' ###################################### ' ################## Binäruhr (groove version ##################### ' ###################################### 'Zuordnung Pins: 'Pin: '28. PC5 - Taster Stellen '6. PD4 - Taster Auswahl '2. PD0 - Stunden2 Reset '3. PD1 - Stunden2 Clock '4. PD2 - Stunden1 Reset '5. PD3 - Stunden1 Clock '11. PD5 - Minuten2 Reset '12. PD6 - Minuten2 Clock '15. PB1 - Minuten1 Reset '16. PB2 - Minuten1 Clock '17. PB3 - Sekunden2 Reset '18. PB4 - Sekunden2 Clock '19. PB5 - Sekunden1 Reset '23. PC0 - Sekunden1 Clock $regfile = "m8def.dat" $crystal = 1000000 Declare Sub Anhalten Declare Sub Stellen Ddrd = &B11101111 Portd = &B00010000 Ddrc = &B11011111 Portc = &B00100000 Ddrb = &B11111111 Portb = &B00000000 Dim S1 As Byte Dim S2 As Byte Dim M1 As Byte Dim M2 As Byte Dim H1 As Byte Dim H2 As Byte Dim X As Byte Dim Y As Bit Dim Stacht As Bit S1 = 0 S2 = 0 M1 = 0 M2 = 0 H1 = 0 H2 = 0 X = 0 Y = 0 Stacht = 0 Do Debounce Pind.4 , 0 , Anhalten , Sub 'entprellen Debounce Pinc.5 , 0 , Stellen , Sub 'Start Reset: If Stacht = 0 Then Portd.0 = 1 Portd.2 = 1 Portd.5 = 1 Portb.1 = 1 Portb.3 = 1 Portb.5 = 1 Waitms 20 Portd.0 = 0 Portd.2 = 0 Portd.5 = 0 Portb.1 = 0 Portb.3 = 0 Portb.5 = 0 Stacht = 1 Else End If '--------------------------- 'Startbedingungen: Select Case X Case 0: Goto Normal Case 1 To 3: Goto Stellmodus Case 4: X = 0 Goto Ende Case Else End Select '---------------------------- 'Normalbetrieb: Normal: 'Sekunden: Waitms 500 Portb.4 = 1 Waitms 500 Portb.4 = 0 'takt jede sekunde S2 = S2 + 1 If S2 = 10 Then 'wenn s2 = 10 dann reset sek2, set sek1 S1 = S1 + 1 S2 = 0 Portb.3 = 1 Portc.0 = 1 Waitms 10 Portb.3 = 0 Portc.0 = 0 Else End If 'Minuten: If S1 = 6 Then 'wenn sek1 = 6 dann reset sek1, set min2 M2 = M2 + 1 S1 = 0 Portb.5 = 1 Portd.6 = 1 Waitms 10 Portb.5 = 0 Portd.6 = 0 Else End If If M2 = 10 Then 'wenn min2 = 10 dann reset min2, set min1 M1 = M1 + 1 M2 = 0 Portd.5 = 1 Portb.2 = 1 Waitms 10 Portd.5 = 0 Portb.2 = 0 Else End If 'Stunden: If M1 = 6 Then 'wenn min1 = 6 dann reset min1, set h2 H2 = H2 + 1 M1 = 0 Portb.1 = 1 Portd.1 = 1 Waitms 10 Portb.1 = 0 Portd.1 = 0 Else End If If H2 = 10 Then 'wenn h2 = 10 dann reset h2, set h1 H1 = H1 + 1 H2 = 0 Portd.0 = 1 Portd.3 = 1 Waitms 10 Portd.0 = 0 Portd.3 = 0 Else End If If H1 = 2 And H2 = 4 Then 'wenn h1 = 2 und h2 = 4 dann reset h1,h2 H1 = 0 H2 = 0 Portd.2 = 1 Portd.0 = 1 Waitms 500 Portd.2 = 0 Portd.0 = 0 Else End If Goto Ende '--------------------------- 'Uhrzeit einstellen: Stellmodus: 'Stunden: If X = 1 And Y = 1 Then 'wenn x=1 und taster gedrückt dann takt H2 = H2 + 1 Portd.1 = 1 Waitms 10 Portd.1 = 0 Y = 0 Else End If If H2 = 10 Then 'wenn h2 = 10 dann reset h2, set h1 H1 = H1 + 1 H2 = 0 Portd.0 = 1 Portd.3 = 1 Waitms 10 Portd.0 = 0 Portd.3 = 0 Else End If If H1 = 2 And H2 = 4 Then 'wenn h1 = 2 und h2 = 4 dann reset h1,h2 H1 = 0 H2 = 0 Portd.2 = 1 Portd.0 = 1 Waitms 10 Portd.2 = 0 Portd.0 = 0 Else End If 'Minuten: If X = 2 And Y = 1 Then 'wenn x=2 und taster gedrückt dann takt M2 = M2 + 1 Portd.6 = 1 Waitms 10 Portd.6 = 0 Y = 0 Else End If If M2 = 10 Then 'wenn min2 = 10 dann reset min2, set min1 M1 = M1 + 1 M2 = 0 Portd.5 = 1 Portb.2 = 1 Waitms 10 Portd.5 = 0 Portb.2 = 0 Else End If If M1 = 6 Then 'wenn min1 = 6 dann reset min1 M1 = 0 Portb.1 = 1 Waitms 10 Portb.1 = 0 Else End If 'Sekunden: If X = 3 And Y = 1 Then Portb.4 = 1 Waitms 20 Portb.4 = 0 'sekundentakt auf tastendruck S2 = S2 + 1 Y = 0 Else End If If S2 = 10 Then 'wenn s1 = 10 dann reset sek2, set sek1 S1 = S1 + 1 S2 = 0 Portb.3 = 1 Portc.0 = 1 Waitms 10 Portb.3 = 0 Portc.0 = 0 Else End If If S1 = 6 Then 'wenn sek1 = 6 dann reset sek1 S1 = 0 Portb.5 = 1 Waitms 10 Portb.5 = 0 Else End If 'Ende: Ende: Loop '------------------------ 'Unterprogramme: Sub Anhalten X = X + 1 End Sub Sub Stellen Y = 1 End Sub '------------------------ End
