// THIS FILE IS A DEMO FOR IKEA OBERGRANSÄD KIT // AS INTERNET CLOCK // (C)2023 DR. ARMIN ZINK // parts inspired by // By /u/frumperino // goodwires.org // Use of 100 Hz refresh rate // Use of interrupt for button handling // Use PWM of P_EN for propper brightness control // By Stefan Mahrhold #include #include #include #define STASSID "JSHomeWLAN" #define STAPSK "LiET91z5JUw_pciF1vVt" #define P_EN D5 // ORANGE #define P_DI D6 // YELLO #define P_CLK D7 // BLUE #define P_CLA D8 // LILA #define P_KEY D4 // ROT // SET YOUR TIMEZONE HERE #define MY_NTP_SERVER "pool.ntp.org" // set the best fitting NTP server (pool) for your location #define MY_TZ "CET-1CEST,M3.5.0/02,M10.5.0/03" // https://github.com/nayarsystems/posix_tz_db/blob/master/zones.csv unsigned long usec; unsigned long mil1; unsigned long mil60; unsigned long mil3600; int dutyCycle = 90; // Duty Cycle of the P_EN PWM signal in %. int dutyCycleDec = 10; // Decrement by which the dutyCycle is changed. int dutyCycleMin = 10; // Minimum dutyCycle (brightest LEDs). int dutyCycleMax = 90; // Maximum dutyCycle (dimmest LEDs). unsigned long msecButton = 0; // Time since the button was pressed unsigned long debounceTime = 350; // Time until a new interrupt is accepted int refreshRate = 100; // Refresh Rate of the display in Hz. bool colon; uint8_t minute; uint8_t hour; time_t now; // this is the epoch (UNIX time epoch = seconds elapsed since 00:00:00 UTC on 1 January 1970) tm tm; // struct tm frome time.h #define TT 5 // delay for digital IO // -------------------------------------------------------------------------- // -------------------------------------------------------------------------- // -------------------------------------------------------------------------- // THIS IS SYSTEM FONT FOR 6x7 Bitmaps.with FAT NUMBERS ! // Jedes Zeichen besteht aus 6 Spalten mit 7 Pixeln. // Eine Spalte entspricht einem Byte. // Immer 6 Bytes ergeben ein Zeichen, um 90 Grad gedreht ist. static const uint8_t System6x7[] PROGMEM = { // Fixed width; // font data 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // (space) 0 0x00, 0x00, 0x5F, 0x00, 0x00, 0x00, // ! 1 0x00, 0x07, 0x00, 0x07, 0x00, 0x00, // " 2 0x14, 0x7F, 0x14, 0x7F, 0x14, 0x00, // # 3 0x24, 0x2A, 0x7F, 0x2A, 0x12, 0x00, // $ 4 0x23, 0x13, 0x08, 0x64, 0x62, 0x00, // % 5 0x36, 0x49, 0x55, 0x22, 0x50, 0x00, // & 6 0x00, 0x05, 0x03, 0x00, 0x00, 0x00, // ' 7 0x00, 0x1C, 0x22, 0x41, 0x00, 0x00, // ( 8 0x00, 0x41, 0x22, 0x1C, 0x00, 0x00, // ) 9 0x08, 0x2A, 0x1C, 0x2A, 0x08, 0x00, // * 10 0x08, 0x08, 0x3E, 0x08, 0x08, 0x00, // + 11 0x00, 0x50, 0x30, 0x00, 0x00, 0x00, // , 12 0x08, 0x08, 0x08, 0x08, 0x08, 0x00, // - 13 0x00, 0x60, 0x60, 0x00, 0x00, 0x00, // . 14 0x20, 0x10, 0x08, 0x04, 0x02, 0x00, // / 15 0b00111110, // 0 16 0b01111111, 0b01100011, 0b01100011, 0b01111111, 0b00111110, 0b00000000, // 1 0b00000010, 0b01111111, 0b01111111, 0b00000000, 0b00000000, 0b01100010, // 2 0b01110011, 0b01111011, 0b01101011, 0b01101111, 0b01100110, 0b00100010, // 3 0b01101011, 0b01101011, 0b01101011, 0b01111111, 0b00111110, 0b00000111, // 4 0b00001111, 0b00001100, 0b00001100, 0b01111111, 0b01111111, 0b01101111, // 5 0b01101111, 0b01101011, 0b01101011, 0b01111011, 0b00110011, 0b00111110, // 6 0b01111111, 0b01101011, 0b01101011, 0b01111011, 0b00110010, 0b00000011, // 7 0b00000011, 0b01111011, 0b01111111, 0b00000111, 0b00000011, 0b00110110, // 8 0b01111111, 0b01101011, 0b01101011, 0b01111111, 0b00110110, 0b00100110, // 9 0b01101111, 0b01101011, 0b01101011, 0b01111111, 0b00111110, 0x00, 0x36, 0x36, 0x00, 0x00, 0x00, // : 0x00, 0x56, 0x36, 0x00, 0x00, 0x00, // ; 0x00, 0x08, 0x14, 0x22, 0x41, 0x00, // < 0x14, 0x14, 0x14, 0x14, 0x14, 0x00, // = 0x41, 0x22, 0x14, 0x08, 0x00, 0x00, // > 0x02, 0x01, 0x51, 0x09, 0x06, 0x00, // ? 0x32, 0x49, 0x79, 0x41, 0x3E, 0x00, // @ 0x7E, 0x11, 0x11, 0x11, 0x7E, 0x00, // A 0x7F, 0x49, 0x49, 0x49, 0x36, 0x00, // B 0x3E, 0x41, 0x41, 0x41, 0x22, 0x00, // C 0x7F, 0x41, 0x41, 0x22, 0x1C, 0x00, // D 0x7F, 0x49, 0x49, 0x49, 0x41, 0x00, // E 0x7F, 0x09, 0x09, 0x01, 0x01, 0x00, // F 0x3E, 0x41, 0x41, 0x51, 0x32, 0x00, // G 0x7F, 0x08, 0x08, 0x08, 0x7F, 0x00, // H 0x00, 0x41, 0x7F, 0x41, 0x00, 0x00, // I 0x20, 0x40, 0x41, 0x3F, 0x01, 0x00, // J 0x7F, 0x08, 0x14, 0x22, 0x41, 0x00, // K 0x7F, 0x40, 0x40, 0x40, 0x40, 0x00, // L 0x7F, 0x02, 0x04, 0x02, 0x7F, 0x00, // M 0x7F, 0x04, 0x08, 0x10, 0x7F, 0x00, // N 0x3E, 0x41, 0x41, 0x41, 0x3E, 0x00, // O 0x7F, 0x09, 0x09, 0x09, 0x06, 0x00, // P 0x3E, 0x41, 0x51, 0x21, 0x5E, 0x00, // Q 0x7F, 0x09, 0x19, 0x29, 0x46, 0x00, // R 0x46, 0x49, 0x49, 0x49, 0x31, 0x00, // S 0x01, 0x01, 0x7F, 0x01, 0x01, 0x00, // T 0x3F, 0x40, 0x40, 0x40, 0x3F, 0x00, // U 0x1F, 0x20, 0x40, 0x20, 0x1F, 0x00, // V 0x7F, 0x20, 0x18, 0x20, 0x7F, 0x00, // W 0x63, 0x14, 0x08, 0x14, 0x63, 0x00, // X 0x03, 0x04, 0x78, 0x04, 0x03, 0x00, // Y 0x61, 0x51, 0x49, 0x45, 0x43, 0x00, // Z 0x00, 0x00, 0x7F, 0x41, 0x41, 0x00, // [ 0x02, 0x04, 0x08, 0x10, 0x20, 0x00, // "\" 0x41, 0x41, 0x7F, 0x00, 0x00, 0x00, // ] 0x04, 0x02, 0x01, 0x02, 0x04, 0x00, // ^ 0x40, 0x40, 0x40, 0x40, 0x40, 0x00, // _ 0x00, 0x01, 0x02, 0x04, 0x00, 0x00, // ` 0x20, 0x54, 0x54, 0x54, 0x78, 0x00, // a 0x7F, 0x48, 0x44, 0x44, 0x38, 0x00, // b 0x38, 0x44, 0x44, 0x44, 0x20, 0x00, // c 0x38, 0x44, 0x44, 0x48, 0x7F, 0x00, // d 0x38, 0x54, 0x54, 0x54, 0x18, 0x00, // e 0x08, 0x7E, 0x09, 0x01, 0x02, 0x00, // f 0x08, 0x14, 0x54, 0x54, 0x3C, 0x00, // g 0x7F, 0x08, 0x04, 0x04, 0x78, 0x00, // h 0x00, 0x44, 0x7D, 0x40, 0x00, 0x00, // i 0x20, 0x40, 0x44, 0x3D, 0x00, 0x00, // j 0x00, 0x7F, 0x10, 0x28, 0x44, 0x00, // k 0x00, 0x41, 0x7F, 0x40, 0x00, 0x00, // l 0x7C, 0x04, 0x18, 0x04, 0x78, 0x00, // m 0x7C, 0x08, 0x04, 0x04, 0x78, 0x00, // n 0x38, 0x44, 0x44, 0x44, 0x38, 0x00, // o 0x7C, 0x14, 0x14, 0x14, 0x08, 0x00, // p 0x08, 0x14, 0x14, 0x18, 0x7C, 0x00, // q 0x7C, 0x08, 0x04, 0x04, 0x08, 0x00, // r 0x48, 0x54, 0x54, 0x54, 0x20, 0x00, // s 0x04, 0x3F, 0x44, 0x40, 0x20, 0x00, // t 0x3C, 0x40, 0x40, 0x20, 0x7C, 0x00, // u 0x1C, 0x20, 0x40, 0x20, 0x1C, 0x00, // v 0x3C, 0x40, 0x30, 0x40, 0x3C, 0x00, // w 0x44, 0x28, 0x10, 0x28, 0x44, 0x00, // x 0x0C, 0x50, 0x50, 0x50, 0x3C, 0x00, // y 0x44, 0x64, 0x54, 0x4C, 0x44, 0x00, // z 0x00, 0x08, 0x36, 0x41, 0x00, 0x00, // { 0x00, 0x00, 0x7F, 0x00, 0x00, 0x00, // | 0x00, 0x41, 0x36, 0x08, 0x00, 0x00, // } 0x08, 0x08, 0x2A, 0x1C, 0x08, 0x00, // -> 0x08, 0x1C, 0x2A, 0x08, 0x08, 0x00 // <- }; // -------------------------------------------------------------------------- // -------------------------------------------------------------------------- // -------------------------------------------------------------------------- // THIS IS CLASS p_panel, for freqenz and OBERGRÄNSAD IKEA Panels int lut[16][16] = { {23, 22, 21, 20, 19, 18, 17, 16, 7, 6, 5, 4, 3, 2, 1, 0}, {24, 25, 26, 27, 28, 29, 30, 31, 8, 9, 10, 11, 12, 13, 14, 15}, {39, 38, 37, 36, 35, 34, 33, 32, 55, 54, 53, 52, 51, 50, 49, 48}, {40, 41, 42, 43, 44, 45, 46, 47, 56, 57, 58, 59, 60, 61, 62, 63}, {87, 86, 85, 84, 83, 82, 81, 80, 71, 70, 69, 68, 67, 66, 65, 64}, {88, 89, 90, 91, 92, 93, 94, 95, 72, 73, 74, 75, 76, 77, 78, 79}, {103, 102, 101, 100, 99, 98, 97, 96, 119, 118, 117, 116, 115, 114, 113, 112}, {104, 105, 106, 107, 108, 109, 110, 111, 120, 121, 122, 123, 124, 125, 126, 127}, {151, 150, 149, 148, 147, 146, 145, 144, 135, 134, 133, 132, 131, 130, 129, 128}, {152, 153, 154, 155, 156, 157, 158, 159, 136, 137, 138, 139, 140, 141, 142, 143}, {167, 166, 165, 164, 163, 162, 161, 160, 183, 182, 181, 180, 179, 178, 177, 176}, {168, 169, 170, 171, 172, 173, 174, 175, 184, 185, 186, 187, 188, 189, 190, 191}, {215, 214, 213, 212, 211, 210, 209, 208, 199, 198, 197, 196, 195, 194, 193, 192}, {216, 217, 218, 219, 220, 221, 222, 223, 200, 201, 202, 203, 204, 205, 206, 207}, {231, 230, 229, 228, 227, 226, 225, 224, 247, 246, 245, 244, 243, 242, 241, 240}, {232, 233, 234, 235, 236, 237, 238, 239, 248, 249, 250, 251, 252, 253, 254, 255}}; unsigned short _pLatch; unsigned short _pClock; unsigned short _pData; uint8_t p_buf[16*16]; void p_init(int p_latch, int p_clock, int p_data) //, int bitDepth, int numPanels) { _pLatch = p_latch; _pClock = p_clock; _pData = p_data; pinMode(_pLatch, OUTPUT); pinMode(_pClock, OUTPUT); pinMode(_pData, OUTPUT); } // Clear the Panel Buffer void p_clear() { for (int i = 0; i < 256; i++) { p_buf[i] = 0; } } // SCAN DISPLAY, output Bytes to Serial void p_scan() { unsigned long EN_start = micros(); digitalWrite(P_EN, HIGH); // war mal digitalWrite(P_EN, 255); uint8_t w = 0; uint8_t w2 = 0; for (int i = 0; i < 256 ; i++) { digitalWrite(_pData, 1 & p_buf[w++]); // make count faster digitalWrite(_pClock, HIGH); //delayMicroseconds(TT); digitalWrite(_pClock, LOW); w2++; if(w2 > 15) { w2 = 0; digitalWrite(_pLatch, HIGH); //delayMicroseconds(TT); digitalWrite(_pLatch, LOW); } } unsigned long EN_end = micros(); unsigned long EN_diff = EN_end - EN_start; unsigned long EN_high = (unsigned long)(1.0 / refreshRate * 1000000 * dutyCycle / 100); unsigned long EN_delay = EN_high - EN_diff; /* Serial.print("EN_start: "); Serial.println(EN_start); Serial.print("EN_end: "); Serial.println(EN_end); Serial.print("EN_diff: "); Serial.println(EN_diff); Serial.print("EN_high: "); Serial.println(EN_high); Serial.print("EN_delay: "); Serial.println(EN_delay); */ while (EN_end + EN_delay > micros()) {} // Wait until P_EN high state corresponds tu dutyCycle digitalWrite(P_EN, LOW); // war mal digitalWrite(P_EN,0); } // SET a Pixel in Panel Buffer, calculate position from LUT void p_drawPixel(int8_t x, int8_t y, uint8_t color) { p_buf[lut[y][x]] = color; // x und y müssen wahrscheinlich aufgrund der Speicherung der Zeichen vertauscht sein. } // Draw a Char Glyph into Panel Buffer void p_printChar(uint8_t xs, uint8_t ys, char ch) { uint8_t d; for (uint8_t x = 0; x < 6; x++) { // get Data from Memory d = pgm_read_byte_near(System6x7 + (ch - 32) * 6 + x); // System6x7 ist wahrscheinlich die Startadresse des Zeichensatz-Arrays im Programmspeicher. // Um die Adresse des gesuchten Bytes zu finden muss man die tatsächliche Position des Zeichens // im verwendeten Zeichensatz berechnen mit (ch-32). (ch-32)*6 ergibt dann die Position des // ersten Bytes (1. Spalte) des Zeichens im Zeichensatz. Je nachdem in welcher Spalte ich mich // gerade befinde (0-5) bekomme ich das Byte also mit der Startadresse System6x7+(ch-32)*6+x. // check which pixel to draw if ((d&1) == 1) p_drawPixel(x+xs, 0+ys, 0xff); else p_drawPixel(x+xs, 0+ys, 0x00); if ((d&2) == 2) p_drawPixel(x+xs, 1+ys, 0xff); else p_drawPixel(x+xs, 1+ys, 0x00); if ((d&4) == 4) p_drawPixel(x+xs, 2+ys, 0xff); else p_drawPixel(x+xs, 2+ys, 0x00); if ((d&8) == 8) p_drawPixel(x+xs, 3+ys, 0xff); else p_drawPixel(x+xs, 3+ys, 0x00); if ((d&16) == 16) p_drawPixel(x+xs, 4+ys, 0xff); else p_drawPixel(x+xs, 4+ys, 0x00); if ((d&32) == 32) p_drawPixel(x+xs, 5+ys, 0xff); else p_drawPixel(x+xs, 5+ys, 0x00); if ((d&64) == 64) p_drawPixel(x+xs, 6+ys, 0xff); else p_drawPixel(x+xs, 6+ys, 0x00); // d&1, d&2 usw. prüft ob das 0., 1., 2. usw. Bit in dem betrachteten Byte gesetzt ist. // Falls ja, wird das Pixel and der Position des Zeichen xs+x:ys+0 +1 usw. eingeschaltet (0xff) // je nach dem, in welcher Spalte wir gerade sind (+x) und in welcher Zeile +0 - +6. // Ist das Bit nicht gesetzt, wird das Pixel ausgeschaltet (0x00). } } // -------------------------------------------------------------------------- // ------------------------ NTP --------------------------------------------- // -------------------------------------------------------------------------- const char* getTimeString(void) { static char acTimeString[32]; time_t now = time(nullptr); ctime_r(&now, acTimeString); size_t stLength; while (((stLength = strlen(acTimeString))) && ('\n' == acTimeString[stLength - 1])) { acTimeString[stLength - 1] = 0; // Remove trailing line break... } return acTimeString; } void set_clock(void) { //configTime(((MY_TIMEZ) * 3600), (DST_OFFSET * 3600), "pool.ntp.org", "time.nist.gov", "time.windows.com"); configTime(MY_TZ, MY_NTP_SERVER); // --> Here is the IMPORTANT ONE LINER needed in your sketch! Serial.print("Waiting for NTP time sync: "); //time_t now = time(nullptr); // Secs since 01.01.1970 (when uninitialized starts with (8 * 3600 = 28800) now = time(nullptr); // Secs since 01.01.1970 (when uninitialized starts with (8 * 3600 = 28800) while (now < 8 * 3600 * 2) { // Wait for realistic value. // Warum muss man das machen? // Es scheint sonst vorzukommen, dass die Zeit auf 01:00 Uhr steht. // Das kommt zwar irgendwie nicht hin (müsste 08:00 Uhr), aber irgendwie ist es so. Serial.print("."); now = time(nullptr); } Serial.println(""); Serial.printf("Current time: %s\n", getTimeString()); } void set_clock_from_tm() { time(&now); // read the current time localtime_r(&now, &tm); // update the structure tm with the current time // update time from struct minute = tm.tm_min; hour = tm.tm_hour; } void IRAM_ATTR ButtonISR() { if((millis() - msecButton) > debounceTime) { if (dutyCycle > dutyCycleMin) { dutyCycle = dutyCycle - dutyCycleDec; } else { dutyCycle = dutyCycleMax; } } msecButton = millis(); } // -------------------------------------------------------------------------- // ----------------------SETUP ---------------------------------------------- // -------------------------------------------------------------------------- void setup() { // vars_init(); pinMode(P_EN, OUTPUT); pinMode(P_CLK, OUTPUT); pinMode(P_CLA, OUTPUT); pinMode(P_DI, OUTPUT); p_init(P_CLA, P_CLK, P_DI); Serial.begin(74880); pinMode(P_KEY, INPUT_PULLUP); p_clear(); p_scan(); colon = true; // start network WiFi.mode(WIFI_STA); WiFi.begin(STASSID, STAPSK); while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); } //if you get here you have connected to the WiFi Serial.println(" Wifi connected!"); // Sync clock set_clock(); set_clock_from_tm(); // Attaching interrupt for P_KEY attachInterrupt(P_KEY, ButtonISR, FALLING); } // -------------------------------------------------------------------------- // ---------------------- LOOP ---------------------------------------------- // -------------------------------------------------------------------------- void loop() { // Alle 10 msec (100x pro Sekunde = 100 Hz) if (micros() >= usec + (unsigned long)(1.0 / refreshRate * 1000000)) { usec = micros(); // PRINT THE TIME p_printChar(2,0,(hour / 10) + 48); // Die + 48 beziehen sich auf den vollständigen ASCII-Zeichensatz p_printChar(9,0,(hour % 10) + 48); // Später in p_printChar() werden wieder 32 abgezogen, damit man auf die p_printChar(2,9,(minute / 10) + 48); // tatsächliche Position 16 der 0 kommt. p_printChar(9,9,(minute % 10) + 48); if (millis() >= mil1 + 1000) { mil1 = millis(); if (!colon) { p_drawPixel(7, 7, 0xff); p_drawPixel(8, 7, 0xff); p_drawPixel(7, 8, 0xff); p_drawPixel(8, 8, 0xff); colon = true; } else { p_drawPixel(7, 7, 0x00); p_drawPixel(8, 7, 0x00); p_drawPixel(7, 8, 0x00); p_drawPixel(8, 8, 0x00); colon = false; } } p_scan(); // refreshes display } // Alle 60 sec (1x pro Minute) if (millis() >= mil60 + 60000) { mil60 = millis(); set_clock_from_tm(); } // jede Stunde (1x pro Stunde) if (millis() >= mil3600 + 3600000) { mil3600 = millis(); set_clock(); } }
