---------------------------------------------------------------------------------- -- Company: www.Circuit-Break.de -- Engineer: Jens Weiss -- -- Create Date: 13:36:13 02/21/2024 -- Design Name: -- Module Name: Parameter_memory - Behavioral -- Project Name: -- Target Devices: -- Tool versions: -- Description: -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- ---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity Parameter_memory is Generic(ADRESSWIDTH : natural := 5; --memory depth = 2^ADDRESSWIDTH DATAWIDTH : natural := 16); Port ( clk : in std_logic; A : in std_logic_vector(ADRESSWIDTH-1 downto 0); Dout : out std_logic_vector(DATAWIDTH-1 downto 0) ); end Parameter_memory; architecture Behavioral of Parameter_memory is signal RomAddr : integer range 0 to (2**ADRESSWIDTH)-1; type Rom is array (0 to (2**ADRESSWIDTH)-1) of signed (DATAWIDTH-1 downto 0); constant Parameter_Rom : Rom := ( x"C0F8", -- Parameter: a1 | Adress: 00000 x"0000", -- Parameter: a2 | Adress: 00001 x"0000", -- Parameter: a3 | Adress: 00010 x"0000", -- Parameter: a4 | Adress: 00011 x"F6CE", -- Parameter: a5 | Adress: 00100 x"3F08", -- Parameter: b1 | Adress: 00101 x"0000", -- Parameter: b2 | Adress: 00110 x"0000", -- Parameter: b3 | Adress: 00111 x"0000", -- Parameter: b4 | Adress: 01000 x"2999", -- Parameter: b5 | Adress: 01001 x"0000", -- Parameter: c1 | Adress: 01010 x"0000", -- Parameter: c2 | Adress: 01011 x"0000", -- Parameter: c3 | Adress: 01100 x"0000", -- Parameter: c4 | Adress: 01101 x"0000", -- Parameter: d13 | Adress: 01110 x"0000", -- Parameter: d14 | Adress: 01111 x"20A8", -- Parameter: d15 | Adress: 10000 x"0000", -- Parameter: d24 | Adress: 10001 x"0000", -- Parameter: d25 | Adress: 10010 x"0000", -- Parameter: d35 | Adress: 10011 x"0000", -- Parameter: e21 | Adress: 10100 x"0000", -- Parameter: e31 | Adress: 10101 x"0000", -- Parameter: e32 | Adress: 10110 x"0000", -- Parameter: e41 | Adress: 10111 x"0000", -- Parameter: e42 | Adress: 11000 x"0000", -- Parameter: e43 | Adress: 11001 x"0000", -- Parameter: dummy | Adress: 11010 x"0000", -- Parameter: dummy | Adress: 11011 x"0000", -- Parameter: dummy | Adress: 11100 x"0000", -- Parameter: dummy | Adress: 11101 x"0000", -- Parameter: dummy | Adress: 11110 x"0000" -- Parameter: dummy | Adress: 11111 ); begin --BROM process begin wait until rising_edge(clk); RomAddr <= to_integer(unsigned(A)); -- clocked address --> BRAM end process; Dout <= std_logic_vector(Parameter_Rom(RomAddr)); end Behavioral;
