library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity dsf is end dsf; architecture Behavioral of dsf is signal ac97_sdata_out: std_logic := '0'; signal audio_reset_b_MM: std_logic := '1'; signal ac97_sdata_out2_MM: std_logic := '0'; signal ac97_synch_MM: std_logic := '0'; signal ac97_bit_clock_MM: std_logic := '0'; signal audio_reset_b: std_logic; signal ac97_sdata_out2: std_logic; signal ac97_synch: std_logic; signal ac97_bit_clock: std_logic; signal audio_reset_b_M: std_logic; signal ac97_sdata_out2_M: std_logic; signal ac97_synch_M: std_logic; signal ac97_bit_clock_M: std_logic; -- -- signal Kommando : std_logic_vector (56 downto 0) := "011100000000000000001101000000000000000000100000001000000"; --RecordSelect-Register 0x1A, Line-L/R als ADC-Source signal Kommando1 : std_logic_vector (56 downto 0) := "011100000000000000001110000000000000000001111000011110000"; --RecordGain-Register 0x1C, Max. Gain für Line L/R signal Kommando2 : std_logic_vector (56 downto 0) := "011100000000000000001000000000000000000000000000000000000"; --MixerInput-Register 0x10, LineIn L/R als Mixerquelle signal shift_reg : std_logic_vector (56 downto 0) := "001110000000000000000000100000000000000000000000000000000"; --LineOut-Register 0x02h, Lauteste Einstellung und Unmuted signal pwmvalue : integer range 0 to 16 := 16; signal cnt : integer range 0 to 255 := 255; signal pwmvalue2 : integer range 0 to 255 := 254; signal cnt2 : integer range 0 to 255 := 0; signal puls : std_logic := '0'; signal framezaehler : std_logic_vector (2 downto 0) := "000"; signal und_eingang : std_logic := '1'; begin process begin wait until rising_edge(ac97_bit_clock_MM); -- Zähler if (cnt<255) then cnt <= cnt+1; else cnt <= 0; end if; -- Vergleicher if (cnt>=(pwmvalue)) then ac97_synch_MM <= '0'; else ac97_synch_MM <= '1'; end if; end process; process begin wait until rising_edge(ac97_bit_clock_MM); -- Zähler if (cnt2<255) then cnt2 <= cnt2+1; else cnt2 <= 0; end if; -- Vergleicher if (cnt2>=(pwmvalue2)) then puls <= '1'; else puls <= '0'; end if; end process; process (puls) begin if puls='1' and puls'event then framezaehler <= framezaehler + 1; end if; end process; process begin wait until rising_edge(ac97_bit_clock_MM); if puls = '1' then case framezaehler is when "001" => shift_reg <= Kommando; when "010" => shift_reg <= Kommando1; when "011" => shift_reg <= Kommando2; when others => und_eingang <= '0'; end case; elsif (ac97_bit_clock_MM'event and ac97_bit_clock_MM = '1') then ac97_sdata_out <= shift_reg(56); shift_reg(56 downto 1) <= shift_reg(55 downto 0); end if; end process; ac97_sdata_out2 <= ac97_sdata_out and und_eingang; ac97_sdata_out2_M <= ac97_sdata_out and und_eingang; audio_reset_b <= audio_reset_b_MM; audio_reset_b_M <= audio_reset_b_MM; ac97_synch <= ac97_synch_MM; ac97_synch_M <= ac97_synch_MM; ac97_bit_clock_MM <= ac97_bit_clock; ac97_bit_clock_M <= ac97_bit_clock_MM; process begin ac97_bit_clock <= '0'; wait for 5 ns; ac97_bit_clock <= '1'; wait for 5 ns; end process; end Behavioral;
