library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity TIMING is port ( RW_INIT : out std_logic ); -- R/w Ausgang end TIMING; ------------------------------------------------------------------------------------------------------------------------------------ architecture VERHALTEN of TIMING is type ZUSTAENDE is (Y0,Y1,Y2); signal ZUSTAND, FOLGE_Y : ZUSTAENDE; signal CLK_1_MHZ, INIT_BUTTON : std_logic; signal ZW_ZUSTAND : boolean; ------------------------------------------------------------------------------------------------------------------------------------ begin TIMING_SPEICHER: process (INIT_BUTTON) begin if INIT_BUTTON = '0' then ZUSTAND <= Y0; --INIT_BUTTON -> nicht gedrueckt elsif falling_edge (INIT_BUTTON) then ZUSTAND <= Y1; if falling_edge (CLK_1_MHZ) then ZW_ZUSTAND <= true; ZUSTAND <= FOLGE_Y; end if; end if; end process TIMING_SPEICHER; RW_REGISTER: process (ZUSTAND) begin case ZUSTAND is when Y0 => RW_INIT <= '0'; when Y1 => if ZW_ZUSTAND then --Fallende Flanke INIT_BUTTON FOLGE_Y <= Y2; end if; when Y2 => RW_INIT <= '1'; ZW_ZUSTAND <= false; end case; end process RW_REGISTER; --------------------------------------------------------Testbench--------------------------------------------------------------------------- TAKTGEN: process begin CLK_1_MHZ <= '1'; wait for 500 ns; CLK_1_MHZ <= '0'; wait for 500 ns; end process TAKTGEN; SET_INIT_BUTTON : process begin INIT_BUTTON <= '0'; wait for 10 us; INIT_BUTTON <= '1'; wait for 10 us; INIT_BUTTON <= '0'; wait for 10 us; end process SET_INIT_BUTTON; ------------------------------------------Ende der Testbench-------------------------------- end VERHALTEN;
