;**************************************************************************** ;* * ;* 320 x 240 Pixel LCD Controller * ;* Version 3 * ;* * ;**************************************************************************** ; ; ATMega8 ; +--+-+--+ ; (!RESET)PC6 | |_| | PC5(ADC5 SCL) ; (RXD)PD0 | | PC4(ADC4 SDA) ; (TXD)PD1 | | PC3(ADC3) ; (INT0)PD2 | | PC2(ADC2) ; (INT1)PD3 | | PC1(ADC1) ; (XCK T0)PD4 | | PC0(ADC0) ; VCC | | GND ; GND | | AREF ; (XTAL1 TOSC1)PB6 | | AVcc ; (XTAL2 TOSC2)PB7 | | PB5(SCK) ; (T1)PD5 | | PB4(MISO) ; (AIN0)PD6 | | PB3(MOSI OC2) ; (AIN1)PD7 | | PB2(/SS OC1B) ; (ICP1)PB0 | | PB1(OC1A) ; +-------+ ; ; PB0 O PCLK ; PB1 O Kontrast ; PB2 O Load ; PB3 O Frame ; PB4 O AC ; PB5 O ONOFF ; PB6 O Quarz ; PB7 O Quarz ; PC0 O LCD_D0 ; PC1 O LCD_D1 ; PC2 O LCD_D2 ; PC3 O LCD_D3 ; PC4 O nc ; PC5 O nc ; PC6 O nc ; PD0 I RXD (pullup) ; PD1 I nc(pullup) ; PD2 I nc(pullup) ; PD3 I nc(pullup) ; PD4 I nc(pullup) ; PD5 I nc(pullup) ; PD6 I nc(pullup) ; PD7 I nc(pullup) .include "m8def.inc" ;Im Interrupt genutzte und geänderte Register: .def regsave =r2 .def clockL =r3 .def clockH =r4 .def X_Cnt =r5 .def XSaveL =r14 .def XSaveH =r15 .def tempi =r16 .def Y_Cnt =r17 .def C_Cnt =r18 ;zusätzlich: X und Z ;Sonstige Register: .def temp =r19 .def temp2 =r20 .def temp3 =r21 .def temp4 =r22 .def Cnt =r23 ;zusätzlich: Y ;PortB .equ CLOCK =0 ; Pixelclock .equ PWM =1 ; PWM für Contrast .equ LP =2 ; Latch Puls (HSync) .equ FRAME =3 ; First Line Marker (VSync) .equ ONOFF =5 ; LCD (VLCD) Enable ;Werte .equ Framerate =65 ; Refreshrate .equ F_CPU =16000000 ; CPU Freq .equ RX_Buffer =32 ; Interne Konstanten .equ HFREQ =Framerate*240 .equ TDIV =((F_CPU/8+(HFREQ)/2)/HFREQ) .equ CSize =24 .equ XSize =40 .equ YSize =10 .dseg Inhalt: .byte 960 ;**************************************************************************** ; Interrupt Vektoren ;**************************************************************************** .cseg .org 0 rjmp Reset .org OC2addr rjmp LCD_Line ;**************************************************************************** ; CPU Register Initialisierung ;**************************************************************************** Reset: ldi temp, low(RAMEND) out SPL, temp ;setup stack pointer ldi temp, high(RAMEND) out SPH, temp ;setup stack pointer ser temp ;set register -> 0xFF out DDRB, temp ;PCLK, LOAD, FLM, M, ONOFF out DDRC, temp ;D0 - D3 out PORTD, temp ;RXD (UART) ;Timer 1 (16 bit) zur Kontrastregelung ldi temp, (1< 62,5kHz PWM out TCCR1B, temp ;Timer Counter Control Register 1B (Timer 1) ldi temp, 128 ;low byte des 16 bit Vergleichswertes out OCR1AL, temp ;Output Compare Register Timer 1A Low ;Timer 2 (8 bit) zur Interruptsteuerung für LCD ldi temp, (1< 4 Takte H ld tempi, Y+ nop out PORTB, clockH ;PCLK H 1 -> 4 Takte L out PORTC, tempi ;Low Nibble ausgeben 1 out PORTB, clockL ;PCLK L 1 -> 2 Takte H swap tempi ; 1 out PORTC, tempi ;High Nibble ausgeben 1 out PORTB, clockH ;PCLK H 1 -> 3 Takte L dec X_Cnt ; 1 brne hloop ; 2 ; =13 Takte pro Byte out PORTB, clockL ;PCLK L sbi PORTB, LP dec C_Cnt ;Zähler für Zeichenhöhe erniedrigen nop nop cbi PORTB, LP cbi PORTB, FRAME breq skipcloop ;1 Textzeile fertig ausgegeben ? rjmp exit_int skipcloop: ;Alles für neue Textzeile einrichten inc Y_Cnt ;Zeilencounter erhöhen cpi Y_Cnt, YSize ;Bildende ? brne exit_int sbi PORTB, FRAME ldi ZL,LOW(font*2) ldi ZH,HIGH(font*2) clr Y_Cnt exit_int: out sreg, regsave reti ;*** CG ROM Daten *** font: ;Zeile 1 .db 0x28 ,0x00 .db 0x00 ,0x00 ,0xF0 ,0xCF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xF0 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xF1 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xF1 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xE1 ,0xF0 ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xE1 ,0x70 ,0x0C ,0xE7 ,0x30 ,0xFC ,0x30 ,0xFC ,0x00 ,0x8F ,0xF0 ,0x07 ,0xCF ,0xF1 ,0x1E ,0x8F ,0x70 ,0xF8 ,0x00 ,0x00 ,0x10 ,0x3F ,0x1C ,0x0F ,0xE1 ,0x87 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xE1 ,0x30 ,0x1C ,0xFF ,0x70 ,0xFF ,0x7C ,0xFF ,0x1C ,0xEF ,0xF1 ,0x3F ,0xEF ,0xF3 ,0x7E ,0xCF ,0xF1 ,0xFE ,0x00 ,0x00 ,0x30 ,0xBF ,0x3C ,0xCF ,0xF3 ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xC3 ,0x30 ,0x3C ,0xFF ,0x78 ,0xFF ,0x7C ,0xFF ,0x3C ,0xEF ,0xF1 ,0x7E ,0xFF ,0xF3 ,0x7C ,0xEF ,0xF1 ,0xFF ,0x00 ,0x00 ,0x70 ,0xFF ,0x78 ,0xCF ,0xF3 ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xC3 ,0x30 ,0x7C ,0x7C ,0x7C ,0x3E ,0x7C ,0x3E ,0x7C ,0xF8 ,0xF1 ,0x78 ,0xF8 ,0xF0 ,0xF0 ,0xE1 ,0xE3 ,0xE7 ,0x00 ,0x00 ,0xF0 ,0xF9 ,0xF8 ,0xE1 ,0xF3 ,0xE1 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xC3 ,0x30 ,0x7C ,0x38 ,0x7C ,0x3C ,0x7C ,0x3C ,0x7C ,0x70 ,0xF1 ,0x70 ,0x08 ,0xF1 ,0x00 ,0xE1 ,0xC3 ,0xE3 ,0x00 ,0x00 ,0xF0 ,0xF0 ,0xE8 ,0xE0 ,0xE3 ,0xE1 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xC3 ,0x30 ,0xFC ,0x38 ,0x7C ,0x38 ,0x7C ,0x38 ,0xFC ,0x70 ,0xE1 ,0x70 ,0x0E ,0xE1 ,0x00 ,0xE1 ,0x87 ,0xE3 ,0x00 ,0x00 ,0xF1 ,0xF0 ,0xE9 ,0xE0 ,0xC3 ,0xE1 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xC7 ,0x70 ,0xFC ,0x30 ,0xFC ,0x38 ,0xFC ,0x38 ,0xFC ,0xFF ,0xE3 ,0x30 ,0x8F ,0xE1 ,0x10 ,0xEF ,0x87 ,0xE3 ,0x00 ,0x00 ,0xE1 ,0xF0 ,0xF9 ,0xEF ,0xC7 ,0xE1 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x87 ,0x70 ,0xF8 ,0x30 ,0xFC ,0x70 ,0xF8 ,0x70 ,0xF8 ,0xFF ,0xC3 ,0x10 ,0xCF ,0xE1 ,0xF1 ,0xEF ,0x87 ,0xC3 ,0x00 ,0x00 ,0xE1 ,0xF0 ,0xF1 ,0xEF ,0x87 ,0xC3 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x87 ,0xF0 ,0xF8 ,0x70 ,0xFC ,0x70 ,0xF8 ,0x70 ,0xE8 ,0x00 ,0xC3 ,0x00 ,0xE7 ,0xE1 ,0xF3 ,0xC3 ,0x87 ,0xC3 ,0x00 ,0x00 ,0xE1 ,0xF0 ,0xC1 ,0x00 ,0x87 ,0xC3 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x87 ,0xF3 ,0xF0 ,0x70 ,0xF8 ,0x70 ,0xF8 ,0x70 ,0xE8 ,0x00 ,0xC3 ,0x00 ,0xE1 ,0xE3 ,0xC3 ,0xC3 ,0x87 ,0xC7 ,0x00 ,0x00 ,0xE1 ,0xF1 ,0xC1 ,0x00 ,0x87 ,0xC3 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xF7 ,0xFF ,0xF0 ,0xF8 ,0xF8 ,0x70 ,0xF8 ,0x70 ,0xF8 ,0xC1 ,0xC3 ,0xE1 ,0xE1 ,0xC3 ,0xC3 ,0xC3 ,0xC7 ,0xCF ,0x00 ,0x00 ,0xF1 ,0xF1 ,0xE1 ,0x83 ,0x87 ,0xC3 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xFF ,0xEF ,0x70 ,0xFF ,0xF1 ,0xF0 ,0xF9 ,0xF0 ,0x78 ,0xEF ,0xC7 ,0xF0 ,0xCF ,0xF3 ,0xEB ,0xCF ,0xF3 ,0xCF ,0x00 ,0x00 ,0xF0 ,0xFF ,0xF0 ,0xCF ,0x8F ,0xC7 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xFF ,0x8F ,0x30 ,0xEF ,0xE1 ,0xF0 ,0xE1 ,0xF0 ,0x30 ,0xCF ,0x87 ,0xF0 ,0xCF ,0xF3 ,0xF9 ,0xCF ,0xF3 ,0x8F ,0x00 ,0x00 ,0xF0 ,0xEF ,0x70 ,0x8F ,0x0F ,0x87 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xFF ,0x0E ,0x10 ,0x8F ,0xE1 ,0xF0 ,0xE1 ,0xF0 ,0x10 ,0x0F ,0x87 ,0x30 ,0x0F ,0xF1 ,0xF0 ,0xCB ,0xE1 ,0x87 ,0x00 ,0x00 ,0x70 ,0xE9 ,0x30 ,0x0E ,0x0F ,0x87 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x87 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x0F ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF3 ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ;Zeile2 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0xF3 ,0x0C ,0x00 ,0xF1 ,0x0C ,0x00 ,0x00 ,0x8F ,0x00 ,0xF1 ,0x0C ,0x00 ,0x00 .db 0x00 ,0xFF ,0x0F ,0x00 ,0xF7 ,0x0F ,0x00 ,0x10 ,0x8F ,0x00 ,0xF7 ,0x0F ,0x00 ,0x00 .db 0x30 ,0xFF ,0x8F ,0x00 ,0xFF ,0x8F ,0x00 ,0x30 ,0x8F ,0x00 ,0xFF ,0x8F ,0x00 ,0x00 .db 0x70 ,0xFF ,0xCF ,0x10 ,0xFF ,0xCF ,0x00 ,0x70 ,0x0F ,0x10 ,0xFF ,0xCF ,0x00 ,0x00 .db 0x70 ,0xFF ,0xEF ,0x30 ,0xFF ,0xEF ,0x00 ,0xF1 ,0x0F ,0x30 ,0xFF ,0xEF ,0x00 ,0x00 .db 0xF0 ,0x0F ,0xEF ,0x70 ,0x8F ,0xEF ,0x00 ,0xF7 ,0x0F ,0x70 ,0x8F ,0xEF ,0x00 ,0x00 .db 0xF0 ,0x0E ,0xF7 ,0xF0 ,0x0E ,0xE7 ,0x10 ,0xFF ,0x0F ,0xF0 ,0x0E ,0xE7 ,0x00 ,0x00 .db 0xF1 ,0x0C ,0xF3 ,0xF0 ,0x0C ,0xF3 ,0x70 ,0xFF ,0x0F ,0xF0 ,0x0C ,0xF3 ,0x00 ,0x00 .db 0xF1 ,0x08 ,0xF3 ,0xF1 ,0x0C ,0xF3 ,0xF0 ,0xFF ,0x0E ,0xF1 ,0x0C ,0xF3 ,0x00 ,0x00 .db 0x30 ,0x08 ,0xF3 ,0xF1 ,0x08 ,0xF3 ,0xF0 ,0xFF ,0x0E ,0xF1 ,0x08 ,0xF3 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xF3 ,0xF3 ,0x08 ,0xF3 ,0xF0 ,0x7F ,0x0E ,0xF3 ,0x08 ,0xF3 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xF7 ,0xF3 ,0x00 ,0xF3 ,0xF1 ,0xFC ,0x0E ,0xF3 ,0x00 ,0xF3 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xEF ,0xF3 ,0x00 ,0xF3 ,0xF1 ,0xF0 ,0x0C ,0xF3 ,0x00 ,0xF3 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xEF ,0xF7 ,0x00 ,0xF3 ,0x81 ,0xF0 ,0x0C ,0xF7 ,0x00 ,0xF3 ,0x00 ,0x00 ;Zeile3 .db 0x28 ,0x00 .db 0x00 ,0x00 ,0x30 ,0x0E ,0x70 ,0xEF ,0x00 ,0x00 ,0x70 ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xCF ,0xF7 ,0x00 ,0xF7 ,0x00 ,0xF0 ,0x0C ,0xF7 ,0x00 ,0xF7 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x70 ,0x8F ,0xF0 ,0xEF ,0x00 ,0x00 ,0xF0 ,0x8F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0xCF ,0xE7 ,0x00 ,0xF7 ,0x00 ,0xF0 ,0x0C ,0xE7 ,0x00 ,0xF7 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xF0 ,0x8F ,0xF0 ,0xCF ,0x00 ,0x00 ,0xF1 ,0xCF ,0x00 ,0x00 ,0x00 ,0x00 ,0xC0 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0x8F ,0xEF ,0x00 ,0xF7 ,0x00 ,0xF1 ,0x0C ,0xEF ,0x00 ,0xF7 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xF1 ,0xC3 ,0xF0 ,0x00 ,0x00 ,0x00 ,0xE3 ,0xE3 ,0x00 ,0x00 ,0x00 ,0x00 ,0xC1 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF1 ,0x0F ,0xEF ,0x00 ,0xE7 ,0x00 ,0xF1 ,0x08 ,0xEF ,0x00 ,0xE7 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xE1 ,0xC3 ,0xF0 ,0x00 ,0x00 ,0x00 ,0xC3 ,0xE1 ,0x00 ,0x00 ,0x00 ,0x00 ,0xC3 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF3 ,0x0E ,0xEF ,0x00 ,0xEF ,0x00 ,0xF1 ,0x08 ,0xEF ,0x00 ,0xEF ,0x00 ,0x00 .db 0x00 ,0x00 ,0xE1 ,0xC3 ,0xF1 ,0x00 ,0x00 ,0x00 ,0xC3 ,0xE1 ,0x70 ,0x0C ,0xB7 ,0x0E ,0xFF ,0xF0 ,0x08 ,0x3F ,0x3C ,0x1C ,0xFE ,0x08 ,0xC7 ,0x70 ,0x8B ,0x00 ,0x00 ,0xF7 ,0x0C ,0xCF ,0x00 ,0xEF ,0x00 ,0xF1 ,0x08 ,0xCF ,0x00 ,0xEF ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0xC3 ,0xF1 ,0x0E ,0x00 ,0x00 ,0xE3 ,0x00 ,0xF0 ,0x0F ,0xF7 ,0x1F ,0xFF ,0xF1 ,0x1E ,0xFF ,0xFE ,0x1E ,0xFF ,0x0C ,0xFF ,0xF0 ,0x8F ,0x00 ,0x00 ,0xFF ,0x08 ,0xCF ,0x00 ,0xCF ,0x00 ,0xF1 ,0x08 ,0xCF ,0x00 ,0xCF ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0xC7 ,0xF1 ,0x8F ,0x00 ,0x00 ,0xF3 ,0x08 ,0xF1 ,0x0F ,0xFF ,0x1F ,0xEF ,0xF3 ,0x1E ,0xFF ,0xFF ,0x3E ,0xFF ,0x1C ,0xFF ,0xF0 ,0x0F ,0x00 ,0x10 ,0xFF ,0x00 ,0xCF ,0x00 ,0xCF ,0x00 ,0xF3 ,0x08 ,0xCF ,0x00 ,0xCF ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x8F ,0xF3 ,0x8F ,0x00 ,0x00 ,0xF1 ,0x0E ,0xC3 ,0x87 ,0x8F ,0x8F ,0x87 ,0x87 ,0x1F ,0x9F ,0x1F ,0x3E ,0x3F ,0x3E ,0x7C ,0xF8 ,0x0C ,0x00 ,0x30 ,0xCF ,0x00 ,0xCF ,0x10 ,0xCF ,0x00 ,0xF3 ,0x00 ,0xCF ,0x10 ,0xCF ,0x00 ,0x00 .db 0x00 ,0x00 ,0x10 ,0x8F ,0xC3 ,0xC7 ,0x00 ,0x00 ,0xF0 ,0x0F ,0x83 ,0x83 ,0x0F ,0x87 ,0x8F ,0x07 ,0x17 ,0x1F ,0x1F ,0x3E ,0x1E ,0x3E ,0x38 ,0xF8 ,0x08 ,0x00 ,0x70 ,0x8F ,0x00 ,0xCF ,0x10 ,0x8F ,0x00 ,0xF3 ,0x00 ,0xCF ,0x10 ,0x8F ,0x00 ,0x00 .db 0x00 ,0x00 ,0x30 ,0x0F ,0x00 ,0xC3 ,0x00 ,0x00 ,0x30 ,0x8F ,0x87 ,0x83 ,0x0F ,0x87 ,0x0F ,0x0F ,0x17 ,0x1E ,0x1E ,0x3E ,0x1C ,0x7E ,0x38 ,0xF8 ,0x00 ,0x00 ,0xF0 ,0x0F ,0x00 ,0xCF ,0x30 ,0x8F ,0x00 ,0xF3 ,0x00 ,0xCF ,0x30 ,0x8F ,0x00 ,0x00 .db 0x00 ,0x00 ,0x70 ,0x0E ,0x00 ,0xC3 ,0x00 ,0x00 ,0x00 ,0xCF ,0xF7 ,0x8F ,0x0F ,0x87 ,0x0F ,0xFF ,0x3F ,0x1E ,0x1E ,0x7E ,0x1C ,0x7E ,0xFF ,0xF9 ,0x00 ,0x00 ,0xF1 ,0x0E ,0x00 ,0xCF ,0x30 ,0x0F ,0x00 ,0xF3 ,0x00 ,0xCF ,0x30 ,0x0F ,0x00 ,0x00 .db 0x00 ,0x00 ,0xF0 ,0x0C ,0x00 ,0xC3 ,0x00 ,0x00 ,0x00 ,0xC7 ,0xF7 ,0x9F ,0x0E ,0x87 ,0x0F ,0xFF ,0x3F ,0x3C ,0x3C ,0x7C ,0x1C ,0x7E ,0xFF ,0xE9 ,0x00 ,0x00 ,0xF1 ,0x0C ,0x00 ,0xE7 ,0x70 ,0x0F ,0x00 ,0xF7 ,0x00 ,0xE7 ,0x70 ,0x0F ,0x00 ,0x00 .db 0x00 ,0x00 ,0xF0 ,0x08 ,0x87 ,0xC3 ,0x00 ,0x00 ,0x0F ,0xC3 ,0x07 ,0x10 ,0x0E ,0x8F ,0x0F ,0x0E ,0x30 ,0x3C ,0x3C ,0x7C ,0x1C ,0x7E ,0x00 ,0xE1 ,0x00 ,0x00 ,0xF3 ,0xFF ,0xCF ,0xF7 ,0xF1 ,0x0E ,0x00 ,0xE7 ,0x00 ,0xF7 ,0xF1 ,0x0E ,0x00 ,0x00 .db 0x00 ,0x00 ,0xF1 ,0x00 ,0x87 ,0x87 ,0x00 ,0x00 ,0x0F ,0xC3 ,0x07 ,0x10 ,0x0F ,0x1F ,0x0F ,0x0E ,0x30 ,0x3C ,0x3C ,0x7C ,0x3C ,0x7C ,0x00 ,0xE1 ,0x00 ,0x00 ,0xF7 ,0xFF ,0xCF ,0xF7 ,0xFF ,0x0C ,0x00 ,0xE7 ,0x00 ,0xF7 ,0xFF ,0x0C ,0x00 ,0x00 .db 0x00 ,0x00 ,0xE3 ,0x00 ,0xC7 ,0x8F ,0xF0 ,0x00 ,0x8F ,0xC7 ,0x87 ,0x1E ,0x1F ,0x1F ,0x0E ,0x1F ,0x3C ,0x3C ,0x3C ,0x7C ,0x7E ,0x7C ,0xE8 ,0xE1 ,0x00 ,0x00 ,0xF7 ,0xFF ,0xCF ,0xF3 ,0xFF ,0x08 ,0x00 ,0xE7 ,0x00 ,0xF3 ,0xFF ,0x08 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xF3 ,0x8F ,0xF3 ,0x0F ,0xF0 ,0x00 ,0xF7 ,0x8F ,0xF3 ,0x1F ,0xFF ,0x1E ,0xCF ,0xF7 ,0x7E ,0x7C ,0x7C ,0xFC ,0xFF ,0x38 ,0xFF ,0xE3 ,0x00 ,0x00 ,0xF7 ,0xFF ,0x8F ,0xF1 ,0xFF ,0x00 ,0x00 ,0xEF ,0x00 ,0xF1 ,0xFF ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xF7 ,0x8F ,0xF1 ,0x0E ,0xE1 ,0x00 ,0xF3 ,0x0F ,0xF1 ,0x3E ,0xFD ,0x1C ,0xCF ,0xF3 ,0x7C ,0x78 ,0x78 ,0xF8 ,0xF7 ,0x10 ,0xEF ,0xC3 ,0x00 ,0x00 ,0xFF ,0xFF ,0x8F ,0xF0 ,0xEF ,0x00 ,0x00 ,0xCF ,0x00 ,0xF0 ,0xEF ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0xF7 ,0x0F ,0xF0 ,0x08 ,0xE1 ,0x00 ,0xF0 ,0x0C ,0xF0 ,0x38 ,0xFC ,0x08 ,0x8F ,0xF1 ,0x70 ,0x78 ,0x78 ,0xF8 ,0xE3 ,0x00 ,0x8F ,0xC3 ,0x00 ,0x00 ,0xFF ,0xFF ,0x8F ,0x30 ,0x8F ,0x00 ,0x00 ,0xCF ,0x00 ,0x30 ,0x8F ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ;Zeile 5 .db 0x28 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xCF ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0xFF ,0xFF ,0x8F ,0x00 ,0x00 ,0xF0 ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0xCF ,0x00 ,0x00 ,0x00 ,0x70 ,0xFF ,0xCF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0xFF ,0xFF ,0x8F ,0x00 ,0x00 ,0xF3 ,0xFF ,0x8F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0xCF ,0x00 ,0x00 ,0x00 ,0xF1 ,0xFF ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0xFF ,0xFF ,0x8F ,0x00 ,0x00 ,0xFF ,0xFF ,0xCF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF0 ,0xCF ,0x00 ,0x00 ,0x00 ,0xF3 ,0xFF ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0xFF ,0xFF ,0x0F ,0x00 ,0x10 ,0xFF ,0xFF ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF0 ,0x8F ,0x00 ,0x00 ,0x00 ,0xF7 ,0xFF ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0xFF ,0xFF ,0x0F ,0x00 ,0x30 ,0xFF ,0xFF ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF1 ,0x8F ,0x00 ,0x00 ,0x00 ,0xFF ,0xFF ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0xFF ,0xFF ,0x0F ,0x00 ,0x70 ,0xFF ,0xFF ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF3 ,0x8F ,0x00 ,0x00 ,0x00 ,0xFF ,0xFF ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0xFF ,0xFF ,0x0F ,0x00 ,0x70 ,0xFF ,0xFF ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x8F ,0x00 ,0x00 ,0x10 ,0xFF ,0xFF ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0xFF ,0xFF ,0x0F ,0x00 ,0xF0 ,0xFF ,0xFF ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0x8F ,0x00 ,0x00 ,0x30 ,0xFF ,0xFF ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0xFF ,0xFF ,0x0F ,0x00 ,0xF1 ,0xFF ,0xFF ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0x8F ,0x00 ,0x00 ,0x30 ,0xFF ,0xFF ,0xFF ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0xFF ,0xFF ,0x0E ,0x00 ,0xF1 ,0xFF ,0x78 ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0xFF ,0x0F ,0x00 ,0x00 ,0x70 ,0xFF ,0x1E ,0xFF ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0xFF ,0xFF ,0xFF ,0x0E ,0x00 ,0xF3 ,0xFF ,0x10 ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF1 ,0xFF ,0x0F ,0x00 ,0x00 ,0x70 ,0xFF ,0x0C ,0xFF ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0xFF ,0xFF ,0xFF ,0x0E ,0x00 ,0xF3 ,0xEF ,0x00 ,0xFF ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF3 ,0xFF ,0x0F ,0x00 ,0x00 ,0x70 ,0xFF ,0x08 ,0xF7 ,0x8F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0xF3 ,0xCF ,0x00 ,0xFF ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0xFF ,0x0F ,0x00 ,0x00 ,0xF0 ,0xFF ,0x00 ,0xF7 ,0x8F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0xF3 ,0x8F ,0x00 ,0xFF ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0xFF ,0x0F ,0x00 ,0x00 ,0xF0 ,0xFF ,0x00 ,0xF3 ,0x8F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF0 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0x8F ,0x00 ,0xF7 ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0xFF ,0xFF ,0x0F ,0x00 ,0x00 ,0xF0 ,0xEF ,0x00 ,0xF3 ,0x8F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF0 ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0x0F ,0x00 ,0xF7 ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF0 ,0xFF ,0xFF ,0x0E ,0x00 ,0x00 ,0xF1 ,0xEF ,0x00 ,0xF3 ,0x8F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF0 ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0x0F ,0x00 ,0xF7 ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF3 ,0xFF ,0xFF ,0x0E ,0x00 ,0x00 ,0xF1 ,0xEF ,0x00 ,0xF3 ,0x8F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF0 ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0x0F ,0x00 ,0xF7 ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0xFF ,0xFF ,0x0E ,0x00 ,0x00 ,0x30 ,0xCF ,0x00 ,0xF3 ,0x8F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF1 ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0x0F ,0x00 ,0xF7 ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0xFF ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0xC1 ,0x00 ,0xF3 ,0x8F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF1 ,0xCF ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0x0F ,0x00 ,0xF7 ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0xFF ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF3 ,0x8F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF1 ,0xCF ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0x0F ,0x00 ,0xFF ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0xFF ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF3 ,0x8F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF1 ,0xCF ,0xF7 ,0x00 ,0x00 ,0x00 ,0xF7 ,0x0F ,0x00 ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0xFF ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF3 ,0xDF ,0xFF ,0x0C ,0x00 ,0x00 ,0xF7 ,0x0F ,0x00 ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ;Zeile 6 .db 0x28 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x9F ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0x0F ,0x00 ,0x00 ,0x70 ,0xFF ,0x08 ,0x00 ,0x00 ,0xF3 ,0xFF ,0xFF ,0x0F ,0x00 ,0x00 ,0xF3 ,0x8F ,0x10 ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x1F ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x0F ,0x00 ,0x00 ,0x70 ,0xFF ,0x08 ,0x00 ,0x00 ,0xF3 ,0xFF ,0xFF ,0x8F ,0x00 ,0x00 ,0xF3 ,0x8F ,0x30 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x1C ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0x0E ,0x00 ,0x00 ,0x70 ,0xFF ,0x08 ,0x00 ,0x00 ,0xF3 ,0xFF ,0xFF ,0xCF ,0x00 ,0x00 ,0xF1 ,0xCF ,0x70 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x30 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0x0E ,0x00 ,0x00 ,0x70 ,0xFF ,0x00 ,0x00 ,0x00 ,0xF7 ,0xFF ,0xFF ,0xEF ,0x00 ,0x00 ,0xF1 ,0xFF ,0xF0 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xCF ,0x30 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0xFF ,0x0C ,0x00 ,0x00 ,0xF0 ,0xFF ,0x00 ,0x00 ,0x00 ,0xF7 ,0xFF ,0xFF ,0xEF ,0x00 ,0x00 ,0xF0 ,0xFF ,0xFF ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0x0E ,0x30 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0xFF ,0x0C ,0x00 ,0x00 ,0xF0 ,0xFF ,0x00 ,0x00 ,0x00 ,0xF7 ,0xFF ,0xFF ,0xFF ,0x00 ,0x00 ,0x70 ,0xFF ,0xFF ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0x08 ,0x30 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0xFF ,0x08 ,0x00 ,0x00 ,0xF0 ,0xFF ,0x00 ,0x00 ,0x00 ,0xFF ,0xFF ,0xFF ,0xFF ,0x08 ,0x00 ,0x30 ,0xFF ,0xFF ,0xCF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0xFF ,0x00 ,0x00 ,0x00 ,0xF0 ,0xFF ,0x00 ,0x00 ,0x00 ,0xFF ,0xFF ,0xFF ,0xFF ,0x08 ,0x00 ,0x10 ,0xFF ,0xFF ,0x8F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0xEF ,0x00 ,0x00 ,0x00 ,0xF0 ,0xFF ,0x00 ,0x00 ,0x00 ,0xFF ,0xCF ,0xF1 ,0xFF ,0x0C ,0x00 ,0x10 ,0xFF ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0xCF ,0x00 ,0x00 ,0x00 ,0xF0 ,0xEF ,0x00 ,0x00 ,0x00 ,0xFF ,0x0F ,0x70 ,0xFF ,0x0C ,0x00 ,0x70 ,0xFF ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0x0F ,0x00 ,0x00 ,0x00 ,0xF1 ,0xEF ,0x00 ,0x00 ,0x10 ,0xFF ,0x0C ,0x30 ,0xFF ,0x0C ,0x00 ,0xF0 ,0xFF ,0xFF ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0x0F ,0x00 ,0x00 ,0x00 ,0xF1 ,0xEF ,0x00 ,0x00 ,0x00 ,0xF0 ,0x08 ,0x10 ,0xFF ,0x0C ,0x00 ,0xF3 ,0xFF ,0xFF ,0x8F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0x8F ,0x00 ,0x00 ,0x00 ,0xF1 ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0x0E ,0x00 ,0xF7 ,0xFF ,0xFF ,0x8F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0xCF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0x0E ,0x00 ,0xF7 ,0xFF ,0xFF ,0xCF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x0E ,0x00 ,0xFF ,0x8F ,0xF3 ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF0 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x0E ,0x10 ,0xFF ,0x0F ,0xF1 ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF0 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF3 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x0E ,0x10 ,0xFF ,0x0E ,0xF0 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF0 ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF0 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x0E ,0x30 ,0xFF ,0x0C ,0x70 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF0 ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x0E ,0x30 ,0xFF ,0x08 ,0x70 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF0 ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x0E ,0x70 ,0xFF ,0x08 ,0x30 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF0 ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x0E ,0x70 ,0xFF ,0x00 ,0x30 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF1 ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x0E ,0x70 ,0xFF ,0x00 ,0x30 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF1 ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x0E ,0x70 ,0xFF ,0x00 ,0x30 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF1 ,0xCF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x0E ,0xF0 ,0xFF ,0x00 ,0x30 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ;Zeile 7 .db 0x28 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF1 ,0xCF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xCF ,0x00 ,0x10 ,0xFF ,0x0E ,0xF0 ,0xEF ,0x00 ,0x30 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF1 ,0xCF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF1 ,0xCF ,0x00 ,0x10 ,0xFF ,0x0C ,0xF0 ,0xEF ,0x00 ,0x30 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF1 ,0xCF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF1 ,0xCF ,0x00 ,0x10 ,0xFF ,0x0C ,0xF0 ,0xEF ,0x00 ,0x30 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF3 ,0xCF ,0x00 ,0x00 ,0x00 ,0xE0 ,0x00 ,0x10 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF1 ,0xCF ,0x00 ,0x10 ,0xFF ,0x0C ,0xF0 ,0xEF ,0x00 ,0x70 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF3 ,0x8F ,0x00 ,0x00 ,0x10 ,0xEF ,0x00 ,0x10 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF1 ,0xCF ,0x00 ,0x30 ,0xFF ,0x0C ,0xF0 ,0xEF ,0x00 ,0x70 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF3 ,0x8F ,0x00 ,0x00 ,0xF0 ,0xEF ,0x00 ,0x10 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF1 ,0xCF ,0x00 ,0x30 ,0xFF ,0x08 ,0xF0 ,0xEF ,0x00 ,0x70 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF3 ,0x8F ,0x00 ,0x00 ,0xF0 ,0xFF ,0x00 ,0x30 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF1 ,0xCF ,0x00 ,0x70 ,0xFF ,0x08 ,0xF0 ,0xEF ,0x00 ,0xF0 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF3 ,0x8F ,0x00 ,0x00 ,0xF0 ,0xFF ,0x00 ,0x30 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF0 ,0xEF ,0x00 ,0x70 ,0xFF ,0x08 ,0xF0 ,0xEF ,0x00 ,0xF0 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF3 ,0x8F ,0x00 ,0x00 ,0x70 ,0xFF ,0x00 ,0x70 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF0 ,0xEF ,0x00 ,0xF0 ,0xFF ,0x00 ,0xF0 ,0xFF ,0x00 ,0xF0 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0x8F ,0x00 ,0x00 ,0x70 ,0xFF ,0x08 ,0x70 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF0 ,0xEF ,0x00 ,0xF1 ,0xFF ,0x00 ,0xF0 ,0xFF ,0x00 ,0xF1 ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0x0F ,0x00 ,0x00 ,0x70 ,0xFF ,0x08 ,0xF0 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF0 ,0xFF ,0x00 ,0xF3 ,0xEF ,0x00 ,0x70 ,0xFF ,0x08 ,0xF3 ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0x0F ,0x00 ,0x00 ,0x70 ,0xFF ,0x0C ,0xF1 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0xFF ,0x08 ,0xF7 ,0xEF ,0x00 ,0x70 ,0xFF ,0x08 ,0xF7 ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0x0F ,0x00 ,0x00 ,0x30 ,0xFF ,0x0F ,0xF7 ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0xFF ,0x1E ,0xFF ,0xCF ,0x00 ,0x70 ,0xFF ,0x0E ,0xFF ,0xCF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0x0F ,0x00 ,0x00 ,0x30 ,0xFF ,0xFF ,0xFF ,0xEF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x70 ,0xFF ,0xFF ,0xFF ,0xCF ,0x00 ,0x70 ,0xFF ,0xFF ,0xFF ,0xCF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0x0F ,0x00 ,0x00 ,0x10 ,0xFF ,0xFF ,0xFF ,0xCF ,0x00 ,0x00 ,0x10 ,0xFF ,0x0E ,0x00 ,0x00 ,0x30 ,0xFF ,0xFF ,0xFF ,0x8F ,0x00 ,0x30 ,0xFF ,0xFF ,0xFF ,0x8F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x0F ,0x00 ,0x00 ,0x10 ,0xFF ,0xFF ,0xFF ,0x8F ,0x00 ,0x00 ,0x10 ,0xFF ,0x0E ,0x00 ,0x00 ,0x30 ,0xFF ,0xFF ,0xFF ,0x0F ,0x00 ,0x30 ,0xFF ,0xFF ,0xFF ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0xFF ,0xFF ,0xFF ,0x8F ,0x00 ,0x00 ,0x10 ,0xFF ,0x0E ,0x00 ,0x00 ,0x10 ,0xFF ,0xFF ,0xFF ,0x0E ,0x00 ,0x10 ,0xFF ,0xFF ,0xFF ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0xFF ,0xFF ,0xFF ,0x0F ,0x00 ,0x00 ,0x10 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0xFF ,0xFF ,0xFF ,0x0E ,0x00 ,0x00 ,0xFF ,0xFF ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0xF7 ,0xFF ,0xFF ,0x0E ,0x00 ,0x00 ,0x30 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0xFF ,0xFF ,0xFF ,0x0C ,0x00 ,0x00 ,0xFF ,0xFF ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0xF3 ,0xFF ,0xFF ,0x0C ,0x00 ,0x00 ,0x30 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0xF7 ,0xFF ,0xFF ,0x00 ,0x00 ,0x00 ,0xF7 ,0xFF ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0xF1 ,0xFF ,0xFF ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0xF1 ,0xFF ,0xEF ,0x00 ,0x00 ,0x00 ,0xF3 ,0xFF ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0x70 ,0xFF ,0xEF ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0xF0 ,0xFF ,0x8F ,0x00 ,0x00 ,0x00 ,0xF0 ,0xFF ,0xCF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0x8F ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0x0E ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x10 ,0xFF ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0xF7 ,0x0C ,0x00 ,0x00 ,0x00 ,0x30 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0xFF ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ;Zeile 8 Sekunden .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x10 ,0x0E ,0x30 ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x30 ,0x0F ,0xF0 ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x70 ,0x8F ,0xF0 ,0x8F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0xF0 ,0x83 ,0xE1 ,0x87 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0xE0 ,0x83 ,0xC1 ,0x83 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x83 ,0xC1 ,0x83 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x83 ,0xE1 ,0x87 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x07 ,0xF0 ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x10 ,0x0F ,0xF0 ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x10 ,0x0C ,0xF1 ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x10 ,0x0E ,0xC1 ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x07 ,0x83 ,0x07 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x07 ,0x83 ,0x07 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x83 ,0x07 ,0x83 ,0x07 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x83 ,0x07 ,0x83 ,0x0F ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0xC3 ,0x0F ,0xC3 ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0xF1 ,0x0E ,0xF1 ,0x0E ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0xF0 ,0x0C ,0xF1 ,0x0C ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x70 ,0x08 ,0xF0 ,0x08 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 .db 0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00
