# # Automatically generated by make menuconfig: don't edit # # # General Setup # CONFIG_EXPERIMENTAL=y # CONFIG_EXPERT is not set ARCH=ARCH_AVR ARCH_AVR=y # ARCH_HOST is not set # atmega8 is not set # atmega88 is not set # atmega128 is not set # atmega16 is not set # atmega162 is not set # atmega168 is not set # atmega168p is not set # atmega169 is not set MCU=atmega32 atmega32=y # atmega328p is not set # atmega64 is not set # atmega644 is not set # atmega644p is not set # atmega1284p is not set FREQ=16000000 # Arduino_Duemilanove is not set # Fimser is not set # Jackalope is not set # JeeLinkv2 is not set # MicroWebServer is not set # conrad_probot is not set # ehaserl is not set # etherrape is not set # fnordlicht_servo is not set # generic_usb_teensy is not set # hr20 is not set HARDWARE=netio netio=y # netio_addon is not set # other is not set # pollin_evalboard is not set # pollin_evalboard_addon is not set # pollin_funkevalboard is not set # radig_web is not set # thermy is not set # volkszaehler_so_server is not set # CPU_SLEEP is not set # SRAM_SUPPORT is not set # SRAM_MEMTEST_ON_BOOT is not set # BOOTLOADER_SUPPORT is not set BOOTLOADER_START_ADDRESS=0x7000 # TEENSY_SUPPORT is not set # SPI_TIMEOUT is not set # USART_SPI_SUPPORT is not set # SOFT_SPI_SUPPORT is not set # USE_GIT_VERSION is not set VERSION_STRING_CHOICE=USE_RELEASE_VERSION USE_RELEASE_VERSION=y # USE_BUILDDATE_VERSION is not set VERSION_GIT="de4330e" # DEBUG_DISCARD_SOME is not set # DEBUG is not set DEBUG_BAUDRATE=115200 # DEBUG_USE_SYSLOG is not set # SOFT_UART_SUPPORT is not set # DEBUG_HOOK is not set # DEBUG_RESET_REASON is not set # STATUSLEDS is not set # STATUSLED_POWER_SUPPORT is not set # STATUSLED_BOOTED_SUPPORT is not set # STATUSLED_NETLINK_SUPPORT is not set # STATUSLED_TX_SUPPORT is not set # RFM12_TX_PIN is not set # ZBUS_TX_PIN is not set # IRMP_TX_LED is not set # STATUSLED_RX_SUPPORT is not set # RFM12_RX_PIN is not set # ZBUS_RX_PIN is not set # IRMP_RX_LED is not set # STATUSLED_HB_ACT_SUPPORT is not set # STATUSLED_HEARTBEAT_SUPPORT is not set # STATUSLED_RFM12_TX_ACT_SUPPORT is not set # STATUSLED_RFM12_RX_ACT_SUPPORT is not set # STATUSLED_ZBUS_TX_ACT_SUPPORT is not set # STATUSLED_ZBUS_RX_ACT_SUPPORT is not set # STATUSLED_ECMD_ACT_SUPPORT is not set # CRYPTO_SUPPORT is not set # CAST5_SUPPORT is not set # MD5_SUPPORT is not set # SHA1_SUPPORT is not set VFS_SUPPORT=y # VFS_DF_SUPPORT is not set VFS_INLINE_SUPPORT=y # CONFIG_INLINE_SUPPORT is not set # VFS_CONFIG_INLINE_SUPPORT is not set # MOTD_INLINE_SUPPORT is not set # RFM12_INLINE_SUPPORT is not set # I2C_INLINE_SUPPORT is not set VFS_IO_INLINE_SUPPORT=y # KTY_INLINE_SUPPORT is not set ADC_INLINE_SUPPORT=y ONEWIRE_INLINE_SUPPORT=y # CAMERA_INLINE_SUPPORT is not set # NAMED_PIN_INLINE_SUPPORT is not set # STELLA_INLINE_SUPPORT is not set # MOTORCURTAIN_INLINE_SUPPORT is not set # MSR1_INLINE_SUPPORT is not set # TO1_INLINE_SUPPORT is not set # MCUF_INLINE_SUPPORT is not set # GAME_INPUT_INLINE_SUPPORT is not set # UPNP_INLINE_SUPPORT is not set # LCD_INLINE_SUPPORT is not set # NMEA_INLINE_SUPPORT is not set # PWM_SERVO_INLINE_SUPPORT is not set # CW_INLINE_SUPPORT is not set VFS_INLINE_INLINESVG_SUPPORT=y # VFS_INLINE_HTML_CLEAN_SUPPORT is not set # VFS_INLINE_OBSOLETE_BROWSER_SUPPORT is not set # DEBUG_INLINE_DUMMY is not set # DEBUG_INLINE_GZ is not set # DEBUG_INLINE_DISABLE_GZ is not set VFS_INLINE_INLINESVG_SUPPORT=y # VFS_HOST_SUPPORT is not set # VFS_SD_SUPPORT is not set # SD_READER_SUPPORT is not set # SD_READ_TIMEOUT is not set # SD_PING_READ is not set # VFS_EEPROM_SUPPORT is not set # VFS_EEPROM_RAW_SUPPORT is not set # VFS_DC3840_SUPPORT is not set # DATAFLASH_SUPPORT is not set # DEBUG_FS is not set # DEBUG_FS_INODETABLE is not set # DEBUG_FS_MARK is not set # VFS_EEPROM_DEBUG_SUPPORT is not set # DEBUG_SD_READER is not set # PAM_SUPPORT is not set # CONTROL6_SUPPORT is not set # # Network # CONF_HOSTNAME="0_89" NET_MAX_FRAME_LENGTH=500 ENC28J60_SUPPORT=y CONF_ENC_MAC="00:22:f9:01:6d:82" # IPV6_STATIC_SUPPORT is not set CONF_ENC_IP="192.168.178.100" CONF_ENC_IP4_NETMASK="255.255.255.0" # IEEE8021Q_SUPPORT is not set # DEBUG_ENC28J60 is not set # DEBUG_INTERRUPT is not set # DEBUG_REV4_WORKAROUND is not set ETHERNET_SUPPORT=y # TAP_SUPPORT is not set CONF_TAP_MAC="ac:de:48:fd:0f:d0" # IPV6_STATIC_SUPPORT is not set CONF_TAP_IP="192.168.23.244" CONF_TAP_IP4_NETMASK="255.255.255.0" CONF_TAP_LOCALIP="192.168.23.1" # IEEE8021Q_SUPPORT is not set # RFM12_IP_SUPPORT is not set CONF_RFM12_FREQ=RFM12_FREQ_433920 RFM12_FREQ_433920=y # RFM12_FREQ_869775 is not set # RFM12_FREQ_869800 is not set # RFM12_FREQ_869825 is not set # RFM12_FREQ_869850 is not set # RFM12_FREQ_869875 is not set # RFM12_FREQ_869900 is not set # RFM12_FREQ_869925 is not set # CONF_RFM12_SLOW_SPI is not set # CONF_RFM12B_SUPPORT is not set CONF_RFM12_BAUD=19200 CONF_RFM12_IP="192.168.11.51" CONF_RFM12_IP4_NETMASK="255.255.255.0" # RFM12_SOURCE_ROUTE_ALL is not set # RFM12_PCKT_FWD is not set # RFM12_ARP_PROXY is not set # RFM12_DISABLE is not set # RFM12_RAW_SUPPORT is not set # USB_SUPPORT is not set # USB_KEYBOARD_SUPPORT is not set # USB_HID_KEYBOARD_SEQUENCE_SUPPORT is not set # USB_HID_KEYBOARD_STATIC_SUPPORT is not set # USB_HID_KEYBOARD_ECMD_SUPPORT is not set # USB_MOUSE_SUPPORT is not set # USB_MOUSE_SEQUENCE_SUPPORT is not set # USB_NET_SUPPORT is not set # DEBUG_USB_HID_KEYBOARD is not set # DEBUG_USB_HID_MOUSE is not set # ZBUS_SUPPORT is not set # ZBUS_RAW_SUPPORT is not set # ROUTER_SUPPORT is not set UIP_SUPPORT=y NET_SUPPORT=y # IPV6_SUPPORT is not set IPV4_SUPPORT=y # IP_FORWARDING_SUPPORT is not set # UIP_TIMEOUT_SUPPORT is not set CONF_ETHERRAPE_GATEWAY="192.168.178.1" # UIP_MULTI_STACK is not set # IPCHAIR_SUPPORT is not set # IPCHAIR_MASQ is not set TCP_SUPPORT=y # UDP_SUPPORT is not set # BROADCAST_SUPPORT is not set ICMP_SUPPORT=y # DNS_SUPPORT is not set CONF_DNS_SERVER="192.168.11.1" # BOOTP_SUPPORT is not set # BOOTP_TO_EEPROM_SUPPORT is not set # DHCP_SUPPORT is not set # OPENVPN_SUPPORT is not set CONF_OPENVPN_KEY=00000000000000000000000000000000 CONF_OPENVPN_HMAC_KEY=00000000000000000000000000000000 CONF_OPENVPN_IP="0.0.0.0" CONF_OPENVPN_IP4_NETMASK="255.255.255.0" # OPENVPN_STATIC_REMOTE is not set # DEBUG_NET is not set # DEBUG_NET_CONFIG is not set # DEBUG_NET_IP6 is not set # DEBUG_OPENVPN is not set # DEBUG_ROUTER is not set # DEBUG_UIP is not set # DEBUG_NTP is not set # DEBUG_UNKNOWN_PACKETS is not set # # I/O # # CONFIG_IO_NONE is not set PORTIO_SCHEME=PORTIO_SIMPLE PORTIO_SIMPLE=y # PORTIO_FULL_FEATURED is not set PORTIO_SIMPLE_SUPPORT=y # NAMED_PIN_SUPPORT is not set # TTY_SUPPORT is not set TTY_COLS=16 TTY_LINES=4 # TTY_LL_HD44780 is not set # TTY_LL_S1D15G10 is not set # TTY_LL_S1D13305 is not set # TTY_LL_VT100_TELNET is not set # DEBUG_TTY_LAYER is not set # HC595_SUPPORT is not set HC595_REGISTERS=5 # HC165_SUPPORT is not set # HC165_INVERSE_OUTPUT is not set HC165_REGISTERS=1 ADC_SUPPORT=y CONFIG_ADC_AREF=y # CONFIG_ADC_AVCC is not set # CONFIG_ADC_1_1 is not set # CONFIG_ADC_2_56 is not set ADC_REF=ADC_AREF # HR20_TEMP_SUPPORT is not set NEED_TEMP2TEXT=y # SMS_SUPPORT is not set SMS_USART_0=y SMS_USE_USART=0 # DEBUG_SMS is not set # KTY_SUPPORT is not set # ADS7822_SUPPORT is not set # DAC_SUPPORT is not set # TLC5620_SUPPORT is not set # LTC1257_SUPPORT is not set CONF_LTC1257_NUM_DEVICES=4 # DEBUG_LTC1257_CORE is not set # DEBUG_LTC1257_ECMD is not set # # LCD Displays # # HD44780_SUPPORT is not set # HD44780_BACKLIGHT_INV is not set # HR20_LCD_SUPPORT_FULL is not set # S1D15G10_SUPPORT is not set # ST7626_SUPPORT is not set # S1D13305_SUPPORT is not set # DEBUG_S1D13305 is not set # LCD_SUPPORT is not set # DEBUG_HD44780 is not set # DEBUG_LCD_MENU is not set # I2C_MASTER_SUPPORT is not set # I2C_DETECT_SUPPORT is not set # I2C_GENERIC_SUPPORT is not set # I2C_24CXX_SUPPORT is not set # I2C_LM75_SUPPORT is not set # I2C_DS1631_SUPPORT is not set # I2C_DS13X7_SUPPORT is not set # I2C_TSL2550_SUPPORT is not set # I2C_PCA9531_SUPPORT is not set # I2C_PCF8574X_SUPPORT is not set # I2C_MAX7311_SUPPORT is not set # I2C_UDP_SUPPORT is not set # DEBUG_I2C is not set # CAMERA_SUPPORT is not set # DC3840_SUPPORT is not set # CONFIG_DC3840_RES80 is not set # CONFIG_DC3840_RES160 is not set # CONFIG_DC3840_RES320 is not set # CONFIG_DC3840_RES640 is not set # DC3840_HIGH_COMPRESSION is not set # DC3840_BLACK_WHITE is not set DC3840_USART_0=y DC3840_USE_USART=0 # DC3840_UDP_DEBUG is not set # FS20_SUPPORT is not set # FS20_SEND_SUPPORT is not set # FS20_RECEIVE_SUPPORT is not set # FS20_RECEIVE_WS300_SUPPORT is not set # DEBUG_FS20_REC is not set # DEBUG_FS20_REC_QUEUE is not set # DEBUG_FS20_REC_VERBOSE is not set # DEBUG_FS20_WS300 is not set # DEBUG_FS20_WS300_VERBOSE is not set # IR_SUPPORT is not set # RC5_SUPPORT is not set # RC5_SUPPORT is not set # RC5_UDP_SUPPORT is not set CONF_RC5_SERVER="192.168.100.3" # DEBUG_RC5 is not set # IRMP_SUPPORT is not set # IRMP_RX_SUPPORT is not set # IRMP_TX_SUPPORT is not set # IRMP_EXTERNAL_MODULATOR is not set # IRMP_ECMD is not set # IRMP_SUPPORT_SIRCS_PROTOCOL is not set # IRMP_SUPPORT_NEC_PROTOCOL is not set # IRMP_SUPPORT_JVC_PROTOCOL is not set # IRMP_SUPPORT_SAMSUNG_PROTOCOL is not set # IRMP_SUPPORT_MATSUSHITA_PROTOCOL is not set # IRMP_SUPPORT_KASEIKYO_PROTOCOL is not set # IRMP_SUPPORT_DENON_PROTOCOL is not set # IRMP_SUPPORT_RECS80_PROTOCOL is not set # IRMP_SUPPORT_RECS80EXT_PROTOCOL is not set # IRMP_SUPPORT_RC5_PROTOCOL is not set # IRMP_SUPPORT_RC6_PROTOCOL is not set # IRMP_SUPPORT_RC6A_PROTOCOL is not set # IRMP_SUPPORT_NUBERT_PROTOCOL is not set # IRMP_SUPPORT_BANG_OLUFSEN_PROTOCOL is not set # IRMP_SUPPORT_GRUNDIG_PROTOCOL is not set # IRMP_SUPPORT_NOKIA_PROTOCOL is not set # IRMP_SUPPORT_SIEMENS_PROTOCOL is not set # IRMP_SUPPORT_FDC_PROTOCOL is not set # IRMP_SUPPORT_RCCAR_PROTOCOL is not set # IRMP_SUPPORT_NIKON_PROTOCOL is not set # DEBUG_IRMP is not set # PSB2186_SUPPORT is not set # PWM_SUPPORT is not set # PWM_GENERAL_SUPPORT is not set # PWM_GENERAL_INVERT_SUPPORT is not set # PWM_GENERAL_FADING_SUPPORT is not set # CH_A_PWM_GENERAL_SUPPORT is not set # CH_B_PWM_GENERAL_SUPPORT is not set # CH_C_PWM_GENERAL_SUPPORT is not set # PWM_WAV_SUPPORT is not set # VFS_PWM_WAV_SUPPORT is not set # PWM_MELODY_SUPPORT is not set # ENTCHEN_PWM_MELODY_SUPPORT is not set # TETRIS_PWM_MELODY_SUPPORT is not set # PWM_SERVO_SUPPORT is not set PWM_SERVOS=1 # PWM_SERVO_INVERT is not set # PWM_SERVO_DEFAULT_ENABLED is not set # PWM_FREQ_SUPPORT is not set # PWM_DTMF_SUPPORT is not set # DEBUG_PWM is not set # DEBUG_PWM_SERVO is not set ONEWIRE_SUPPORT=y ONEWIRE_DETECT_SUPPORT=y # ONEWIRE_DS2502_SUPPORT is not set # ONEWIRE_DS2450_SUPPORT is not set ONEWIRE_DETECT_ECMD_SUPPORT=y # DEBUG_ECMD_OW_ROM is not set # DEBUG_ECMD_OW_LIST is not set # DEBUG_OW_DS2450_CORE is not set # DEBUG_OW_DS2450_ECMD is not set # HR20_INPUT_SUPPORT is not set # PS2_SUPPORT is not set # PS2_GERMAN_LAYOUT is not set # DEBUG_PS2 is not set # BUTTONS_INPUT_SUPPORT is not set CONF_NUM_BUTTONS= # GAME_INPUT_SUPPORT is not set # JOYSTICK_DIGITAL_SUPPORT is not set # DEBUG_JOYSTICK_DIGITAL is not set # DEBUG_GAME_INPUT is not set # RFM12_ASK_SUPPORT is not set # RFM12_ASK_SENDER_SUPPORT is not set # RFM12_ASK_2272_SUPPORT is not set # RFM12_ASK_1527_SUPPORT is not set # RFM12_ASK_TEVION_SUPPORT is not set # RFM12_ASK_INTERTECHNO_SUPPORT is not set # RFM12_ASK_EXTERNAL_FILTER_SUPPORT is not set # RFM12_ASK_SENSING_SUPPORT is not set # DEBUG_ASK_SENSE is not set # SHT_SUPPORT is not set # ZACWIRE_SUPPORT is not set # ZACWIRE_RAW_SUPPORT is not set # ZACWIRE_CONVERT306_SUPPORT is not set # ZACWIRE_CONVERT506_SUPPORT is not set # ULTRASONIC_SUPPORT is not set # DEBUG_ULTRASONIC is not set # HBRIDGE_SUPPORT is not set # DEBUG_HBRIDGE is not set # MCUF_SUPPORT is not set # MCUF_SERIAL_SUPPORT is not set MCUF_USART_0=y MCUF_USE_USART=0 # MCUF_OUTPUT_SUPPORT is not set # BLP_SUPPORT is not set # LEDRG_SUPPORT is not set # MCUF_SERIAL_WORKAROUND_FOR_BAD_MCUF_UDP_PACKETS is not set # MCUF_SCROLLTEXT_SUPPORT is not set CONF_MCUF_SCROLLTEXT_STARTUP="Hi I am your ethersex ;-) " CONF_MCUF_SCROLLTEXT_STARTUP_COLOR=240 CONF_MCUF_SCROLLTEXT_STARTUP_BG_COLOR=1 CONF_MCUF_SCROLLTEXT_STARTUP_SPEED=2 # MCUF_CLOCK_SUPPORT is not set # MCUF_CLOCK_AUTOSTART_SUPPORT is not set # MCUF_MODUL_SUPPORT is not set # MCUF_MODUL_CRON_SUPPORT is not set # MCUF_MODUL_DISPLAY_MODE_CRON_SEQUENCE is not set MCUF_MODUL_DISPLAY_MODE_CRON=MCUF_MODUL_DISPLAY_MODE_CRON_RANDOM MCUF_MODUL_DISPLAY_MODE_CRON_RANDOM=y # MCUF_MODUL_DISPLAY_MODE_SUPPORT is not set # MCUF_MODUL_DISPLAY_MODE_SEQUENCE is not set MCUF_MODUL_DISPLAY_MODE=MCUF_MODUL_DISPLAY_MODE_RANDOM MCUF_MODUL_DISPLAY_MODE_RANDOM=y # MCUF_MODUL_DISPLAY_MODE_MANUAL is not set # MCUF_TEST_GAME_INPUT is not set # MCUF_CHESS_SUPPORT is not set # MCUF_BOX_SUPPORT is not set # MCUF_CLEAN_SUPPORT is not set # MCUF_SPIRAL_SUPPORT is not set # MCUF_IMAGE_SUPPORT is not set # MCUF_MODUL_BORG16_SUPPORT is not set # MCUF_MODUL_BORG16_XONI_STUDY_SUPPORT is not set # MCUF_MODUL_BORG16_SNAKE_SUPPORT is not set # MCUF_MODUL_BORG16_SNAKE_INTERACTIVE_SUPPORT is not set # DEBUG_MCUF is not set # # Protocols # # ARTNET_SUPPORT is not set CONF_ARTNET_PORT=1936 CONF_ARTNET_MAX_PORTS=4 CONF_ARTNET_MAX_DATA_LENGTH=511 CONF_ARTNET_MAX_CHANNELS=512 CONF_ARTNET_OEM_ID="0xB108" # DEBUG_ARTNET is not set # DMX_SUPPORT is not set CONF_DMX_MAX_CHAN=512 DMX_USART_0=y DMX_USE_USART=0 ECMD_PARSER_SUPPORT=y # ECMD_REMOVE_BACKSPACE_SUPPORT is not set # ALIASCMD_SUPPORT is not set # ECMD_PAM_SUPPORT is not set # ECMD_SCRIPT_SUPPORT is not set # ECMD_SERIAL_USART_SUPPORT is not set # ECMD_TCP_SUPPORT is not set # ECMD_UDP_SUPPORT is not set # ECMD_SERIAL_I2C_SUPPORT is not set # ECMD_USB_SUPPORT is not set # ECMD_JABBER_SUPPORT is not set # ECMD_IRC_SUPPORT is not set # ECMD_SMS_SUPPORT is not set # ECMD_EEPROM_SUPPORT is not set # ECMD_SENDER_SUPPORT is not set # UECMD_SENDER_SUPPORT is not set # DISABLE_IPCONF_SUPPORT is not set # DISABLE_REBOOT_SUPPORT is not set # IPSTATS_SUPPORT is not set # FREE_SUPPORT is not set # ECMD_MIRROR_REQUEST is not set # DEBUG_ECMD is not set # DEBUG_ECMD_FS20 is not set # DEBUG_ECMD_IP is not set # DEBUG_ECMD_MAC is not set # DEBUG_ECMD_NET is not set # DEBUG_ECMD_OW_LIST is not set # DEBUG_ECMD_OW_ROM is not set # DEBUG_ECMD_PORTIO is not set # DEBUG_ECMD_RC5 is not set # DEBUG_ECMD_SCRIPT is not set # FNORDLICHT_BASIC_SUPPORT is not set FNORDLICHT_BAUDRATE=19200 FNORDLICHT_USART_0=y FNORDLICHT_USE_USART=0 # FNORDLICHT_SUPPORT is not set CONF_FNORDLICHTER=1 # FNORDLICHT_SERVO_SUPPORT is not set # DEBUG_FNORDLICHT is not set # HTTPLOG_SUPPORT is not set CONF_HTTPLOG_SERVICE="volkszaehler.org" CONF_HTTPLOG_PATH="/httplog/httplog.php" # CONF_HTTPLOG_INCLUDE_TIMESTAMP is not set # CONF_HTTPLOG_INCLUDE_UUID is not set CONF_HTTPLOG_UUID="12345678-9ABC-DEF0-1234-56789ABCDEF0" # DEBUG_HTTPLOG is not set # IRC_SUPPORT is not set CONF_IRC_IP="192.168.168.55" CONF_IRC_PORT=6667 CONF_IRC_CHANNEL="ethersex" CONF_IRC_USERNAME="ethersex" CONF_IRC_NICKNAME="ethersex" CONF_IRC_REALNAME="Ethersex" # IRC_GREET_SUPPORT is not set # DEBUG_IRC is not set # MDNS_SD_SUPPORT is not set # MODBUS_SUPPORT is not set # MYSQL_SUPPORT is not set CONF_MYSQL_IP="192.168.23.254" CONF_MYSQL_USERNAME="root" CONF_MYSQL_PASSWORD="password" CONF_MYSQL_SCHEMA="mavisdb" # DEBUG_MYSQL is not set # NETSTAT_SUPPORT is not set CONF_NETSTAT_SERVICE_IP="212.202.153.62" CONF_NETSTAT_SERVICE="ku.rs-west.de" CONF_NETSTAT_API="/ethersex/stat/" # DEBUG_NETSTAT is not set # SOAP_SUPPORT is not set # SNMP_SUPPORT is not set # SENDMAIL_SUPPORT is not set CONF_SENDMAIL_IP="192.168.11.254" CONF_SENDMAIL_FROM="sysinfo@dl2oam.local" CONF_SENDMAIL_TO="sysinfo@dl2oam.local" # SENDMAIL_AUTH_SUPPORT is not set # DEBUG_SENDMAIL is not set # SMS77_SUPPORT is not set CONF_SMS77_SERVICE="gateway.sms77.de" CONF_SMS77_USER="" CONF_SMS77_PASS="" CONF_SMS77_TO="" # SMS77_EEPROM_SUPPORT is not set # DEBUG_SMS77 is not set # SYSLOG_SUPPORT is not set CONF_SYSLOG_SERVER="192.168.11.11" # TWITTER_SUPPORT is not set CONF_TWITTER_SERVICE="identi.ca" CONF_TWITTER_API="/api" CONF_TWITTER_USERNAME="ethersex" CONF_TWITTER_PASSWORD="" CONF_TWITTER_AUTH="ZXRoZXJzZXg6" # DEBUG_TWITTER is not set # USTREAM_SUPPORT is not set CONF_USTREAM_IP="205.188.234.7" CONF_USTREAM_PORT=80 # DEBUG_USTREAM is not set # YPORT_SUPPORT is not set YPORT_USART_0=y YPORT_USE_USART=0 YPORT_PORT=7970 YPORT_BAUDRATE=115200 YPORT_BUFFER_LEN=32 # DEBUG_YPORT is not set # MSR1_SUPPORT is not set MSR1_USART_0=y MSR1_USE_USART=0 # DEBUG_MSR1 is not set # TO1_SUPPORT is not set TO1_USART_0=y TO1_USE_USART=0 TO1_SENSOR_COUNT=1 # DEBUG_TO1 is not set # SERIAL_LINE_LOG_SUPPORT is not set SERIAL_LINE_LOG_USART_0=y SERIAL_LINE_LOG_USE_USART=0 SERIAL_LINE_LOG_TIMEOUT=20 SERIAL_LINE_LOG_EOL=0A SERIAL_LINE_LOG_COUNT=60 SERIAL_LINE_LOG_BAUDRATE=9600 # SERIAL_LINE_LOG_SPACE_COMPRESSION is not set # DEBUG_SERIAL_LINE_LOG is not set # NMEA_SUPPORT is not set NMEA_USART_0=y NMEA_USE_USART=0 # STELLA_PROTOCOL_SUPPORT is not set UDP_STELLA_PORT=2702 # IOUDP_PROTOCOL_SUPPORT is not set UDP_IO_PORT=2702 # MOTORCURTAIN_PROTOCOL_SUPPORT is not set UDP_MOTORCURTAIN_PORT=2704 # CW_SUPPORT is not set CW_WPM=12 # CW_BOOT_SUPPORT is not set # CW_BEACON_SUPPORT is not set # CW_PIN_SUPPORT is not set # CW_PWM_FREQ_SUPPORT is not set # CW_RFM12_ASK_SUPPORT is not set # DEBUG_CW is not set # # Applications # # APP_SAMPLE_SUPPORT is not set # APP_SAMPLE_INIT_AUTOSTART_SUPPORT is not set # APP_SAMPLE_PERIODIC_AUTOSTART_SUPPORT is not set # DEBUG_APP_SAMPLE is not set # BULBDIAL_SUPPORT is not set # DEBUG_BULBDIAL is not set # CLOCK_SUPPORT is not set # CLOCK_DATETIME_SUPPORT is not set # CLOCK_CRYSTAL_SUPPORT is not set # CLOCK_CPU_SUPPORT is not set # CLOCK_NTP_ADJUST_SUPPORT is not set # DCF77_SUPPORT is not set # DEBUG_DCF77 is not set # NTP_SUPPORT is not set # NTPD_SUPPORT is not set # WHM_SUPPORT is not set # DEBUG_NTP_ADJUST is not set # CRON_SUPPORT is not set # CRON_DEFAULT_UTC is not set # CRON_SUPPORT_TEST is not set # CRON_VFS_SUPPORT is not set # DEBUG_CRON_DRYRUN is not set # DEBUG_CRON is not set # CRON_STATIC_SUPPORT is not set # DYNDNS_SUPPORT is not set # UDP_ECHO_NET_SUPPORT is not set # WOL_SUPPORT is not set # MOTD_SUPPORT is not set CONF_MOTD_DEFAULT="empty" CONF_MOTD_SIZE=50 HTTPD_SUPPORT=y # HTTPD_SOAP_SUPPORT is not set # HTTPD_AUTH_SUPPORT is not set # HTTP_SD_DIR_SUPPORT is not set # MIME_SUPPORT is not set HTTPD_PORT=80 HTTPD_ALTERNATE_PORT=8000 # HTTP_FAVICON_SUPPORT is not set # DEBUG_HTTPD is not set # JABBER_SUPPORT is not set CONF_JABBER_IP="78.47.210.246" CONF_JABBER_HOSTNAME="jabber.zerties.org" CONF_JABBER_USERNAME="esex" CONF_JABBER_PASSWORD="password" CONF_JABBER_RESOURCE="ethersex" CONF_JABBER_BUDDY="stesie@jabber.zerties.org" # JABBER_EEPROM_SUPPORT is not set # JABBER_STARTUP_MESSAGE_SUPPORT is not set # JABBER_LAST_SUPPORT is not set # JABBER_VERSION_SUPPORT is not set # DEBUG_JABBER is not set # MOODLIGHT_SUPPORT is not set MOODLIGHT_CHANGEGAP_INIT=120 # STELLA_SUPPORT is not set # STELLA_HIGHFREQ is not set STELLA_START=stella_start_zero stella_start_zero=y # stella_start_all is not set # stella_start_eeprom is not set STELLA_FADE_STEP_INIT=10 STELLA_FADE_FUNCTION_INIT=stella_fade_func_0 stella_fade_func_0=y # stella_fade_func_1 is not set # DEBUG_STELLA is not set # MOTORCURTAIN_SUPPORT is not set # MOTORCURTAIN_INVERTED_MOTOR is not set # MOTORCURTAIN_INVERTED_DIRECTION is not set # MOTORCURTAIN_INVERTED_SENSORS is not set # MOTORCURTAIN_INVERTED_SAFETYSWITCH is not set # MOTORCURTAIN_PROGRESS_SUPPORT is not set # TFTP_SUPPORT is not set # TFTPOMATIC_SUPPORT is not set # UPNP_SUPPORT is not set CONF_UPNP_MULTICAST_IP="255.255.255.0" CONF_UPNP_SCHEME_FILENAME="/ih.xml" # DEBUG_UPNP is not set # WATCHCAT_SUPPORT is not set # VNC_SUPPORT is not set VNC_PORT=5900 # GUI_SUPPORT is not set # DEBUG_VNC is not set # WATCHASYNC_SUPPORT is not set CONF_WATCHASYNC_SERVER="volkszaehler.org" WATCHASYNC_SERVER_IP="78.46.142.232" CONF_WATCHASYNC_PORT=80 CONF_WATCHASYNC_METHOD="GET" CONF_WATCHASYNC_PATH="/httplog/httplog.php" CONF_WATCHASYNC_END_PATH="" # CONF_WATCHASYNC_TIMESTAMP is not set # CONF_WATCHASYNC_SUMMARIZE is not set CONF_WATCHASYNC_BUFFERSIZE=64 # CONF_WATCHASYNC_EDGDETECTVIAPOLLING is not set # # Pin Configuration # # # Port A # # CONF_WATCHASYNC_PA0 is not set # CONF_WATCHASYNC_PA1 is not set # CONF_WATCHASYNC_PA2 is not set # CONF_WATCHASYNC_PA3 is not set # CONF_WATCHASYNC_PA4 is not set # CONF_WATCHASYNC_PA5 is not set # CONF_WATCHASYNC_PA6 is not set # CONF_WATCHASYNC_PA7 is not set # # Port B # # CONF_WATCHASYNC_PB0 is not set # CONF_WATCHASYNC_PB1 is not set # CONF_WATCHASYNC_PB2 is not set # CONF_WATCHASYNC_PB3 is not set # CONF_WATCHASYNC_PB4 is not set # CONF_WATCHASYNC_PB5 is not set # CONF_WATCHASYNC_PB6 is not set # CONF_WATCHASYNC_PB7 is not set # # Port C # # CONF_WATCHASYNC_PC0 is not set # CONF_WATCHASYNC_PC1 is not set # CONF_WATCHASYNC_PC2 is not set # CONF_WATCHASYNC_PC3 is not set # CONF_WATCHASYNC_PC4 is not set # CONF_WATCHASYNC_PC5 is not set # CONF_WATCHASYNC_PC6 is not set # CONF_WATCHASYNC_PC7 is not set # # Port D # # CONF_WATCHASYNC_PD0 is not set # CONF_WATCHASYNC_PD1 is not set # CONF_WATCHASYNC_PD2 is not set # CONF_WATCHASYNC_PD3 is not set # CONF_WATCHASYNC_PD4 is not set # CONF_WATCHASYNC_PD5 is not set # CONF_WATCHASYNC_PD6 is not set # CONF_WATCHASYNC_PD7 is not set # DEBUG_WATCHASYNC is not set # GLCD_MENU_SUPPORT is not set # GLCDMENU_S1D13305 is not set # DEBUG_GLCD_MENU is not set # RFM12_SUPPORT is not set IPV4_SUPPORT=y
