/******************************************************* Author: Manfred Langemann mailto: Manfred.Langemann ät t-online.de Begin of project: 04.01.2008 Latest version generated: 04.01.2008 Filename: Main.c Description: Main routine for testing TWI_Master_main.c ********************************************************/ #include #include #define F_CPU 16000000 #include "General.h" #include "RS232.h" #include "Delay.h" #include "TWI_Master.h" #include "lcd.h" /* ** This main programm demonstrates how to use the ** implemented TWI master functions. These are: ** TWIM_Init ** TWIM_ReadAck ** TWIM_ReadNack ** TWIM_Write ** TWIM_Stop ** ** For testing this program, use the program ** TWI_Slave_main.c in the slave uC and connect the ** two TWI lines properly (don't forget to also ** connect GND between Master and Slave!) ** ** Used uC for Master is ATMega32 */ int main (void) { uint8_t i; uint8_t j=0; uint8_t Data[8]; uint8_t SlaveAddress = 15; /* ** Clear any interrupt */ cli (); /* ** Wait 1 second for POR */ lcd_init(LCD_DISP_ON); lcd_clrscr(); Delay_ms (1000); /* ** Initiate RS232 */ RS232_Init (); lcd_puts ("Hello world...\n"); /* ** Initiate TWI Master Interface with bitrate of 100000 Hz */ if (!TWIM_Init (100000)) { lcd_puts ("Error in initiating TWI interface\n"); while (1); } /* ** Endless loop */ while (1) { /* ** Read byte(s) from the slave. ** It is implicitely assumed, that the slave will send ** 8 bytes */ lcd_clrscr(); if (!TWIM_Start (SlaveAddress, TWIM_READ)) { TWIM_Stop (); lcd_puts("Could not start TWI Bus for READ\n"); } else { for (i=0;i<7;i++) { Data[i] = TWIM_ReadAck (); } Data[7] = TWIM_ReadNack (); lcd_puts("Reading Byte "); TWIM_Stop (); Delay_ms (1000); } lcd_puts(Data[0]); lcd_puts(Data[1]); lcd_puts(Data[2]); lcd_puts(Data[3]); lcd_puts(Data[4]); lcd_puts(Data[5]); lcd_puts(Data[6]); lcd_puts(Data[7]); /* ** Write byte(s) to the slave. ** It is implicitely assumed, that the slave will ** accepts 8 bytes */ if (!TWIM_Start (SlaveAddress, TWIM_WRITE)) { TWIM_Stop (); lcd_puts("Could not start TWI Bus for WRITE\n"); } else { lcd_clrscr(); for (i=0;i<8;i++) { TWIM_Write (j++); lcd_puts("Byte sent:"); } TWIM_Stop (); Delay_ms (1000); } /* ** Do something else */ i++; } return 0; }
