## Hey Emacs, this is a -*- makefile -*- #---------------------------------------------------------------------------- # WinAVR Makefile Template written by Eric B. Weddington, Jörg Wunsch, et al. # # Released to the Public Domain # # Additional material for this makefile was written by: # Peter Fleury # Tim Henigan # Colin O'Flynn # Reiner Patommel # Markus Pfaff # Sander Pool # Frederik Rouleau # #---------------------------------------------------------------------------- # On command line: # # make all = Make software. # # make clean = Clean out built project files. # # make coff = Convert ELF to AVR COFF. # # make extcoff = Convert ELF to AVR Extended COFF. # # make program = Download the hex file to the device, using avrdude. # Please customize the avrdude settings below first! # # make debug = Start either simulavr or avarice as specified for debugging, # with avr-gdb or avr-insight as the front end for debugging. # # make filename.s = Just compile filename.c into the assembler code only. # # make filename.i = Create a preprocessed source file for use in submitting # bug reports to the GCC project. # # To rebuild project do "make clean" then "make all". #---------------------------------------------------------------------------- MEGALOAD_NET = EEPROM = LOCKBIT = BAUDRATE = UART = # CT_PROJ wird für den Bootloader des c't projektes "microcontroller im lan" gesetzt. # BAUDRATE muss entsprechend XPORT/WIPORT gesetzt werden. #CT_PROJ = CT_PROJ = -DCT_PROJ -DDEST_COM #CT_PROJ = -DCT_PROJ -DDEST_XPORT # MEGALOAD_NET = -DMEGALOAD_NET #EEPROM = -DEEPROM #LOCKBIT = -DLOCKBIT UART = -DUART=1 #BAUDRATE = -DBAUDRATE=38400 BAUDRATE = -DBAUDRATE=9600 # Processor frequency. # This will define a symbol, F_CPU, in all source code files equal to the # processor frequency. You can then use this symbol in your source code to # calculate timings. Do NOT tack on a 'UL' at the end, this will be done # automatically to create a 32-bit value in your source code. F_CPU = 14745600 #F_CPU = 14318180 #F_CPU = 16000000 #F_CPU = 16257000 # MCU name # BootLoader mega8(5x5) 512 bytes => 0x1E00 = (0x1000words<<1)-0x200bytes #BOOTSTRT = 0x1E00 #MCU = atmega8 #MCU = atmega8515 MCU = atmega8535 #MCU = atmega88 # ----------- # BootLoader mega16 1k = 0x3C00 = (0x2000words<<1)-0x400bytes #BOOTSTRT = 0x3C00 # if (!lockbit && baudrate && !megaload_net) || !eeprom -> 0x3e00 #BOOTSTRT = 0x3E00 #MCU = atmega16 #MCU = atmega162 # - does not compile -- MCU = atmega165 #MCU = atmega168 #MCU = atmega169 # ------------- # BootLoader mega32 1k = 0x7C00 = (0x4000words<<1)-0x400bytes #BOOTSTRT = 0x7C00 #BOOTSTRT = 0x7E00 #MCU = atmega32 # - does not compile -- MCU = atmega3250 # - does not compile -- MCU = atmega3290 # ------------- # BootLoader mega48 1k = 0x???? = (0x????words<<1)-0x400bytes #BOOTSTRT = 0x0C00 #BOOTSTRT = 0x0E00 #MCU = atmega48 # ------------- # BootLoader mega64 1k = 0xFC00 = (0x8000words<<1)-0x400bytes # Wenn text > 512 #BOOTSTRT = 0xFC00 # Wenn text <= 512 #BOOTSTRT = 0xFE00 #MCU = atmega64 # - does not compile -- MCU = atmega640 # - does not compile -- MCU = atmega6450 # - does not compile -- MCU = atmega6490 # ------------- # BootLoader mega128 1k = 0x1FC00 = (0x10000words<<1)-0x400bytes #BOOTSTRT = 0x1FC00 #MCU = atmega128 # - does not compile -- MCU = atmega1280 # ------------- # --- FUSES mega32 # Fuses High Byte # 7 6 5 4 3 2 1 0 # OCDEN JTAGEN SPIEN CKOPT EESAVE BOOTSZ1 BOOTSZ0 BOOTRST # 1 = disabled 0 1 x x x 1 Boot from 0 # x 1 = disabled 1 x 1 1 0 256 Words = 512 bytes (0x7E00) # x x 0 = enabled x 1 0 0 512 words = 1024 bytes (0x7C00) # x x 0 1 x 0 1 0 1024 words = 2048 bytes (0x7800) # x x 0 enabled = 0 0 0 0 2048 words = 4096 bytes (0x7000) # ->0x7C00 #FUSEHIGH = 0xE4 # ->0x7E00 #FUSEHIGH = 0xE6 # --- FUSES mega8535 # Fuses High Byte # 7 6 5 4 3 2 1 0 # S8535C WDTON SPIEN CKOPT EESAVE BOOTSZ1 BOOTSZ0 BOOTRST # 1 = disabled 0 1 x x x 1 Boot from 0 # x 1 = disabled 1 x 1 1 0 128 Words = 256 bytes (0x1F00) # x x 0 = enabled x 1 0 0 256 words = 512 bytes (0x1E00) # x x 0 1 x 0 1 0 512 words = 1024 bytes (0x1C00) # x x 0 enabled = 0 0 0 0 1024 words = 2048 bytes (0x1800) # ->0x1E00 #FUSEHIGH = 0xE4 #BOOTSTRT = 0x1E00 # ->0x1F00 BOOTSTRT = 0x1F00 FUSEHIGH = 0xE6 # --- FUSES mega8 # Fuses High Byte # 7 6 5 4 3 2 1 0 # RSTDIS WDTON SPIEN CKOPT EESAVE BOOTSZ1 BOOTSZ0 BOOTRST # 1 = disabled 0 1 x x x 1 Boot from 0 # x 1 = disabled 1 x 1 1 0 128 Words = 256 bytes (0x1F00) # x x 0 = enabled x 1 0 0 256 words = 512 bytes (0x1E00) # x x 0 1 x 0 1 0 512 words = 1024 bytes (0x1C00) # x x 0 enabled = 0 0 0 0 1024 words = 2048 bytes (0x1800) # ->0x1E00 #FUSEHIGH = 0xE4 # ->0x7F00 #FUSEHIGH = 0xE6 # Output format. (can be srec, ihex, binary) FORMAT = ihex # Target file name (without extension). TARGET = $(MCU) # List C source files here. (C dependencies are automatically generated.) SRC = main.c # List Assembler source files here. # Make them always end in a capital .S. Files ending in a lowercase .s # will not be considered source files but generated files (assembler # output from the compiler), and will be deleted upon "make clean"! # Even though the DOS/Win* filesystem matches both .s and .S the same, # it will preserve the spelling of the filenames, and gcc itself does # care about how the name is spelled on its command-line. ASRC = asmPart.S gcrt1.S # Optimization level, can be [0, 1, 2, 3, s]. # 0 = turn off optimization. s = optimize for size. # (Note: 3 is not always the best optimization level. See avr-libc FAQ.) OPT = s -mcall-prologues # Debugging format. # Native formats for AVR-GCC's -g are dwarf-2 [default] or stabs. # AVR Studio 4.10 requires dwarf-2. # AVR [Extended] COFF format requires stabs, plus an avr-objcopy run. DEBUG = dwarf-2 # List any extra directories to look for include files here. # Each directory must be seperated by a space. # Use forward slashes for directory separators. # For a directory that has spaces, enclose it in quotes. EXTRAINCDIRS = # Compiler flag to set the C Standard level. # c89 = "ANSI" C # gnu89 = c89 plus GCC extensions # c99 = ISO C99 standard (not yet fully implemented) # gnu99 = c99 plus GCC extensions CSTANDARD = -std=gnu99 # Place -D or -U options here CDEFS = -DF_CPU=$(F_CPU)UL $(CT_PROJ) $(EEPROM) $(MEGALOAD_NET) $(UART) $(BAUDRATE) $(LOCKBIT) # Place -I options here CINCS = -I /WinAVR/avr/include #---------------- Compiler Options ---------------- # -g*: generate debugging information # -O*: optimization level # -f...: tuning, see GCC manual and avr-libc documentation # -Wall...: warning level # -Wa,...: tell GCC to pass this to the assembler. # -adhlns...: create assembler listing CFLAGS = -g$(DEBUG) CFLAGS += $(CDEFS) $(CINCS) CFLAGS += -O$(OPT) CFLAGS += -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums CFLAGS += -Wall -Wstrict-prototypes CFLAGS += -Wa,-adhlns=$(<:.c=.lst) CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS)) CFLAGS += $(CSTANDARD) #---------------- Assembler Options ---------------- # -Wa,...: tell GCC to pass this to the assembler. # -ahlms: create listing # -gstabs: have the assembler create line number information; note that # for use in COFF files, additional information about filenames # and function names needs to be present in the assembler source # files -- see avr-libc docs [FIXME: not yet described there] ASFLAGS = $(LOCKBIT) -Wa,-adhlns=$(<:.S=.lst),-gstabs #---------------- Library Options ---------------- # Minimalistic printf version PRINTF_LIB_MIN = -Wl,-u,vfprintf -lprintf_min # Floating point printf version (requires MATH_LIB = -lm below) PRINTF_LIB_FLOAT = -Wl,-u,vfprintf -lprintf_flt # If this is left blank, then it will use the Standard printf version. PRINTF_LIB = #PRINTF_LIB = $(PRINTF_LIB_MIN) #PRINTF_LIB = $(PRINTF_LIB_FLOAT) # Minimalistic scanf version SCANF_LIB_MIN = -Wl,-u,vfscanf -lscanf_min # Floating point + %[ scanf version (requires MATH_LIB = -lm below) SCANF_LIB_FLOAT = -Wl,-u,vfscanf -lscanf_flt # If this is left blank, then it will use the Standard scanf version. SCANF_LIB = #SCANF_LIB = $(SCANF_LIB_MIN) #SCANF_LIB = $(SCANF_LIB_FLOAT) #MATH_LIB = -lm #---------------- External Memory Options ---------------- # 64 KB of external RAM, starting after internal RAM (ATmega128!), # used for variables (.data/.bss) and heap (malloc()). #EXTMEMOPTS = -Wl,-Tdata=0x801100,--defsym=__heap_end=0x80ffff # 64 KB of external RAM, starting after internal RAM (ATmega128!), # only used for heap (malloc()). #EXTMEMOPTS = -Wl,--defsym=__heap_start=0x801100,--defsym=__heap_end=0x80ffff EXTMEMOPTS = #---------------- Linker Options ---------------- # -Wl,...: tell GCC to pass this to linker. # -Map: create map file # --cref: add cross reference to map file LDFLAGS = -Wl,-Map=$(TARGET).map,--cref,--section-start=.text=$(BOOTSTRT) LDFLAGS += $(EXTMEMOPTS) #LDFLAGS += -Ttext=0x1FC00 LDFLAGS += $(PRINTF_LIB) $(SCANF_LIB) $(MATH_LIB) #---------------- Programming Options (avrdude) ---------------- # Programming hardware: alf avr910 avrisp bascom bsd # dt006 pavr picoweb pony-stk200 sp12 stk200 stk500 # # Type: avrdude -c ? # to get a full listing. # AVRDUDE_PROGRAMMER = picoweb # com1 = serial port. Use lpt1 to connect to parallel port. AVRDUDE_PORT = lpt1 AVRDUDE_WRITE_FLASH = -U flash:w:$(TARGET).hex #AVRDUDE_WRITE_EEPROM = -U eeprom:w:$(TARGET).eep # Uncomment the following if you want avrdude's erase cycle counter. # Note that this counter needs to be initialized first using -Yn, # see avrdude manual. #AVRDUDE_ERASE_COUNTER = -y # Uncomment the following if you do /not/ wish a verification to be # performed after programming the device. #AVRDUDE_NO_VERIFY = -V # Increase verbosity level. Please use this when submitting bug # reports about avrdude. See # to submit bug reports. #AVRDUDE_VERBOSE = -v -v AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER) AVRDUDE_FLAGS += $(AVRDUDE_NO_VERIFY) AVRDUDE_FLAGS += $(AVRDUDE_VERBOSE) AVRDUDE_FLAGS += $(AVRDUDE_ERASE_COUNTER) #---------------- Debugging Options ---------------- # For simulavr only - target MCU frequency. DEBUG_MFREQ = $(F_CPU) # Set the DEBUG_UI to either gdb or insight. # DEBUG_UI = gdb DEBUG_UI = insight # Set the debugging back-end to either avarice, simulavr. #DEBUG_BACKEND = avarice DEBUG_BACKEND = simulavr # GDB Init Filename. GDBINIT_FILE = __avr_gdbinit # When using avarice settings for the JTAG JTAG_DEV = /dev/com1 # Debugging port used to communicate between GDB / avarice / simulavr. DEBUG_PORT = 4242 # Debugging host used to communicate between GDB / avarice / simulavr, normally # just set to localhost unless doing some sort of crazy debugging when # avarice is running on a different computer. DEBUG_HOST = localhost #============================================================================ # Define programs and commands. SHELL = sh CC = avr-gcc OBJCOPY = avr-objcopy OBJDUMP = avr-objdump SIZE = avr-size NM = avr-nm AVRDUDE = avrdude REMOVE = rm -f COPY = cp WINSHELL = cmd # Define Messages # English MSG_ERRORS_NONE = Errors: none MSG_BEGIN = -------- begin -------- MSG_END = -------- end -------- MSG_SIZE_BEFORE = Size before: MSG_SIZE_AFTER = Size after: MSG_COFF = Converting to AVR COFF: MSG_EXTENDED_COFF = Converting to AVR Extended COFF: MSG_FLASH = Creating load file for Flash: MSG_EEPROM = Creating load file for EEPROM: MSG_EXTENDED_LISTING = Creating Extended Listing: MSG_SYMBOL_TABLE = Creating Symbol Table: MSG_LINKING = Linking: MSG_COMPILING = Compiling: MSG_ASSEMBLING = Assembling: MSG_CLEANING = Cleaning project: # Define all object files. OBJ = $(SRC:.c=.o) $(ASRC:.S=.o) # Define all listing files. LST = $(SRC:.c=.lst) $(ASRC:.S=.lst) # Compiler flags to generate dependency files. GENDEPFLAGS = -MD -MP -MF .dep/$(@F).d # Combine all necessary flags and optional flags. # Add target processor to flags. ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS) $(GENDEPFLAGS) -nostartfiles -nodefaultlibs ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS) -nostartfiles -nodefaultlibs # Default target. all: begin gccversion sizebefore build sizeafter end build: elf hex eep lss sym elf: $(TARGET).elf hex: $(TARGET).hex eep: $(TARGET).eep lss: $(TARGET).lss sym: $(TARGET).sym # Eye candy. # AVR Studio 3.x does not check make's exit code but relies on # the following magic strings to be generated by the compile job. begin: @echo @echo $(MSG_BEGIN) end: @echo $(MSG_END) @echo # Display size of file. HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex ELFSIZE = $(SIZE) -A $(TARGET).elf AVRMEM = avr-mem.sh $(TARGET).elf $(MCU) sizebefore: @if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); \ $(AVRMEM) 2>/dev/null; echo; fi sizeafter: @if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); \ $(AVRMEM) 2>/dev/null; echo; fi # Display compiler version information. gccversion : @$(CC) --version # Program the device. program: $(TARGET).hex $(TARGET).eep $(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM) # Generate avr-gdb config/init file which does the following: # define the reset signal, load the target file, connect to target, and set # a breakpoint at main(). gdb-config: @$(REMOVE) $(GDBINIT_FILE) @echo define reset >> $(GDBINIT_FILE) @echo SIGNAL SIGHUP >> $(GDBINIT_FILE) @echo end >> $(GDBINIT_FILE) @echo file $(TARGET).elf >> $(GDBINIT_FILE) @echo target remote $(DEBUG_HOST):$(DEBUG_PORT) >> $(GDBINIT_FILE) ifeq ($(DEBUG_BACKEND),simulavr) @echo load >> $(GDBINIT_FILE) endif @echo break main >> $(GDBINIT_FILE) debug: gdb-config $(TARGET).elf ifeq ($(DEBUG_BACKEND), avarice) @echo Starting AVaRICE - Press enter when "waiting to connect" message displays. @$(WINSHELL) /c start avarice --jtag $(JTAG_DEV) --erase --program --file \ $(TARGET).elf $(DEBUG_HOST):$(DEBUG_PORT) @$(WINSHELL) /c pause else @$(WINSHELL) /c start simulavr --gdbserver --device $(MCU) --clock-freq \ $(DEBUG_MFREQ) --port $(DEBUG_PORT) endif @$(WINSHELL) /c start avr-$(DEBUG_UI) --command=$(GDBINIT_FILE) # Convert ELF to COFF for use in debugging / simulating in AVR Studio or VMLAB. COFFCONVERT=$(OBJCOPY) --debugging \ --change-section-address .data-0x800000 \ --change-section-address .bss-0x800000 \ --change-section-address .noinit-0x800000 \ --change-section-address .eeprom-0x810000 coff: $(TARGET).elf @echo @echo $(MSG_COFF) $(TARGET).cof $(COFFCONVERT) -O coff-avr $< $(TARGET).cof extcoff: $(TARGET).elf @echo @echo $(MSG_EXTENDED_COFF) $(TARGET).cof $(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof # Create final output files (.hex, .eep) from ELF output file. %.hex: %.elf @echo @echo $(MSG_FLASH) $@ $(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@ %.eep: %.elf @echo @echo $(MSG_EEPROM) $@ -$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \ --change-section-lma .eeprom=0 -O $(FORMAT) $< $@ # Create extended listing file from ELF output file. %.lss: %.elf @echo @echo $(MSG_EXTENDED_LISTING) $@ $(OBJDUMP) -h -S $< > $@ # Create a symbol table from ELF output file. %.sym: %.elf @echo @echo $(MSG_SYMBOL_TABLE) $@ $(NM) -n $< > $@ # Link: create ELF output file from object files. .SECONDARY : $(TARGET).elf .PRECIOUS : $(OBJ) %.elf: $(OBJ) @echo @echo $(MSG_LINKING) $@ $(CC) $(ALL_CFLAGS) $^ --output $@ $(LDFLAGS) # Compile: create object files from C source files. %.o : %.c Makefile @echo @echo $(MSG_COMPILING) $< $(CC) -c $(ALL_CFLAGS) $< -o $@ # Compile: create assembler files from C source files. %.s : %.c Makefile $(CC) -S $(ALL_CFLAGS) $< -o $@ # Assemble: create object files from assembler source files. %.o : %.S Makefile @echo @echo $(MSG_ASSEMBLING) $< $(CC) -c $(ALL_ASFLAGS) $< -o $@ # Create preprocessed source for use in sending a bug report. %.i : %.c Makefile $(CC) -E -mmcu=$(MCU) -I. $(CFLAGS) $< -o $@ # Target: clean project. clean: begin clean_list end clean_list : @echo @echo $(MSG_CLEANING) $(REMOVE) $(TARGET).hex $(REMOVE) $(TARGET).eep $(REMOVE) $(TARGET).cof $(REMOVE) $(TARGET).elf $(REMOVE) $(TARGET).map $(REMOVE) $(TARGET).sym $(REMOVE) $(TARGET).lss $(REMOVE) $(OBJ) $(REMOVE) $(LST) $(REMOVE) $(SRC:.c=.s) $(REMOVE) $(SRC:.c=.d) $(REMOVE) .dep/* # Include the dependency files. -include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*) # Listing of phony targets. .PHONY : all begin finish end sizebefore sizeafter gccversion \ build elf hex eep lss sym coff extcoff \ clean clean_list program debug gdb-config
