---------------------------------------------------------------------------------- -- Company: www.Circuit-Break.de -- Engineer: Jens Weiss -- -- Create Date: 10:14:32 02/23/2024 -- Design Name: -- Module Name: Opcode_memory - Behavioral -- Project Name: -- Target Devices: -- Tool versions: -- Description: -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- ---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity Opcode_memory is Generic(ADRESSWIDTH : natural := 5; --memory depth = 2^ADDRESSWIDTH DATAWIDTH : natural := 8); Port ( clk : in std_logic; A : in std_logic_vector(ADRESSWIDTH-1 downto 0); Dout : out std_logic_vector(DATAWIDTH-1 downto 0) ); end Opcode_memory; architecture Behavioral of Opcode_memory is signal RomAddr : integer range 0 to (2**ADRESSWIDTH)-1; type Rom is array (0 to (2**ADRESSWIDTH)-1) of STD_LOGIC_VECTOR(DATAWIDTH-1 downto 0); constant Parameter_Rom : Rom := ( -- Integrator LT1 "00101000", -- Ocode: "00101 000" Parameter: b1 | Dataselect: 000 (data_in) "00000001", -- Ocode: "00000 001" Parameter: a1 | Dataselect: 001 (int_data_out) "10100011", -- Ocode: "10100 011" Parameter:e21 | Dataselect: 011 (LT2_out) "10101100", -- Ocode: "10101 100" Parameter:e31 | Dataselect: 100 (LT3_out) "10111101", -- Ocode: "10111 101" Parameter:e41 | Dataselect: 101 (LT4_out) -- Integrator LT2 "00110000", -- Ocode: "00110 000" Parameter: b2 | Dataselect: 000 (data_in) "00001001", -- Ocode: "00001 001" Parameter: a2 | Dataselect: 001 (int_data_out) "01010010", -- Ocode: "01010 010" Parameter: c1 | Dataselect: 010 (LT1_out) "10110100", -- Ocode: "10110 100" Parameter:e32 | Dataselect: 100 (LT3_out) "11000101", -- Ocode: "11000 101" Parameter:e42 | Dataselect: 101 (LT4_out) -- Integrator LT3 "00111000", -- Ocode: "00111 000" Parameter: b3 | Dataselect: 000 (data_in) "00010001", -- Ocode: "00010 001" Parameter: a3 | Dataselect: 001 (int_data_out) "01110010", -- Ocode: "01110 010" Parameter:d13 | Dataselect: 010 (LT1_out) "01011011", -- Ocode: "01011 011" Parameter: c2 | Dataselect: 011 (LT2_out) "11001101", -- Ocode: "11001 101" Parameter:e43 | Dataselect: 101 (LT4_out) -- Integrator LT4 "01000000", -- Ocode: "01000 000" Parameter: b4 | Dataselect: 000 (data_in) "00011001", -- Ocode: "00011 001" Parameter: a4 | Dataselect: 001 (int_data_out) "01111010", -- Ocode: "01111 010" Parameter:d14 | Dataselect: 010 (LT1_out) "10001011", -- Ocode: "10001 011" Parameter:d24 | Dataselect: 011 (LT2_out) "01100100", -- Ocode: "01100 100" Parameter: c3 | Dataselect: 100 (LT3_out) -- Output/to Quantizer "01001000", -- Ocode: "01001 000" Parameter: b5 | Dataselect: 000 (data_in) "00100001", -- Ocode: "00100 001" Parameter: a5 | Dataselect: 001 (int_data_out) "10000010", -- Ocode: "10000 010" Parameter:d15 | Dataselect: 010 (LT1_out) "10010011", -- Ocode: "10010 011" Parameter:d25 | Dataselect: 011 (LT2_out) "10011100", -- Ocode: "10011 100" Parameter:d35 | Dataselect: 100 (LT3_out) "01101101", -- Ocode: "01101 101" Parameter: c4 | Dataselect: 101 (LT4_out) others => "00000000" ); begin --BROM process begin wait until rising_edge(clk); RomAddr <= to_integer(unsigned(A)); -- clocked address --> BRAM end process; --Dout <= Parameter_Rom(to_integer(unsigned(A))); Dout <= std_logic_vector(Parameter_Rom(RomAddr)); end Behavioral;
