target remote | m68k-elf-sprite pe://USBMultilink m52235evb m68k-elf-sprite: Opening P&E USBMultilink port 1 (USB1 : USB-ML-CF Rev C (PE6015045)) m68k-elf-sprite: Target reset 0x00000000 in InterruptVectorTable () set $pc=_startup Quit (expect signal SIGINT when the program is resumed) continue Note: automatically using hardware breakpoints for read-only addresses. target remote | m68k-elf-sprite pe://USBMultilink m52235evb m68k-elf-sprite: Opening P&E USBMultilink port 1 (USB1 : USB-ML-CF Rev C (PE6015045)) m68k-elf-sprite: Target reset 0x00000000 in InterruptVectorTable () set $pc=_startup continue Note: automatically using hardware breakpoints for read-only addresses. _startup () at Sources/crt0.s:54 54 move.w #0x2700,sr Quit (expect signal SIGINT when the program is resumed) target remote | m68k-elf-sprite pe://USBMultilink m52235evb m68k-elf-sprite: Opening P&E USBMultilink port 1 (USB1 : USB-ML-CF Rev C (PE6015045)) m68k-elf-sprite: Target reset 0x00000000 in InterruptVectorTable () load m68k-elf-sprite: Flash programming is unsupported in this release Error erasing flash with vFlashErase packet continue Note: automatically using hardware breakpoints for read-only addresses.
