/* https://github.com/pra22/GC-20 SBM-20 based Geiger Counter Author: Prabhat Email: pra22@pitt.edu Sketch for ESP8266 that counts clicks from the Geiger tube, calculates the counts per minute, and displays information on a TFT touchscreen. Attribution-ShareAlike 4.0 International (CC BY-SA 4.0) */ #include #include #include #include #include #include #include #include "SPI.h" #include "Adafruit_GFX.h" #include #include #include "Adafruit_ILI9341.h" #include #define CS_PIN D2 XPT2046_Touchscreen ts(CS_PIN); #define TS_MINX 250 #define TS_MINY 200 // calibration points for touchscreen #define TS_MAXX 3800 #define TS_MAXY 3750 #define TFT_DC D4 #define TFT_CS D8 #define BLACK 0x0000 #define BLUE 0x001F #define RED 0xF800 #define GREEN 0x07E0 #define CYAN 0x07FF #define MAGENTA 0xF81F #define YELLOW 0xFFE0 #define WHITE 0xFFFF #define DOSEBACKGROUND 0x0455 // WiFi variables unsigned long currentUploadTime; unsigned long previousUploadTime; int passwordLength; int SSIDLength; int channelIDLength; int writeAPILength; char ssid[20]; char password[20]; char channelID[20]; // = "864288"; char channelAPIkey[20]; // = "37SAHQPEQ7FOBC20"; char server[] = "api.thingspeak.com"; int attempts; // number of connection attempts when device starts up in monitoring mode WiFiClient client; Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC); const int interruptPin = 5; long count[61]; long fastCount[6]; // arrays to store running counts long slowCount[181]; int i = 0; // array elements int j = 0; int k = 0; int page = 0; long currentMillis; long previousMillis; unsigned long currentMicros; unsigned long previousMicros; unsigned long averageCount; unsigned long currentCount; // incremented by interrupt unsigned long previousCount; // to activate buzzer and LED unsigned long cumulativeCount; float doseRate; float totalDose; char dose[5]; int doseLevel; // determines home screen warning signs int previousDoseLevel; bool ledSwitch = 1; bool buzzerSwitch = 1; bool wasTouched; int integrationMode = 0; // 0 = medium, 1 = fast, 2 == slow; bool doseUnits = 0; // 0 = Sievert, 1 = Rem unsigned int alarmThreshold = 5; unsigned int conversionFactor = 175; int x, y; // touch points // Battery indicator variables int batteryInput; int batteryPercent; int batteryMapped = 212; // pixel location of battery icon int batteryUpdateCounter = 29; // EEPROM variables const int saveUnits = 0; const int saveAlertThreshold = 1; // Addresses for storing settings data in the EEPROM const int saveCalibration = 2; const int saveDeviceMode = 3; const int saveLoggingMode = 4; const int saveSSIDLen = 5; const int savePWLen = 6; const int saveIDLen = 7; const int saveAPILen = 8; // Data Logging variables int addr = 200; // starting address for data logging char jsonBuffer[14000] = "["; char data[14500] = "{\"write_api_key\":\""; unsigned long currentLogTime; unsigned long previousLogTime; // Timed Count Variables: int interval = 5; unsigned long intervalMillis; unsigned long startMillis; unsigned long elapsedTime; int progress; float cpm; bool completed = 0; int intervalSize; // stores how many digits are in the interval // Logging variables bool isLogging; bool deviceMode; // interrupt routine declaration void ICACHE_RAM_ATTR isr(); unsigned int previousIntMicros; // timers to limit count increment rate in the ISR const unsigned char gammaBitmap [] PROGMEM = { 0x30, 0x00, 0x78, 0x70, 0xe8, 0xe0, 0xc4, 0xe0, 0x84, 0xc0, 0x05, 0xc0, 0x05, 0x80, 0x07, 0x80, 0x03, 0x00, 0x07, 0x00, 0x0e, 0x00, 0x0e, 0x00, 0x1e, 0x00, 0x1e, 0x00, 0x1e, 0x00, 0x3e, 0x00, 0x1c, 0x00, 0x00, 0x00 }; const unsigned char betaBitmap [] PROGMEM = { 0x00, 0xc0, 0x00, 0x03, 0xf0, 0x00, 0x07, 0x18, 0x00, 0x06, 0x18, 0x00, 0x0e, 0x18, 0x00, 0x0e, 0x18, 0x00, 0x0e, 0xf8, 0x00, 0x0e, 0x1c, 0x00, 0x0e, 0x0c, 0x00, 0x0e, 0x0c, 0x00, 0x0e, 0x0c, 0x00, 0x0e, 0x0c, 0x00, 0x0f, 0x1c, 0x00, 0x0f, 0xf8, 0x00, 0x0e, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00 }; const unsigned char wifiBitmap [] PROGMEM = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xf0, 0x00, 0x0f, 0xfe, 0x00, 0x3f, 0xff, 0x80, 0x78, 0x03, 0xc0, 0xe0, 0x00, 0xe0, 0x47, 0xfc, 0x40, 0x0f, 0xfe, 0x00, 0x1c, 0x07, 0x00, 0x08, 0x02, 0x00, 0x01, 0xf0, 0x00, 0x03, 0xf8, 0x00, 0x01, 0x10, 0x00, 0x00, 0x40, 0x00, 0x00, 0xe0, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }; const unsigned char settingsBitmap[] PROGMEM = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x7f, 0xe0, 0x38, 0x00, 0x00, 0x00, 0x03, 0xf0, 0x7f, 0xe0, 0xfc, 0x00, 0x00, 0x00, 0x07, 0xf9, 0xff, 0xf9, 0xfe, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0x07, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x00, 0x07, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x00, 0x03, 0xff, 0xff, 0xff, 0xfc, 0x00, 0x00, 0x00, 0x01, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x00, 0x00, 0x01, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x00, 0x00, 0x03, 0xff, 0xf0, 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x03, 0xff, 0xc0, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x1f, 0xff, 0x80, 0x1f, 0xff, 0x80, 0x00, 0x00, 0xff, 0xff, 0x00, 0x0f, 0xff, 0xf0, 0x00, 0x01, 0xff, 0xff, 0x00, 0x07, 0xff, 0xf8, 0x00, 0x01, 0xff, 0xfe, 0x00, 0x07, 0xff, 0xf8, 0x00, 0x01, 0xff, 0xfe, 0x00, 0x07, 0xff, 0xf8, 0x00, 0x01, 0xff, 0xfe, 0x00, 0x07, 0xff, 0xf8, 0x00, 0x01, 0xff, 0xfe, 0x00, 0x07, 0xff, 0xf8, 0x00, 0x01, 0xff, 0xfe, 0x00, 0x07, 0xff, 0xf8, 0x00, 0x00, 0xff, 0xff, 0x00, 0x0f, 0xff, 0xf0, 0x00, 0x00, 0x1f, 0xff, 0x80, 0x1f, 0xff, 0x80, 0x00, 0x00, 0x03, 0xff, 0xc0, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x03, 0xff, 0xe0, 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x01, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x00, 0x00, 0x01, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x00, 0x00, 0x03, 0xff, 0xff, 0xff, 0xfc, 0x00, 0x00, 0x00, 0x07, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x00, 0x07, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0x07, 0xf9, 0xff, 0xf9, 0xfe, 0x00, 0x00, 0x00, 0x03, 0xf0, 0x7f, 0xe0, 0xfc, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x7f, 0xe0, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}; const unsigned char buzzerOnBitmap[] PROGMEM = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x0c, 0x00, 0x00, 0x00, 0x07, 0x80, 0x0e, 0x00, 0x00, 0x00, 0x0f, 0x80, 0x0f, 0x00, 0x00, 0x00, 0x1f, 0x80, 0x07, 0x00, 0x00, 0x00, 0x3f, 0x80, 0xc7, 0x80, 0x00, 0x00, 0xff, 0x80, 0xe3, 0x80, 0x00, 0x01, 0xff, 0x80, 0xf3, 0xc0, 0x00, 0x03, 0xff, 0x80, 0x71, 0xc0, 0x00, 0x07, 0xff, 0x8c, 0x79, 0xc0, 0x3f, 0xff, 0xff, 0x9e, 0x38, 0xe0, 0x3f, 0xff, 0xff, 0x8e, 0x38, 0xe0, 0x3f, 0xff, 0xff, 0x8e, 0x3c, 0xe0, 0x3f, 0xff, 0xff, 0x87, 0x1c, 0xe0, 0x3f, 0xff, 0xff, 0x87, 0x1c, 0x60, 0x3f, 0xff, 0xff, 0x87, 0x1c, 0x70, 0x3f, 0xff, 0xff, 0x87, 0x1c, 0x70, 0x3f, 0xff, 0xff, 0x87, 0x1c, 0x70, 0x3f, 0xff, 0xff, 0x87, 0x1c, 0x70, 0x3f, 0xff, 0xff, 0x87, 0x1c, 0x70, 0x3f, 0xff, 0xff, 0x87, 0x1c, 0xe0, 0x3f, 0xff, 0xff, 0x8e, 0x3c, 0xe0, 0x3f, 0xff, 0xff, 0x8e, 0x38, 0xe0, 0x3f, 0xff, 0xff, 0x9e, 0x38, 0xe0, 0x00, 0x07, 0xff, 0x8c, 0x79, 0xc0, 0x00, 0x03, 0xff, 0x80, 0x71, 0xc0, 0x00, 0x00, 0xff, 0x80, 0xf1, 0xc0, 0x00, 0x00, 0x7f, 0x80, 0xe3, 0x80, 0x00, 0x00, 0x3f, 0x80, 0xc7, 0x80, 0x00, 0x00, 0x1f, 0x80, 0x07, 0x00, 0x00, 0x00, 0x0f, 0x80, 0x0f, 0x00, 0x00, 0x00, 0x07, 0x80, 0x0e, 0x00, 0x00, 0x00, 0x03, 0x80, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}; const unsigned char buzzerOffBitmap[] PROGMEM = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x0f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x3f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x80, 0x00, 0x00, 0x00, 0x00, 0xff, 0x80, 0x00, 0x00, 0x00, 0x03, 0xff, 0x80, 0x00, 0x00, 0x00, 0x07, 0xff, 0x80, 0x00, 0x00, 0x00, 0x0f, 0xff, 0x80, 0x00, 0x00, 0x0f, 0xff, 0xff, 0x80, 0x00, 0x00, 0x1f, 0xff, 0xff, 0x80, 0x00, 0x00, 0x3f, 0xff, 0xff, 0x8f, 0x00, 0x78, 0x7f, 0xff, 0xff, 0x8f, 0x80, 0xf8, 0x7f, 0xff, 0xff, 0x8f, 0xc1, 0xf8, 0x7f, 0xff, 0xff, 0x87, 0xe3, 0xf0, 0x7f, 0xff, 0xff, 0x83, 0xf7, 0xe0, 0x7f, 0xff, 0xff, 0x81, 0xff, 0xc0, 0x7f, 0xff, 0xff, 0x80, 0xff, 0x80, 0x7f, 0xff, 0xff, 0x80, 0x7f, 0x00, 0x7f, 0xff, 0xff, 0x80, 0x7f, 0x00, 0x7f, 0xff, 0xff, 0x80, 0xff, 0x80, 0x7f, 0xff, 0xff, 0x81, 0xff, 0xc0, 0x7f, 0xff, 0xff, 0x83, 0xf7, 0xe0, 0x7f, 0xff, 0xff, 0x87, 0xe3, 0xf0, 0x7f, 0xff, 0xff, 0x8f, 0xc1, 0xf0, 0x7f, 0xff, 0xff, 0x8f, 0x80, 0xf8, 0x3f, 0xff, 0xff, 0x8f, 0x00, 0x70, 0x3f, 0xff, 0xff, 0x84, 0x00, 0x20, 0x1f, 0xff, 0xff, 0x80, 0x00, 0x00, 0x0f, 0xff, 0xff, 0x80, 0x00, 0x00, 0x00, 0x07, 0xff, 0x80, 0x00, 0x00, 0x00, 0x03, 0xff, 0x80, 0x00, 0x00, 0x00, 0x01, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x0f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}; const unsigned char ledOnBitmap[] PROGMEM = { 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x18, 0x07, 0x00, 0xc0, 0x00, 0x00, 0x1c, 0x07, 0x01, 0xc0, 0x00, 0x00, 0x1e, 0x07, 0x03, 0xc0, 0x00, 0x00, 0x0e, 0x07, 0x03, 0x80, 0x00, 0x00, 0x0f, 0x00, 0x07, 0x80, 0x00, 0x00, 0x07, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x1f, 0xc0, 0x03, 0xc0, 0x0f, 0x80, 0x7f, 0xf0, 0x0f, 0x80, 0x07, 0xc1, 0xff, 0xfc, 0x1f, 0x00, 0x03, 0xc3, 0xe0, 0x3e, 0x1e, 0x00, 0x00, 0x07, 0xc0, 0x0f, 0x00, 0x00, 0x00, 0x07, 0x00, 0x07, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x07, 0x80, 0x00, 0x00, 0x0e, 0x00, 0x03, 0x80, 0x00, 0x00, 0x0e, 0x00, 0x03, 0x80, 0x00, 0x00, 0x1c, 0x00, 0x01, 0xc0, 0x00, 0x7f, 0x1c, 0x00, 0x01, 0xc3, 0xf0, 0x7f, 0x1c, 0x00, 0x01, 0xc7, 0xf0, 0x3c, 0x0e, 0x00, 0x03, 0x81, 0xe0, 0x00, 0x0e, 0x00, 0x03, 0x80, 0x00, 0x00, 0x0e, 0x00, 0x03, 0x80, 0x00, 0x00, 0x0f, 0x00, 0x07, 0x80, 0x00, 0x00, 0x07, 0x00, 0x07, 0x00, 0x00, 0x00, 0x07, 0x80, 0x0f, 0x00, 0x00, 0x01, 0xc3, 0xc0, 0x1e, 0x1c, 0x00, 0x07, 0xc1, 0xc0, 0x1c, 0x1f, 0x00, 0x0f, 0x81, 0xe0, 0x3c, 0x0f, 0x80, 0x1e, 0x00, 0xe0, 0x38, 0x03, 0xc0, 0x0c, 0x00, 0xe0, 0x38, 0x01, 0x80, 0x00, 0x00, 0xf0, 0x78, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00}; const unsigned char ledOffBitmap[] PROGMEM = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x01, 0xff, 0xfc, 0x00, 0x00, 0x00, 0x03, 0xe0, 0x3e, 0x00, 0x00, 0x00, 0x07, 0xc0, 0x0f, 0x00, 0x00, 0x00, 0x07, 0x00, 0x07, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x07, 0x80, 0x00, 0x00, 0x0e, 0x00, 0x03, 0x80, 0x00, 0x00, 0x0e, 0x00, 0x03, 0x80, 0x00, 0x00, 0x1c, 0x00, 0x01, 0xc0, 0x00, 0x00, 0x1c, 0x00, 0x01, 0xc0, 0x00, 0x00, 0x1c, 0x00, 0x01, 0xc0, 0x00, 0x00, 0x0e, 0x00, 0x03, 0x80, 0x00, 0x00, 0x0e, 0x00, 0x03, 0x80, 0x00, 0x00, 0x0e, 0x00, 0x03, 0x80, 0x00, 0x00, 0x0f, 0x00, 0x07, 0x80, 0x00, 0x00, 0x07, 0x00, 0x07, 0x00, 0x00, 0x00, 0x07, 0x80, 0x0f, 0x00, 0x00, 0x00, 0x03, 0xc0, 0x1e, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x1c, 0x00, 0x00, 0x00, 0x01, 0xe0, 0x3c, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x38, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x38, 0x00, 0x00, 0x00, 0x00, 0xf0, 0x78, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00}; const unsigned char backBitmap [] PROGMEM = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0x01, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }; void drawHomePage(); // page 0 void drawSettingsPage(); // page 1 void drawUnitsPage(); // page 2 void drawAlertPage(); // page 3 void drawCalibrationPage(); // page 4 void drawWifiPage(); // page 5 void drawTimedCountPage(); // page 6 void drawTimedCountRunningPage(int duration, int size); // page 7 void drawDeviceModePage(); // page 8 void drawFrame(); void drawBackButton(); void drawCancelButton(); void drawCloseButton(); void drawBlankDialogueBox(); long EEPROMReadlong(long address); void EEPROMWritelong(int address, long value); // logging functions void createJsonFile(); void clearLogs(); void setup() { Serial.begin(38400); ts.begin(); ts.setRotation(2); tft.begin(); tft.setRotation(2); tft.fillScreen(ILI9341_BLACK); pinMode(D0, OUTPUT); // buzzer switch pinMode(D3, OUTPUT); // LED digitalWrite(D3, LOW); digitalWrite(D0, LOW); EEPROM.begin(4096); // initialize emulated EEPROM sector with 4 kb doseUnits = EEPROM.read(saveUnits); alarmThreshold = EEPROM.read(saveAlertThreshold); conversionFactor = EEPROM.read(saveCalibration); deviceMode = EEPROM.read(saveDeviceMode); isLogging = EEPROM.read(saveLoggingMode); addr = EEPROMReadlong(96); SSIDLength = EEPROM.read(saveSSIDLen); passwordLength = EEPROM.read(savePWLen); channelIDLength = EEPROM.read(saveIDLen); writeAPILength = EEPROM.read(saveAPILen); for (int i = 10; i < 10 + SSIDLength; i++) { ssid[i - 10] = EEPROM.read(i); } Serial.println(ssid); for (int j = 30; j < 30 + passwordLength; j++) { password[j - 30] = EEPROM.read(j); } Serial.println(password); for (int k = 50; k < 50 + channelIDLength; k++) { channelID[k - 50] = EEPROM.read(k); } Serial.println(channelID); for (int l = 70; l < 70 + writeAPILength; l++) { channelAPIkey[l - 70] = EEPROM.read(l); } Serial.println(channelAPIkey); attachInterrupt(interruptPin, isr, FALLING); drawHomePage(); if (!deviceMode) { WiFi.mode( WIFI_OFF ); // turn off wifi WiFi.forceSleepBegin(); delay(1); } else { WiFi.mode(WIFI_STA); WiFi.begin(ssid, password); drawBlankDialogueBox(); tft.setTextSize(1); tft.setFont(&FreeSans9pt7b); tft.setTextColor(ILI9341_WHITE); tft.setCursor(38, 140); tft.println("Connecting to WiFi.."); while ((WiFi.status() != WL_CONNECTED) && (attempts < 300)) { delay(100); attempts ++; } if (attempts >= 300) { deviceMode = 0; tft.setCursor(45, 200); tft.println("Failed to connect."); delay(1000); } else { tft.setCursor(68, 200); tft.println("Connected!"); delay(1000); } drawHomePage(); } } void loop() { if (page == 0) // homepage { currentMillis = millis(); if (currentMillis - previousMillis >= 1000) { previousMillis = currentMillis; batteryUpdateCounter ++; if (batteryUpdateCounter == 30){ // update battery level every 30 seconds. Prevents random fluctations of battery level. batteryInput = analogRead(A0); batteryInput = constrain(batteryInput, 590, 800); batteryPercent = map(batteryInput, 590, 800, 0, 100); batteryMapped = map(batteryPercent, 100, 0, 212, 233); tft.fillRect(212, 6, 22, 10, ILI9341_BLACK); if (batteryPercent < 10) { tft.fillRect(batteryMapped, 6, (234 - batteryMapped), 10, ILI9341_RED); } else { tft.fillRect(batteryMapped, 6, (234 - batteryMapped), 10, ILI9341_GREEN); // draws battery icon } batteryUpdateCounter = 0; Serial.println(batteryInput); Serial.println(batteryPercent); } count[i] = currentCount; i++; fastCount[j] = currentCount; // keep concurrent arrays of counts. Use only one depending on user choice j++; slowCount[k] = currentCount; k++; if (i == 61) { i = 0; } if (j == 6) { j = 0; } if (k == 181) { k = 0; } if (integrationMode == 2) { averageCount = (currentCount - slowCount[k]) / 3; } if (integrationMode == 1) { averageCount = (currentCount - fastCount[j]) * 12; } else if (integrationMode == 0) { averageCount = currentCount - count[i]; // count[i] stores the value from 60 seconds ago } averageCount = ((averageCount) / (1 - 0.00000333 * float(averageCount))); // accounts for dead time of the geiger tube. relevant at high count rates if (doseUnits == 0) { doseRate = averageCount / float(conversionFactor); totalDose = cumulativeCount / (60 * float(conversionFactor)); } else if (doseUnits == 1) { doseRate = averageCount / float(conversionFactor * 10.0); totalDose = cumulativeCount / (60 * float(conversionFactor * 10.0)); // 1 mRem == 10 uSv } if (averageCount < conversionFactor/2) // 0.5 uSv/hr doseLevel = 0; // determines alert level displayed on homescreen else if (averageCount < alarmThreshold * conversionFactor) doseLevel = 1; else doseLevel = 2; if (doseRate < 10.0) { dtostrf(doseRate, 4, 2, dose); // display two digits after the decimal point if value is less than 10 } else if ((doseRate >= 10) && (doseRate < 100)) { dtostrf(doseRate, 4, 1, dose); // display one digit after decimal point when dose is greater than 10 } else if ((doseRate >= 100)) { dtostrf(doseRate, 4, 0, dose); // whole numbers only when dose is higher than 100 } else { dtostrf(doseRate, 4, 0, dose); // covers the rare edge case where the dose rate is sometimes errorenously calculated to be negative } tft.setFont(); tft.setCursor(44, 52); tft.setTextSize(5); tft.setTextColor(ILI9341_WHITE, DOSEBACKGROUND); tft.println(dose); // display effective dose rate tft.setTextSize(1); tft.setFont(); tft.setCursor(73, 122); tft.setTextColor(ILI9341_WHITE, ILI9341_BLACK); tft.setTextSize(3); tft.println(averageCount); // Display CPM if (averageCount < 10) { tft.fillRect(90, 120, 144, 25, ILI9341_BLACK); // erase numbers that may have been left from previous high readings } else if (averageCount < 100) { tft.fillRect(107, 120, 127, 25, ILI9341_BLACK); } else if (averageCount < 1000) { tft.fillRect(124, 120, 110, 25, ILI9341_BLACK); } else if (averageCount < 10000) { tft.fillRect(141, 120, 93, 25, ILI9341_BLACK); } else if (averageCount < 100000) { tft.fillRect(160, 120, 74, 25, ILI9341_BLACK); } tft.setCursor(80, 192); tft.setTextSize(2); tft.setTextColor(ILI9341_WHITE, 0x630C); tft.println(cumulativeCount); // display total counts since reset tft.setCursor(80, 222); tft.println(totalDose); // display cumulative dose if (doseLevel != previousDoseLevel) // only update alert level if it changed. This prevents flicker { if (doseLevel == 0) { tft.drawRect(0, 0, tft.width(), tft.height(), ILI9341_WHITE); tft.fillRoundRect(3, 94, 234, 21, 3, 0x2DC6); tft.setCursor(15, 104); tft.setFont(&FreeSans9pt7b); tft.setTextColor(ILI9341_WHITE); tft.setTextSize(1); tft.println("NORMAL BACKGROUND"); previousDoseLevel = doseLevel; } else if (doseLevel == 1) { tft.drawRect(0, 0, tft.width(), tft.height(), ILI9341_WHITE); tft.fillRoundRect(3, 94, 234, 21, 3, 0xCE40); tft.setCursor(29, 104); tft.setFont(&FreeSans9pt7b); tft.setTextColor(ILI9341_WHITE); tft.setTextSize(1); tft.println("ELEVATED ACTIVITY"); previousDoseLevel = doseLevel; } else if (doseLevel == 2) { tft.drawRect(0, 0, tft.width(), tft.height(), ILI9341_RED); tft.fillRoundRect(3, 94, 234, 21, 3, 0xB8A2); tft.setCursor(17, 104); tft.setFont(&FreeSans9pt7b); tft.setTextColor(ILI9341_WHITE); tft.setTextSize(1); tft.println("HIGH RADIATION LEVEL"); previousDoseLevel = doseLevel; } } Serial.println(currentCount); } // end of millis()-controlled block that runs once every second. The rest of the code on page 0 runs every loop if (currentCount > previousCount) { if (ledSwitch) digitalWrite(D3, HIGH); // trigger buzzer and led if they are activated if (buzzerSwitch) digitalWrite(D0, HIGH); previousCount = currentCount; previousMicros = micros(); } currentMicros = micros(); if (currentMicros - previousMicros >= 200) { digitalWrite(D3, LOW); digitalWrite(D0, LOW); previousMicros = currentMicros; } if (!ts.touched()) wasTouched = 0; if (ts.touched() && !wasTouched) // A way of "debouncing" the touchscreen. Prevents multiple inputs from single touch { wasTouched = 1; TS_Point p = ts.getPoint(); x = map(p.x, TS_MINX, TS_MAXX, 240, 0); // get touch point and map to screen pixels y = map(p.y, TS_MINY, TS_MAXY, 320, 0); if ((x > 162 && x < 238) && (y > 259 && y < 318)) { integrationMode ++; if (integrationMode == 3) { integrationMode = 0; } currentCount = 0; previousCount = 0; for (int a = 0; a < 61; a++) // reset counts when integretation speed is changed { count[a] = 0; } for (int b = 0; b < 6; b++) { fastCount[b] = 0; } for (int c = 0; c < 181; c++) { slowCount[c] = 0; } if (integrationMode == 0) // change button based on touch and previous state { tft.fillRoundRect(162, 259, 74, 57, 3, 0x2A86); tft.setFont(&FreeSans12pt7b); tft.setTextSize(1); tft.setCursor(180, 283); tft.println("INT"); tft.setCursor(177, 309); tft.println("60 s"); } else if (integrationMode == 1) { tft.fillRoundRect(162, 259, 74, 57, 3, 0x2A86); tft.setFont(&FreeSans12pt7b); tft.setTextSize(1); tft.setCursor(180, 283); tft.println("INT"); tft.setCursor(184, 309); tft.println("5 s"); } else if (integrationMode == 2) { tft.fillRoundRect(162, 259, 74, 57, 3, 0x2A86); tft.setFont(&FreeSans12pt7b); tft.setTextSize(1); tft.setCursor(180, 283); tft.println("INT"); tft.setCursor(169, 309); tft.println("180 s"); } } else if ((x > 64 && x < 159) && (y > 259 && y < 318)) // timed count { page = 6; drawTimedCountPage(); } else if ((x > 190 && x < 238) && (y > 151 && y < 202)) // toggle LED { ledSwitch = !ledSwitch; if (ledSwitch) { tft.fillRoundRect(190, 151, 46, 51, 3, 0x6269); tft.drawBitmap(190, 153, ledOnBitmap, 45, 45, ILI9341_WHITE); } else { tft.fillRoundRect(190, 151, 46, 51, 3, 0x6269); tft.drawBitmap(190, 153, ledOffBitmap, 45, 45, ILI9341_WHITE); } } else if ((x > 190 && x < 238) && (y > 205 && y < 256)) // toggle buzzer { buzzerSwitch = !buzzerSwitch; if (buzzerSwitch) { tft.fillRoundRect(190, 205, 46, 51, 3, 0x6269); tft.drawBitmap(190, 208, buzzerOnBitmap, 45, 45, ILI9341_WHITE); } else { tft.fillRoundRect(190, 205, 46, 51, 3, 0x6269); tft.drawBitmap(190, 208, buzzerOffBitmap, 45, 45, ILI9341_WHITE); } } else if ((x > 3 && x < 61) && (y > 259 && y < 316)) // settings button pressed { page = 1; drawSettingsPage(); } } if (isLogging) { if(addr < 2100) { currentLogTime = millis(); if ((currentLogTime - previousLogTime) >= 600000) // log every 10 minutes { EEPROMWritelong(addr, averageCount); addr += 4; EEPROMWritelong(96, addr); // write current address number to an adress just before the logged data previousLogTime = currentLogTime; EEPROM.commit(); } } } if (deviceMode) // deviceMode is 1 when in monitoring station mode. Uploads CPM to thingspeak every 5 minutes { currentUploadTime = millis(); if ((currentUploadTime - previousUploadTime) > 300000) { previousUploadTime = currentUploadTime; if (client.connect(server, 80)) { String postStr = channelAPIkey; postStr += "&field2="; postStr += String(averageCount); postStr += "\r\n\r\n"; char temp[50] = "X-THINGSPEAKAPIKEY:"; strcat(temp, channelAPIkey); strcat(temp, "\n"); client.print("POST /update HTTP/1.1\n"); client.print("Host: api.thingspeak.com\n"); client.print("Connection: close\n"); client.print(temp); client.print("Content-Type: application/x-www-form-urlencoded\n"); client.print("Content-Length: "); client.print(postStr.length()); client.print("\n\n"); client.print(postStr); Serial.println(postStr); } client.stop(); } } } else if (page == 1) // settings page. all display elements are drawn when drawSettingsPage() is called { if (!ts.touched()) wasTouched = 0; if (ts.touched() && !wasTouched) { wasTouched = 1; TS_Point p = ts.getPoint(); x = map(p.x, TS_MINX, TS_MAXX, 240, 0); y = map(p.y, TS_MINY, TS_MAXY, 320, 0); if ((x > 4 && x < 62) && (y > 271 && y < 315)) // back button. draw homepage, reset counts and go back { currentCount = 0; previousCount = 0; for (int a = 0; a < 61; a++) { count[a] = 0; // counts need to be reset to prevent errorenous readings } for (int b = 0; b < 6; b++) { fastCount[b] = 0; } for (int c = 0; c < 181; c++) { slowCount[c] = 0; } page = 0; drawHomePage(); } else if ((x > 3 && x < 234) && (y > 64 && y < 108)) { page = 2; drawUnitsPage(); } else if ((x > 3 && x < 234) && (y > 114 && y < 158)) { page = 3; drawAlertPage(); } else if ((x > 3 && x < 234) && (y > 164 && y < 208)) { page = 4; drawCalibrationPage(); } else if ((x > 3 && x < 234) && (y > 214 && y < 268)) { page = 5; drawWifiPage(); } } } else if (page == 2) // units page { if (!ts.touched()) wasTouched = 0; if (ts.touched() && !wasTouched) { wasTouched = 1; TS_Point p = ts.getPoint(); x = map(p.x, TS_MINX, TS_MAXX, 240, 0); y = map(p.y, TS_MINY, TS_MAXY, 320, 0); if ((x > 4 && x < 62) && (y > 271 && y < 315)) // back button { page = 1; if (EEPROM.read(saveUnits) != doseUnits) // check current EEPROM value and only write if new value is different { EEPROM.write(saveUnits, doseUnits); // save current units to EEPROM during exit. This will be retrieved at startup EEPROM.commit(); } drawSettingsPage(); } else if ((x > 4 && x < 234) && (y > 70 && y < 120)) { doseUnits = 0; tft.fillRoundRect(4, 71, 232, 48, 4, 0x2A86); tft.setCursor(30, 103); tft.println("Sieverts (uSv/hr)"); tft.fillRoundRect(4, 128, 232, 48, 4, ILI9341_BLACK); tft.setCursor(47, 160); tft.println("Rems (mR/hr)"); } else if ((x > 4 && x < 234) && (y > 127 && y < 177)) { doseUnits = 1; tft.fillRoundRect(4, 71, 232, 48, 4, ILI9341_BLACK); tft.setCursor(30, 103); tft.println("Sieverts (uSv/hr)"); tft.fillRoundRect(4, 128, 232, 48, 4, 0x2A86); tft.setCursor(47, 160); tft.println("Rems (mR/hr)"); } } } else if (page == 3) // alert thresold page { tft.setFont(); tft.setTextSize(3); tft.setTextColor(ILI9341_WHITE, ILI9341_BLACK); tft.setCursor(151, 146); tft.println(alarmThreshold); if (alarmThreshold < 10) tft.fillRect(169, 146, 22, 22, ILI9341_BLACK); if (!ts.touched()) wasTouched = 0; if (ts.touched() && !wasTouched) { wasTouched = 1; TS_Point p = ts.getPoint(); x = map(p.x, TS_MINX, TS_MAXX, 240, 0); y = map(p.y, TS_MINY, TS_MAXY, 320, 0); if ((x > 4 && x < 62) && (y > 271 && y < 315)) { page = 1; if (EEPROM.read(saveAlertThreshold) != alarmThreshold) { EEPROM.write(saveAlertThreshold, alarmThreshold); EEPROM.commit(); // save to EEPROM to be retrieved at startup } drawSettingsPage(); } else if ((x > 130 && x < 190) && (y > 70 && y < 120)) { alarmThreshold++; if (alarmThreshold > 100) alarmThreshold = 100; } else if ((x > 130 && x < 190) && (y > 185 && y < 245)) { alarmThreshold--; if (alarmThreshold <= 2) alarmThreshold = 2; } } } else if (page == 4) // calibration page { tft.setFont(); tft.setTextSize(3); tft.setTextColor(ILI9341_WHITE, ILI9341_BLACK); tft.setCursor(161, 146); tft.println(conversionFactor); if (conversionFactor < 100) tft.fillRect(197, 146, 22, 22, ILI9341_BLACK); if (!ts.touched()) wasTouched = 0; if (ts.touched() && !wasTouched) { wasTouched = 1; TS_Point p = ts.getPoint(); x = map(p.x, TS_MINX, TS_MAXX, 240, 0); y = map(p.y, TS_MINY, TS_MAXY, 320, 0); if ((x > 4 && x < 62) && (y > 271 && y < 315)) { page = 1; if (EEPROM.read(saveCalibration) != conversionFactor) { EEPROM.write(saveCalibration, conversionFactor); EEPROM.commit(); } drawSettingsPage(); } else if ((x > 160 && x < 220) && (y > 70 && y < 120)) { conversionFactor++; } else if ((x > 160 && x < 220) && (y > 185 && y < 245)) { conversionFactor--; if (conversionFactor <= 1) conversionFactor = 1; } } } else if (page == 5) // Wifi page { if (!ts.touched()) wasTouched = 0; if (ts.touched() && !wasTouched) { wasTouched = 1; TS_Point p = ts.getPoint(); x = map(p.x, TS_MINX, TS_MAXX, 240, 0); y = map(p.y, TS_MINY, TS_MAXY, 320, 0); if ((x > 4 && x < 62) && (y > 271 && y < 315)) { page = 1; if (EEPROM.read(saveLoggingMode) != isLogging) // check current EEPROM value and only write if new value is different { EEPROM.write(saveLoggingMode, isLogging); EEPROM.commit(); } drawSettingsPage(); } else if ((x > 3 && x < 237) && (y > 64 && y < 108)) // wifi setup button { tft.setFont(&FreeSans9pt7b); tft.setTextSize(1); tft.fillRoundRect(10, 30, 220, 260, 6, ILI9341_BLACK); tft.drawRoundRect(10, 30, 220, 260, 6, ILI9341_WHITE); tft.setCursor(50, 50); tft.println("AP SETUP MODE"); tft.drawFastHLine(50, 53, 145, ILI9341_WHITE); tft.setCursor(20, 80); tft.println("With any WiFi capable"); tft.setCursor(20, 100); tft.println("device, connect to"); tft.setCursor(20, 120); tft.println("network \"GC20\" and "); tft.setCursor(20, 140); tft.println("browse to 192.168.4.1"); tft.setCursor(20, 160); tft.println("Enter credentials"); tft.setCursor(20, 180); tft.println("of your WiFi network"); tft.setCursor(20, 200); tft.println("and the Channel ID and"); tft.setCursor(20, 220); tft.println("write API key of your"); tft.setCursor(20, 240); tft.println("ThingSpeak channel"); delay(100); WiFiManager wifiManager; char channelIDSt[20]; char writeAPISt[20]; WiFiManagerParameter channel_id("0", "Channel ID", channelIDSt, 20); // create custom parameters for setup WiFiManagerParameter write_api("1", "Write API", writeAPISt, 20); wifiManager.addParameter(&channel_id); wifiManager.addParameter(&write_api); wifiManager.startConfigPortal("GC20"); // put the esp in AP mode for wifi setup, create a network with name "GC20" strcpy(channelIDSt, channel_id.getValue()); strcpy(writeAPISt, write_api.getValue()); size_t idLen = String(channelIDSt).length(); size_t apiLen = String(writeAPISt).length(); char channelInit = EEPROM.read(4001); // first character of channelID is stored in EEPROM address 4001 char apiKeyInit = EEPROM.read(4002); // Only overwrite channelIDSt and writeAPISt if new value of the first character is different from what was saved. if (channelInit != channelIDSt[0]) { for (unsigned int a = 50; a < 50 + idLen; a++) { EEPROM.write((a), channelIDSt[a - 50]); } EEPROM.write(saveIDLen, idLen); } if(apiKeyInit != writeAPISt[0]) { for (unsigned int b = 70; b < 70 + apiLen; b++) { EEPROM.write((b), writeAPISt[b - 70]); } EEPROM.write(saveAPILen, apiLen); } String ssidString = WiFi.SSID(); // retrieve ssid and password form the WifiManager library String passwordString = WiFi.psk(); size_t ssidLen = ssidString.length(); size_t passLen = passwordString.length(); Serial.println(ssidLen); Serial.println(passLen); char ssidChar[20]; char passwordChar[20]; ssidString.toCharArray(ssidChar, ssidLen + 1); passwordString.toCharArray(passwordChar, passLen + 1); for (unsigned int a = 10; a < 10 + ssidLen; a++) { EEPROM.write((a), ssidChar[a - 10]); // save ssid and ssid length to EEPROM } EEPROM.write(saveSSIDLen, ssidLen); for (unsigned int b = 30; b < 30 + passLen; b++) { EEPROM.write((b), passwordChar[b - 30]); // save password and password length to EEPROM } EEPROM.write(savePWLen, passLen); EEPROM.write(4001, channelIDSt[0]); // save first characters of channel ID and api key to EEPROM EEPROM.write(4002, writeAPISt[0]); EEPROM.commit(); tft.setCursor(16, 265); tft.println("Settings saved. Restarting"); delay(1000); ESP.reset(); } else if ((x > 3 && x < 237) && (y > 162 && y < 206)) // upload data { drawBlankDialogueBox(); tft.setCursor(38, 100); tft.println("Connecting to Wifi.."); delay(100); Serial.println(ssid); Serial.println(password); WiFi.begin(ssid, password); while (WiFi.status() != WL_CONNECTED) { // Wait for the Wi-Fi to connect delay(100); } tft.setCursor(36, 160); tft.println("Creating JSON file.."); createJsonFile(); // reads logged data from EEPROM and creates a json file Serial.println(jsonBuffer); delay(1000); tft.setCursor(70, 220); tft.println("Uploading.."); delay(1000); char secondHalf[50] = "\",\"updates\":"; strcat(data, channelAPIkey); strcat(data, secondHalf); strcat(data,jsonBuffer); // concatenate strings together and store in array named data strcat(data,"}"); Serial.println(data); client.stop(); String data_length = String(strlen(data)+1); if (client.connect(server, 80)) { // post data to thingspeak char temp1[100] = "POST /channels/"; char temp2[30] = "/bulk_update.json HTTP/1.1"; strcat(temp1, channelID); strcat(temp1, temp2); client.println(temp1); client.println("Host: api.thingspeak.com"); client.println("User-Agent: mw.doc.bulk-update (Arduino ESP8266)"); client.println("Connection: close"); client.println("Content-Type: application/json"); client.println("Content-Length: "+data_length); client.println(); client.println(data); client.stop(); WiFi.disconnect(); WiFi.mode( WIFI_OFF ); // turn off wifi WiFi.forceSleepBegin(); delay(1); clearLogs(); // erase logs and re-initialize the json buffer tft.setCursor(43, 260); tft.println("Resetting Device.."); delay(1000); ESP.reset(); } else { tft.setCursor(50, 260); tft.println("Failed to upload"); delay(1000); ESP.reset(); } } else if ((x > 3 && x < 237) && (y > 114 && y < 158)) // logging { isLogging = !isLogging; if (isLogging) { tft.fillRoundRect(3, 114, 234, 44, 4, 0x3B8F); tft.drawRoundRect(3, 114, 234, 44, 4, WHITE); tft.setCursor(38, 145); tft.println("LOGGING ON"); } else { tft.fillRoundRect(3, 114, 234, 44, 4, 0xB9C7); tft.drawRoundRect(3, 114, 234, 44, 4, WHITE); tft.setCursor(33, 145); tft.println("LOGGING OFF"); } } else if ((x > 3 && x < 237) && (y > 214 && y < 258)) // device mode { page = 8; drawDeviceModePage(); } } } else if (page == 6) // timed count setup page { if (interval < 10) { intervalSize = 1; } else if (interval < 100) { intervalSize = 2; } else { intervalSize = 3; } tft.setFont(); tft.setTextSize(3); tft.setTextColor(ILI9341_WHITE, ILI9341_BLACK); tft.setCursor((185 - (intervalSize - 1) * 11), 146); tft.println(interval); if (!ts.touched()) wasTouched = 0; if (ts.touched() && !wasTouched) { wasTouched = 1; TS_Point p = ts.getPoint(); x = map(p.x, TS_MINX, TS_MAXX, 240, 0); y = map(p.y, TS_MINY, TS_MAXY, 320, 0); if ((x > 4 && x < 62) && (y > 271 && y < 315)) { page = 0; drawHomePage(); currentCount = 0; previousCount = 0; for (int a = 0; a < 60; a++) { count[a] = 0; // counts need to be reset to prevent errorenous readings } for (int b = 0; b < 5; b++) { fastCount[b] = 0; } for (int c = 0; c < 180; c++) { slowCount[c] = 0; } } else if ((x > 145 && x < 235) && (y > 271 && y < 315)) { page = 7; drawTimedCountRunningPage(interval, intervalSize); } else if ((x > 160 && x < 220) && (y > 70 && y < 120)) { interval += 5; if (interval >= 995) { interval = 995; } tft.fillRect(160, 130, 70, 40, ILI9341_BLACK); } else if ((x > 160 && x < 220) && (y > 185 && y < 245)) { interval -= 5; if (interval <= 5) { interval = 5; } tft.fillRect(160, 130, 70, 40, ILI9341_BLACK); } } } else if (page == 7) // timed count running page { elapsedTime = millis() - startMillis; if(elapsedTime < intervalMillis) { if((millis() - previousMillis) >= 1000) { previousMillis = millis(); tft.setFont(); tft.setTextSize(3); tft.setTextColor(ILI9341_WHITE, ILI9341_BLACK); tft.setCursor(101, 181); tft.println(currentCount); cpm = float(currentCount) / float((1 + elapsedTime) / 60000.0); tft.setCursor(101, 226); tft.println(cpm); if(cpm < 10) { tft.fillRect(170, 225, 50, 40, ILI9341_BLACK); } else if(cpm < 100) { tft.fillRect(190, 225, 35, 40, ILI9341_BLACK); } else if(cpm < 1000) { tft.fillRect(209, 225, 18, 40, ILI9341_BLACK); } } progress = map(elapsedTime, 0, intervalMillis, 0, 217); tft.fillRect(12, 105, progress, 16, 0x25A6); } else { if (completed == 0) { drawCloseButton(); completed = 1; } } if (!ts.touched()) wasTouched = 0; if (ts.touched() && !wasTouched) { wasTouched = 1; TS_Point p = ts.getPoint(); x = map(p.x, TS_MINX, TS_MAXX, 240, 0); y = map(p.y, TS_MINY, TS_MAXY, 320, 0); if ((x > 70 && x < 170) && (y > 271 && y < 315)) { page = 0; drawHomePage(); currentCount = 0; previousCount = 0; for (int a = 0; a < 60; a++) { count[a] = 0; // counts need to be reset to prevent errorenous readings } for (int b = 0; b < 5; b++) { fastCount[b] = 0; } for (int c = 0; c < 180; c++) { slowCount[c] = 0; } } } } else if (page == 8) // device mode selection page { if (!ts.touched()) wasTouched = 0; if (ts.touched() && !wasTouched) { wasTouched = 1; TS_Point p = ts.getPoint(); x = map(p.x, TS_MINX, TS_MAXX, 240, 0); y = map(p.y, TS_MINY, TS_MAXY, 320, 0); if ((x > 4 && x < 62) && (y > 271 && y < 315)) // back button { page = 5; if (EEPROM.read(saveDeviceMode) != deviceMode) // check current EEPROM value and only write if new value is different { EEPROM.write(saveDeviceMode, deviceMode); EEPROM.commit(); } drawWifiPage(); } else if ((x > 4 && x < 234) && (y > 70 && y < 120)) { deviceMode = 0; tft.setFont(&FreeSans12pt7b); tft.fillRoundRect(4, 71, 232, 48, 4, 0x2A86); tft.setCursor(13, 103); tft.println("GEIGER COUNTER"); tft.fillRoundRect(4, 128, 232, 48, 4, ILI9341_BLACK); tft.setCursor(30, 160); tft.println("MON. STATION"); } else if ((x > 4 && x < 234) && (y > 127 && y < 177)) { deviceMode = 1; tft.setFont(&FreeSans12pt7b); tft.fillRoundRect(4, 71, 232, 48, 4, ILI9341_BLACK); tft.setCursor(13, 103); tft.println("GEIGER COUNTER"); tft.fillRoundRect(4, 128, 232, 48, 4, 0x2A86); tft.setCursor(30, 160); tft.println("MON. STATION"); } } } } void drawHomePage() { tft.fillRect(1, 21, 237, 298, ILI9341_BLACK); tft.drawRect(0, 0, tft.width(), tft.height(), ILI9341_WHITE); tft.drawRoundRect(210, 4, 26, 14, 3, ILI9341_WHITE); tft.drawLine(209, 8, 209, 13, ILI9341_WHITE); // Battery symbol tft.drawLine(208, 8, 208, 13, ILI9341_WHITE); tft.fillRect(212, 6, 22, 10, ILI9341_BLACK); tft.fillRect(batteryMapped, 6, (234 - batteryMapped), 10, ILI9341_GREEN); tft.setTextSize(1); tft.setTextColor(ILI9341_CYAN); tft.setFont(&FreeSans9pt7b); tft.setCursor(2, 16); tft.println("GC-20"); tft.setTextColor(ILI9341_WHITE); tft.setFont(); tft.setTextSize(2); tft.setCursor(118, 4); tft.println("+"); tft.setTextSize(1); tft.setFont(&FreeSans9pt7b); tft.drawBitmap(103, 2, betaBitmap, 18, 18, ILI9341_WHITE); tft.drawBitmap(128, 2, gammaBitmap, 12, 18, ILI9341_WHITE); tft.drawLine(1, 20, 238, 20, ILI9341_WHITE); tft.fillRoundRect(3, 23, 234, 69, 3, DOSEBACKGROUND); tft.setCursor(16, 40); tft.println("EFFECTIVE DOSE RATE:"); tft.setCursor(165, 85); tft.setFont(&FreeSans12pt7b); if (doseUnits == 0) { tft.println("uSv/hr"); } else if (doseUnits == 1) { tft.println("mR/hr"); } tft.fillRoundRect(3, 94, 234, 21, 3, 0x2DC6); tft.setCursor(15, 110); tft.setFont(&FreeSans9pt7b); tft.setTextColor(ILI9341_WHITE); tft.setTextSize(1); tft.println("NORMAL BACKGROUND"); tft.setFont(&FreeSans12pt7b); tft.setCursor(7, 141); tft.println("CPM:"); tft.drawRoundRect(3, 117, 234, 32, 3, DOSEBACKGROUND); tft.fillRoundRect(3, 151, 185, 105, 4, 0x630C); tft.setFont(&FreeSans9pt7b); tft.setCursor(9, 171); tft.println("CUMULATIVE DOSE"); tft.setCursor(7, 205); tft.println("Counts:"); if (doseUnits == 0) { tft.setCursor(34, 235); tft.println("uSv:"); } else if (doseUnits == 1) { tft.setCursor(37, 235); tft.println("mR:"); } tft.fillRoundRect(3, 259, 58, 57, 3, 0x3B8F); tft.drawBitmap(1, 257, settingsBitmap, 60, 60, ILI9341_WHITE); tft.fillRoundRect(64, 259, 95, 57, 3, 0x6269); tft.setFont(&FreeSans12pt7b); tft.setTextSize(1); tft.setCursor(74, 284); tft.println("TIMED"); tft.setCursor(70, 309); tft.println("COUNT"); if (integrationMode == 0) { tft.fillRoundRect(162, 259, 74, 57, 3, 0x2A86); tft.setCursor(180, 283); tft.println("INT"); tft.setCursor(177, 309); tft.println("60 s"); } else if (integrationMode == 1) { tft.fillRoundRect(162, 259, 74, 57, 3, 0x2A86); tft.setCursor(180, 283); tft.println("INT"); tft.setCursor(184, 309); tft.println("5 s"); } else if (integrationMode == 2) { tft.fillRoundRect(162, 259, 74, 57, 3, 0x2A86); tft.setCursor(180, 283); tft.println("INT"); tft.setCursor(169, 309); tft.println("180 s"); } if (ledSwitch) { tft.fillRoundRect(190, 151, 46, 51, 3, 0x6269); tft.drawBitmap(190, 153, ledOnBitmap, 45, 45, ILI9341_WHITE); } else if (!ledSwitch) { tft.fillRoundRect(190, 151, 46, 51, 3, 0x6269); tft.drawBitmap(190, 153, ledOffBitmap, 45, 45, ILI9341_WHITE); } if (buzzerSwitch) { tft.fillRoundRect(190, 205, 46, 51, 3, 0x6269); tft.drawBitmap(190, 208, buzzerOnBitmap, 45, 45, ILI9341_WHITE); } else if (!buzzerSwitch) { tft.fillRoundRect(190, 205, 46, 51, 3, 0x6269); tft.drawBitmap(190, 208, buzzerOffBitmap, 45, 45, ILI9341_WHITE); } tft.setFont(&FreeSans9pt7b); if (isLogging) { tft.setCursor(175, 16); tft.println("L"); } else { tft.fillRect(175, 2, 18, 18, ILI9341_BLACK); } if (deviceMode) { tft.drawBitmap(188, 1, wifiBitmap, 19, 19, ILI9341_WHITE); } else { tft.fillRect(188, 1, 19, 19, ILI9341_BLACK); } } void drawSettingsPage() { digitalWrite(D3, LOW); digitalWrite(D0, LOW); drawFrame(); tft.fillRoundRect(3, 23, 234, 35, 3, 0x3B8F); tft.setFont(&FreeSans12pt7b); tft.setCursor(57, 48); tft.println("SETTINGS"); tft.drawFastHLine(59, 51, 117, WHITE); tft.fillRoundRect(3, 64, 234, 44, 4, 0x2A86); tft.drawRoundRect(3, 64, 234, 44, 4, WHITE); tft.setCursor(44, 94); tft.println("DOSE UNITS"); tft.fillRoundRect(3, 114, 234, 44, 4, 0x2A86); tft.drawRoundRect(3, 114, 234, 44, 4, WHITE); tft.setCursor(5, 145); tft.println("ALERT THRESHOLD"); tft.fillRoundRect(3, 164, 234, 44, 4, 0x2A86); tft.drawRoundRect(3, 164, 234, 44, 4, WHITE); tft.setCursor(37, 194); tft.println("CALIBRATION"); tft.fillRoundRect(3, 214, 234, 44, 4, 0x2A86); tft.drawRoundRect(3, 214, 234, 44, 4, WHITE); tft.setCursor(8, 244); tft.println("LOGGING AND WIFI"); drawBackButton(); } void drawUnitsPage() { drawFrame(); tft.fillRoundRect(3, 23, 234, 40, 3, 0x3B8F); tft.setFont(&FreeSans12pt7b); tft.setCursor(84, 51); tft.println("UNITS"); tft.drawFastHLine(86, 55, 71, WHITE); drawBackButton(); tft.drawRoundRect(3, 70, 234, 50, 4, WHITE); if (doseUnits == 0) tft.fillRoundRect(4, 71, 232, 48, 4, 0x2A86); tft.setCursor(30, 103); tft.println("Sieverts (uSv/hr)"); tft.drawRoundRect(3, 127, 234, 50, 4, WHITE); if (doseUnits == 1) tft.fillRoundRect(4, 128, 232, 48, 4, 0x2A86); tft.setCursor(47, 160); tft.println("Rems (mR/hr)"); } void drawAlertPage() { drawFrame(); tft.fillRoundRect(3, 23, 234, 40, 3, 0x3B8F); tft.setFont(&FreeSans12pt7b); tft.setCursor(4, 51); tft.println("ALERT THRESHOLD"); tft.drawFastHLine(5, 55, 229, WHITE); drawBackButton(); tft.setCursor(30, 164); tft.println("uSv/hr:"); tft.drawRoundRect(130, 70, 60, 60, 4, ILI9341_WHITE); tft.fillRoundRect(131, 71, 58, 58, 4, 0x2A86); tft.drawRoundRect(130, 185, 60, 60, 4, ILI9341_WHITE); tft.fillRoundRect(131, 186, 58, 58, 4, 0x2A86); tft.setCursor(140, 113); tft.setTextSize(3); tft.println("+"); tft.setCursor(148, 232); tft.println("-"); tft.setTextSize(1); } void drawCalibrationPage() { drawFrame(); tft.fillRoundRect(3, 23, 234, 40, 3, 0x3B8F); tft.setFont(&FreeSans12pt7b); tft.setCursor(47, 51); tft.println("CALIBRATE"); tft.drawFastHLine(48, 55, 133, WHITE); drawBackButton(); tft.setFont(&FreeSans9pt7b); tft.setCursor(8, 154); tft.println("Conversion Factor"); tft.setCursor(8, 174); tft.println("(CPM per uSv/hr)"); tft.drawRoundRect(160, 70, 60, 60, 4, ILI9341_WHITE); tft.fillRoundRect(161, 71, 58, 58, 4, 0x2A86); tft.drawRoundRect(160, 185, 60, 60, 4, ILI9341_WHITE); tft.fillRoundRect(161, 186, 58, 58, 4, 0x2A86); tft.setCursor(170, 113); tft.setFont(&FreeSans12pt7b); tft.setTextSize(3); tft.println("+"); tft.setCursor(178, 232); tft.println("-"); tft.setTextSize(1); } void drawWifiPage() { drawFrame(); drawBackButton(); tft.fillRoundRect(3, 23, 234, 35, 3, 0x3B8F); tft.setFont(&FreeSans12pt7b); tft.setCursor(7, 48); tft.println("LOGGING AND WIFI"); tft.drawFastHLine(8, 51, 222, WHITE); tft.fillRoundRect(3, 64, 234, 44, 4, 0x2A86); tft.drawRoundRect(3, 64, 234, 44, 4, WHITE); tft.setCursor(48, 94); tft.println("WIFI SETUP"); if (isLogging) { tft.fillRoundRect(3, 114, 234, 44, 4, 0x3B8F); tft.drawRoundRect(3, 114, 234, 44, 4, WHITE); tft.setCursor(38, 145); tft.println("LOGGING ON"); } else { tft.fillRoundRect(3, 114, 234, 44, 4, 0xB9C7); tft.drawRoundRect(3, 114, 234, 44, 4, WHITE); tft.setCursor(33, 145); tft.println("LOGGING OFF"); } tft.fillRoundRect(3, 164, 234, 44, 4, 0x2A86); tft.drawRoundRect(3, 164, 234, 44, 4, WHITE); tft.setCursor(31, 194); tft.println("UPLOAD DATA"); tft.fillRoundRect(3, 214, 234, 44, 4, 0x2A86); tft.drawRoundRect(3, 214, 234, 44, 4, WHITE); tft.setCursor(35, 244); tft.println("DEVICE MODE"); if (addr > 2000) { tft.setFont(&FreeSans9pt7b); tft.setCursor(80, 297); tft.println("Log memory full"); } } void drawTimedCountPage() { drawFrame(); drawBackButton(); tft.fillRoundRect(145, 271, 92, 45, 3, 0x3B8F); tft.drawRoundRect(145, 271, 92, 45, 3, ILI9341_WHITE); tft.setFont(&FreeSans12pt7b); tft.setCursor(149, 302); tft.println("BEGIN!"); tft.fillRoundRect(3, 23, 234, 40, 3, 0x3B8F); tft.setCursor(34, 51); tft.println("TIMED COUNT"); tft.drawFastHLine(35, 55, 163, WHITE); tft.setFont(&FreeSans9pt7b); tft.setCursor(5, 162); tft.println("Duration (minutes):"); tft.drawRoundRect(160, 70, 60, 60, 4, ILI9341_WHITE); tft.fillRoundRect(161, 71, 58, 58, 4, 0x2A86); tft.drawRoundRect(160, 185, 60, 60, 4, ILI9341_WHITE); tft.fillRoundRect(161, 186, 58, 58, 4, 0x2A86); tft.setCursor(170, 113); tft.setFont(&FreeSans12pt7b); tft.setTextSize(3); tft.println("+"); tft.setCursor(178, 232); tft.println("-"); tft.setTextSize(1); cpm = 0; progress = 0; } void drawTimedCountRunningPage(int duration, int size) { drawFrame(); drawCancelButton(); tft.fillRoundRect(3, 23, 234, 40, 3, 0x3B8F); tft.setFont(&FreeSans12pt7b); tft.setTextSize(1); tft.setCursor(34, 51); tft.println("TIMED COUNT"); tft.drawFastHLine(35, 55, 163, WHITE); tft.drawRoundRect(3, 66, 234, 95, 4, ILI9341_WHITE); tft.drawRect(10, 103, 220, 20, ILI9341_WHITE); tft.drawRoundRect(3, 164, 234, 103, 4, ILI9341_WHITE); tft.setCursor(58, 90); tft.println("Progress:"); tft.setCursor(13, 150); tft.println("Duration:"); tft.setCursor(115, 150); tft.println(duration); tft.setCursor((135 + (size - 1)*15), 150); tft.println("min"); tft.setCursor(15, 200); tft.println("Counts:"); tft.setCursor(37, 245); tft.println("CPM:"); currentCount = 0; startMillis = millis(); intervalMillis = duration * 60000; completed = 0; } void drawDeviceModePage() { drawFrame(); tft.fillRoundRect(3, 23, 234, 40, 3, 0x3B8F); tft.setFont(&FreeSans12pt7b); tft.setCursor(34, 51); tft.println("DEVICE MODE"); tft.drawFastHLine(35, 57, 160, WHITE); drawBackButton(); tft.drawRoundRect(3, 70, 234, 50, 4, WHITE); if (deviceMode == 0) tft.fillRoundRect(4, 71, 232, 48, 4, 0x2A86); tft.setCursor(13, 103); tft.println("GEIGER COUNTER"); tft.drawRoundRect(3, 127, 234, 50, 4, WHITE); if (deviceMode == 1) tft.fillRoundRect(4, 128, 232, 48, 4, 0x2A86); tft.setCursor(30, 160); tft.println("MON. STATION"); tft.setFont(&FreeSans9pt7b); tft.setCursor(20, 200); tft.println("Press Back button and"); tft.setCursor(20, 220); tft.println("reset device for changes"); tft.setCursor(20, 240); tft.println("to take effect"); } void isr() // interrupt service routine { if ((micros() - 200) > previousIntMicros){ currentCount++; cumulativeCount++; } previousIntMicros = micros(); } void drawBackButton(){ tft.fillRoundRect(4, 271, 62, 45, 3, 0x3B8F); tft.drawRoundRect(4, 271, 62, 45, 3, ILI9341_WHITE); tft.drawBitmap(4, 271, backBitmap, 62, 45, ILI9341_WHITE); } void drawFrame(){ tft.fillRect(2, 21, 236, 298, ILI9341_BLACK); tft.drawRect(0, 0, tft.width(), tft.height(), ILI9341_WHITE); tft.drawRoundRect(210, 4, 26, 14, 3, ILI9341_WHITE); tft.drawLine(209, 8, 209, 13, ILI9341_WHITE); // Battery symbol tft.drawLine(208, 8, 208, 13, ILI9341_WHITE); tft.fillRect(212, 6, 22, 10, ILI9341_BLACK); tft.fillRect(batteryMapped, 6, (234 - batteryMapped), 10, ILI9341_GREEN); tft.setFont(&FreeSans9pt7b); tft.setCursor(2, 16); tft.setTextColor(ILI9341_CYAN); tft.setTextSize(1); tft.println("GC-20"); tft.setTextColor(ILI9341_WHITE); tft.setFont(); tft.setTextSize(2); tft.setCursor(118, 4); tft.println("+"); tft.setTextSize(1); tft.setFont(&FreeSans9pt7b); tft.drawBitmap(103, 2, betaBitmap, 18, 18, ILI9341_WHITE); tft.drawBitmap(128, 2, gammaBitmap, 12, 18, ILI9341_WHITE); tft.drawLine(1, 20, 238, 20, ILI9341_WHITE); tft.setFont(&FreeSans9pt7b); if (isLogging) { tft.setCursor(175, 16); tft.println("L"); } else { tft.fillRect(175, 2, 18, 18, ILI9341_BLACK); } if (deviceMode) { tft.drawBitmap(188, 1, wifiBitmap, 18, 18, ILI9341_WHITE); } else { tft.fillRect(188, 1, 19, 19, ILI9341_BLACK); } } void drawCancelButton() { tft.fillRoundRect(70, 271, 100, 45, 3, 0xB9C7); tft.drawRoundRect(70, 271, 100, 45, 3, ILI9341_WHITE); tft.setFont(&FreeSans12pt7b); tft.setCursor(72, 302); tft.println("CANCEL"); } void drawCloseButton() { tft.fillRoundRect(70, 271, 100, 45, 3, 0x3B8F); tft.drawRoundRect(70, 271, 100, 45, 3, ILI9341_WHITE); tft.setTextSize(1); tft.setFont(&FreeSans12pt7b); tft.setCursor(79, 302); tft.println("CLOSE"); } long EEPROMReadlong(long address) { long four = EEPROM.read(address); long three = EEPROM.read(address + 1); long two = EEPROM.read(address + 2); long one = EEPROM.read(address + 3); return ((four << 0) & 0xFF) + ((three << 8) & 0xFFFF) + ((two << 16) & 0xFFFFFF) + ((one << 24) & 0xFFFFFFFF); } void EEPROMWritelong(int address, long value) { byte four = (value & 0xFF); byte three = ((value >> 8) & 0xFF); byte two = ((value >> 16) & 0xFF); byte one = ((value >> 24) & 0xFF); EEPROM.write(address, four); EEPROM.write(address + 1, three); EEPROM.write(address + 2, two); EEPROM.write(address + 3, one); } void createJsonFile() { Serial.println(addr); for (int i = 100; i < addr; i += 4) { int count = EEPROMReadlong(i); int deltaT = 600; strcat(jsonBuffer,"{\"delta_t\":"); size_t lengthT = String(deltaT).length(); char temp[10]; String(deltaT).toCharArray(temp,lengthT + 1); strcat(jsonBuffer,temp); strcat(jsonBuffer,","); strcat(jsonBuffer, "\"field1\":"); lengthT = String(count).length(); String(count).toCharArray(temp, lengthT + 1); strcat(jsonBuffer,temp); strcat(jsonBuffer,"},"); } size_t len = strlen(jsonBuffer); jsonBuffer[len-1] = ']'; } void drawBlankDialogueBox() { tft.setFont(&FreeSans9pt7b); tft.setTextSize(1); tft.fillRoundRect(20, 50, 200, 220, 6, ILI9341_BLACK); tft.drawRoundRect(20, 50, 200, 220, 6, ILI9341_WHITE); } void clearLogs() { for (int j = 100; j < 4000; j ++) { EEPROMWritelong(j, 0); } for (int k = 1; k < 1000; k++) // keep the first character in jsonBuffer: "[" { jsonBuffer[k] = 0; } addr = 100; EEPROMWritelong(96, addr); EEPROM.write(saveLoggingMode, 0); EEPROM.commit(); isLogging = 0; }
