library IEEE; use IEEE.STD_LOGIC_1164.ALL; entity dsf is end dsf; architecture Behavioral of dsf is signal clock: std_logic := '1'; signal audio_reset_b: std_logic := '1'; signal ac97_sdata_out: std_logic := '0'; signal ac97_sdata_in: std_logic := '0'; signal ac97_synch: std_logic := '0'; signal ac97_bit_clock: std_logic := '0'; signal Kommando : std_logic_vector (56 downto 0) := "011100000000000000000001100000000000000000000000000000000"; --Erstes Kommando: -- signal shift_reg : std_logic_vector (56 downto 0) := "011100000000000000000001100000000000000000000000000000000"; signal pwmvalue : integer range 0 to 16 := 16; signal cnt : integer range 0 to 255 := 255; signal pwmvalue2 : integer range 0 to 255 := 255; signal cnt2 : integer range 0 to 255 := 0; signal puls : std_logic := '0'; begin process begin wait until rising_edge(ac97_bit_clock); -- Zähler if (cnt<255) then cnt <= cnt+1; else cnt <= 0; end if; -- Vergleicher if (cnt>=(pwmvalue)) then ac97_synch <= '0'; else ac97_synch <= '1'; end if; end process; process begin wait until rising_edge(ac97_bit_clock); -- Zähler if (cnt2<255) then cnt2 <= cnt2+1; else cnt2 <= 0; end if; -- Vergleicher if (cnt2>=(pwmvalue2)) then puls <= '1'; else puls <= '0'; end if; end process; process begin wait until rising_edge(ac97_bit_clock); if puls'event then shift_reg <= Kommando; elsif (ac97_bit_clock'event and ac97_bit_clock = '1') then ac97_sdata_out <= shift_reg(56); shift_reg(56 downto 1) <= shift_reg(55 downto 0); end if; end process; process begin ac97_bit_clock <= '0'; wait for 5 ns; ac97_bit_clock <= '1'; wait for 5 ns; end process; end Behavioral;
