/***************************************************** This program was produced by the CodeWizardAVR V2.04.9a UL Standard Automatic Program Generator © Copyright 1998-2010 Pavel Haiduc, HP InfoTech s.r.l. http://www.hpinfotech.com Chip type : ATmega16U4 Program type : Application AVR Core Clock frequency: 8,000000 MHz Memory model : Small External RAM size : 0 Data Stack size : 320 *****************************************************/ #include // Declare your global variables here void main(void) { // Declare your local variables here // Crystal Oscillator division factor: 1 #pragma optsize- CLKPR=0x0F; CLKPR=0x0F; #ifdef _OPTIMIZE_SIZE_ #pragma optsize+ #endif // Input/Output Ports initialization // Port B initialization // Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out // State7=1 State6=1 State5=1 State4=1 State3=1 State2=1 State1=1 State0=1 PORTB=0x0F; DDRB=0xFF; // Port C initialization // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T PORTC=0xFF; DDRC=0x00; // Port D initialization // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T PORTD=0xFF; DDRD=0x00; // Port E initialization // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T PORTE=0x00; DDRE=0x00; // Port F initialization // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T PORTF=0x00; DDRF=0x00; // PLL initialization // PLL Input Clock: 4,000 MHz, XTAL // PLL VCO Output: 48 MHz PLLCSR=0x10; PLLFRQ=0x04; // Timer/Counter 0 initialization // Clock source: System Clock // Clock value: Timer 0 Stopped // Mode: Normal top=0xFF // OC0A output: Disconnected // OC0B output: Disconnected TCCR0A=0x00; TCCR0B=0x00; TCNT0=0x00; OCR0A=0x00; OCR0B=0x00; // Timer/Counter 1 initialization // Clock source: System Clock // Clock value: Timer1 Stopped // Mode: Normal top=0xFFFF // OC1A output: Discon. // OC1B output: Discon. // OC1C output: Discon. // Noise Canceler: Off // Input Capture on Falling Edge // Timer1 Overflow Interrupt: Off // Input Capture Interrupt: Off // Compare A Match Interrupt: Off // Compare B Match Interrupt: Off // Compare C Match Interrupt: Off TCCR1A=0x00; TCCR1B=0x00; TCNT1H=0x00; TCNT1L=0x00; ICR1H=0x00; ICR1L=0x00; OCR1AH=0x00; OCR1AL=0x00; OCR1BH=0x00; OCR1BL=0x00; OCR1CH=0x00; OCR1CL=0x00; // Timer/Counter 3 initialization // Clock source: System Clock // Clock value: Timer3 Stopped // Mode: Normal top=0xFFFF // OC3A output: Discon. // OC3B output: Discon. // OC3C output: Discon. // Noise Canceler: Off // Input Capture on Falling Edge // Timer3 Overflow Interrupt: Off // Input Capture Interrupt: Off // Compare A Match Interrupt: Off // Compare B Match Interrupt: Off // Compare C Match Interrupt: Off TCCR3A=0x00; TCCR3B=0x00; TCNT3H=0x00; TCNT3L=0x00; ICR3H=0x00; ICR3L=0x00; OCR3AH=0x00; OCR3AL=0x00; OCR3BH=0x00; OCR3BL=0x00; OCR3CH=0x00; OCR3CL=0x00; // Timer/Counter 4 initialization // Clock: Timer4 Stopped // Mode: Normal top=OCR4C // OC4A output: OC4A=Disc. /OC4A=Disc. // OC4B output: OC4B=Disc. /OC4B=Disc. // OC4D output: OC4D=Disc. /OC4D=Disc. // Fault Protection: Off // Fault Protection Noise Canceler: Off // Fault Protection triggered on Falling Edge // Timer4 Overflow Interrupt: Off // Compare A Match Interrupt: Off // Compare B Match Interrupt: Off // Compare D Match Interrupt: Off // Fault Protection Interrupt: Off // Dead Time Prescaler: 1 // Dead Time Rising Edge: 0.000 us // Dead Time Falling Edge: 0.000 us // Set Timer4 synchronous operation PLLFRQ&=0xcf; TCCR4A=0x00; TCCR4B=0x00; TCCR4C=0x00; TCCR4D=0x00; TC4H=0x00; TCNT4=0x00; TC4H=0x00; OCR4A=0x00; TC4H=0x00; OCR4B=0x00; TC4H=0x00; OCR4C=0x00; TC4H=0x00; OCR4D=0x00; DT4=0x00; // External Interrupt(s) initialization // INT0: Off // INT1: Off // INT2: Off // INT3: Off // INT6: Off EICRA=0x00; EICRB=0x00; EIMSK=0x00; // PCINT0 interrupt: Off // PCINT1 interrupt: Off // PCINT2 interrupt: Off // PCINT3 interrupt: Off // PCINT4 interrupt: Off // PCINT5 interrupt: Off // PCINT6 interrupt: Off // PCINT7 interrupt: Off PCMSK0=0x00; PCICR=0x00; // Timer/Counter 0 Interrupt(s) initialization TIMSK0=0x00; // Timer/Counter 1 Interrupt(s) initialization TIMSK1=0x00; // Timer/Counter 3 Interrupt(s) initialization TIMSK3=0x00; // Timer/Counter 4 Interrupt(s) initialization TIMSK4=0x00; // Analog Comparator initialization // Analog Comparator: Off // Analog Comparator Input Capture by Timer/Counter 1: Off ACSR=0x80; ADCSRB=0x00; while (1) { // Place your code here PORTB=0xFF; PORTD = 0xFF; PORTC = 0xFF; } }
