Index: sd_raw_config.h =================================================================== --- sd_raw_config.h (Revision 145) +++ sd_raw_config.h (Revision 146) @@ -74,16 +74,19 @@ /* defines for customisation of sd/mmc port access */ #if defined(__AVR_ATmega8__) || \ defined(__AVR_ATmega48__) || \ + defined(__AVR_ATmega48P__) || \ defined(__AVR_ATmega88__) || \ + defined(__AVR_ATmega88P__) || \ defined(__AVR_ATmega168__) || \ - defined(__AVR_ATmega328__) + defined(__AVR_ATmega168P__) || \ + defined(__AVR_ATmega328P__) #define configure_pin_mosi() DDRB |= (1 << DDB3) #define configure_pin_sck() DDRB |= (1 << DDB5) #define configure_pin_ss() DDRB |= (1 << DDB2) #define configure_pin_miso() DDRB &= ~(1 << DDB4) - #define select_card() PORTB &= ~(1 << PB2) - #define unselect_card() PORTB |= (1 << PB2) + #define select_card() PORTB &= ~(1 << PORTB2) + #define unselect_card() PORTB |= (1 << PORTB2) #elif defined(__AVR_ATmega16__) || \ defined(__AVR_ATmega32__) #define configure_pin_mosi() DDRB |= (1 << DDB5) @@ -91,8 +94,8 @@ #define configure_pin_ss() DDRB |= (1 << DDB4) #define configure_pin_miso() DDRB &= ~(1 << DDB6) - #define select_card() PORTB &= ~(1 << PB4) - #define unselect_card() PORTB |= (1 << PB4) + #define select_card() PORTB &= ~(1 << PORTB4) + #define unselect_card() PORTB |= (1 << PORTB4) #elif defined(__AVR_ATmega64__) || \ defined(__AVR_ATmega128__) || \ defined(__AVR_ATmega169__) @@ -101,8 +104,8 @@ #define configure_pin_ss() DDRB |= (1 << DDB0) #define configure_pin_miso() DDRB &= ~(1 << DDB3) - #define select_card() PORTB &= ~(1 << PB0) - #define unselect_card() PORTB |= (1 << PB0) + #define select_card() PORTB &= ~(1 << PORTB0) + #define unselect_card() PORTB |= (1 << PORTB0) #else #error "no sd/mmc pin mapping available!" #endif @@ -110,8 +113,8 @@ #define configure_pin_available() DDRC &= ~(1 << DDC4) #define configure_pin_locked() DDRC &= ~(1 << DDC5) -#define get_pin_available() ((PINC >> PC4) & 0x01) -#define get_pin_locked() ((PINC >> PC5) & 0x01) +#define get_pin_available() (PINC & (1 << PINC4)) +#define get_pin_locked() (PINC & (1 << PINC5)) #if SD_RAW_SDHC typedef uint64_t offset_t;
