/**************************************************************************** * Project : Welec W2000A ***************************************************************************** * File : DSO_SFR.h * Author : Alexander Lindert * Date : 20.04.2009 ***************************************************************************** * Description : ***************************************************************************** * Copyright (c) 2009, Alexander Lindert * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 2 of the License, or * (at your option) any later version. * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * You should have received a copy of the GNU General Public License * along with this program; if not, write to the Free Software * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA * For commercial applications where source-code distribution is not * desirable or possible, I offer low-cost commercial IP licenses. * Please contact me per mail. ***************************************************************************** * Remarks : - * Revision : 0 ****************************************************************************/ #ifndef DSO_SFR_H #define DSO_SFR_H #include "DSO_Main.h" /* TODO make this doxygen conform*/ #define DEVICEADDR (DSO_SFR_BASE_ADDR+ 4*0) #define INTERRUPTADDR (DSO_SFR_BASE_ADDR+ 4*1) #define INTERRUPTMASKADDR (DSO_SFR_BASE_ADDR+ 4*2) #define SAMPLINGFREQADDR (DSO_SFR_BASE_ADDR+ 4*4) #define FILTERENABLEADDR (DSO_SFR_BASE_ADDR+ 4*5) #define EXTTRIGGERSRCADDR (DSO_SFR_BASE_ADDR+ 4*6) #define EXTTRIGGERPWMADDR (DSO_SFR_BASE_ADDR+ 4*7) #define INPUTCH0ADDR (DSO_SFR_BASE_ADDR+ 4*8) #define INPUTCH1ADDR (DSO_SFR_BASE_ADDR+ 4*9) #define INPUTCH2ADDR (DSO_SFR_BASE_ADDR+ 4*10) #define INPUTCH3ADDR (DSO_SFR_BASE_ADDR+ 4*11) #define TRIGGERONCHADDR (DSO_SFR_BASE_ADDR+ 4*12) #define TRIGGERONCEADDR (DSO_SFR_BASE_ADDR+ 4*13) #define TRIGGERPREFETCHADDR (DSO_SFR_BASE_ADDR+ 4*14) #define TRIGGERSTORAGEMODEADDR (DSO_SFR_BASE_ADDR+ 4*15) #define TRIGGERREADOFFSETADDR (DSO_SFR_BASE_ADDR+ 4*16) #define TRIGGERTYPEADDR (DSO_SFR_BASE_ADDR+ 4*17) #define TRIGGERLOWVALUEADDR (DSO_SFR_BASE_ADDR+ 4*18) #define TRIGGERLOWTIMEADDR (DSO_SFR_BASE_ADDR+ 4*19) #define TRIGGERHIGHVALUEADDR (DSO_SFR_BASE_ADDR+ 4*20) #define TRIGGERHIGHTIMEADDR (DSO_SFR_BASE_ADDR+ 4*21) #define TRIGGERSTATUSREGISTER (DSO_SFR_BASE_ADDR+ 4*22) #define TRIGGERCURRENTADDR (DSO_SFR_BASE_ADDR+ 4*23) #define CONFIGADCENABLE (DSO_SFR_BASE_ADDR+ 4*24) #define LEDADDR (DSO_SFR_BASE_ADDR+ 4*25) #define KEYADDR0 (DSO_SFR_BASE_ADDR+ 4*26) #define KEYADDR1 (DSO_SFR_BASE_ADDR+ 4*27) #define ANALOGSETTINGSADDR (DSO_SFR_BASE_ADDR+ 4*28) #define LASTADDR (DSO_SFR_BASE_ADDR+ 4*28) #define DSO_REG_SIZE (4*28) /* DEVICEADDR*/ #define WELEC2012 (2012) #define WELEC2014 (2014) #define WELEC2022 (2022) #define WELEC2024 (2024) #define SANDBOXX (1014) #define CURRENTDEVICE (WELEC2022) #define WELECMAXFS 1000000000 /* The first decimator is for the parallel input data (eg. 1Gs @ 125 MHz)*/ /* If this is not used the max fs must be set 10 times higher! */ #define SANDBOXXFS (100000000*10) /*INTERRUPTADDR*/ #define CAPTUREDATA_FINISHED 0 #define CAPTUREDATA_TRIGGERED 1 #define ANALOGSETTINGS_FINISHED 2 #define KEYCHANGE 3 /* SAMPLINGFREQADDR*/ /* write the sampling frequence as decimal number in Hz*/ /* unsupported sampling frequencys are set to 1 GS!*/ /* FILTERENABLEADDR*/ /* Digital Anti Aliasing Filter Enable*/ /* For now on the W2000A*/ #define D1GHZTO100MHZ 0 #define D100MHZTO10MHZ 1 #define D10MHZTO1MHZ 2 #define D1MHZTO100KHZ 3 /* EXTTRIGGERSRCADDR*/ #define FORCETOGGE 0 #define EXTTRIGGER1 1 /* Note that most devices have none only one Exttrigger input!*/ /* Welec W20xx devices have 1*/ /* SandboxX has also only 1*/ #define MAX_EXT_TRIGGER 1 #define EXTTRIGGER2 2 #define EXTTRIGGER3 3 #define EXTTRIGGER4 4 /* ...*/ /* EXTTRIGGERPWMADDR*/ #define EXTTRIGGERPWM0_STARTBIT 0 #define EXTTRIGGERPWM1_STARTBIT 8 #define EXTTRIGGERPWM2_STARTBIT 16 #define EXTTRIGGERPWM3_STARTBIT 24 /* INPUTCH0ADDR INPUTCH0ADDR INPUTCH1ADDR INPUTCH2ADDR*/ /* Signal Selector: The trigger does always have on each device 4 channels with each 8 bits*/ /* For the lower 8 bits from a 16 bit signal use CHxLOWER */ #define CH0UPPER 0 #define CH1UPPER 1 #define CH2UPPER 2 #define CH3UPPER 3 #define CH0LOWER 4 #define CH1LOWER 5 #define CH2LOWER 6 #define CH3LOWER 7 /* TRIGGERONCHADDR*/ /* Trigger on Channel out of the SignalSelector*/ #define INCH0ADDR 0 #define INCH1ADDR 1 #define INCH2ADDR 2 #define INCH3ADDR 3 /* TRIGGERONCEADDR*/ /* start trigger one time, no continious triggering on the hardware (because it's stupid)*/ /* write 1 to start and 0 to stop the trigger*/ /* TRIGGERPREFETCHADDR*/ /* Here you can set the frame start address for the triggered buffer.*/ /* When the trigger is started, it first writes TRIGGERPREFETCHADDR */ /* samplesint o the trigger data RAM before the trigger starts triggering.*/ /* It is simply the data offset of the triggered sample, so post triggering is possible!*/ /* TRIGGERSTORAGEMODEADDR*/ /* Data of the TRIGGER_MEM address range */ /* Data(i)(j) data bits from ((i+1)*8)+j-1 (i*8)+j*/ /* chx(k) is the sample offset */ /* TODO: Correct it + 4*This may change, too!*/ #define TRIGGERSTORAGEMODE4CH 0 /* "00" : 4 CH each 8 KB*/ /* Data(0)(0) = ch0(0), Data(1)(0) = ch1(0), Data(2)(0) = ch2(0), Data(3)(0) = ch3(0)*/ #define TRIGGERSTORAGEMODE2CH 1 /* "01" : 2 CH each 16 KB*/ /*#define 0)(0) = ch0(0), Data(1)(0) = ch1(0), Data(2)(0) = ch0(8192), Data(3)(0) = ch1(8192)*/ #define TRIGGERSTORAGEMODE1CH 3 /* "11" : 1 CH with 32 KB*/ /* Data(0)(0) = ch0(0),#define (1)(0) = ch0(8192),#define (2)(0) = ch0(16384),#define (3)(0) = ch0(24576)*/ /* TRIGGERREADOFFSETADDR*/ /* start and stop address for the trigger */ /* write on it and the trigger sample capture size can be extended easily by software*/ /* but take care about the TRIGGERCURRENTADDR and the sampling speed to avoid race conditions*/ /* TRIGGERTYPEADDR*/ /* Choose the trigger type here */ #define EXTTRIGGER_LH 0 #define EXTTRIGGER_HL 1 #define NORMALTRIGGER_LH 2 #define NORMALTRIGGER_HL 3 #define GLITCHTRIGGER_LH 4 #define GLITCHTRIGGER_HL 5 #define DIGITALTRIGGER_ARRIVE 6 #define DIGITALTRIGGER_LEAVE 7 #define MAX_TRIGGER_TYPES 8 /* TODO add more trigger types*/ /* NORMALTRIGGER is an 8 bit trigger*/ /* The NORMALTRIGGER is a schmitt trigger with an stable counter.*/ /* TRIGGERLOWVALUEADDR is the low reference level.*/ /* TRIGGERLOWTIMEADDR is the minimum stable time for the low level in samples.*/ /* TRIGGERHIGHVALUEADDR is the high reference level.*/ /* TRIGGERHIGHTIMEADDR is the minimum stable time for the high level in samples.*/ /* TRIGGERSTATUSREGISTER */ #define TRIGGERBUSYBIT 0 #define TRIGGERRECORDINGBIT 1 /* TRIGGERCURRENTADDR */ /* read only */ /* CONFIGADCENABLE */ /* for SandboxX and possible other boards which using a seperate microprocessor to * make the analog settings now this is a wake up legacy interrupt to enable the uart * communication */ #define ADC0 0 #define ADC1 1 /* ... */ /* LEDADDR*/ /* switch on the led by setting the corresponding bit to 1*/ /* TODO interrupt */ #define LED_CH0 0 #define LED_CH1 1 #define LED_CH2 2 #define LED_CH3 3 #define LED_MATH 4 #define LED_QUICKMEAS 5 #define LED_CURSORS 6 #define LED_WHEEL 7 #define LED_PULSEWIDTH 8 #define LED_EDGE 9 #define RUN_GREEN 10 #define RUN_RED 11 #define SINGLE_GREEN 12 #define SINGLE_RED 13 /* (read only) */ /* rotary nob counter (3 bit) base adresses */ #define EN_TIME_DIV 16 #define EN_LEFT_RIGHT 20 #define EN_LEVEL 24 #define EN_F 28 /* KEYADDR0 */ /* (read only)*/ #define EN_CH0_UPDN 0 #define EN_CH1_UPDN 4 #define EN_CH2_UPDN 8 #define EN_CH3_UPDN 12 #define EN_CH0_VDIV 16 #define EN_CH1_VDIV 20 #define EN_CH2_VDIV 24 #define EN_CH3_VDIV 28 /* KEYADDR1 */ /* (read only)*/ #define BTN_F1 0 #define BTN_F2 1 #define BTN_F3 2 #define BTN_F4 3 #define BTN_F5 4 #define BTN_F6 5 #define BTN_MATH 6 #define BTN_CH0 7 #define BTN_CH1 8 #define BTN_CH2 9 #define BTN_CH3 10 #define BTN_MAINDEL 11 #define BTN_RUNSTOP 12 #define BTN_SINGLE 13 #define BTN_CURSORS 14 #define BTN_QUICKMEAS 15 #define BTN_ACQUIRE 16 #define BTN_DISPLAY 17 #define BTN_EDGE 18 #define BTN_MODECOUPLING 19 #define BTN_AUTOSCALE 20 #define BTN_SAVERECALL 21 #define BTN_QUICKPRINT 22 #define BTN_UTILITY 23 #define BTN_PULSEWIDTH 24 #define BTN_X1 25 #define BTN_X2 26 /* ANALOGSETTINGSADDR */ #define SET_PWM_OFFSET 31 #define PWM_OFFSET_SIZE 8 #define ANALOGDATA_START 0 #define ENABLEKEYCLOCK 30 /*#define EnableProbeClock 29 -- not implemented #define EnableProbeStrobe 28 -- not implemented*/ #define ANALOGSETTINGSBUSY 27 #define ANC_ADDR_OFFSET 24 #define SET_ANALOG(addr) ((1 << ENABLEKEYCLOCK) | (1 << 27) | ((addr & 0x7) << ANC_ADDR_OFFSET)) #define ANC_CH0 7 /* subset of ANC_CH0 */ #define CH0_K1_ON 0 #define CH0_K1_OFF 1 #define CH0_K2_ON 2 #define CH0_K2_OFF 3 #define CH0_OPA656 4 #define CH0_BW_Limit 5 #define CH0_U14 6 #define CH0_U13 7 #define CH0_DC 8 #define CH1_DC 9 #define CH2_DC 10 #define CH3_DC 11 #define ANC_DAC0 6 /* subset of ANC_DAC0 */ #define DAC_OFFSET 0 #define DAC_CH_OFFSET 16 #define DAC_SETT_OFFSET 17 #define SET_OFFSET_CH0(offset) (SET_ANALOG(ANC_DAC0) | (0x30 << DAC_CH_OFFSET) | (1 << DAC_CH_OFFSET) | (offset & 0xffff)) #define SET_OFFSET_CH1(offset) (SET_ANALOG(ANC_DAC0) | (0x30 << DAC_CH_OFFSET) | (offset & 0xffff)) #define ANC_CH1 5 /* subset of ANC_CH1 */ #define CH1_K1_ON 0 #define CH1_K1_OFF 1 #define CH1_K2_ON 2 #define CH1_K2_OFF 3 #define CH1_OPA656 4 #define CH1_BW_Limit 5 #define CH1_U14 6 #define CH1_U13 7 #define CH0_SRC2_ADDR 8 #define CH1_SRC2_ADDR 10 #define CH2_SRC2_ADDR 12 #define CH3_SRC2_ADDR 14 /* CHX_SRC2_ADDR*/ #define SRC2_NONE 0 #define SRC2_PWM 1 #define SRC2_GND 2 #define SRC2_LOWPASS 3 /*int Uart16550Addr 40;*/ /*int Uart16550Data 41;*/ #endif
