/******************************************************* Author: Manfred Langemann mailto: Manfred.Langemann ät t-online.de Begin of project: 04.01.2008 Latest version generated: 04.01.2008 Filename: Main.c Description: Main routine for testing TWI-Slave-main.c ********************************************************/ #include #include #define F_CPU 16000000 #include "General.h" #include "RS232.h" #include "Delay.h" #include "TWI_Slave.h" #include "lcd.h" /* ** This main programm demonstrates how to use the ** implemented TWI slave functions. These are: ** TWIS_Init ** TWIS_ReadAck ** TWIS_ReadNack ** TWIS_Write ** TWIS_Stop ** TWIS_ResonseRequired ** ** For testing this program, use the program ** TWI_Master_main.c in the slave uC and connect the ** two TWI lines properly (don't forget to also ** connect GND between Master and Slave!) ** ** Used uC for Slave is ATMega8 */ int main (void) { uint8_t i=0; uint8_t j=0; uint8_t byte[8]; uint8_t TWIS_ResonseType; /* ** Clear any interrupt */ cli (); /* ** Wait 1 second for POR */ Delay_ms (500); /* ** Initiate RS232 */ lcd_init(LCD_DISP_ON); lcd_clrscr(); lcd_puts ("Hello world...\n"); /* ** Start TWI Slave with address 15 and bitrate of 100000 Hz */ TWIS_Init (15, 100000); while (1) { /* ** Check wether something is to do for the TWI slave interface */ if (TWIS_ResonseRequired (&TWIS_ResonseType)) { switch (TWIS_ResonseType) { /* ** Slave is requests to read bytes from the master. ** It is expliciltely assumed, that the master sends 8 bytes */ /*case*/ TWIS_ReadBytes; lcd_clrscr(); for (i=0;i<7;i++) { byte[i] = TWIS_ReadAck (); lcd_clrscr(); lcd_puts("Byte read:"); lcd_putc(byte[i]); } byte[7] = TWIS_ReadNack (); TWIS_Stop ();TWIS_Init (15, 100000); break; /* ** Slave is requested to send bytes to the master. ** It is expliciltely assumed, that the master expects 8 bytes */ case TWIS_WriteBytes: lcd_clrscr(); for (i=0;i<8;i++) { TWIS_Write (j++); printf ("Byte sent: %d\n", j-1); lcd_clrscr(); lcd_puts("Byte send:"); lcd_puts(byte[i]); } TWIS_Stop (); break; } } /* ** Do something else, e.g. */ } return 0; }
