#!/bin/sh
# Get AVR architecture
# (c) 2010 Heike C. Zimmerer <hcz@hczim.de>
# License: PGL v3
# 2010-08-19: now runs gawk instead of awk.  WinAVR only knows about gawk.
usage(){
    echo "\
Usage: $pname -mmcu=<mcutype> <objfile.o>
Function: return AVR architecture (the
  architecture which avr-gcc uses for linking) as
  string on stdout.
  <mcutype> may be any mcu type accepted by avr-gcc.
  <objfile.o> must exist but may be empty.
Opts:
  -x   Script debug (set -x)"
    exit
pname="${0##*/}"
while getopts m:-:hx argv; do
    case $argv in
	m) mcu="$OPTARG";;
	x) set -x;;
	*) usage;;
    esac
done
shift $((OPTIND-1))
case "$#" in
    0) echo >&2 "$pname: missing object file"; exit 1;;
    1) ;;
    *) echo >&2 "$pname: Too many arguments: $*"; exit 1;;
esac
magic=";#magic1295671ghkl-."
# call gcc, asking it for the command line which it would use for
# linking:
set -- $(avr-gcc -m"$mcu" -### "$1" -o "$magic" 2>&1 \
         | gawk '/^avr-gcc:/||/"-m".*'"$magic"'.*"-lgcc"/')
if [ "$1" = "avr-gcc:" ]; then
    # we have an error message from gcc:
    echo "$*"
    exit 1
fi
# retrieve architecture argument from gcc's commandline (the argument
# which follows '"-m"'):
while [ -n "$2" ]; do
    if [ "$1" = '"-m"' ]; then
	eval echo $2		# eval: remove quotes
	exit 0
    fi
    shift
done
echo >&2 "\
$pname: Could not find an architecture in avr-gcc's internal ld command line"
exit 1
