library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; -- Uncomment the following lines to use the declarations that are -- provided for instantiating Xilinx primitive components. --library UNISIM; --use UNISIM.VComponents.all; entity kompe is Port ( eina : in bit_vector(0 to 2); einb : in bit_vector(0 to 2); ein : in std_logic; groesser : out std_logic; gleich : out std_logic; kleiner : out std_logic); end kompe; architecture Behavioral of kompe is signal einaa, einbb : bit_vector(0 to 2); begin komp: process (eina,einb,einaa,einbb) begin einaa<=eina; einbb<=einb; groesser<='1'; gleich<='1'; kleiner<='1'; if(einaa > einbb) then groesser <= '0'; end if; if(einaa = einbb) then gleich <= '0'; end if; if(einaa < einbb) then kleiner <= '0'; end if; end process komp; end Behavioral;
