EESchema-LIBRARY Version 2.2 Date: 10/01/2010-19:43:24 # # ATxmega128A1-AU # DEF ATxmega128A1-AU U 0 40 Y Y 1 0 N F0 "U" 0 -100 50 H V C C F1 "ATxmega128A1-AU" 0 100 50 H V C C DRAW S -2600 -2200 2600 2200 0 0 0 N X PA6 (ACA6/ADCA6) 1 -2900 1200 300 R 50 50 1 1 B X PA7 (ACA7/ADCA7) 2 -2900 1100 300 R 50 50 1 1 B X GND 3 -2900 1000 300 R 50 50 1 1 U X AVCC 4 -2900 900 300 R 50 50 1 1 W X PB0 (ACB0/ADCB0/AREFB+) 5 -2900 800 300 R 50 50 1 1 B X PB1 (ACB1/ADCB1/AREF-) 6 -2900 700 300 R 50 50 1 1 B X PB2 (DACB0/ACB2/ADCB2) 7 -2900 600 300 R 50 50 1 1 B X PB3 (DACB1/ACB3/ADCB3) 8 -2900 500 300 R 50 50 1 1 B X PB4 (TMS/ACB4/ADCB4) 9 -2900 400 300 R 50 50 1 1 B X PB5 (TDI/ACB5/ADCB5) 10 -2900 300 300 R 50 50 1 1 B X PB6 (TCK/ACB6/ADCB6) 11 -2900 200 300 R 50 50 1 1 B X PB7 (TDO/ACB7/ADCB7) 12 -2900 100 300 R 50 50 1 1 B X GND 13 -2900 0 300 R 50 50 1 1 U X VCC 14 -2900 -100 300 R 50 50 1 1 W X PC0 (SDA/OC0A/_OC0A) 15 -2900 -200 300 R 50 50 1 1 B X PC1 (SCL/XCK0/OC0B/0C0A) 16 -2900 -300 300 R 50 50 1 1 B X PC2 (RXD0/OC0C/_OC0B) 17 -2900 -400 300 R 50 50 1 1 B X PC3 (TXD0/OC0D/OC0B) 18 -2900 -500 300 R 50 50 1 1 B X PC4 (_SS/OC1A/_OC0C) 19 -2900 -600 300 R 50 50 1 1 B X PC5 (XCJ1/MOSI/OC1B/OS0C) 20 -2900 -700 300 R 50 50 1 1 B X PC6 (RXD1/MISO/_OC0D) 21 -2900 -800 300 R 50 50 1 1 B X PC7 (TXD1/SCK/OC0D) 22 -2900 -900 300 R 50 50 1 1 B X GND 23 -2900 -1000 300 R 50 50 1 1 U X VCC 24 -2900 -1100 300 R 50 50 1 1 W X PD0 (SDA) 25 -2900 -1200 300 R 50 50 1 1 B X PD1 (SCL) 26 -1200 -2500 300 U 50 50 1 1 B X PD2 27 -1100 -2500 300 U 50 50 1 1 B X PD3 28 -1000 -2500 300 U 50 50 1 1 B X PD4 29 -900 -2500 300 U 50 50 1 1 B X PD5 30 -800 -2500 300 U 50 50 1 1 B X PD6 31 -700 -2500 300 U 50 50 1 1 B X PD7 32 -600 -2500 300 U 50 50 1 1 B X GND 33 -500 -2500 300 U 50 50 1 1 U X VCC 34 -400 -2500 300 U 50 50 1 1 W X PE0 (SDA) 35 -300 -2500 300 U 50 50 1 1 B X PE1 (SCL) 36 -200 -2500 300 U 50 50 1 1 B X PE2 37 -100 -2500 300 U 50 50 1 1 B X PE3 38 0 -2500 300 U 50 50 1 1 B X PE4 39 100 -2500 300 U 50 50 1 1 B X PE5 40 200 -2500 300 U 50 50 1 1 B X PE6 41 300 -2500 300 U 50 50 1 1 B X PE7 42 400 -2500 300 U 50 50 1 1 B X GND 43 500 -2500 300 U 50 50 1 1 B X VCC 44 600 -2500 300 U 50 50 1 1 B X PF0 (SDA) 45 700 -2500 300 U 50 50 1 1 B X PF1 (SCL) 46 800 -2500 300 U 50 50 1 1 B X PF2 47 900 -2500 300 U 50 50 1 1 B X PF3 48 1000 -2500 300 U 50 50 1 1 B X PF4 49 1100 -2500 300 U 50 50 1 1 B X PF5 50 1200 -2500 300 U 50 50 1 1 B X PF6 51 2900 -1200 300 L 50 50 1 1 B X PF7 52 2900 -1100 300 L 50 50 1 1 B X GND 53 2900 -1000 300 L 50 50 1 1 U X VCC 54 2900 -900 300 L 50 50 1 1 W X PH0 (EBI) 55 2900 -800 300 L 50 50 1 1 B X PH1 (EBI) 56 2900 -700 300 L 50 50 1 1 B X PH2 (EBI) 57 2900 -600 300 L 50 50 1 1 B X PH3 (EBI) 58 2900 -500 300 L 50 50 1 1 B X PH4 (EBI) 59 2900 -400 300 L 50 50 1 1 B X PH5 (EBI) 60 2900 -300 300 L 50 50 1 1 B X PH6 (EBI) 61 2900 -200 300 L 50 50 1 1 B X PH7 (EBI) 62 2900 -100 300 L 50 50 1 1 B X GND 63 2900 0 300 L 50 50 1 1 U X VCC 64 2900 100 300 L 50 50 1 1 W X PJ0 (EBI) 65 2900 200 300 L 50 50 1 1 B X PJ1 (EBI) 66 2900 300 300 L 50 50 1 1 B X PJ2 (EBI) 67 2900 400 300 L 50 50 1 1 B X PJ3 (EBI) 68 2900 500 300 L 50 50 1 1 B X PJ4 (EBI) 69 2900 600 300 L 50 50 1 1 B X PJ5 (EBI) 70 2900 700 300 L 50 50 1 1 B X PJ6 (EBI) 71 2900 800 300 L 50 50 1 1 B X PJ7 (EBI) 72 2900 900 300 L 50 50 1 1 B X GND 73 2900 1000 300 L 50 50 1 1 U X VCC 74 2900 1100 300 L 50 50 1 1 W X PK0 (EBI) 75 2900 1200 300 L 50 50 1 1 B X PK1 (EBI) 76 1200 2500 300 D 50 50 1 1 B X PK2 (EBI) 77 1100 2500 300 D 50 50 1 1 B X PK3 (EBI) 78 1000 2500 300 D 50 50 1 1 B X PK4 (EBI) 79 900 2500 300 D 50 50 1 1 B X PK5 (EBI) 80 800 2500 300 D 50 50 1 1 B X PK6 (EBI) 81 700 2500 300 D 50 50 1 1 B X PK7 (EBI) 82 600 2500 300 D 50 50 1 1 B X VCC 83 500 2500 300 D 50 50 1 1 W X GND 84 400 2500 300 D 50 50 1 1 U X PQ0 (TOSC1) 85 300 2500 300 D 50 50 1 1 B X PQ1 (TOSC2) 86 200 2500 300 D 50 50 1 1 B X PQ2 87 100 2500 300 D 50 50 1 1 B X PQ3 88 0 2500 300 D 50 50 1 1 B X PROG/TEST (D2W_DATA) 89 -100 2500 300 D 50 50 1 1 B X RESET/PDI (D2W_CLK) 90 -200 2500 300 D 50 50 1 1 B X PR0 (XTAL2) 91 -300 2500 300 D 50 50 1 1 B X PR1 (XTAL1) 92 -400 2500 300 D 50 50 1 1 B X GND 93 -500 2500 300 D 50 50 1 1 U X AVCC 94 -600 2500 300 D 50 50 1 1 W X PA0 (ADCA0/ACA0/AREFA+) 95 -700 2500 300 D 50 50 1 1 B X PA1 (ADCA1/ACA1/AREFA-) 96 -800 2500 300 D 50 50 1 1 B X PA2 (ADCA2/ACA2/DACA0) 97 -900 2500 300 D 50 50 1 1 B X PA3 (ADCA3/ACA3/DACA1) 98 -1000 2500 300 D 50 50 1 1 B X PA4 (ADCA4/ACA4) 99 -1100 2500 300 D 50 50 1 1 B X PA5 (ADCA5/ACA5) 100 -1200 2500 300 D 50 50 1 1 B ENDDRAW ENDDEF # #End Library
