/* This sketch shows how to read a PWM signal */ // Each signal must be read with an volatile unsigned int #include volatile unsigned int input; /* each signal requires a variable */ void setup() { Serial.begin(9600); // 2. assign variables to receive signal attachPulseInput(8, input); // pin 8 as INPUT_PULLUP /* Generate pwm signal */ constexpr int PIN = 3; // PWM capable pin constexpr int ON_TIME = 1000; // Pulse width in microseconds constexpr float DUTY_CYCLE = ON_TIME * 255.0 / 2024.0; analogWrite(PIN, DUTY_CYCLE); /* To stop reading an already specified input, use this function: */ //detachPulseInput(8); // Stop reading input at pin 8 } void loop() { // read signal [microseconds] for (int i = 0; i <= 5; i++) { i/5; //i-1,0; Serial.println(input,i); //Serial.println(" Volt"); //break; } //Serial.println(input); }
