void Init_ADC(void) { //ADCON1 Register //Set up A/D for Automatic Sampling //Use Timer3 to provide sampling time //Set up A/D conversrion results to be read in 1.15 fractional //number format. //All other bits to their default state ADCON1bits.FORM = 3; ADCON1bits.SSRC = 2; ADCON1bits.ASAM = 1; //ADCON2 Register ADCON2bits.VCFG = 0; //Internal V+ / V- ADCON2bits.SMPI = 15; //Set up A/D for interrupting after 16 samples get filled in the buffer //ADCON3 Register //We would like to set up a sampling rate of 7998.6981Hz or 87252.071 Hz //Total Conversion Time= 1/Sampling Rate = 100 microseconds //For fosc=117.968MHz, Tcy = 33.91 ns = Instruction Cycle Time //We will set up Sampling Time using Timer3 & Tad using ADCS<5:0> bits //All other bits to their default state //Let's set up ADCS arbitrarily to 38 //So Tad = Tcy*(ADCS+1)/2 = 661.2 nanoseconds //So, the A/D converter will take 14*Tad periods to convert each sample ADCON3bits.ADCS = 38; //Next, we will to set up Timer 3 to time-out every X=125.02 microseconds (for mode 1) or X=11.461 microseconds (for mode 2) //As a result, the module will stop sampling and trigger a conversion //on every Timer3 time-out, i.e., 125.02 microseconds or 11.461 microseconds. At that time, //the conversion process starts and completes 14*Tad periods later. TMR3 = 0x0000; PR3 = 0x0BAF; IFS0bits.T3IF = 0; IEC0bits.T3IE = 0; T3CONbits.TCS = 0; T3CONbits.TCKPS=0; //ADCHS Register //Set up A/D Channel Select Register to convert AN5 on Mux A input ADCHS = 0x0005; //ADCSSL Register //Channel Scanning is disabled. All bits left to their default state ADCSSL = 0x0000; //ADPCFG Register //Set up channels AN9 as analog inputs and configure rest as digital //Recall that we configured all A/D pins as digital when code execution //entered main() out of reset ADPCFG = 0xFFFF; ADPCFGbits.PCFG5 = 0; //Clear the A/D interrupt flag bit IFS0bits.ADIF = 0; //Set the A/D interrupt enable bit IEC0bits.ADIE = 1; //Turn on the A/D converter //This is typically done after configuring other registers ADCON1bits.ADON = 1; //Start Timer 3 T3CONbits.TON = 1; } void __attribute__((__interrupt__)) _ADCInterrupt(void) { //Clear the Timer3 Interrupt Flag IFS0bits.T3IF = 0; int i = 0; //Clear the A/D Interrupt flag bit or else the CPU will //keep vectoring back to the ISR IFS0bits.ADIF = 0; //Put the A/D conversion results to sigCmpx.real adcPtr = &ADCBUF0 ; for (i=0;i<16;i++) { (*p_sigCmpx).imag = 0x0000; (*p_sigCmpx++).real = *adcPtr++; } if (p_sigCmpx > &sigCmpx[FFT_BLOCK_LENGTH-1]) { SamplesReadyFlag ++; // Sampling completed IEC0bits.ADIE = 0; // Disable ADC interrupt } }
