = CANInit(CAN_500KBPS, 2); // CAN_RX mapped to PB8, CAN_TX mapped to PB9 //bool ret = CANInit(CAN_500KBPS, 3); // CAN_RX mapped to PD0, CAN_TX mapped to PD1 //bool ret = CANInit(CAN_1000KBPS, 0); // CAN_RX mapped to PA11, CAN_TX mapped to PA12 //bool ret = CANInit(CAN_1000KBPS, 2); // CAN_RX mapped to PB8, CAN_TX mapped to PB9 //bool ret = CANInit(CAN_1000KBPS, 3); // CAN_RX mapped to PD0, CAN_TX mapped to PD1 if (!ret) while(true); } void loop() { CAN_msg_t CAN_TX_msg; CAN_msg_t CAN_RX_msg; CAN_TX_msg.data[0] = 0x00; CAN_TX_msg.data[1] = 0x01; CAN_TX_msg.data[2] = 0x02; CAN_TX_msg.data[3] = 0x03; CAN_TX_msg.data[4] = 0x04; CAN_TX_msg.data[5] = 0x05; CAN_TX_msg.data[6] = 0x06; CAN_TX_msg.data[7] = 0x07; CAN_TX_msg.len = frameLength; unsigned long currentMillis = millis(); if (currentMillis - previousMillis >= interval) { previousMillis = currentMillis; if ( ( counter % 2) == 0) { CAN_TX_msg.type = DATA_FRAME; if (CAN_TX_msg.len == 0) CAN_TX_msg.type = REMOTE_FRAME; CAN_TX_msg.format = EXTENDED_FORMAT; CAN_TX_msg.id = 0x32F103; } else { CAN_TX_msg.type = DATA_FRAME; if (CAN_TX_msg.len == 0) CAN_TX_msg.type = REMOTE_FRAME; CAN_TX_msg.format = STANDARD_FORMAT; CAN_TX_msg.id = 0x103; } CANSend(&CAN_TX_msg); frameLength++; if (frameLength == 9) frameLength = 0; counter++; } if(CANMsgAvail()) { CANReceive(&CAN_RX_msg); if (CAN_RX_msg.format == EXTENDED_FORMAT) { Serial.print("Extended ID: 0x"); if (CAN_RX_msg.id < 0x10000000) Serial.print("0"); if (CAN_RX_msg.id < 0x1000000) Serial.print("00"); if (CAN_RX_msg.id < 0x100000) Serial.print("000"); if (CAN_RX_msg.id < 0x10000) Serial.print("0000"); Serial.print(CAN_RX_msg.id, HEX); } else { Serial.print("Standard ID: 0x"); if (CAN_RX_msg.id < 0x100) Serial.print("0"); if (CAN_RX_msg.id < 0x10) Serial.print("00"); Serial.print(CAN_RX_msg.id, HEX); Serial.print(" "); } Serial.print(" DLC: "); Serial.print(CAN_RX_msg.len); if (CAN_RX_msg.type == DATA_FRAME) { Serial.print(" Data: "); for(int i=0; i
