/* -------------------------------------------------------------------------- TCF - 24-bit Timer/Counter for frequency generation -------------------------------------------------------------------------- */ /* 24-bit Timer/Counter for frequency generation */ typedef struct TCF_struct { register8_t CTRLA; /* Control A */ register8_t CTRLB; /* Control B */ register8_t CTRLC; /* Control C */ register8_t CTRLD; /* Control D */ register8_t EVCTRL; /* Event Control */ register8_t INTCTRL; /* Interrupt Control */ register8_t INTFLAGS; /* Interrupt Flags */ register8_t STATUS; /* Status */ register8_t reserved_1[5]; register8_t DBGCTRL; /* Debug Control */ register8_t reserved_2[2]; _DWORDREGISTER(CNT); /* Count */ _DWORDREGISTER(CMP); /* Compare */ register8_t reserved_3[8]; } TCF_t; /* Clock Select */ typedef enum TCF_CLKSEL_enum { TCF_CLKSEL_CLKPER_gc = (0x00<<3), /* Peripheral Clock */ TCF_CLKSEL_EVENT_gc = (0x01<<3), /* Event as clock source */ TCF_CLKSEL_OSCHF_gc = (0x02<<3), /* Internal High Frequency Oscillator */ TCF_CLKSEL_OSC32K_gc = (0x03<<3), /* Internal 32.768 kHz Oscillator */ TCF_CLKSEL_PLL_gc = (0x05<<3) /* PLL */ } TCF_CLKSEL_t; /* Command select */ typedef enum TCF_CMD_enum { TCF_CMD_NONE_gc = (0x00<<0), /* No command */ TCF_CMD_UPDATE_gc = (0x01<<0), /* Force update */ TCF_CMD_RESTART_gc = (0x02<<0) /* Force restart */ } TCF_CMD_t; /* Compare # Event Generation select */ typedef enum TCF_CMP0EV_enum { TCF_CMP0EV_PULSE_gc = (0x00<<6), /* Event is generated as pulse */ TCF_CMP0EV_WAVEFORM_gc = (0x01<<6) /* Waveform is used as event output */ } TCF_CMP0EV_t; /* Compare # Event Generation select */ typedef enum TCF_CMP1EV_enum { TCF_CMP1EV_PULSE_gc = (0x00<<7), /* Event is generated as pulse */ TCF_CMP1EV_WAVEFORM_gc = (0x01<<7) /* Waveform is used as event output */ } TCF_CMP1EV_t; /* Event Action A select */ typedef enum TCF_EVACTA_enum { TCF_EVACTA_RESTART_gc = (0x00<<1), /* Restart Counter */ TCF_EVACTA_BLANK_gc = (0x01<<1) /* Mask waveform output to '0' */ } TCF_EVACTA_t; /* Clock Prescaler select */ typedef enum TCF_PRESC_enum { TCF_PRESC_DIV1_gc = (0x00<<1), /* Runs directly on Clock Source */ TCF_PRESC_DIV2_gc = (0x01<<1), /* Divide clock source by 2 */ TCF_PRESC_DIV4_gc = (0x02<<1), /* Divide clock source by 4 */ TCF_PRESC_DIV8_gc = (0x03<<1), /* Divide clock source by 8 */ TCF_PRESC_DIV16_gc = (0x04<<1), /* Divide clock source by 16 */ TCF_PRESC_DIV32_gc = (0x05<<1), /* Divide clock source by 32 */ TCF_PRESC_DIV64_gc = (0x06<<1), /* Divide clock source by 64 */ TCF_PRESC_DIV128_gc = (0x07<<1) /* Divide clock source by 128 */ } TCF_PRESC_t; /* Waveform Generation Mode select */ typedef enum TCF_WGMODE_enum { TCF_WGMODE_FRQ_gc = (0x00<<0), /* Frequency */ TCF_WGMODE_NCOPF_gc = (0x01<<0), /* Numerically Controlled Oscillator Pulse-Frequency */ TCF_WGMODE_NCOFDC_gc = (0x02<<0), /* Numerically Controlled Oscillator Fixed Duty Cycle */ TCF_WGMODE_PWM8_gc = (0x07<<0) /* 8-bit PWM */ } TCF_WGMODE_t; /* Waveform Generation Pulse Length select */ typedef enum TCF_WGPULSE_enum { TCF_WGPULSE_CLK1_gc = (0x00<<4), /* High pulse duration is 1 clock period */ TCF_WGPULSE_CLK2_gc = (0x01<<4), /* High pulse duration is 2 clock period */ TCF_WGPULSE_CLK4_gc = (0x02<<4), /* High pulse duration is 4 clock period */ TCF_WGPULSE_CLK8_gc = (0x03<<4), /* High pulse duration is 8 clock period */ TCF_WGPULSE_CLK16_gc = (0x04<<4), /* High pulse duration is 16 clock period */ TCF_WGPULSE_CLK32_gc = (0x05<<4), /* High pulse duration is 32 clock period */ TCF_WGPULSE_CLK64_gc = (0x06<<4), /* High pulse duration is 64 clock period */ TCF_WGPULSE_CLK128_gc = (0x07<<4) /* High pulse duration is 128 clock period */ } TCF_WGPULSE_t; /* Waveform Output # Polarity select */ typedef enum TCF_WO0POL_enum { TCF_WO0POL_NORMAL_gc = (0x00<<2), /* Waveform output set on update and cleared on match */ TCF_WO0POL_INVERSE_gc = (0x01<<2) /* Waveform output cleared on update and set on match */ } TCF_WO0POL_t; /* Waveform Output # Polarity select */ typedef enum TCF_WO1POL_enum { TCF_WO1POL_NORMAL_gc = (0x00<<3), /* Waveform output set on update and cleared on match */ TCF_WO1POL_INVERSE_gc = (0x01<<3) /* Waveform output cleared on update and set on match */ } TCF_WO1POL_t;
