/** * @file pal_board.c * * @brief PAL board specific functionality * * This file implements PAL board specific functionality. * * $Id: pal_board.c 17186 2009-08-14 11:53:24Z sschneid $ * * @author Atmel Corporation: http://www.atmel.com * @author Support email: avr@atmel.com */ /* * Copyright (c) 2009, Atmel Corporation All rights reserved. * * Licensed under Atmel's Limited License Agreement --> EULA.txt */ /* === Includes ============================================================ */ #include #include #include "pal.h" #include "pal_boardtypes.h" #include "pal_config.h" /* * 'sys_time' is a entity of timer module which is given to other modules * through the interface file below. 'sys_time' is required to obtain the * frame timestamp */ #include "pal_timer.h" #if (BOARD_TYPE == RCB_5_3_PLAIN) /* === Macros ============================================================== */ /* command bytes */ #define AT25010_CMD_WREN 0x06 /* Set Write Enable Latch */ #define AT25010_CMD_WRDI 0x04 /* Reset Write Enable Latch */ #define AT25010_CMD_RDSR 0x05 /* Read Status Register */ #define AT25010_CMD_WRSR 0x01 /* Write Status Register */ #define AT25010_CMD_READ 0x03 /* Read Data from Memory Array */ #define AT25010_CMD_WRITE 0x02 /* Write Data to Memory Array */ /* status register bits */ #define AT25010_STATUS_NRDY 0x01 /* not ready */ #define AT25010_STATUS_WE 0x02 /* write enabled */ #define AT25010_BP0 0x04 /* block-protection bit 0 */ #define AT25010_BP1 0x08 /* block-protection bit 1 */ /* Values for Feature Byte 1: RF frontend features */ /** RF connector enabled */ #define CFG_FEATURE1_RFCONN 0x01 /** On-board antenna enabled */ #define CFG_FEATURE1_ANTENNA 0x02 /** External antenna diversity */ #define CFG_FEATURE1_EXDIV 0x04 /** Reserved */ #define CFG_FEATURE1_RESV3 0x08 /** Transceiver-controlled PA present */ #define CFG_FEATURE1_PA 0x10 /** Transceiver-controlled LNA present */ #define CFG_FEATURE1_LNA 0x20 /** Reserved */ #define CFG_FEATURE1_RESV6 0x40 /** Reserved */ #define CFG_FEATURE1_RESV7 0x80 /** Base address (in EEPROM) of configuration data record */ #define CFG_BASE_ADDRESS 64 /** Maximal length of textual board name */ #define CFG_NAMELEN (32 - sizeof(uint16_t)) /** Total space reserved for binary configuration data */ #define CFG_BINARYLEN 32 #ifdef EXTERN_EEPROM_AVAILABLE #if defined(__GNUC__) #include #define CRC_CCITT_UPDATE(crc, data) _crc_ccitt_update(crc, data) #endif /* defined(__GNUC__) */ #if defined(__ICCAVR__) #define CRC_CCITT_UPDATE(crc, data) crc_ccitt_update(crc, data) /* Internal helper function for CRC_CCITT_UPDATE. */ uint16_t crc_ccitt_update(uint16_t crc, uint8_t data); #endif /* __ICCAVR__ */ #endif /* EXTERN_EEPROM_AVAILABLE */ /* === Types =============================================================== */ /** * Encoding of the board family in the board_family configuration * record member. */ enum boardfamilycode { CFG_BFAMILY_RADIO_EXTENDER, /**< Radio Extender boards */ CFG_BFAMILY_RCB /**< Radio Controller boards */ } SHORTENUM; /** * Structure of the configuration record EEPROM data. These data * reside at offset CFG_BASE_ADDR, and allocate the upper address * space of the EEPROM. The lower address space is available for * further extensions, and/or customer use (the upper part can be * software write-protected on demand). * * The record is divided into 32 bytes of structured binary * configuration data, followed by up to 30 bytes of textual * configuration data (terminated with \0), and terminated by a CRC-16 * checksum. The CRC algorithm used is the same CCITT algorithm that * is also used to protect IEEE 802.15.4 frames. * * All multibyte integer values are stored in little-endia byte order. */ struct cfg_eeprom_data { union { /** Raw access to binary configuration data. */ uint8_t raw_binary[CFG_BINARYLEN]; /* Structured access to binary configuration data. */ struct { /** factory-supplied EUI-64 address */ uint64_t mac_address; /** factory-supplied board serial number */ uint64_t serial_number; /** board ID: family */ enum boardfamilycode board_family; /** board ID: major, minor, revision */ uint8_t board_id[3]; /** feature byte 1: RF frontend features */ uint8_t feature1; /** 16 MHz crystal oscillator calibration value */ uint8_t cal_16mhz; /** RC oscillator calibration value, Vcc = 3.6 V */ uint8_t cal_rc_36; /** RC oscillator calibration value, Vcc = 2.0 V */ uint8_t cal_rc_20; /** antenna gain, 1/10 dB */ int8_t antenna_gain; /* 7 bytes reserved, leave as 0xFF */ } struct_binary; } binary_data; /** Textual board name, ASCIZ string */ char board_name[CFG_NAMELEN]; /** CRC-16 over binary_data and board_name[] */ uint16_t crc; }; /* === Globals ============================================================= */ /* === Prototypes ========================================================== */ #ifdef EXTERN_EEPROM_AVAILABLE static uint8_t at25010_read_byte(uint8_t addr); #endif /* === Implementation ======================================================= */ /** * @brief Provides timestamp of the last received frame * * This function provides the timestamp (in microseconds) * of the last received frame. * * @param[out] Timestamp in microseconds */ void pal_trx_read_timestamp(uint32_t *timestamp) { /* * Everytime a transceiver interrupt is triggred, input capture register of * the AVR is latched. The 'sys_time' is concatenated to the ICR to * generate the time stamp of the received frame. * 'sys_time' 'ICR' * ---------|--------- => 32 bit timestamp * 16 bits 16 bits */ *timestamp = (uint32_t)sys_time << (uint32_t)16; *timestamp |= (uint32_t)TIME_STAMP_REGISTER; } /** * @brief Calibrates the internal RC oscillator * * This function calibrates the internal RC oscillator, based * on the external 32.768 Hz crystal clock source. * * @return True if calibration is successful, false otherwise. */ bool pal_calibrate_rc_osc(void) { /* * Use the 32.768 kHz external crystal oscillator as reference clock source. */ /* * This is the actual value of the timer to be calibrated * after each calibration run. */ uint16_t curr_value_cal_timer = 0; /* This is the best OSCCAL value. */ uint8_t best_value_osccal = 0; /* * This is the smallest difference between the target value and the actual value * of the timer the timer to be calibrated. */ uint16_t best_dif_timers = ~(0); /* * This is the difference between between the target value and the actual value * of the timer the timer to be calibrated of the current calibration attempt. */ uint16_t curr_dif_timers = 0; uint16_t counter; uint8_t tccr2b; uint8_t tccr1b; uint8_t tccr1a; bool cal_result = true; ENTER_CRITICAL_REGION(); /* * Save current values of timer status. */ tccr2b = TCCR2B; tccr1b = TCCR1B; tccr1a = TCCR1A; /* * Stop timers 1 and 2. * Set timer 1 to normal mode (no CTC, no PWM, just count). */ TCCR2B = 0; TCCR1B = 0; TCCR1A = 0; for (counter = 0; counter < MAX_CAL_LOOP_CNT; counter++) { /* * Delete pending timer 1 and 2 interrupts, and clear the * counters. */ TIFR1 = 0xFF; TIFR2 = 0xFF; TCNT2 = 0; TCNT1 = 0; /* Kick timer1 with internal clock source and no prescaler */ TCCR1B = (1 << CS10); /* * Kick timer2 with external 32.768 Hz asynchronous clock * and no prescaler */ TCCR2B = (1 << CS20); ASSR = (1 << AS2); /* * Wait for timer 2 to overflow. */ while (!(TIFR2 & (1 << TOV2))) { /* Wait */ } /* * Stop timer 1. Now, TCNT1 contains the number of CPU cycles * counted during F_CPU / (32 * 256) cycles. */ TCCR1B = 0; TCCR2B = 0; curr_value_cal_timer = TCNT1; /* * Check if reference timer is running at all, * i.e. the reference clock is available. */ if (0 == curr_value_cal_timer) { /* Reference timer is not running, return error. */ cal_result = false; break; } if (curr_value_cal_timer <= (uint16_t)(TARGETVAL_CALIBRATION)) { curr_dif_timers = (uint16_t)(TARGETVAL_CALIBRATION) - curr_value_cal_timer; } else { curr_dif_timers = curr_value_cal_timer - (uint16_t)(TARGETVAL_CALIBRATION); } if (curr_dif_timers < best_dif_timers) { best_dif_timers = curr_dif_timers; best_value_osccal = OSCCAL; } if (curr_value_cal_timer <= (uint16_t)(TARGETVAL_CALIBRATION)) { /* Too slow, increase speed */ OSCCAL++; } else { /* Too fast, lower speed */ OSCCAL--; } } TCCR2B = tccr2b; TCCR1B = tccr1b; TCCR1A = tccr1a; LEAVE_CRITICAL_REGION(); OSCCAL = best_value_osccal; return (cal_result); } /** * @brief Initializes the GPIO pins * * This function is used to initialize the port pins used to connect * the microcontroller to transceiver. */ void gpio_init(void) { /* The following pins are output pins. */ TRX_PORT1_DDR |= _BV(SEL); TRX_PORT1_DDR |= _BV(SCK); TRX_PORT1_DDR |= _BV(RST); TRX_PORT1_DDR |= _BV(MOSI); TRX_PORT1_DDR |= _BV(SLP_TR); /* The following pins are input pins. */ TRX_PORT1_DDR &= ~_BV(MISO); } /* * This function is called by timer_init() to perform the non-generic portion * of the initialization of the timer module. */ void timer_init_non_generic(void) { /* Select proper clock as timer clock source when radio is sleeping */ TIMER_SRC_DURING_TRX_SLEEP(); /* * Clear pending output compare matches of all the OCR1A, OCR1B and * OCR1C. */ TIFR1 = _BV(OCF1A); TIFR1 = _BV(OCF1B); TIFR1 = _BV(OCF1C); /* Enable the timer overflow interrupt */ TIMSK1 |= _BV(TOIE1); } /** * @brief Read one byte from an AT25010 EEPROM. * * Due to the connection between MCU, TRX and EEPROM, an EEPROM access * causes a transceiver reset. Therefore an entire transceiver configuration * is necessary after EEPROM access. * * @param addr Byte address to read from * * @return Data read from EEPROM */ #ifdef EXTERN_EEPROM_AVAILABLE static uint8_t at25010_read_byte(uint8_t addr) { uint8_t read_value; ENTER_TRX_REGION(); RST_LOW(); SS_LOW(); PAL_WAIT_1_US(); SPDR = AT25010_CMD_READ; SPI_WAIT(); SPDR = addr & 0x7F; // mask out Bit 7 for 128x8 EEPROM SPI_WAIT(); SPDR = 0; // dummy value to start SPI transfer SPI_WAIT(); read_value = SPDR; SS_HIGH(); RST_HIGH(); LEAVE_TRX_REGION(); return read_value; } #endif /** * @brief Get data from external EEPROM * * param[in] start_offset Start offset within EEPROM * param[in] length Number of bytes to read from EEPROM * param[out] value Data from persistence storage * * @return MAC_SUCCESS if external EERPOM is available and contains valid contents * FAILURE else */ #ifdef EXTERN_EEPROM_AVAILABLE retval_t extern_eeprom_get(uint8_t start_offset, uint8_t length, void *value) { uint8_t i; struct cfg_eeprom_data cfg; uint8_t *up; uint16_t crc; uint8_t *data_ptr; uint8_t *value_ptr; // Read data from external EEPROM. for (i = 0, up = (uint8_t *)&cfg; i < sizeof(cfg); i++, up++) { *up = at25010_read_byte(i); } // Calcute CRC to validate data correctness for (i = 0, crc = 0, up = (uint8_t *)&cfg; i < sizeof(cfg); i++, up++) { crc = CRC_CCITT_UPDATE(crc, *up); } if (crc != 0) { return FAILURE; } /* Copy data from local cfg structure variable to target storage location */ data_ptr = (uint8_t *)&cfg; data_ptr = &data_ptr[start_offset]; value_ptr = (uint8_t *)value; for (i = 0; i < length; i++) { *value_ptr = *data_ptr; value_ptr++; data_ptr++; } return MAC_SUCCESS; } #endif #if defined(__ICCAVR__) || defined(DOXYGEN) /* This function is available in WINAVR library */ /** * @brief Computes the CCITT-CRC16 on a byte by byte basis * * This function computes the CCITT-CRC16 on a byte by byte basis. * It updates the CRC for transmitted and received data using the CCITT 16bit * algorithm (X^16 + X^12 + X^5 + 1). * * @param crc Current crc value * @param data Next byte that should be included into the CRC16 * * @return updated CRC16 */ #ifdef EXTERN_EEPROM_AVAILABLE uint16_t crc_ccitt_update(uint16_t crc, uint8_t data) { data ^= crc & 0xFF; data ^= data << 4; return ((((uint16_t)data << 8) | ((crc & 0xFF00) >> 8)) ^ \ (uint8_t)(data >> 4) ^ \ ((uint16_t)data << 3)); } #endif /* EXTERN_EEPROM_AVAILABLE */ #endif /* __ICCAVR__ || defined(DOXYGEN) */ /** * @brief Initialize LEDs */ void pal_led_init(void) { LED_PORT &= ~(1 << LED_PIN_0); LED_PORT &= ~(1 << LED_PIN_1); LED_PORT &= ~(1 << LED_PIN_2); LED_PORT_DIR |= (1 << LED_PIN_0); LED_PORT_DIR |= (1 << LED_PIN_1); LED_PORT_DIR |= (1 << LED_PIN_2); } /** * @brief Control LED status * * param[in] led_no LED ID * param[in] led_setting LED_ON, LED_OFF, LED_TOGGLE */ void pal_led(led_id_t led_no, led_action_t led_setting) { uint8_t pin; switch (led_no) { case LED_0: pin = LED_PIN_0; break; case LED_1: pin = LED_PIN_1; break; case LED_2: pin = LED_PIN_2; break; default: pin = LED_PIN_0; break; } switch (led_setting) { case LED_ON: LED_PORT &= ~(1 << pin); break; case LED_OFF: LED_PORT |= (1 << pin); break; case LED_TOGGLE: if ((LED_PORT & (1 << pin)) == 0x00) { LED_PORT |= (1 << pin); } else { LED_PORT &= ~(1 << pin); } break; default: /* do nothing */ break; } } /** * @brief Initialize the button */ void pal_button_init(void) { BUTTON_PORT |= (1 << BUTTON_PIN_0); BUTTON_PORT_DIR &= ~(1 << BUTTON_PIN_0); } /** * @brief Read button * * param button_no Button ID */ button_state_t pal_button_read(button_id_t button_no) { uint8_t pin; switch (button_no) { case BUTTON_0: pin = BUTTON_PIN_0; break; default: pin = BUTTON_PIN_0; break; } if ((BUTTON_INPUT_PINS & (1 << pin)) == 0x00) { return BUTTON_PRESSED; } else { return BUTTON_OFF; } } #endif /* RCB_5_3_PLAIN */ /* EOF */
