;/* LPC2300.S: Startup file for Philips LPC2300/LPC2400 device series */
;/* <<< Use Configuration Wizard in Context Menu >>> */
;/* This file is part of the uVision/ARM development tools. */
;/* Copyright (c) 2007 Keil - An ARM Company. All rights reserved. */
;/* This software may only be used under the terms of a valid, current, */
;/* end user licence from KEIL for a compatible version of KEIL software */
;/* development tools. Nothing else gives you the right to use this software. */
; * The LPC2300.S code is executed after CPU Reset. This file may be
; * translated with the following SET symbols. In uVision these SET
; * symbols are entered under Options - ASM - Define.
; * REMAP: when set the startup code initializes the register MEMMAP
; * which overwrites the settings of the CPU configuration pins. The
; * startup and interrupt vectors are remapped from:
; * 0x00000000 default setting (not remapped)
; * 0x40000000 when RAM_MODE is used
; * RAM_MODE: when set the device is configured for code execution
; * from on-chip RAM starting at address 0x40000000.
; Standard definitions of Mode bits and Interrupt (I & F) flags in PSRs
Mode_USR EQU 0x10
Mode_FIQ EQU 0x11
Mode_IRQ EQU 0x12
Mode_SVC EQU 0x13
Mode_ABT EQU 0x17
Mode_UND EQU 0x1B
Mode_SYS EQU 0x1F
I_Bit EQU 0x80 ; when I bit is set, IRQ is disabled
F_Bit EQU 0x40 ; when F bit is set, FIQ is disabled
;// Stack Configuration (Stack Sizes in Bytes)
;// Undefined Mode <0x0-0xFFFFFFFF:8>
;// Supervisor Mode <0x0-0xFFFFFFFF:8>
;// Abort Mode <0x0-0xFFFFFFFF:8>
;// Fast Interrupt Mode <0x0-0xFFFFFFFF:8>
;// Interrupt Mode <0x0-0xFFFFFFFF:8>
;// User/System Mode <0x0-0xFFFFFFFF:8>
UND_Stack_Size EQU 0x00000000
SVC_Stack_Size EQU 0x00000080
ABT_Stack_Size EQU 0x00000000
FIQ_Stack_Size EQU 0x00000000
IRQ_Stack_Size EQU 0x00000400
USR_Stack_Size EQU 0x00001540
ISR_Stack_Size EQU (UND_Stack_Size + SVC_Stack_Size + ABT_Stack_Size + \
FIQ_Stack_Size + IRQ_Stack_Size)
AREA STACK, NOINIT, READWRITE, ALIGN=3
Stack_Mem SPACE USR_Stack_Size
__initial_sp SPACE ISR_Stack_Size
Stack_Top
;// Heap Configuration
;// Heap Size (in Bytes) <0x0-0xFFFFFFFF>
Heap_Size EQU 0x00000600
AREA HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
Heap_Mem SPACE Heap_Size
__heap_limit
; System Control Block (SCB) Module Definitions
SCB_BASE EQU 0xE01FC000 ; SCB Base Address
PLLCON_OFS EQU 0x80 ; PLL Control Offset
PLLCFG_OFS EQU 0x84 ; PLL Configuration Offset
PLLSTAT_OFS EQU 0x88 ; PLL Status Offset
PLLFEED_OFS EQU 0x8C ; PLL Feed Offset
CCLKCFG_OFS EQU 0x104 ; CPU Clock Divider Reg Offset
USBCLKCFG_OFS EQU 0x108 ; USB Clock Divider Reg Offset
CLKSRCSEL_OFS EQU 0x10C ; Clock Source Select Reg Offset
SCS_OFS EQU 0x1A0 ; System Control and Status Reg Offset
PCLKSEL0_OFS EQU 0x1A8 ; Peripheral Clock Select Reg 0 Offset
PCLKSEL1_OFS EQU 0x1AC ; Peripheral Clock Select Reg 1 Offset
; Constants
OSCRANGE EQU (1<<4) ; Oscillator Range Select
OSCEN EQU (1<<5) ; Main oscillator Enable
OSCSTAT EQU (1<<6) ; Main Oscillator Status
PLLCON_PLLE EQU (1<<0) ; PLL Enable
PLLCON_PLLC EQU (1<<1) ; PLL Connect
PLLSTAT_M EQU (0x7FFF<<0) ; PLL M Value
PLLSTAT_N EQU (0xFF<<16) ; PLL N Value
PLLSTAT_PLOCK EQU (1<<26) ; PLL Lock Status
;// Clock Setup
;// System Controls and Status Register (SCS)
;// OSCRANGE: Main Oscillator Range Select
;// <0=> 1 MHz to 20 MHz
;// <1=> 15 MHz to 24 MHz
;// OSCEN: Main Oscillator Enable
;// Clock Source Select Register (CLKSRCSEL)
;// CLKSRC: PLL Clock Source Selection
;// <0=> Internal RC oscillator
;// <1=> Main oscillator
;// <1=> RTC oscillator
;// PLL Configuration Register (PLLCFG)
;// PLL_clk = (2* M * PLL_clk_src) / N
;// MSEL: PLL Multiplier Selection
;// <1-32768><#-1>
;// M Value
;// NSEL: PLL Divider Selection
;// <1-256><#-1>
;// N Value
;// CPU Clock Configuration Register (CCLKCFG)
;// CCLKSEL: Divide Value for CPU Clock from PLL
;// <1-256><#-1>
;// USB Clock Configuration Register (USBCLKCFG)
;// USBSEL: Divide Value for USB Clock from PLL
;// <1-16><#-1>
;// Peripheral Clock Selection Register 0 (PCLKSEL0)
;// PCLK_WDT: Peripheral Clock Selection for WDT
;// <0=> Pclk = Cclk / 4
;// <1=> Pclk = Cclk
;// <2=> Pclk = Cclk / 2
;// <3=> Pclk = Hclk / 8
;// PCLK_TIMER0: Peripheral Clock Selection for TIMER0
;// PCLK_TIMER1: Peripheral Clock Selection for TIMER1
;// PCLK_UART0: Peripheral Clock Selection for UART0
;// PCLK_UART1: Peripheral Clock Selection for UART1
;// PCLK_PWM0: Peripheral Clock Selection for PWM0
;// PCLK_PWM1: Peripheral Clock Selection for PWM1
;// PCLK_I2C0: Peripheral Clock Selection for I2C0
;// PCLK_SPI: Peripheral Clock Selection for SPI
;// PCLK_RTC: Peripheral Clock Selection for RTC
;// PCLK_SSP1: Peripheral Clock Selection for SSP1
;// PCLK_DAC: Peripheral Clock Selection for DAC
;// PCLK_ADC: Peripheral Clock Selection for ADC
;// PCLK_CAN1: Peripheral Clock Selection for CAN1
;// <3=> Pclk = Hclk / 6
;// PCLK_CAN2: Peripheral Clock Selection for CAN2
;// PCLK_ACF: Peripheral Clock Selection for ACF
;// Peripheral Clock Selection Register 1 (PCLKSEL1)
;// PCLK_BAT_RAM: Peripheral Clock Selection for the Battery Supported RAM
;// PCLK_GPIO: Peripheral Clock Selection for GPIOs
;// PCLK_PCB: Peripheral Clock Selection for Pin Connect Block
;// PCLK_I2C1: Peripheral Clock Selection for I2C1
;// PCLK_SSP0: Peripheral Clock Selection for SSP0
;// PCLK_TIMER2: Peripheral Clock Selection for TIMER2
;// PCLK_TIMER3: Peripheral Clock Selection for TIMER3
;// PCLK_UART2: Peripheral Clock Selection for UART2
;// PCLK_UART3: Peripheral Clock Selection for UART3
;// PCLK_I2C2: Peripheral Clock Selection for I2C2
;// PCLK_I2S: Peripheral Clock Selection for I2S
;// PCLK_MCI: Peripheral Clock Selection for MCI
;// PCLK_SYSCON: Peripheral Clock Selection for System Control Block
CLOCK_SETUP EQU 1
SCS_Val EQU 0x00000020
CLKSRCSEL_Val EQU 0x00000001
PLLCFG_Val EQU 0x0000000B
CCLKCFG_Val EQU 0x00000004
USBCLKCFG_Val EQU 0x00000005
PCLKSEL0_Val EQU 0x00000000
PCLKSEL1_Val EQU 0x00000000
; Memory Accelerator Module (MAM) definitions
MAM_BASE EQU 0xE01FC000 ; MAM Base Address
MAMCR_OFS EQU 0x00 ; MAM Control Offset
MAMTIM_OFS EQU 0x04 ; MAM Timing Offset
;// MAM Setup
;// MAM Control
;// <0=> Disabled
;// <1=> Partially Enabled
;// <2=> Fully Enabled
;// Mode
;// MAM Timing
;// <0=> Reserved <1=> 1 <2=> 2 <3=> 3
;// <4=> 4 <5=> 5 <6=> 6 <7=> 7
;// Fetch Cycles
MAM_SETUP EQU 1
MAMCR_Val EQU 0x00000000
MAMTIM_Val EQU 0x00000004
; Area Definition and Entry Point
; Startup Code must be linked first at Address at which it expects to run.
AREA RESET, CODE, READONLY
ARM
; Exception Vectors
; Mapped to Address 0.
; Absolute addressing mode must be used.
; Dummy Handlers are implemented as infinite loops which can be modified.
Vectors LDR PC, Reset_Addr
LDR PC, Undef_Addr
LDR PC, SWI_Addr
LDR PC, PAbt_Addr
LDR PC, DAbt_Addr
NOP ; Reserved Vector
LDR PC, IRQ_Addr
; LDR PC, [PC, #-0x0120] ; Vector from VicVectAddr
; LDR PC, =0xFFFFFF00
LDR PC, FIQ_Addr
Reset_Addr DCD Reset_Handler
Undef_Addr DCD Undef_Handler
SWI_Addr DCD SWI_Handler
PAbt_Addr DCD PAbt_Handler
DAbt_Addr DCD DAbt_Handler
DCD 0 ; Reserved Address
IRQ_Addr DCD IRQ_Handler
FIQ_Addr DCD FIQ_Handler
Vic_Addr DCD 0xFFFFFF00
Undef_Handler B Undef_Handler
SWI_Handler B SWI_Handler
PAbt_Handler B PAbt_Handler
DAbt_Handler B DAbt_Handler
;IRQ_Handler B IRQ_Handler
IRQ_Handler LDR R5, Vic_Addr
LDR PC, [R5]
FIQ_Handler B FIQ_Handler
; Reset Handler
EXPORT Reset_Handler
Reset_Handler
; Setup Clock
IF CLOCK_SETUP != 0
LDR R0, =SCB_BASE
MOV R1, #0xAA
MOV R2, #0x55
; Configure and Enable PLL
LDR R3, =SCS_Val ; Enable main oscillator
STR R3, [R0, #SCS_OFS]
IF (SCS_Val:AND:OSCEN) != 0
OSC_Loop LDR R3, [R0, #SCS_OFS] ; Wait for main osc stabilize
ANDS R3, R3, #OSCSTAT
BEQ OSC_Loop
ENDIF
LDR R3, =CLKSRCSEL_Val ; Select PLL source clock
STR R3, [R0, #CLKSRCSEL_OFS]
LDR R3, =PLLCFG_Val
STR R3, [R0, #PLLCFG_OFS]
STR R1, [R0, #PLLFEED_OFS]
STR R2, [R0, #PLLFEED_OFS]
MOV R3, #PLLCON_PLLE
STR R3, [R0, #PLLCON_OFS]
; Wait until PLL Locked
PLL_Loop LDR R3, [R0, #PLLSTAT_OFS]
ANDS R3, R3, #PLLSTAT_PLOCK
BEQ PLL_Loop
M_N_Lock LDR R3, [R0, #PLLSTAT_OFS]
LDR R4, =(PLLSTAT_M:OR:PLLSTAT_N)
AND R3, R3, R4
LDR R4, =PLLCFG_Val
EORS R3, R3, R4
BNE M_N_Lock
; Setup CPU clock divider
MOV R3, #CCLKCFG_Val
STR R3, [R0, #CCLKCFG_OFS]
; Setup USB clock divider
LDR R3, =USBCLKCFG_Val
STR R3, [R0, #USBCLKCFG_OFS]
; Setup Peripheral Clock
LDR R3, =PCLKSEL0_Val
STR R3, [R0, #PCLKSEL0_OFS]
LDR R3, =PCLKSEL1_Val
STR R3, [R0, #PCLKSEL1_OFS]
; Switch to PLL Clock
MOV R3, #(PLLCON_PLLE:OR:PLLCON_PLLC)
ENDIF ; CLOCK_SETUP
; Setup MAM
IF MAM_SETUP != 0
LDR R0, =MAM_BASE
MOV R1, #MAMTIM_Val
STR R1, [R0, #MAMTIM_OFS]
MOV R1, #MAMCR_Val
STR R1, [R0, #MAMCR_OFS]
ENDIF ; MAM_SETUP
; Memory Mapping (when Interrupt Vectors are in RAM)
MEMMAP EQU 0xE01FC040 ; Memory Mapping Control
IF :DEF:REMAP
LDR R0, =MEMMAP
IF :DEF:RAM_MODE
MOV R1, #2
ELSE
MOV R1, #1
ENDIF
STR R1, [R0]
ENDIF
; Initialise Interrupt System
; Setup Stack for each mode
;SWI_RAM_ADDR EQU 0x40000028
; LDR R8, =SWI_RAM_ADDR
; LDR R7, [R8] ;Save SWI_Handler address
; LDR R9, =Stack_Set_Addr
; STR R9, [R8] ;Replace SWI_Handler (for next command) with Stack_Set_Addr
; SWI 11 ;Just jump to Stack_Set_Addr in Supervisor mode
;Stack_Set_Addr DCD Stack_Setup
;Stack_Setup STR R7, [R8] ;Restore SWI_Handler address
;End of edit
LDR R0, =Stack_Top
; Enter Undefined Instruction Mode and set its Stack Pointer
MSR CPSR_c, #Mode_UND:OR:I_Bit:OR:F_Bit
MOV SP, R0
SUB R0, R0, #UND_Stack_Size
; Enter Abort Mode and set its Stack Pointer
MSR CPSR_c, #Mode_ABT:OR:I_Bit:OR:F_Bit
MOV SP, R0
SUB R0, R0, #ABT_Stack_Size
; Enter FIQ Mode and set its Stack Pointer
MSR CPSR_c, #Mode_FIQ:OR:I_Bit:OR:F_Bit
MOV SP, R0
SUB R0, R0, #FIQ_Stack_Size
; Enter IRQ Mode and set its Stack Pointer
MSR CPSR_c, #Mode_IRQ:OR:I_Bit:OR:F_Bit
MOV SP, R0
SUB R0, R0, #IRQ_Stack_Size
; Enter Supervisor Mode and set its Stack Pointer
MSR CPSR_c, #Mode_SVC:OR:I_Bit:OR:F_Bit
MOV SP, R0
SUB R0, R0, #SVC_Stack_Size
; Enter User Mode and set its Stack Pointer
MSR CPSR_c, #Mode_USR
IF :DEF:__MICROLIB
EXPORT __initial_sp
ELSE
MOV SP, R0
SUB SL, SP, #USR_Stack_Size
ENDIF
; Enter the C code
IMPORT __main
LDR R0, =__main
BX R0
IF :DEF:__MICROLIB
EXPORT __heap_base
EXPORT __heap_limit
ELSE
; User Initial Stack & Heap
AREA |.text|, CODE, READONLY
IMPORT __use_two_region_memory
EXPORT __user_initial_stackheap
LDR R0, = Heap_Mem
LDR R1, =(Stack_Mem + USR_Stack_Size)
LDR R2, = (Heap_Mem + Heap_Size)
LDR R3, = Stack_Mem
BX LR
ENDIF
END
