> "make.exe" all -------- begin -------- avr-gcc (WinAVR 20080610) 4.3.0 Copyright (C) 2008 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. Size before: AVR Memory Usage ---------------- Device: atmega8 Program: 2346 bytes (28.6% Full) (.text + .data + .bootloader) Data: 0 bytes (0.0% Full) (.data + .bss + .noinit) AVR Memory Usage ---------------- Device: atmega8 Program: 2346 bytes (28.6% Full) (.text + .data + .bootloader) Data: 0 bytes (0.0% Full) (.data + .bss + .noinit) Linking: main.elf avr-gcc -mmcu=atmega8 -I. -gdwarf-2 -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wa,-adhlns=main.cpp.lst -I. -std=gnu99 -Wstrict-prototypes -DF_OSC=16000000 -DF_CPU=16000000 -MD -MP -MF .deppp/main.elf.d main.cpp --output main.elf -Wl,-Map=main.map,--cref -Wl,-u,vfprintf -lprintf_min -Wl,-u,vfscanf -lscanf_min cc1plus.exe: warning: command line option "-Wstrict-prototypes" is valid for Ada/C/ObjC but not for C++ cc1plus.exe: warning: command line option "-std=gnu99" is valid for C/ObjC but not for C++ Creating load file for Flash: main.hex avr-objcopy -O ihex -R .eeprom main.elf main.hex Creating load file for EEPROM: main.eep avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" \ --change-section-lma .eeprom=0 -O ihex main.elf main.eep c:\Programme\WinAVR\bin\avr-objcopy.exe: --change-section-lma .eeprom=0x00000000 never used Creating Extended Listing: main.lss avr-objdump -h -S main.elf > main.lss Creating Symbol Table: main.sym avr-nm -n main.elf > main.sym Size after: AVR Memory Usage ---------------- Device: atmega8 Program: 2300 bytes (28.1% Full) (.text + .data + .bootloader) Data: 0 bytes (0.0% Full) (.data + .bss + .noinit) AVR Memory Usage ---------------- Device: atmega8 Program: 2300 bytes (28.1% Full) (.text + .data + .bootloader) Data: 0 bytes (0.0% Full) (.data + .bss + .noinit) Errors: none -------- end -------- > Process Exit Code: 0 > Time Taken: 00:01
