Place & Route TRACE Report
Lattice TRACE Report - Setup, Version ispLever_v72_PROD_Build (44)
Wed Dec 02 16:20:12 2009
Copyright (c) 1991-1994 by NeoCAD Inc. All rights reserved.
Copyright (c) 1995 AT&T Corp.   All rights reserved.
Copyright (c) 1995-2001 Lucent Technologies Inc.  All rights reserved.
Copyright (c) 2001 Agere Systems   All rights reserved.
Copyright (c) 2002-2008 Lattice Semiconductor Corporation,  All rights reserved.
Report Information
Command line:    trce.exe -v 1 -o receiver_dpram.twr receiver_dpram.ncd receiver_dpram.prf
Design file:     receiver_dpram.ncd
Preference file: receiver_dpram.prf
Device,speed:    LCMXO2280C,3
Report level:    verbose report, limited to 1 item per preference
Preference Summary
  • FREQUENCY PORT "RXC" 100.000000 MHz (5 errors)
  • 1011 items scored, 5 timing errors detected. BLOCK ASYNCPATHS BLOCK RESETPATHS -------------------------------------------------------------------------------- ================================================================================ Preference: FREQUENCY PORT "RXC" 100.000000 MHz ; 1011 items scored, 5 timing errors detected. -------------------------------------------------------------------------------- Error: The following path exceeds requirements by 0.143ns Logical Details: Cell type Pin type Cell/ASIC name (clock net +/-) Source: FF Q RECEIVE_CONTROL/wr_adr_i_4 (from RXC_c -) Destination: FF Unknown RAM_A/mem_1_0/RAM1 (to RXC_c +) Delay: 4.517ns (21.8% logic, 78.2% route), 2 logic levels. Constraint Details: 4.517ns physical path delay RECEIVE_CONTROL/SLICE_12 to RAM_A/mem_1_0/SLICE_30 exceeds 5.000ns delay constraint less 0.000ns skew and 0.626ns WREN_SET requirement (totaling 4.374ns) by 0.143ns Physical Path Details: Name Fanout Delay (ns) Site Resource REG_DEL --- 0.613 R11C7C.CLK to R11C7C.Q0 RECEIVE_CONTROL/SLICE_12 (from RXC_c) ROUTE 5 1.518 R11C7C.Q0 to R10C8D.A0 RECEIVE_CONTROL/wr_adr_i_4 CTOF_DEL --- 0.371 R10C8D.A0 to R10C8D.F0 SLICE_55 ROUTE 4 2.015 R10C8D.F0 to R9C8D.LSR RAM_A/dec1_wre7 (to RXC_c) -------- 4.517 (21.8% logic, 78.2% route), 2 logic levels. Clock Skew Details: Source Clock: Delay Connection 4.968ns 55.PADDI to R11C7C.CLK Destination Clock Path: Destination Clock: Delay Connection 4.968ns 55.PADDI to R9C8D.CLK2 Warning: 97.220MHz is the maximum frequency for this preference. Report Summary -------------- ---------------------------------------------------------------------------- Preference | Constraint| Actual|Levels ---------------------------------------------------------------------------- | | | FREQUENCY PORT "RXC" 100.000000 MHz ; | 100.000 MHz| 97.220 MHz| 2 * | | | ---------------------------------------------------------------------------- 1 preference(marked by "*" above) not met. ---------------------------------------------------------------------------- Critical Nets | Loads| Errors| % of total ---------------------------------------------------------------------------- RECEIVE_CONTROL/rd_adr_i_0 | 3| 1| 20.00% | | | RECEIVE_CONTROL/wr_adr_i_4 | 5| 1| 20.00% | | | RECEIVE_CONTROL/wr_adr_i_2 | 3| 1| 20.00% | | | RECEIVE_CONTROL/wr_adr_i_0 | 3| 1| 20.00% | | | RECEIVE_CONTROL/read_ram_i | 21| 1| 20.00% | | | RAM_A/dec1_wre7 | 4| 1| 20.00% | | | RECEIVE_CONTROL_N_185_i | 8| 1| 20.00% | | | wadr_a_i_2 | 8| 1| 20.00% | | | RECEIVE_CONTROL_N_183_i | 8| 1| 20.00% | | | N_13_i | 8| 1| 20.00% | | | ---------------------------------------------------------------------------- Clock Domains Analysis ------------------------ Found 1 clocks: Clock Domain: RXC_c Source: RXC.PAD Loads: 45 Covered under: FREQUENCY PORT "RXC" 100.000000 MHz ; Timing summary: --------------- Timing errors: 5 Score: 688 Cumulative negative slack: 344 Constraints cover 1011 paths, 1 nets, and 460 connections (77.1% coverage) -------------------------------------------------------------------------------- Generated from the file 'C:\ispTOOLS7_2_STRT\work\i2s_ip_25_receiver_v2\receiver_dpram.twr'
