# # Automatically generated make config: don't edit # Linux kernel version: 2.6.32-rc8 # Fri Jul 23 22:31:43 2010 # CONFIG_ARM=y CONFIG_HAVE_PWM=y CONFIG_SYS_SUPPORTS_APM_EMULATION=y CONFIG_GENERIC_GPIO=y CONFIG_NO_IOPORT=y CONFIG_GENERIC_HARDIRQS=y CONFIG_STACKTRACE_SUPPORT=y CONFIG_HAVE_LATENCYTOP_SUPPORT=y CONFIG_LOCKDEP_SUPPORT=y CONFIG_TRACE_IRQFLAGS_SUPPORT=y CONFIG_HARDIRQS_SW_RESEND=y CONFIG_GENERIC_IRQ_PROBE=y CONFIG_RWSEM_GENERIC_SPINLOCK=y CONFIG_ARCH_HAS_CPUFREQ=y CONFIG_GENERIC_HWEIGHT=y CONFIG_GENERIC_CALIBRATE_DELAY=y CONFIG_GENERIC_HARDIRQS_NO__DO_IRQ=y CONFIG_VECTORS_BASE=0xffff0000 CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config" CONFIG_CONSTRUCTORS=y # # General setup # CONFIG_EXPERIMENTAL=y CONFIG_BROKEN_ON_SMP=y CONFIG_INIT_ENV_ARG_LIMIT=32 CONFIG_LOCALVERSION="" # CONFIG_LOCALVERSION_AUTO is not set CONFIG_SWAP=y CONFIG_SYSVIPC=y CONFIG_SYSVIPC_SYSCTL=y CONFIG_POSIX_MQUEUE=y CONFIG_POSIX_MQUEUE_SYSCTL=y # CONFIG_BSD_PROCESS_ACCT is not set # CONFIG_TASKSTATS is not set # CONFIG_AUDIT is not set # # RCU Subsystem # CONFIG_TREE_RCU=y # CONFIG_TREE_PREEMPT_RCU is not set # CONFIG_RCU_TRACE is not set CONFIG_RCU_FANOUT=32 # CONFIG_RCU_FANOUT_EXACT is not set # CONFIG_TREE_RCU_TRACE is not set # CONFIG_IKCONFIG is not set CONFIG_LOG_BUF_SHIFT=17 # CONFIG_GROUP_SCHED is not set # CONFIG_CGROUPS is not set # CONFIG_SYSFS_DEPRECATED_V2 is not set CONFIG_RELAY=y # CONFIG_NAMESPACES is not set CONFIG_BLK_DEV_INITRD=y CONFIG_INITRAMFS_SOURCE="" CONFIG_RD_GZIP=y # CONFIG_RD_BZIP2 is not set CONFIG_RD_LZMA=y CONFIG_CC_OPTIMIZE_FOR_SIZE=y CONFIG_SYSCTL=y CONFIG_ANON_INODES=y CONFIG_EMBEDDED=y CONFIG_UID16=y CONFIG_SYSCTL_SYSCALL=y CONFIG_KALLSYMS=y # CONFIG_KALLSYMS_ALL is not set # CONFIG_KALLSYMS_EXTRA_PASS is not set CONFIG_HOTPLUG=y CONFIG_PRINTK=y CONFIG_BUG=y CONFIG_ELF_CORE=y CONFIG_BASE_FULL=y CONFIG_FUTEX=y CONFIG_EPOLL=y CONFIG_SIGNALFD=y CONFIG_TIMERFD=y CONFIG_EVENTFD=y CONFIG_SHMEM=y CONFIG_AIO=y # # Kernel Performance Events And Counters # CONFIG_VM_EVENT_COUNTERS=y CONFIG_SLUB_DEBUG=y # CONFIG_COMPAT_BRK is not set # CONFIG_SLAB is not set CONFIG_SLUB=y # CONFIG_SLOB is not set # CONFIG_PROFILING is not set CONFIG_HAVE_OPROFILE=y # CONFIG_KPROBES is not set CONFIG_HAVE_KPROBES=y CONFIG_HAVE_KRETPROBES=y CONFIG_HAVE_CLK=y # # GCOV-based kernel profiling # # CONFIG_GCOV_KERNEL is not set # CONFIG_SLOW_WORK is not set CONFIG_HAVE_GENERIC_DMA_COHERENT=y CONFIG_SLABINFO=y CONFIG_RT_MUTEXES=y CONFIG_BASE_SMALL=0 CONFIG_MODULES=y CONFIG_MODULE_FORCE_LOAD=y CONFIG_MODULE_UNLOAD=y CONFIG_MODULE_FORCE_UNLOAD=y # CONFIG_MODVERSIONS is not set # CONFIG_MODULE_SRCVERSION_ALL is not set CONFIG_BLOCK=y # CONFIG_LBDAF is not set # CONFIG_BLK_DEV_BSG is not set CONFIG_BLK_DEV_INTEGRITY=y # # IO Schedulers # CONFIG_IOSCHED_NOOP=y CONFIG_IOSCHED_AS=y CONFIG_IOSCHED_DEADLINE=y CONFIG_IOSCHED_CFQ=y CONFIG_DEFAULT_AS=y # CONFIG_DEFAULT_DEADLINE is not set # CONFIG_DEFAULT_CFQ is not set # CONFIG_DEFAULT_NOOP is not set CONFIG_DEFAULT_IOSCHED="anticipatory" CONFIG_FREEZER=y # # System Type # CONFIG_MMU=y # CONFIG_ARCH_AAEC2000 is not set # CONFIG_ARCH_INTEGRATOR is not set # CONFIG_ARCH_REALVIEW is not set # CONFIG_ARCH_VERSATILE is not set # CONFIG_ARCH_AT91 is not set # CONFIG_ARCH_CLPS711X is not set # CONFIG_ARCH_GEMINI is not set # CONFIG_ARCH_EBSA110 is not set # CONFIG_ARCH_EP93XX is not set # CONFIG_ARCH_FOOTBRIDGE is not set # CONFIG_ARCH_MXC is not set # CONFIG_ARCH_STMP3XXX is not set # CONFIG_ARCH_NETX is not set # CONFIG_ARCH_H720X is not set # CONFIG_ARCH_NOMADIK is not set # CONFIG_ARCH_IOP13XX is not set # CONFIG_ARCH_IOP32X is not set # CONFIG_ARCH_IOP33X is not set # CONFIG_ARCH_IXP23XX is not set # CONFIG_ARCH_IXP2000 is not set # CONFIG_ARCH_IXP4XX is not set # CONFIG_ARCH_L7200 is not set # CONFIG_ARCH_KIRKWOOD is not set # CONFIG_ARCH_LOKI is not set # CONFIG_ARCH_MV78XX0 is not set # CONFIG_ARCH_ORION5X is not set # CONFIG_ARCH_MMP is not set # CONFIG_ARCH_KS8695 is not set # CONFIG_ARCH_NS9XXX is not set # CONFIG_ARCH_W90X900 is not set # CONFIG_ARCH_PNX4008 is not set # CONFIG_ARCH_PXA is not set # CONFIG_ARCH_MSM is not set # CONFIG_ARCH_RPC is not set # CONFIG_ARCH_SA1100 is not set CONFIG_ARCH_S3C2410=y # CONFIG_ARCH_S3C64XX is not set # CONFIG_ARCH_S5PC1XX is not set # CONFIG_ARCH_SHARK is not set # CONFIG_ARCH_LH7A40X is not set # CONFIG_ARCH_U300 is not set # CONFIG_ARCH_DAVINCI is not set # CONFIG_ARCH_OMAP is not set # CONFIG_ARCH_BCMRING is not set CONFIG_PLAT_S3C24XX=y CONFIG_S3C2410_CLOCK=y CONFIG_CPU_S3C244X=y CONFIG_S3C2440_CPUFREQ=y CONFIG_S3C24XX_PWM=y CONFIG_S3C24XX_GPIO_EXTRA=0 CONFIG_S3C2410_DMA=y # CONFIG_S3C2410_DMA_DEBUG is not set CONFIG_S3C24XX_ADC=y CONFIG_S3C2410_CPUFREQ_UTILS=y CONFIG_PLAT_S3C=y CONFIG_CPU_LLSERIAL_S3C2440_ONLY=y CONFIG_CPU_LLSERIAL_S3C2440=y # # Boot options # # CONFIG_S3C_BOOT_WATCHDOG is not set # CONFIG_S3C_BOOT_ERROR_RESET is not set CONFIG_S3C_BOOT_UART_FORCE_FIFO=y # # Power management # # CONFIG_S3C2410_PM_DEBUG is not set # CONFIG_S3C2410_PM_CHECK is not set CONFIG_S3C_LOWLEVEL_UART_PORT=0 CONFIG_S3C_GPIO_SPACE=0 CONFIG_S3C_DMA=y CONFIG_S3C_DEV_USB_HOST=y CONFIG_S3C_DEV_NAND=y # # S3C2400 Machines # CONFIG_S3C2410_PM=y CONFIG_S3C2410_GPIO=y # # S3C2410 Machines # # CONFIG_ARCH_SMDK2410 is not set # CONFIG_ARCH_H1940 is not set # CONFIG_MACH_N30 is not set # CONFIG_ARCH_BAST is not set # CONFIG_MACH_OTOM is not set # CONFIG_MACH_AML_M5900 is not set # CONFIG_MACH_TCT_HAMMER is not set # CONFIG_MACH_VR1000 is not set # CONFIG_MACH_QT2410 is not set # # S3C2412 Machines # # CONFIG_MACH_JIVE is not set # CONFIG_MACH_SMDK2413 is not set # CONFIG_MACH_SMDK2412 is not set # CONFIG_MACH_VSTMS is not set CONFIG_CPU_S3C2440=y CONFIG_S3C2440_DMA=y # # S3C2440 Machines # # CONFIG_MACH_ANUBIS is not set # CONFIG_MACH_OSIRIS is not set # CONFIG_MACH_RX3715 is not set # CONFIG_ARCH_S3C2440 is not set # CONFIG_MACH_NEXCODER_2440 is not set # CONFIG_MACH_AT2440EVB is not set CONFIG_MACH_MINI2440=y # # S3C2442 Machines # # CONFIG_MACH_NEO1973_GTA02 is not set # # S3C2443 Machines # # CONFIG_MACH_SMDK2443 is not set # # Processor Type # CONFIG_CPU_32=y CONFIG_CPU_ARM920T=y CONFIG_CPU_32v4T=y CONFIG_CPU_ABRT_EV4T=y CONFIG_CPU_PABRT_LEGACY=y CONFIG_CPU_CACHE_V4WT=y CONFIG_CPU_CACHE_VIVT=y CONFIG_CPU_COPY_V4WB=y CONFIG_CPU_TLB_V4WBI=y CONFIG_CPU_CP15=y CONFIG_CPU_CP15_MMU=y # # Processor Features # CONFIG_ARM_THUMB=y # CONFIG_CPU_ICACHE_DISABLE is not set # CONFIG_CPU_DCACHE_DISABLE is not set # CONFIG_CPU_DCACHE_WRITETHROUGH is not set CONFIG_ARM_L1_CACHE_SHIFT=5 # # Bus support # # CONFIG_PCI_SYSCALL is not set # CONFIG_ARCH_SUPPORTS_MSI is not set # CONFIG_PCCARD is not set # # Kernel Features # CONFIG_VMSPLIT_3G=y # CONFIG_VMSPLIT_2G is not set # CONFIG_VMSPLIT_1G is not set CONFIG_PAGE_OFFSET=0xC0000000 CONFIG_PREEMPT_NONE=y # CONFIG_PREEMPT_VOLUNTARY is not set # CONFIG_PREEMPT is not set CONFIG_HZ=200 CONFIG_AEABI=y # CONFIG_OABI_COMPAT is not set # CONFIG_ARCH_SPARSEMEM_DEFAULT is not set # CONFIG_ARCH_SELECT_MEMORY_MODEL is not set # CONFIG_HIGHMEM is not set CONFIG_SELECT_MEMORY_MODEL=y CONFIG_FLATMEM_MANUAL=y # CONFIG_DISCONTIGMEM_MANUAL is not set # CONFIG_SPARSEMEM_MANUAL is not set CONFIG_FLATMEM=y CONFIG_FLAT_NODE_MEM_MAP=y CONFIG_PAGEFLAGS_EXTENDED=y CONFIG_SPLIT_PTLOCK_CPUS=4096 # CONFIG_PHYS_ADDR_T_64BIT is not set CONFIG_ZONE_DMA_FLAG=0 CONFIG_VIRT_TO_BUS=y CONFIG_HAVE_MLOCK=y CONFIG_HAVE_MLOCKED_PAGE_BIT=y # CONFIG_KSM is not set CONFIG_DEFAULT_MMAP_MIN_ADDR=4096 CONFIG_ALIGNMENT_TRAP=y CONFIG_UACCESS_WITH_MEMCPY=y # # Boot options # CONFIG_ZBOOT_ROM_TEXT=0 CONFIG_ZBOOT_ROM_BSS=0 CONFIG_CMDLINE="" # CONFIG_XIP_KERNEL is not set CONFIG_KEXEC=y CONFIG_ATAGS_PROC=y # # CPU Power Management # CONFIG_CPU_FREQ=y CONFIG_CPU_FREQ_TABLE=y # CONFIG_CPU_FREQ_DEBUG is not set CONFIG_CPU_FREQ_STAT=y # CONFIG_CPU_FREQ_STAT_DETAILS is not set CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set CONFIG_CPU_FREQ_GOV_PERFORMANCE=y CONFIG_CPU_FREQ_GOV_POWERSAVE=m CONFIG_CPU_FREQ_GOV_USERSPACE=m CONFIG_CPU_FREQ_GOV_ONDEMAND=m CONFIG_CPU_FREQ_GOV_CONSERVATIVE=m CONFIG_CPU_FREQ_S3C=y CONFIG_CPU_FREQ_S3C24XX=y CONFIG_CPU_FREQ_S3C24XX_PLL=y CONFIG_CPU_FREQ_S3C24XX_DEBUG=y # CONFIG_CPU_FREQ_S3C24XX_IODEBUG is not set # CONFIG_CPU_FREQ_S3C24XX_DEBUGFS is not set CONFIG_CPU_IDLE=y CONFIG_CPU_IDLE_GOV_LADDER=y # # Floating point emulation # # # At least one emulation must be selected # # # Userspace binary formats # CONFIG_BINFMT_ELF=y # CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set CONFIG_HAVE_AOUT=y CONFIG_BINFMT_AOUT=m CONFIG_BINFMT_MISC=m # # Power management options # CONFIG_PM=y # CONFIG_PM_DEBUG is not set CONFIG_PM_SLEEP=y CONFIG_SUSPEND=y CONFIG_SUSPEND_FREEZER=y CONFIG_APM_EMULATION=y # CONFIG_PM_RUNTIME is not set CONFIG_ARCH_SUSPEND_POSSIBLE=y CONFIG_NET=y # # Networking options # CONFIG_PACKET=y CONFIG_PACKET_MMAP=y CONFIG_UNIX=y CONFIG_XFRM=y CONFIG_XFRM_USER=m # CONFIG_XFRM_SUB_POLICY is not set # CONFIG_XFRM_MIGRATE is not set # CONFIG_XFRM_STATISTICS is not set CONFIG_NET_KEY=m # CONFIG_NET_KEY_MIGRATE is not set CONFIG_INET=y CONFIG_IP_MULTICAST=y CONFIG_IP_ADVANCED_ROUTER=y CONFIG_ASK_IP_FIB_HASH=y # CONFIG_IP_FIB_TRIE is not set CONFIG_IP_FIB_HASH=y CONFIG_IP_MULTIPLE_TABLES=y CONFIG_IP_ROUTE_MULTIPATH=y CONFIG_IP_ROUTE_VERBOSE=y CONFIG_IP_PNP=y CONFIG_IP_PNP_DHCP=y CONFIG_IP_PNP_BOOTP=y CONFIG_IP_PNP_RARP=y # CONFIG_NET_IPIP is not set # CONFIG_NET_IPGRE is not set CONFIG_IP_MROUTE=y CONFIG_IP_PIMSM_V1=y CONFIG_IP_PIMSM_V2=y # CONFIG_ARPD is not set CONFIG_SYN_COOKIES=y # CONFIG_INET_AH is not set # CONFIG_INET_ESP is not set # CONFIG_INET_IPCOMP is not set # CONFIG_INET_XFRM_TUNNEL is not set # CONFIG_INET_TUNNEL is not set # CONFIG_INET_XFRM_MODE_TRANSPORT is not set # CONFIG_INET_XFRM_MODE_TUNNEL is not set # CONFIG_INET_XFRM_MODE_BEET is not set # CONFIG_INET_LRO is not set CONFIG_INET_DIAG=m CONFIG_INET_TCP_DIAG=m # CONFIG_TCP_CONG_ADVANCED is not set CONFIG_TCP_CONG_CUBIC=y CONFIG_DEFAULT_TCP_CONG="cubic" # CONFIG_TCP_MD5SIG is not set # CONFIG_IPV6 is not set # CONFIG_NETWORK_SECMARK is not set CONFIG_NETFILTER=y # CONFIG_NETFILTER_DEBUG is not set CONFIG_NETFILTER_ADVANCED=y CONFIG_BRIDGE_NETFILTER=y # # Core Netfilter Configuration # # CONFIG_NETFILTER_NETLINK_QUEUE is not set # CONFIG_NETFILTER_NETLINK_LOG is not set # CONFIG_NF_CONNTRACK is not set # CONFIG_NETFILTER_XTABLES is not set # CONFIG_IP_VS is not set # # IP: Netfilter Configuration # # CONFIG_NF_DEFRAG_IPV4 is not set # CONFIG_IP_NF_QUEUE is not set # CONFIG_IP_NF_IPTABLES is not set # CONFIG_IP_NF_ARPTABLES is not set # CONFIG_BRIDGE_NF_EBTABLES is not set # CONFIG_IP_DCCP is not set # CONFIG_IP_SCTP is not set # CONFIG_RDS is not set # CONFIG_TIPC is not set # CONFIG_ATM is not set CONFIG_STP=m CONFIG_GARP=m CONFIG_BRIDGE=m # CONFIG_NET_DSA is not set CONFIG_VLAN_8021Q=m CONFIG_VLAN_8021Q_GVRP=y # CONFIG_DECNET is not set CONFIG_LLC=m # CONFIG_LLC2 is not set # CONFIG_IPX is not set # CONFIG_ATALK is not set # CONFIG_X25 is not set # CONFIG_LAPB is not set # CONFIG_ECONET is not set # CONFIG_WAN_ROUTER is not set # CONFIG_PHONET is not set # CONFIG_IEEE802154 is not set # CONFIG_NET_SCHED is not set # CONFIG_DCB is not set # # Network testing # CONFIG_NET_PKTGEN=m # CONFIG_HAMRADIO is not set # CONFIG_CAN is not set # CONFIG_IRDA is not set CONFIG_BT=m CONFIG_BT_L2CAP=m CONFIG_BT_SCO=m CONFIG_BT_RFCOMM=m CONFIG_BT_RFCOMM_TTY=y CONFIG_BT_BNEP=m CONFIG_BT_BNEP_MC_FILTER=y CONFIG_BT_BNEP_PROTO_FILTER=y CONFIG_BT_HIDP=m # # Bluetooth device drivers # CONFIG_BT_HCIBTUSB=m CONFIG_BT_HCIBTSDIO=m CONFIG_BT_HCIUART=m CONFIG_BT_HCIUART_H4=y CONFIG_BT_HCIUART_BCSP=y CONFIG_BT_HCIUART_LL=y CONFIG_BT_HCIBCM203X=m CONFIG_BT_HCIBPA10X=m CONFIG_BT_HCIBFUSB=m CONFIG_BT_HCIVHCI=m # CONFIG_BT_MRVL is not set # CONFIG_AF_RXRPC is not set CONFIG_FIB_RULES=y CONFIG_WIRELESS=y CONFIG_CFG80211=m # CONFIG_NL80211_TESTMODE is not set # CONFIG_CFG80211_DEVELOPER_WARNINGS is not set CONFIG_CFG80211_REG_DEBUG=y CONFIG_CFG80211_DEFAULT_PS=y CONFIG_CFG80211_DEFAULT_PS_VALUE=1 CONFIG_CFG80211_DEBUGFS=y CONFIG_WIRELESS_OLD_REGULATORY=y CONFIG_WIRELESS_EXT=y CONFIG_WIRELESS_EXT_SYSFS=y CONFIG_LIB80211=m CONFIG_LIB80211_CRYPT_WEP=m CONFIG_LIB80211_CRYPT_CCMP=m CONFIG_LIB80211_CRYPT_TKIP=m # CONFIG_LIB80211_DEBUG is not set CONFIG_MAC80211=m # CONFIG_MAC80211_RC_PID is not set CONFIG_MAC80211_RC_MINSTREL=y # CONFIG_MAC80211_RC_DEFAULT_PID is not set CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y CONFIG_MAC80211_RC_DEFAULT="minstrel" CONFIG_MAC80211_MESH=y CONFIG_MAC80211_LEDS=y # CONFIG_MAC80211_DEBUGFS is not set # CONFIG_MAC80211_DEBUG_MENU is not set # CONFIG_WIMAX is not set # CONFIG_RFKILL is not set # CONFIG_NET_9P is not set # # Device Drivers # # # Generic Driver Options # CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug" # CONFIG_DEVTMPFS is not set CONFIG_STANDALONE=y CONFIG_PREVENT_FIRMWARE_BUILD=y CONFIG_FW_LOADER=y # CONFIG_FIRMWARE_IN_KERNEL is not set CONFIG_EXTRA_FIRMWARE="" # CONFIG_DEBUG_DRIVER is not set # CONFIG_DEBUG_DEVRES is not set # CONFIG_SYS_HYPERVISOR is not set CONFIG_CONNECTOR=m CONFIG_MTD=y # CONFIG_MTD_DEBUG is not set # CONFIG_MTD_TESTS is not set CONFIG_MTD_CONCAT=y CONFIG_MTD_PARTITIONS=y # CONFIG_MTD_REDBOOT_PARTS is not set CONFIG_MTD_CMDLINE_PARTS=y # CONFIG_MTD_AFS_PARTS is not set # CONFIG_MTD_AR7_PARTS is not set # # User Modules And Translation Layers # CONFIG_MTD_CHAR=y CONFIG_MTD_BLKDEVS=y CONFIG_MTD_BLOCK=y # CONFIG_FTL is not set # CONFIG_NFTL is not set # CONFIG_INFTL is not set # CONFIG_RFD_FTL is not set # CONFIG_SSFDC is not set # CONFIG_MTD_OOPS is not set # # RAM/ROM/Flash chip drivers # CONFIG_MTD_CFI=y CONFIG_MTD_JEDECPROBE=y CONFIG_MTD_GEN_PROBE=y # CONFIG_MTD_CFI_ADV_OPTIONS is not set CONFIG_MTD_MAP_BANK_WIDTH_1=y CONFIG_MTD_MAP_BANK_WIDTH_2=y CONFIG_MTD_MAP_BANK_WIDTH_4=y # CONFIG_MTD_MAP_BANK_WIDTH_8 is not set # CONFIG_MTD_MAP_BANK_WIDTH_16 is not set # CONFIG_MTD_MAP_BANK_WIDTH_32 is not set CONFIG_MTD_CFI_I1=y CONFIG_MTD_CFI_I2=y # CONFIG_MTD_CFI_I4 is not set # CONFIG_MTD_CFI_I8 is not set # CONFIG_MTD_CFI_INTELEXT is not set CONFIG_MTD_CFI_AMDSTD=y CONFIG_MTD_CFI_STAA=y CONFIG_MTD_CFI_UTIL=y CONFIG_MTD_RAM=y CONFIG_MTD_ROM=y # CONFIG_MTD_ABSENT is not set # # Mapping drivers for chip access # # CONFIG_MTD_COMPLEX_MAPPINGS is not set # CONFIG_MTD_PHYSMAP is not set # CONFIG_MTD_ARM_INTEGRATOR is not set # CONFIG_MTD_IMPA7 is not set # CONFIG_MTD_PLATRAM is not set # # Self-contained MTD device drivers # # CONFIG_MTD_DATAFLASH is not set # CONFIG_MTD_M25P80 is not set # CONFIG_MTD_SST25L is not set # CONFIG_MTD_SLRAM is not set # CONFIG_MTD_PHRAM is not set # CONFIG_MTD_MTDRAM is not set # CONFIG_MTD_BLOCK2MTD is not set # # Disk-On-Chip Device Drivers # # CONFIG_MTD_DOC2000 is not set # CONFIG_MTD_DOC2001 is not set # CONFIG_MTD_DOC2001PLUS is not set CONFIG_MTD_NAND=y CONFIG_MTD_NAND_VERIFY_WRITE=y # CONFIG_MTD_NAND_ECC_SMC is not set # CONFIG_MTD_NAND_MUSEUM_IDS is not set # CONFIG_MTD_NAND_GPIO is not set CONFIG_MTD_NAND_IDS=y CONFIG_MTD_NAND_S3C2410=y # CONFIG_MTD_NAND_S3C2410_DEBUG is not set # CONFIG_MTD_NAND_S3C2410_HWECC is not set # CONFIG_MTD_NAND_S3C2410_CLKSTOP is not set # CONFIG_MTD_NAND_DISKONCHIP is not set # CONFIG_MTD_NAND_NANDSIM is not set CONFIG_MTD_NAND_PLATFORM=y # CONFIG_MTD_ALAUDA is not set # CONFIG_MTD_ONENAND is not set # # LPDDR flash memory drivers # CONFIG_MTD_LPDDR=y CONFIG_MTD_QINFO_PROBE=y # # UBI - Unsorted block images # CONFIG_MTD_UBI=y CONFIG_MTD_UBI_WL_THRESHOLD=4096 CONFIG_MTD_UBI_BEB_RESERVE=1 # CONFIG_MTD_UBI_GLUEBI is not set # # UBI debugging options # # CONFIG_MTD_UBI_DEBUG is not set # CONFIG_PARPORT is not set CONFIG_BLK_DEV=y # CONFIG_BLK_DEV_COW_COMMON is not set CONFIG_BLK_DEV_LOOP=m # CONFIG_BLK_DEV_CRYPTOLOOP is not set CONFIG_BLK_DEV_NBD=m # CONFIG_BLK_DEV_UB is not set CONFIG_BLK_DEV_RAM=y CONFIG_BLK_DEV_RAM_COUNT=16 CONFIG_BLK_DEV_RAM_SIZE=65536 # CONFIG_BLK_DEV_XIP is not set CONFIG_CDROM_PKTCDVD=m CONFIG_CDROM_PKTCDVD_BUFFERS=8 # CONFIG_CDROM_PKTCDVD_WCACHE is not set # CONFIG_ATA_OVER_ETH is not set # CONFIG_MG_DISK is not set CONFIG_MISC_DEVICES=y # CONFIG_ICS932S401 is not set # CONFIG_ENCLOSURE_SERVICES is not set # CONFIG_ISL29003 is not set # CONFIG_C2PORT is not set # # EEPROM support # CONFIG_EEPROM_AT24=y # CONFIG_EEPROM_AT25 is not set # CONFIG_EEPROM_LEGACY is not set # CONFIG_EEPROM_MAX6875 is not set # CONFIG_EEPROM_93CX6 is not set CONFIG_HAVE_IDE=y # CONFIG_IDE is not set # # SCSI device support # # CONFIG_RAID_ATTRS is not set CONFIG_SCSI=m CONFIG_SCSI_DMA=y # CONFIG_SCSI_TGT is not set # CONFIG_SCSI_NETLINK is not set # CONFIG_SCSI_PROC_FS is not set # # SCSI support type (disk, tape, CD-ROM) # CONFIG_BLK_DEV_SD=m # CONFIG_CHR_DEV_ST is not set # CONFIG_CHR_DEV_OSST is not set # CONFIG_BLK_DEV_SR is not set CONFIG_CHR_DEV_SG=m # CONFIG_CHR_DEV_SCH is not set # CONFIG_SCSI_MULTI_LUN is not set # CONFIG_SCSI_CONSTANTS is not set # CONFIG_SCSI_LOGGING is not set # CONFIG_SCSI_SCAN_ASYNC is not set CONFIG_SCSI_WAIT_SCAN=m # # SCSI Transports # # CONFIG_SCSI_SPI_ATTRS is not set # CONFIG_SCSI_FC_ATTRS is not set # CONFIG_SCSI_ISCSI_ATTRS is not set # CONFIG_SCSI_SAS_LIBSAS is not set # CONFIG_SCSI_SRP_ATTRS is not set # CONFIG_SCSI_LOWLEVEL is not set # CONFIG_SCSI_DH is not set # CONFIG_SCSI_OSD_INITIATOR is not set # CONFIG_ATA is not set # CONFIG_MD is not set CONFIG_NETDEVICES=y # CONFIG_DUMMY is not set # CONFIG_BONDING is not set # CONFIG_MACVLAN is not set # CONFIG_EQUALIZER is not set CONFIG_TUN=m # CONFIG_VETH is not set # CONFIG_PHYLIB is not set CONFIG_NET_ETHERNET=y CONFIG_MII=y # CONFIG_AX88796 is not set # CONFIG_SMC91X is not set CONFIG_DM9000=y CONFIG_DM9000_DEBUGLEVEL=4 # CONFIG_DM9000_FORCE_SIMPLE_PHY_POLL is not set # CONFIG_ENC28J60 is not set # CONFIG_ETHOC is not set # CONFIG_SMC911X is not set # CONFIG_SMSC911X is not set # CONFIG_DNET is not set # CONFIG_IBM_NEW_EMAC_ZMII is not set # CONFIG_IBM_NEW_EMAC_RGMII is not set # CONFIG_IBM_NEW_EMAC_TAH is not set # CONFIG_IBM_NEW_EMAC_EMAC4 is not set # CONFIG_IBM_NEW_EMAC_NO_FLOW_CTRL is not set # CONFIG_IBM_NEW_EMAC_MAL_CLR_ICINTSTAT is not set # CONFIG_IBM_NEW_EMAC_MAL_COMMON_ERR is not set # CONFIG_B44 is not set # CONFIG_KS8842 is not set # CONFIG_KS8851 is not set # CONFIG_KS8851_MLL is not set # CONFIG_NETDEV_1000 is not set # CONFIG_NETDEV_10000 is not set CONFIG_WLAN=y # CONFIG_WLAN_PRE80211 is not set CONFIG_WLAN_80211=y CONFIG_LIBERTAS=m # CONFIG_LIBERTAS_USB is not set CONFIG_LIBERTAS_SDIO=m # CONFIG_LIBERTAS_SPI is not set # CONFIG_LIBERTAS_DEBUG is not set # CONFIG_LIBERTAS_THINFIRM is not set # CONFIG_AT76C50X_USB is not set # CONFIG_USB_ZD1201 is not set # CONFIG_USB_NET_RNDIS_WLAN is not set # CONFIG_RTL8187 is not set # CONFIG_MAC80211_HWSIM is not set # CONFIG_P54_COMMON is not set # CONFIG_ATH_COMMON is not set CONFIG_HOSTAP=m CONFIG_HOSTAP_FIRMWARE=y CONFIG_HOSTAP_FIRMWARE_NVRAM=y # CONFIG_B43 is not set # CONFIG_B43LEGACY is not set CONFIG_ZD1211RW=m CONFIG_ZD1211RW_DEBUG=y # CONFIG_RT2X00 is not set # CONFIG_WL12XX is not set # CONFIG_IWM is not set # # Enable WiMAX (Networking options) to see the WiMAX drivers # # # USB Network Adapters # # CONFIG_USB_CATC is not set # CONFIG_USB_KAWETH is not set # CONFIG_USB_PEGASUS is not set # CONFIG_USB_RTL8150 is not set # CONFIG_USB_USBNET is not set # CONFIG_WAN is not set CONFIG_PPP=m CONFIG_PPP_MULTILINK=y CONFIG_PPP_FILTER=y CONFIG_PPP_ASYNC=m CONFIG_PPP_SYNC_TTY=m CONFIG_PPP_DEFLATE=m CONFIG_PPP_BSDCOMP=m CONFIG_PPP_MPPE=m # CONFIG_PPPOE is not set # CONFIG_PPPOL2TP is not set # CONFIG_SLIP is not set CONFIG_SLHC=m # CONFIG_NETCONSOLE is not set # CONFIG_NETPOLL is not set # CONFIG_NET_POLL_CONTROLLER is not set # CONFIG_ISDN is not set # CONFIG_PHONE is not set # # Input device support # CONFIG_INPUT=y CONFIG_INPUT_FF_MEMLESS=y # CONFIG_INPUT_POLLDEV is not set # # Userland interfaces # CONFIG_INPUT_MOUSEDEV=y CONFIG_INPUT_MOUSEDEV_PSAUX=y CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024 CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768 # CONFIG_INPUT_JOYDEV is not set CONFIG_INPUT_EVDEV=y CONFIG_INPUT_EVBUG=m # CONFIG_INPUT_APMPOWER is not set # # Input Device Drivers # CONFIG_INPUT_KEYBOARD=y # CONFIG_KEYBOARD_ADP5588 is not set # CONFIG_KEYBOARD_ATKBD is not set # CONFIG_QT2160 is not set # CONFIG_KEYBOARD_LKKBD is not set CONFIG_KEYBOARD_GPIO=y # CONFIG_KEYBOARD_MATRIX is not set # CONFIG_KEYBOARD_LM8323 is not set # CONFIG_KEYBOARD_MAX7359 is not set # CONFIG_KEYBOARD_NEWTON is not set # CONFIG_KEYBOARD_OPENCORES is not set # CONFIG_KEYBOARD_STOWAWAY is not set # CONFIG_KEYBOARD_SUNKBD is not set # CONFIG_KEYBOARD_XTKBD is not set CONFIG_INPUT_MOUSE=y CONFIG_MOUSE_PS2=y CONFIG_MOUSE_PS2_ALPS=y CONFIG_MOUSE_PS2_LOGIPS2PP=y CONFIG_MOUSE_PS2_SYNAPTICS=y CONFIG_MOUSE_PS2_TRACKPOINT=y # CONFIG_MOUSE_PS2_ELANTECH is not set # CONFIG_MOUSE_PS2_SENTELIC is not set # CONFIG_MOUSE_PS2_TOUCHKIT is not set # CONFIG_MOUSE_SERIAL is not set # CONFIG_MOUSE_APPLETOUCH is not set # CONFIG_MOUSE_BCM5974 is not set # CONFIG_MOUSE_VSXXXAA is not set # CONFIG_MOUSE_GPIO is not set # CONFIG_MOUSE_SYNAPTICS_I2C is not set # CONFIG_INPUT_JOYSTICK is not set # CONFIG_INPUT_TABLET is not set CONFIG_INPUT_TOUCHSCREEN=y CONFIG_TOUCHSCREEN_FILTER=y CONFIG_TOUCHSCREEN_FILTER_GROUP=y CONFIG_TOUCHSCREEN_FILTER_MEDIAN=y CONFIG_TOUCHSCREEN_FILTER_MEAN=y CONFIG_TOUCHSCREEN_FILTER_LINEAR=y # CONFIG_TOUCHSCREEN_ADS7846 is not set # CONFIG_TOUCHSCREEN_AD7877 is not set # CONFIG_TOUCHSCREEN_AD7879_I2C is not set # CONFIG_TOUCHSCREEN_AD7879_SPI is not set # CONFIG_TOUCHSCREEN_AD7879 is not set # CONFIG_TOUCHSCREEN_EETI is not set # CONFIG_TOUCHSCREEN_FUJITSU is not set CONFIG_TOUCHSCREEN_S3C2410=y # CONFIG_TOUCHSCREEN_S3C2410_DEBUG is not set # CONFIG_TOUCHSCREEN_GUNZE is not set # CONFIG_TOUCHSCREEN_ELO is not set # CONFIG_TOUCHSCREEN_WACOM_W8001 is not set # CONFIG_TOUCHSCREEN_MCS5000 is not set # CONFIG_TOUCHSCREEN_MTOUCH is not set # CONFIG_TOUCHSCREEN_INEXIO is not set # CONFIG_TOUCHSCREEN_MK712 is not set # CONFIG_TOUCHSCREEN_PENMOUNT is not set # CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set # CONFIG_TOUCHSCREEN_TOUCHWIN is not set # CONFIG_TOUCHSCREEN_WM97XX is not set # CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set # CONFIG_TOUCHSCREEN_TSC2007 is not set # CONFIG_TOUCHSCREEN_W90X900 is not set # CONFIG_INPUT_MISC is not set # # Hardware I/O ports # CONFIG_SERIO=y CONFIG_SERIO_SERPORT=y CONFIG_SERIO_LIBPS2=y CONFIG_SERIO_RAW=y # CONFIG_GAMEPORT is not set # # Character devices # CONFIG_VT=y CONFIG_CONSOLE_TRANSLATIONS=y CONFIG_VT_CONSOLE=y CONFIG_HW_CONSOLE=y CONFIG_VT_HW_CONSOLE_BINDING=y CONFIG_DEVKMEM=y # CONFIG_SERIAL_NONSTANDARD is not set # # Serial drivers # # CONFIG_SERIAL_8250 is not set # # Non-8250 serial port support # CONFIG_SERIAL_SAMSUNG=y CONFIG_SERIAL_SAMSUNG_UARTS=3 CONFIG_SERIAL_SAMSUNG_CONSOLE=y CONFIG_SERIAL_S3C2440=y # CONFIG_SERIAL_MAX3100 is not set CONFIG_SERIAL_CORE=y CONFIG_SERIAL_CORE_CONSOLE=y CONFIG_UNIX98_PTYS=y # CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set CONFIG_LEGACY_PTYS=y CONFIG_LEGACY_PTY_COUNT=128 CONFIG_IPMI_HANDLER=m # CONFIG_IPMI_PANIC_EVENT is not set CONFIG_IPMI_DEVICE_INTERFACE=m CONFIG_IPMI_SI=m CONFIG_IPMI_WATCHDOG=m CONFIG_IPMI_POWEROFF=m CONFIG_HW_RANDOM=y # CONFIG_HW_RANDOM_TIMERIOMEM is not set # CONFIG_R3964 is not set # CONFIG_RAW_DRIVER is not set # CONFIG_TCG_TPM is not set CONFIG_I2C=y CONFIG_I2C_BOARDINFO=y CONFIG_I2C_COMPAT=y CONFIG_I2C_CHARDEV=y CONFIG_I2C_HELPER_AUTO=y CONFIG_I2C_ALGOBIT=y # # I2C Hardware Bus support # # # I2C system bus drivers (mostly embedded / system-on-chip) # # CONFIG_I2C_DESIGNWARE is not set # CONFIG_I2C_GPIO is not set # CONFIG_I2C_OCORES is not set CONFIG_I2C_S3C2410=y CONFIG_I2C_SIMTEC=y # # External I2C/SMBus adapter drivers # # CONFIG_I2C_PARPORT_LIGHT is not set # CONFIG_I2C_TAOS_EVM is not set # CONFIG_I2C_TINY_USB is not set # # Other I2C/SMBus bus drivers # # CONFIG_I2C_PCA_PLATFORM is not set # CONFIG_I2C_STUB is not set # # Miscellaneous I2C Chip support # # CONFIG_DS1682 is not set CONFIG_SENSORS_TSL2550=m # CONFIG_I2C_DEBUG_CORE is not set # CONFIG_I2C_DEBUG_ALGO is not set # CONFIG_I2C_DEBUG_BUS is not set # CONFIG_I2C_DEBUG_CHIP is not set CONFIG_SPI=y # CONFIG_SPI_DEBUG is not set CONFIG_SPI_MASTER=y # # SPI Master Controller Drivers # CONFIG_SPI_BITBANG=y # CONFIG_SPI_GPIO is not set CONFIG_SPI_S3C24XX=y # CONFIG_SPI_S3C24XX_GPIO is not set # # SPI Protocol Masters # CONFIG_SPI_SPIDEV=y # CONFIG_SPI_TLE62X0 is not set # # PPS support # # CONFIG_PPS is not set CONFIG_ARCH_REQUIRE_GPIOLIB=y CONFIG_GPIOLIB=y # CONFIG_DEBUG_GPIO is not set CONFIG_GPIO_SYSFS=y # # Memory mapped GPIO expanders: # # # I2C GPIO expanders: # # CONFIG_GPIO_MAX732X is not set # CONFIG_GPIO_PCA953X is not set # CONFIG_GPIO_PCF857X is not set # # PCI GPIO expanders: # # # SPI GPIO expanders: # # CONFIG_GPIO_MAX7301 is not set # CONFIG_GPIO_MCP23S08 is not set # CONFIG_GPIO_MC33880 is not set # # AC97 GPIO expanders: # # CONFIG_W1 is not set # CONFIG_POWER_SUPPLY is not set # CONFIG_HWMON is not set # CONFIG_THERMAL is not set CONFIG_WATCHDOG=y # CONFIG_WATCHDOG_NOWAYOUT is not set # # Watchdog Device Drivers # # CONFIG_SOFT_WATCHDOG is not set CONFIG_S3C2410_WATCHDOG=y # # USB-based Watchdog Cards # # CONFIG_USBPCWATCHDOG is not set CONFIG_SSB_POSSIBLE=y # # Sonics Silicon Backplane # # CONFIG_SSB is not set # # Multifunction device drivers # # CONFIG_MFD_CORE is not set # CONFIG_MFD_SM501 is not set # CONFIG_MFD_ASIC3 is not set # CONFIG_HTC_EGPIO is not set # CONFIG_HTC_PASIC3 is not set # CONFIG_UCB1400_CORE is not set # CONFIG_TPS65010 is not set # CONFIG_TWL4030_CORE is not set # CONFIG_MFD_TMIO is not set # CONFIG_MFD_T7L66XB is not set # CONFIG_MFD_TC6387XB is not set # CONFIG_MFD_TC6393XB is not set # CONFIG_PMIC_DA903X is not set # CONFIG_MFD_WM8400 is not set # CONFIG_MFD_WM831X is not set # CONFIG_MFD_WM8350_I2C is not set # CONFIG_MFD_PCF50633 is not set # CONFIG_MFD_MC13783 is not set # CONFIG_AB3100_CORE is not set # CONFIG_EZX_PCAP is not set # CONFIG_REGULATOR is not set # CONFIG_MEDIA_SUPPORT is not set # # Graphics support # # CONFIG_VGASTATE is not set CONFIG_VIDEO_OUTPUT_CONTROL=y CONFIG_FB=y CONFIG_FIRMWARE_EDID=y # CONFIG_FB_DDC is not set # CONFIG_FB_BOOT_VESA_SUPPORT is not set CONFIG_FB_CFB_FILLRECT=y CONFIG_FB_CFB_COPYAREA=y CONFIG_FB_CFB_IMAGEBLIT=y # CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set # CONFIG_FB_SYS_FILLRECT is not set # CONFIG_FB_SYS_COPYAREA is not set # CONFIG_FB_SYS_IMAGEBLIT is not set # CONFIG_FB_FOREIGN_ENDIAN is not set # CONFIG_FB_SYS_FOPS is not set # CONFIG_FB_SVGALIB is not set # CONFIG_FB_MACMODES is not set # CONFIG_FB_BACKLIGHT is not set CONFIG_FB_MODE_HELPERS=y CONFIG_FB_TILEBLITTING=y # # Frame buffer hardware drivers # # CONFIG_FB_UVESA is not set # CONFIG_FB_S1D13XXX is not set CONFIG_FB_S3C2410=y # CONFIG_FB_S3C2410_DEBUG is not set # CONFIG_FB_VIRTUAL is not set # CONFIG_FB_METRONOME is not set # CONFIG_FB_MB862XX is not set # CONFIG_FB_BROADSHEET is not set CONFIG_BACKLIGHT_LCD_SUPPORT=y CONFIG_LCD_CLASS_DEVICE=y # CONFIG_LCD_LMS283GF05 is not set # CONFIG_LCD_LTV350QV is not set # CONFIG_LCD_ILI9320 is not set # CONFIG_LCD_TDO24M is not set # CONFIG_LCD_VGG2432A4 is not set CONFIG_LCD_PLATFORM=y CONFIG_BACKLIGHT_CLASS_DEVICE=y # CONFIG_BACKLIGHT_GENERIC is not set CONFIG_BACKLIGHT_PWM=y # # Display device support # CONFIG_DISPLAY_SUPPORT=y # # Display hardware drivers # # # Console display driver support # # CONFIG_VGA_CONSOLE is not set CONFIG_DUMMY_CONSOLE=y CONFIG_FRAMEBUFFER_CONSOLE=y CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y CONFIG_FONTS=y CONFIG_FONT_8x8=y # CONFIG_FONT_8x16 is not set # CONFIG_FONT_6x11 is not set # CONFIG_FONT_7x14 is not set # CONFIG_FONT_PEARL_8x8 is not set # CONFIG_FONT_ACORN_8x8 is not set CONFIG_FONT_MINI_4x6=y # CONFIG_FONT_SUN8x16 is not set # CONFIG_FONT_SUN12x22 is not set # CONFIG_FONT_10x18 is not set CONFIG_LOGO=y # CONFIG_LOGO_LINUX_MONO is not set # CONFIG_LOGO_LINUX_VGA16 is not set CONFIG_LOGO_LINUX_CLUT224=y CONFIG_SOUND=y CONFIG_SOUND_OSS_CORE=y CONFIG_SOUND_OSS_CORE_PRECLAIM=y CONFIG_SND=y CONFIG_SND_TIMER=y CONFIG_SND_PCM=y CONFIG_SND_HWDEP=m CONFIG_SND_RAWMIDI=m CONFIG_SND_JACK=y CONFIG_SND_SEQUENCER=y CONFIG_SND_SEQ_DUMMY=y CONFIG_SND_OSSEMUL=y CONFIG_SND_MIXER_OSS=y CONFIG_SND_PCM_OSS=y CONFIG_SND_PCM_OSS_PLUGINS=y CONFIG_SND_SEQUENCER_OSS=y CONFIG_SND_DYNAMIC_MINORS=y CONFIG_SND_SUPPORT_OLD_API=y CONFIG_SND_VERBOSE_PROCFS=y # CONFIG_SND_VERBOSE_PRINTK is not set # CONFIG_SND_DEBUG is not set CONFIG_SND_VMASTER=y CONFIG_SND_RAWMIDI_SEQ=m # CONFIG_SND_OPL3_LIB_SEQ is not set # CONFIG_SND_OPL4_LIB_SEQ is not set # CONFIG_SND_SBAWE_SEQ is not set # CONFIG_SND_EMU10K1_SEQ is not set CONFIG_SND_MPU401_UART=m CONFIG_SND_AC97_CODEC=y CONFIG_SND_DRIVERS=y # CONFIG_SND_DUMMY is not set CONFIG_SND_VIRMIDI=m CONFIG_SND_MTPAV=m CONFIG_SND_SERIAL_U16550=m CONFIG_SND_MPU401=m CONFIG_SND_AC97_POWER_SAVE=y CONFIG_SND_AC97_POWER_SAVE_DEFAULT=0 CONFIG_SND_ARM=y # CONFIG_SND_SPI is not set CONFIG_SND_USB=y CONFIG_SND_USB_AUDIO=m CONFIG_SND_USB_CAIAQ=m CONFIG_SND_USB_CAIAQ_INPUT=y CONFIG_SND_SOC=y CONFIG_SND_SOC_AC97_BUS=y CONFIG_SND_S3C24XX_SOC=y CONFIG_SND_S3C24XX_SOC_I2S=y CONFIG_SND_S3C2443_SOC_AC97=y CONFIG_SND_S3C24XX_SOC_LN2440SBC_ALC650=y CONFIG_SND_S3C24XX_SOC_S3C24XX_UDA134X=y CONFIG_SND_S3C24XX_SOC_SIMTEC=y CONFIG_SND_S3C24XX_SOC_SIMTEC_TLV320AIC23=y CONFIG_SND_S3C24XX_SOC_SIMTEC_HERMES=y CONFIG_SND_SOC_I2C_AND_SPI=y CONFIG_SND_SOC_ALL_CODECS=y CONFIG_SND_SOC_WM_HUBS=y CONFIG_SND_SOC_AC97_CODEC=y CONFIG_SND_SOC_AD1836=y CONFIG_SND_SOC_AD1938=y CONFIG_SND_SOC_AD1980=y CONFIG_SND_SOC_AD73311=y CONFIG_SND_SOC_AK4104=y CONFIG_SND_SOC_AK4535=y CONFIG_SND_SOC_AK4642=y CONFIG_SND_SOC_CS4270=y CONFIG_SND_SOC_L3=y CONFIG_SND_SOC_PCM3008=y CONFIG_SND_SOC_SPDIF=y CONFIG_SND_SOC_SSM2602=y CONFIG_SND_SOC_STAC9766=y CONFIG_SND_SOC_TLV320AIC23=y CONFIG_SND_SOC_TLV320AIC26=y CONFIG_SND_SOC_TLV320AIC3X=y CONFIG_SND_SOC_UDA134X=y CONFIG_SND_SOC_UDA1380=y CONFIG_SND_SOC_WM8510=y CONFIG_SND_SOC_WM8523=y CONFIG_SND_SOC_WM8580=y CONFIG_SND_SOC_WM8728=y CONFIG_SND_SOC_WM8731=y CONFIG_SND_SOC_WM8750=y CONFIG_SND_SOC_WM8753=y CONFIG_SND_SOC_WM8776=y CONFIG_SND_SOC_WM8900=y CONFIG_SND_SOC_WM8903=y CONFIG_SND_SOC_WM8940=y CONFIG_SND_SOC_WM8960=y CONFIG_SND_SOC_WM8961=y CONFIG_SND_SOC_WM8971=y CONFIG_SND_SOC_WM8974=y CONFIG_SND_SOC_WM8988=y CONFIG_SND_SOC_WM8990=y CONFIG_SND_SOC_WM8993=y CONFIG_SND_SOC_WM9081=y CONFIG_SND_SOC_WM9705=y CONFIG_SND_SOC_WM9712=y CONFIG_SND_SOC_WM9713=y CONFIG_SND_SOC_MAX9877=y # CONFIG_SOUND_PRIME is not set CONFIG_AC97_BUS=y CONFIG_HID_SUPPORT=y CONFIG_HID=y CONFIG_HIDRAW=y # # USB Input Devices # CONFIG_USB_HID=y CONFIG_HID_PID=y CONFIG_USB_HIDDEV=y # # Special HID drivers # # CONFIG_HID_A4TECH is not set # CONFIG_HID_APPLE is not set # CONFIG_HID_BELKIN is not set # CONFIG_HID_CHERRY is not set # CONFIG_HID_CHICONY is not set # CONFIG_HID_CYPRESS is not set # CONFIG_HID_DRAGONRISE is not set # CONFIG_HID_EZKEY is not set # CONFIG_HID_KYE is not set # CONFIG_HID_GYRATION is not set # CONFIG_HID_TWINHAN is not set # CONFIG_HID_KENSINGTON is not set # CONFIG_HID_LOGITECH is not set # CONFIG_HID_MICROSOFT is not set # CONFIG_HID_MONTEREY is not set # CONFIG_HID_NTRIG is not set # CONFIG_HID_PANTHERLORD is not set # CONFIG_HID_PETALYNX is not set # CONFIG_HID_SAMSUNG is not set # CONFIG_HID_SONY is not set # CONFIG_HID_SUNPLUS is not set # CONFIG_HID_GREENASIA is not set # CONFIG_HID_SMARTJOYPLUS is not set # CONFIG_HID_TOPSEED is not set # CONFIG_HID_THRUSTMASTER is not set # CONFIG_HID_WACOM is not set # CONFIG_HID_ZEROPLUS is not set CONFIG_USB_SUPPORT=y CONFIG_USB_ARCH_HAS_HCD=y CONFIG_USB_ARCH_HAS_OHCI=y # CONFIG_USB_ARCH_HAS_EHCI is not set CONFIG_USB=y # CONFIG_USB_DEBUG is not set # CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set # # Miscellaneous USB options # # CONFIG_USB_DEVICEFS is not set # CONFIG_USB_DEVICE_CLASS is not set # CONFIG_USB_DYNAMIC_MINORS is not set # CONFIG_USB_SUSPEND is not set # CONFIG_USB_OTG is not set # CONFIG_USB_OTG_WHITELIST is not set # CONFIG_USB_OTG_BLACKLIST_HUB is not set # CONFIG_USB_MON is not set # CONFIG_USB_WUSB is not set # CONFIG_USB_WUSB_CBAF is not set # # USB Host Controller Drivers # # CONFIG_USB_C67X00_HCD is not set # CONFIG_USB_OXU210HP_HCD is not set # CONFIG_USB_ISP116X_HCD is not set # CONFIG_USB_ISP1760_HCD is not set # CONFIG_USB_ISP1362_HCD is not set CONFIG_USB_OHCI_HCD=y # CONFIG_USB_OHCI_BIG_ENDIAN_DESC is not set # CONFIG_USB_OHCI_BIG_ENDIAN_MMIO is not set CONFIG_USB_OHCI_LITTLE_ENDIAN=y # CONFIG_USB_SL811_HCD is not set # CONFIG_USB_R8A66597_HCD is not set # CONFIG_USB_HWA_HCD is not set # CONFIG_USB_MUSB_HDRC is not set # CONFIG_USB_GADGET_MUSB_HDRC is not set # # USB Device Class drivers # CONFIG_USB_ACM=m # CONFIG_USB_PRINTER is not set CONFIG_USB_WDM=m # CONFIG_USB_TMC is not set # # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may # # # also be needed; see USB_STORAGE Help for more info # CONFIG_USB_STORAGE=m # CONFIG_USB_STORAGE_DEBUG is not set CONFIG_USB_STORAGE_DATAFAB=m # CONFIG_USB_STORAGE_FREECOM is not set CONFIG_USB_STORAGE_ISD200=m CONFIG_USB_STORAGE_USBAT=m # CONFIG_USB_STORAGE_SDDR09 is not set # CONFIG_USB_STORAGE_SDDR55 is not set # CONFIG_USB_STORAGE_JUMPSHOT is not set # CONFIG_USB_STORAGE_ALAUDA is not set # CONFIG_USB_STORAGE_ONETOUCH is not set # CONFIG_USB_STORAGE_KARMA is not set # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set CONFIG_USB_LIBUSUAL=y # # USB Imaging devices # # CONFIG_USB_MDC800 is not set # CONFIG_USB_MICROTEK is not set # # USB port drivers # CONFIG_USB_SERIAL=m # CONFIG_USB_EZUSB is not set # CONFIG_USB_SERIAL_GENERIC is not set # CONFIG_USB_SERIAL_AIRCABLE is not set # CONFIG_USB_SERIAL_ARK3116 is not set # CONFIG_USB_SERIAL_BELKIN is not set # CONFIG_USB_SERIAL_CH341 is not set # CONFIG_USB_SERIAL_WHITEHEAT is not set # CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set CONFIG_USB_SERIAL_CP210X=m # CONFIG_USB_SERIAL_CYPRESS_M8 is not set # CONFIG_USB_SERIAL_EMPEG is not set CONFIG_USB_SERIAL_FTDI_SIO=m # CONFIG_USB_SERIAL_FUNSOFT is not set # CONFIG_USB_SERIAL_VISOR is not set # CONFIG_USB_SERIAL_IPAQ is not set # CONFIG_USB_SERIAL_IR is not set # CONFIG_USB_SERIAL_EDGEPORT is not set # CONFIG_USB_SERIAL_EDGEPORT_TI is not set # CONFIG_USB_SERIAL_GARMIN is not set # CONFIG_USB_SERIAL_IPW is not set # CONFIG_USB_SERIAL_IUU is not set # CONFIG_USB_SERIAL_KEYSPAN_PDA is not set # CONFIG_USB_SERIAL_KEYSPAN is not set # CONFIG_USB_SERIAL_KLSI is not set # CONFIG_USB_SERIAL_KOBIL_SCT is not set # CONFIG_USB_SERIAL_MCT_U232 is not set # CONFIG_USB_SERIAL_MOS7720 is not set # CONFIG_USB_SERIAL_MOS7840 is not set # CONFIG_USB_SERIAL_MOTOROLA is not set # CONFIG_USB_SERIAL_NAVMAN is not set # CONFIG_USB_SERIAL_PL2303 is not set # CONFIG_USB_SERIAL_OTI6858 is not set # CONFIG_USB_SERIAL_QUALCOMM is not set CONFIG_USB_SERIAL_SPCP8X5=m # CONFIG_USB_SERIAL_HP4X is not set # CONFIG_USB_SERIAL_SAFE is not set # CONFIG_USB_SERIAL_SIEMENS_MPI is not set # CONFIG_USB_SERIAL_SIERRAWIRELESS is not set # CONFIG_USB_SERIAL_SYMBOL is not set # CONFIG_USB_SERIAL_TI is not set # CONFIG_USB_SERIAL_CYBERJACK is not set # CONFIG_USB_SERIAL_XIRCOM is not set # CONFIG_USB_SERIAL_OPTION is not set # CONFIG_USB_SERIAL_OMNINET is not set # CONFIG_USB_SERIAL_OPTICON is not set # CONFIG_USB_SERIAL_DEBUG is not set # # USB Miscellaneous drivers # # CONFIG_USB_EMI62 is not set # CONFIG_USB_EMI26 is not set # CONFIG_USB_ADUTUX is not set # CONFIG_USB_SEVSEG is not set # CONFIG_USB_RIO500 is not set # CONFIG_USB_LEGOTOWER is not set # CONFIG_USB_LCD is not set # CONFIG_USB_BERRY_CHARGE is not set # CONFIG_USB_LED is not set # CONFIG_USB_CYPRESS_CY7C63 is not set # CONFIG_USB_CYTHERM is not set # CONFIG_USB_IDMOUSE is not set # CONFIG_USB_FTDI_ELAN is not set # CONFIG_USB_APPLEDISPLAY is not set # CONFIG_USB_LD is not set # CONFIG_USB_TRANCEVIBRATOR is not set # CONFIG_USB_IOWARRIOR is not set # CONFIG_USB_TEST is not set # CONFIG_USB_ISIGHTFW is not set # CONFIG_USB_VST is not set CONFIG_USB_GADGET=m # CONFIG_USB_GADGET_DEBUG is not set # CONFIG_USB_GADGET_DEBUG_FILES is not set # CONFIG_USB_GADGET_DEBUG_FS is not set CONFIG_USB_GADGET_VBUS_DRAW=2 CONFIG_USB_GADGET_SELECTED=y # CONFIG_USB_GADGET_AT91 is not set # CONFIG_USB_GADGET_ATMEL_USBA is not set # CONFIG_USB_GADGET_FSL_USB2 is not set # CONFIG_USB_GADGET_LH7A40X is not set # CONFIG_USB_GADGET_OMAP is not set # CONFIG_USB_GADGET_PXA25X is not set # CONFIG_USB_GADGET_R8A66597 is not set # CONFIG_USB_GADGET_PXA27X is not set # CONFIG_USB_GADGET_S3C_HSOTG is not set # CONFIG_USB_GADGET_IMX is not set CONFIG_USB_GADGET_S3C2410=y CONFIG_USB_S3C2410=m # CONFIG_USB_S3C2410_DEBUG is not set # CONFIG_USB_GADGET_M66592 is not set # CONFIG_USB_GADGET_AMD5536UDC is not set # CONFIG_USB_GADGET_FSL_QE is not set # CONFIG_USB_GADGET_CI13XXX is not set # CONFIG_USB_GADGET_NET2280 is not set # CONFIG_USB_GADGET_GOKU is not set # CONFIG_USB_GADGET_LANGWELL is not set # CONFIG_USB_GADGET_DUMMY_HCD is not set # CONFIG_USB_GADGET_DUALSPEED is not set CONFIG_USB_ZERO=m CONFIG_USB_AUDIO=m CONFIG_USB_ETH=m CONFIG_USB_ETH_RNDIS=y # CONFIG_USB_ETH_EEM is not set CONFIG_USB_GADGETFS=m CONFIG_USB_FILE_STORAGE=m # CONFIG_USB_FILE_STORAGE_TEST is not set CONFIG_USB_G_SERIAL=m CONFIG_USB_MIDI_GADGET=m CONFIG_USB_G_PRINTER=m CONFIG_USB_CDC_COMPOSITE=m # # OTG and related infrastructure # # CONFIG_USB_GPIO_VBUS is not set # CONFIG_NOP_USB_XCEIV is not set CONFIG_MMC=y # CONFIG_MMC_DEBUG is not set # CONFIG_MMC_UNSAFE_RESUME is not set # # MMC/SD/SDIO Card Drivers # CONFIG_MMC_BLOCK=y CONFIG_MMC_BLOCK_BOUNCE=y CONFIG_SDIO_UART=m # CONFIG_MMC_TEST is not set # # MMC/SD/SDIO Host Controller Drivers # CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_PLTFM=y CONFIG_MMC_SDHCI_S3C=y CONFIG_MMC_SDHCI_S3C_DMA=y # CONFIG_MMC_AT91 is not set # CONFIG_MMC_ATMELMCI is not set CONFIG_MMC_SPI=m CONFIG_MMC_S3C=y # CONFIG_MMC_S3C_HW_SDIO_IRQ is not set CONFIG_MMC_S3C_PIO=y # CONFIG_MMC_S3C_DMA is not set # CONFIG_MMC_S3C_PIODMA is not set # CONFIG_MEMSTICK is not set CONFIG_NEW_LEDS=y CONFIG_LEDS_CLASS=y # # LED drivers # CONFIG_LEDS_S3C24XX=y # CONFIG_LEDS_PCA9532 is not set CONFIG_LEDS_GPIO=y CONFIG_LEDS_GPIO_PLATFORM=y # CONFIG_LEDS_LP3944 is not set # CONFIG_LEDS_PCA955X is not set # CONFIG_LEDS_DAC124S085 is not set # CONFIG_LEDS_PWM is not set # CONFIG_LEDS_BD2802 is not set # # LED Triggers # CONFIG_LEDS_TRIGGERS=y CONFIG_LEDS_TRIGGER_TIMER=y CONFIG_LEDS_TRIGGER_HEARTBEAT=y CONFIG_LEDS_TRIGGER_BACKLIGHT=y CONFIG_LEDS_TRIGGER_GPIO=y CONFIG_LEDS_TRIGGER_DEFAULT_ON=y # # iptables trigger is under Netfilter config (LED target) # # CONFIG_ACCESSIBILITY is not set CONFIG_RTC_LIB=y CONFIG_RTC_CLASS=y CONFIG_RTC_HCTOSYS=y CONFIG_RTC_HCTOSYS_DEVICE="rtc0" # CONFIG_RTC_DEBUG is not set # # RTC interfaces # CONFIG_RTC_INTF_SYSFS=y CONFIG_RTC_INTF_PROC=y CONFIG_RTC_INTF_DEV=y CONFIG_RTC_INTF_DEV_UIE_EMUL=y # CONFIG_RTC_DRV_TEST is not set # # I2C RTC drivers # # CONFIG_RTC_DRV_DS1307 is not set # CONFIG_RTC_DRV_DS1374 is not set # CONFIG_RTC_DRV_DS1672 is not set # CONFIG_RTC_DRV_MAX6900 is not set # CONFIG_RTC_DRV_RS5C372 is not set # CONFIG_RTC_DRV_ISL1208 is not set # CONFIG_RTC_DRV_X1205 is not set # CONFIG_RTC_DRV_PCF8563 is not set # CONFIG_RTC_DRV_PCF8583 is not set # CONFIG_RTC_DRV_M41T80 is not set # CONFIG_RTC_DRV_S35390A is not set # CONFIG_RTC_DRV_FM3130 is not set # CONFIG_RTC_DRV_RX8581 is not set # CONFIG_RTC_DRV_RX8025 is not set # # SPI RTC drivers # # CONFIG_RTC_DRV_M41T94 is not set # CONFIG_RTC_DRV_DS1305 is not set # CONFIG_RTC_DRV_DS1390 is not set # CONFIG_RTC_DRV_MAX6902 is not set # CONFIG_RTC_DRV_R9701 is not set # CONFIG_RTC_DRV_RS5C348 is not set # CONFIG_RTC_DRV_DS3234 is not set # CONFIG_RTC_DRV_PCF2123 is not set # # Platform RTC drivers # # CONFIG_RTC_DRV_CMOS is not set # CONFIG_RTC_DRV_DS1286 is not set # CONFIG_RTC_DRV_DS1511 is not set # CONFIG_RTC_DRV_DS1553 is not set # CONFIG_RTC_DRV_DS1742 is not set # CONFIG_RTC_DRV_STK17TA8 is not set # CONFIG_RTC_DRV_M48T86 is not set # CONFIG_RTC_DRV_M48T35 is not set # CONFIG_RTC_DRV_M48T59 is not set # CONFIG_RTC_DRV_BQ4802 is not set # CONFIG_RTC_DRV_V3020 is not set # # on-CPU RTC drivers # CONFIG_RTC_DRV_S3C=y CONFIG_DMADEVICES=y # # DMA Devices # # CONFIG_AUXDISPLAY is not set # CONFIG_UIO is not set # # TI VLYNQ # # CONFIG_STAGING is not set # # File systems # CONFIG_EXT2_FS=m CONFIG_EXT2_FS_XATTR=y CONFIG_EXT2_FS_POSIX_ACL=y CONFIG_EXT2_FS_SECURITY=y CONFIG_EXT2_FS_XIP=y CONFIG_EXT3_FS=y # CONFIG_EXT3_DEFAULTS_TO_ORDERED is not set CONFIG_EXT3_FS_XATTR=y CONFIG_EXT3_FS_POSIX_ACL=y CONFIG_EXT3_FS_SECURITY=y # CONFIG_EXT4_FS is not set CONFIG_FS_XIP=y CONFIG_JBD=y # CONFIG_JBD_DEBUG is not set CONFIG_FS_MBCACHE=y # CONFIG_REISERFS_FS is not set # CONFIG_JFS_FS is not set CONFIG_FS_POSIX_ACL=y # CONFIG_XFS_FS is not set # CONFIG_OCFS2_FS is not set # CONFIG_BTRFS_FS is not set # CONFIG_NILFS2_FS is not set CONFIG_FILE_LOCKING=y CONFIG_FSNOTIFY=y CONFIG_DNOTIFY=y CONFIG_INOTIFY=y CONFIG_INOTIFY_USER=y # CONFIG_QUOTA is not set CONFIG_AUTOFS_FS=y CONFIG_AUTOFS4_FS=y # CONFIG_FUSE_FS is not set CONFIG_GENERIC_ACL=y # # Caches # # CONFIG_FSCACHE is not set # # CD-ROM/DVD Filesystems # # CONFIG_ISO9660_FS is not set # CONFIG_UDF_FS is not set # # DOS/FAT/NT Filesystems # CONFIG_FAT_FS=y CONFIG_MSDOS_FS=y CONFIG_VFAT_FS=y CONFIG_FAT_DEFAULT_CODEPAGE=437 CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1" # CONFIG_NTFS_FS is not set # # Pseudo filesystems # CONFIG_PROC_FS=y CONFIG_PROC_SYSCTL=y CONFIG_PROC_PAGE_MONITOR=y CONFIG_SYSFS=y CONFIG_TMPFS=y CONFIG_TMPFS_POSIX_ACL=y # CONFIG_HUGETLB_PAGE is not set CONFIG_CONFIGFS_FS=m CONFIG_MISC_FILESYSTEMS=y # CONFIG_ADFS_FS is not set # CONFIG_AFFS_FS is not set # CONFIG_ECRYPT_FS is not set # CONFIG_HFS_FS is not set # CONFIG_HFSPLUS_FS is not set # CONFIG_BEFS_FS is not set # CONFIG_BFS_FS is not set # CONFIG_EFS_FS is not set CONFIG_JFFS2_FS=y CONFIG_JFFS2_FS_DEBUG=0 CONFIG_JFFS2_FS_WRITEBUFFER=y # CONFIG_JFFS2_FS_WBUF_VERIFY is not set # CONFIG_JFFS2_SUMMARY is not set # CONFIG_JFFS2_FS_XATTR is not set # CONFIG_JFFS2_COMPRESSION_OPTIONS is not set CONFIG_JFFS2_ZLIB=y # CONFIG_JFFS2_LZO is not set CONFIG_JFFS2_RTIME=y # CONFIG_JFFS2_RUBIN is not set CONFIG_UBIFS_FS=m # CONFIG_UBIFS_FS_XATTR is not set # CONFIG_UBIFS_FS_ADVANCED_COMPR is not set CONFIG_UBIFS_FS_LZO=y CONFIG_UBIFS_FS_ZLIB=y # CONFIG_UBIFS_FS_DEBUG is not set # CONFIG_CRAMFS is not set CONFIG_SQUASHFS=y # CONFIG_SQUASHFS_EMBEDDED is not set CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3 # CONFIG_VXFS_FS is not set # CONFIG_MINIX_FS is not set # CONFIG_OMFS_FS is not set # CONFIG_HPFS_FS is not set # CONFIG_QNX4FS_FS is not set # CONFIG_ROMFS_FS is not set # CONFIG_SYSV_FS is not set # CONFIG_UFS_FS is not set CONFIG_NETWORK_FILESYSTEMS=y CONFIG_NFS_FS=y CONFIG_NFS_V3=y CONFIG_NFS_V3_ACL=y CONFIG_NFS_V4=y # CONFIG_NFS_V4_1 is not set CONFIG_ROOT_NFS=y # CONFIG_NFSD is not set CONFIG_LOCKD=y CONFIG_LOCKD_V4=y CONFIG_NFS_ACL_SUPPORT=y CONFIG_NFS_COMMON=y CONFIG_SUNRPC=y CONFIG_SUNRPC_GSS=y CONFIG_RPCSEC_GSS_KRB5=y # CONFIG_RPCSEC_GSS_SPKM3 is not set # CONFIG_SMB_FS is not set # CONFIG_CIFS is not set # CONFIG_NCP_FS is not set # CONFIG_CODA_FS is not set # CONFIG_AFS_FS is not set # # Partition Types # CONFIG_PARTITION_ADVANCED=y # CONFIG_ACORN_PARTITION is not set # CONFIG_OSF_PARTITION is not set # CONFIG_AMIGA_PARTITION is not set # CONFIG_ATARI_PARTITION is not set # CONFIG_MAC_PARTITION is not set CONFIG_MSDOS_PARTITION=y CONFIG_BSD_DISKLABEL=y CONFIG_MINIX_SUBPARTITION=y CONFIG_SOLARIS_X86_PARTITION=y CONFIG_UNIXWARE_DISKLABEL=y CONFIG_LDM_PARTITION=y # CONFIG_LDM_DEBUG is not set # CONFIG_SGI_PARTITION is not set # CONFIG_ULTRIX_PARTITION is not set # CONFIG_SUN_PARTITION is not set # CONFIG_KARMA_PARTITION is not set CONFIG_EFI_PARTITION=y # CONFIG_SYSV68_PARTITION is not set CONFIG_NLS=y CONFIG_NLS_DEFAULT="cp437" CONFIG_NLS_CODEPAGE_437=m CONFIG_NLS_CODEPAGE_737=m CONFIG_NLS_CODEPAGE_775=m CONFIG_NLS_CODEPAGE_850=m CONFIG_NLS_CODEPAGE_852=m CONFIG_NLS_CODEPAGE_855=m CONFIG_NLS_CODEPAGE_857=m CONFIG_NLS_CODEPAGE_860=m CONFIG_NLS_CODEPAGE_861=m CONFIG_NLS_CODEPAGE_862=m CONFIG_NLS_CODEPAGE_863=m CONFIG_NLS_CODEPAGE_864=m CONFIG_NLS_CODEPAGE_865=m CONFIG_NLS_CODEPAGE_866=m CONFIG_NLS_CODEPAGE_869=m CONFIG_NLS_CODEPAGE_936=m CONFIG_NLS_CODEPAGE_950=m CONFIG_NLS_CODEPAGE_932=m CONFIG_NLS_CODEPAGE_949=m CONFIG_NLS_CODEPAGE_874=m CONFIG_NLS_ISO8859_8=m CONFIG_NLS_CODEPAGE_1250=m CONFIG_NLS_CODEPAGE_1251=m CONFIG_NLS_ASCII=m CONFIG_NLS_ISO8859_1=m CONFIG_NLS_ISO8859_2=m CONFIG_NLS_ISO8859_3=m CONFIG_NLS_ISO8859_4=m CONFIG_NLS_ISO8859_5=m CONFIG_NLS_ISO8859_6=m CONFIG_NLS_ISO8859_7=m CONFIG_NLS_ISO8859_9=m CONFIG_NLS_ISO8859_13=m CONFIG_NLS_ISO8859_14=m CONFIG_NLS_ISO8859_15=m CONFIG_NLS_KOI8_R=m CONFIG_NLS_KOI8_U=m CONFIG_NLS_UTF8=m # CONFIG_DLM is not set # # Kernel hacking # # CONFIG_PRINTK_TIME is not set # CONFIG_ENABLE_WARN_DEPRECATED is not set # CONFIG_ENABLE_MUST_CHECK is not set CONFIG_FRAME_WARN=1024 # CONFIG_MAGIC_SYSRQ is not set CONFIG_STRIP_ASM_SYMS=y # CONFIG_UNUSED_SYMBOLS is not set CONFIG_DEBUG_FS=y # CONFIG_HEADERS_CHECK is not set CONFIG_DEBUG_KERNEL=y # CONFIG_DEBUG_SHIRQ is not set CONFIG_DETECT_SOFTLOCKUP=y # CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC is not set CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC_VALUE=0 CONFIG_DETECT_HUNG_TASK=y # CONFIG_BOOTPARAM_HUNG_TASK_PANIC is not set CONFIG_BOOTPARAM_HUNG_TASK_PANIC_VALUE=0 # CONFIG_SCHED_DEBUG is not set # CONFIG_SCHEDSTATS is not set # CONFIG_TIMER_STATS is not set # CONFIG_DEBUG_OBJECTS is not set # CONFIG_SLUB_DEBUG_ON is not set # CONFIG_SLUB_STATS is not set # CONFIG_DEBUG_KMEMLEAK is not set # CONFIG_DEBUG_RT_MUTEXES is not set # CONFIG_RT_MUTEX_TESTER is not set # CONFIG_DEBUG_SPINLOCK is not set # CONFIG_DEBUG_MUTEXES is not set # CONFIG_DEBUG_LOCK_ALLOC is not set # CONFIG_PROVE_LOCKING is not set # CONFIG_LOCK_STAT is not set # CONFIG_DEBUG_SPINLOCK_SLEEP is not set # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set # CONFIG_DEBUG_KOBJECT is not set # CONFIG_DEBUG_BUGVERBOSE is not set CONFIG_DEBUG_INFO=y # CONFIG_DEBUG_VM is not set # CONFIG_DEBUG_WRITECOUNT is not set # CONFIG_DEBUG_MEMORY_INIT is not set # CONFIG_DEBUG_LIST is not set # CONFIG_DEBUG_SG is not set # CONFIG_DEBUG_NOTIFIERS is not set # CONFIG_DEBUG_CREDENTIALS is not set # CONFIG_BOOT_PRINTK_DELAY is not set # CONFIG_RCU_TORTURE_TEST is not set # CONFIG_RCU_CPU_STALL_DETECTOR is not set # CONFIG_BACKTRACE_SELF_TEST is not set # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set # CONFIG_FAULT_INJECTION is not set # CONFIG_LATENCYTOP is not set CONFIG_SYSCTL_SYSCALL_CHECK=y # CONFIG_PAGE_POISONING is not set CONFIG_HAVE_FUNCTION_TRACER=y CONFIG_TRACING_SUPPORT=y CONFIG_FTRACE=y # CONFIG_FUNCTION_TRACER is not set # CONFIG_SCHED_TRACER is not set # CONFIG_ENABLE_DEFAULT_TRACERS is not set # CONFIG_BOOT_TRACER is not set CONFIG_BRANCH_PROFILE_NONE=y # CONFIG_PROFILE_ANNOTATED_BRANCHES is not set # CONFIG_PROFILE_ALL_BRANCHES is not set # CONFIG_STACK_TRACER is not set # CONFIG_KMEMTRACE is not set # CONFIG_WORKQUEUE_TRACER is not set # CONFIG_BLK_DEV_IO_TRACE is not set # CONFIG_DYNAMIC_DEBUG is not set # CONFIG_SAMPLES is not set CONFIG_HAVE_ARCH_KGDB=y # CONFIG_KGDB is not set CONFIG_ARM_UNWIND=y CONFIG_DEBUG_USER=y # CONFIG_DEBUG_ERRORS is not set # CONFIG_DEBUG_STACK_USAGE is not set # CONFIG_DEBUG_LL is not set CONFIG_DEBUG_S3C_UART=0 # # Security options # CONFIG_KEYS=y # CONFIG_KEYS_DEBUG_PROC_KEYS is not set # CONFIG_SECURITY is not set # CONFIG_SECURITYFS is not set CONFIG_SECURITY_FILE_CAPABILITIES=y CONFIG_CRYPTO=y # # Crypto core or helper # CONFIG_CRYPTO_FIPS=y CONFIG_CRYPTO_ALGAPI=y CONFIG_CRYPTO_ALGAPI2=y CONFIG_CRYPTO_AEAD=m CONFIG_CRYPTO_AEAD2=y CONFIG_CRYPTO_BLKCIPHER=y CONFIG_CRYPTO_BLKCIPHER2=y CONFIG_CRYPTO_HASH=y CONFIG_CRYPTO_HASH2=y CONFIG_CRYPTO_RNG=m CONFIG_CRYPTO_RNG2=y CONFIG_CRYPTO_PCOMP=y CONFIG_CRYPTO_MANAGER=y CONFIG_CRYPTO_MANAGER2=y CONFIG_CRYPTO_GF128MUL=m CONFIG_CRYPTO_NULL=m CONFIG_CRYPTO_WORKQUEUE=y CONFIG_CRYPTO_CRYPTD=m CONFIG_CRYPTO_AUTHENC=m CONFIG_CRYPTO_TEST=m # # Authenticated Encryption with Associated Data # CONFIG_CRYPTO_CCM=m CONFIG_CRYPTO_GCM=m CONFIG_CRYPTO_SEQIV=m # # Block modes # CONFIG_CRYPTO_CBC=y CONFIG_CRYPTO_CTR=m CONFIG_CRYPTO_CTS=m CONFIG_CRYPTO_ECB=y CONFIG_CRYPTO_LRW=m CONFIG_CRYPTO_PCBC=m CONFIG_CRYPTO_XTS=m # # Hash modes # CONFIG_CRYPTO_HMAC=y CONFIG_CRYPTO_XCBC=m # CONFIG_CRYPTO_VMAC is not set # # Digest # CONFIG_CRYPTO_CRC32C=m CONFIG_CRYPTO_GHASH=m CONFIG_CRYPTO_MD4=m CONFIG_CRYPTO_MD5=y CONFIG_CRYPTO_MICHAEL_MIC=y CONFIG_CRYPTO_RMD128=m CONFIG_CRYPTO_RMD160=m CONFIG_CRYPTO_RMD256=m CONFIG_CRYPTO_RMD320=m CONFIG_CRYPTO_SHA1=m CONFIG_CRYPTO_SHA256=m CONFIG_CRYPTO_SHA512=m CONFIG_CRYPTO_TGR192=m CONFIG_CRYPTO_WP512=m # # Ciphers # CONFIG_CRYPTO_AES=y CONFIG_CRYPTO_ANUBIS=m CONFIG_CRYPTO_ARC4=y CONFIG_CRYPTO_BLOWFISH=m CONFIG_CRYPTO_CAMELLIA=m CONFIG_CRYPTO_CAST5=m CONFIG_CRYPTO_CAST6=m CONFIG_CRYPTO_DES=y CONFIG_CRYPTO_FCRYPT=m CONFIG_CRYPTO_KHAZAD=m CONFIG_CRYPTO_SALSA20=m CONFIG_CRYPTO_SEED=m CONFIG_CRYPTO_SERPENT=m CONFIG_CRYPTO_TEA=m CONFIG_CRYPTO_TWOFISH=m CONFIG_CRYPTO_TWOFISH_COMMON=m # # Compression # CONFIG_CRYPTO_DEFLATE=m CONFIG_CRYPTO_ZLIB=m CONFIG_CRYPTO_LZO=m # # Random Number Generation # CONFIG_CRYPTO_ANSI_CPRNG=m CONFIG_CRYPTO_HW=y # CONFIG_BINARY_PRINTF is not set # # Library routines # CONFIG_BITREVERSE=y CONFIG_GENERIC_FIND_LAST_BIT=y CONFIG_CRC_CCITT=m CONFIG_CRC16=m CONFIG_CRC_T10DIF=y CONFIG_CRC_ITU_T=y CONFIG_CRC32=y CONFIG_CRC7=y CONFIG_LIBCRC32C=m CONFIG_ZLIB_INFLATE=y CONFIG_ZLIB_DEFLATE=y CONFIG_LZO_COMPRESS=m CONFIG_LZO_DECOMPRESS=m CONFIG_DECOMPRESS_GZIP=y CONFIG_DECOMPRESS_LZMA=y CONFIG_HAS_IOMEM=y CONFIG_HAS_DMA=y CONFIG_NLATTR=y
