/***************************************************** This program was produced by the CodeWizardAVR V2.04.9a Evaluation Automatic Program Generator © Copyright 1998-2010 Pavel Haiduc, HP InfoTech s.r.l. http://www.hpinfotech.com Project : Version : Date : 2/1/2011 Author : Freeware, for evaluation and non-commercial use only Company : Comments: Chip type : ATmega32 Program type : Application AVR Core Clock frequency: 16.000000 MHz Memory model : Small External RAM size : 0 Data Stack size : 512 *****************************************************/ #include #include // Ansteuerung eines HD44780 kompatiblen LCD im 4-Bit-Interfacemodus // http://www.mikrocontroller.net/articles/AVR-GCC-Tutorial/LCD-Ansteuerung // #ifndef LCD_ROUTINES_H #define LCD_ROUTINES_H //////////////////////////////////////////////////////////////////////////////// // Hier die verwendete Taktfrequenz in Hz eintragen, wichtig! #ifndef F_CPU #define F_CPU 16000000 #endif //////////////////////////////////////////////////////////////////////////////// // Pinbelegung für das LCD, an verwendete Pins anpassen // Alle LCD Pins müssen an einem Port angeschlossen sein und die 4 // Datenleitungen müssen auf aufeinanderfolgenden Pins liegen // LCD DB4-DB7 <--> PORTD Bit PD0-PD3 #define LCD_PORT PORTB #define LCD_DDR DDRB #define LCD_DB PORTB.4-PORTB.7 // LCD RS <--> PORTD Bit PD4 (RS: 0=Data, 1=Command) #define LCD_RS PORTB.3 // LCD EN <--> PORTD Bit PD5 (EN: 1-Impuls für Daten) #define LCD_EN_1 PORTB.1 #define LCD_EN_2 PORTA.2 #define LCD_EN_3 PORTA.3 //////////////////////////////////////////////////////////////////////////////// // LCD Ausführungszeiten (MS=Millisekunden, US=Mikrosekunden) #define LCD_BOOTUP_MS 15 #define LCD_ENABLE_US 1 #define LCD_WRITEDATA_US 46 #define LCD_COMMAND_US 42 #define LCD_SOFT_RESET_MS1 5 #define LCD_SOFT_RESET_MS2 1 #define LCD_SOFT_RESET_MS3 1 #define LCD_SET_4BITMODE_MS 5 #define LCD_CLEAR_DISPLAY_MS 2 #define LCD_CURSOR_HOME_MS 2 //////////////////////////////////////////////////////////////////////////////// // Zeilendefinitionen des verwendeten LCD // Die Einträge hier sollten für ein LCD mit einer Zeilenlänge von 16 Zeichen passen // Bei anderen Zeilenlängen müssen diese Einträge angepasst werden #define LCD_DDADR_LINE1 0x00 #define LCD_DDADR_LINE2 0x40 #define LCD_DDADR_LINE3 0x10 #define LCD_DDADR_LINE4 0x50 //////////////////////////////////////////////////////////////////////////////// // Initialisierung: muss ganz am Anfang des Programms aufgerufen werden. void lcd_init_1( void ); void lcd_init_2( void ); void lcd_init_3( void ); //////////////////////////////////////////////////////////////////////////////// // LCD löschen void lcd_clear_1( void ); void lcd_clear_2( void ); void lcd_clear_3( void ); //////////////////////////////////////////////////////////////////////////////// // Cursor in die 1. Zeile, 0-te Spalte void lcd_home_1( void ); void lcd_home_2( void ); void lcd_home_3( void ); //////////////////////////////////////////////////////////////////////////////// // Cursor an eine beliebige Position void lcd_setcursor_1( int spalte1, int zeile1 ); void lcd_setcursor_2( int spalte2, int zeile2 ); void lcd_setcursor_3( int spalte3, int zeile3 ); //////////////////////////////////////////////////////////////////////////////// // Ausgabe eines einzelnen Zeichens an der aktuellen Cursorposition void lcd_data_1( int data1 ); void lcd_data_2( int data2 ); void lcd_data_3( int data3 ); //////////////////////////////////////////////////////////////////////////////// // Ausgabe eines Strings an der aktuellen Cursorposition void lcd_string_1( const char *data1 ); void lcd_string_2( const char *data2 ); void lcd_string_3( const char *data3 ); //////////////////////////////////////////////////////////////////////////////// // Definition eines benutzerdefinierten Sonderzeichens. // data muss auf ein Array[5] mit den Spaltencodes des zu definierenden Zeichens // zeigen void lcd_generatechar_1( int code1, const int *data1 ); void lcd_generatechar_2( int code2, const int *data2 ); void lcd_generatechar_3( int code3, const int *data3 ); //////////////////////////////////////////////////////////////////////////////// // Ausgabe eines Kommandos an das LCD. void lcd_command_1( int data1 ); void lcd_command_2( int data2 ); void lcd_command_3( int data3 ); //////////////////////////////////////////////////////////////////////////////// // LCD Befehle und Argumente. // Zur Verwendung in lcd_command // Clear Display -------------- 0b00000001 #define LCD_CLEAR_DISPLAY 0x01 // Cursor Home ---------------- 0b0000001x #define LCD_CURSOR_HOME 0x02 // Set Entry Mode ------------- 0b000001xx #define LCD_SET_ENTRY 0x04 #define LCD_ENTRY_DECREASE 0x00 #define LCD_ENTRY_INCREASE 0x02 #define LCD_ENTRY_NOSHIFT 0x00 #define LCD_ENTRY_SHIFT 0x01 // Set Display ---------------- 0b00001xxx #define LCD_SET_DISPLAY 0x08 #define LCD_DISPLAY_OFF 0x00 #define LCD_DISPLAY_ON 0x04 #define LCD_CURSOR_OFF 0x00 #define LCD_CURSOR_ON 0x02 #define LCD_BLINKING_OFF 0x00 #define LCD_BLINKING_ON 0x01 // Set Shift ------------------ 0b0001xxxx #define LCD_SET_SHIFT 0x10 #define LCD_CURSOR_MOVE 0x00 #define LCD_DISPLAY_SHIFT 0x08 #define LCD_SHIFT_LEFT 0x00 #define LCD_SHIFT_RIGHT 0x04 // Set Function --------------- 0b001xxxxx #define LCD_SET_FUNCTION 0x20 #define LCD_FUNCTION_4BIT 0x00 #define LCD_FUNCTION_8BIT 0x10 #define LCD_FUNCTION_1LINE 0x00 #define LCD_FUNCTION_2LINE 0x08 #define LCD_FUNCTION_5X7 0x00 #define LCD_FUNCTION_5X10 0x04 #define LCD_SOFT_RESET 0x30 // Set CG RAM Address --------- 0b01xxxxxx (Character Generator RAM) #define LCD_SET_CGADR 0x40 #define LCD_GC_CHAR0 0 #define LCD_GC_CHAR1 1 #define LCD_GC_CHAR2 2 #define LCD_GC_CHAR3 3 #define LCD_GC_CHAR4 4 #define LCD_GC_CHAR5 5 #define LCD_GC_CHAR6 6 #define LCD_GC_CHAR7 7 // Set DD RAM Address --------- 0b1xxxxxxx (Display Data RAM) #define LCD_SET_DDADR 0x80 #endif // Declare your global variables here void main(void) { PORTA=0x00; DDRA=0x00; PORTB=0x00; DDRB=0x00; PORTC=0x00; DDRC=0x00; PORTD=0x00; DDRD=0x00; TCCR0=0x00; TCNT0=0x00; OCR0=0x00; TCCR1A=0x00; TCCR1B=0x00; TCNT1H=0x00; TCNT1L=0x00; ICR1H=0x00; ICR1L=0x00; OCR1AH=0x00; OCR1AL=0x00; OCR1BH=0x00; OCR1BL=0x00; ASSR=0x00; TCCR2=0x00; TCNT2=0x00; OCR2=0x00; MCUCR=0x00; MCUCSR=0x00; TIMSK=0x00; ACSR=0x80; SFIOR=0x00; while (1) { lcd_init_1(); lcd_clear_1(); delay_ms(50); lcd_setcursor_1(1,1); lcd_string_1("test"); lcd_init_2(); delay_ms(50); lcd_setcursor_2(1,1); lcd_string_2("test"); lcd_init_3(); lcd_string_3("test"); } } // Ansteuerung eines HD44780 kompatiblen LCD im 4-Bit-Interfacemodus // http://www.mikrocontroller.net/articles/HD44780 // http://www.mikrocontroller.net/articles/AVR-GCC-Tutorial/LCD-Ansteuerung // // Die Pinbelegung ist über defines in lcd-routines.h einstellbar //////////////////////////////////////////////////////////////////////////////// // Erzeugt einen Enable-Puls static void lcd_enable_1( void ) { LCD_PORT |= (1<>(4-LCD_DB)); // Maske löschen LCD_PORT |= (data1>>(4-LCD_DB)); // Bits setzen lcd_enable_1(); } static void lcd_out_2( int data2 ) { data2 &= 0xF0; // obere 4 Bit maskieren LCD_PORT &= ~(0xF0>>(4-LCD_DB)); // Maske löschen LCD_PORT |= (data2>>(4-LCD_DB)); // Bits setzen lcd_enable_2(); } static void lcd_out_3( int data3 ) { data3 &= 0xF0; // obere 4 Bit maskieren LCD_PORT &= ~(0xF0>>(4-LCD_DB)); // Maske löschen LCD_PORT |= (data3>>(4-LCD_DB)); // Bits setzen lcd_enable_3(); } //////////////////////////////////////////////////////////////////////////////// // Initialisierung: muss ganz am Anfang des Programms aufgerufen werden. void lcd_init_1( void ) { // verwendete Pins auf Ausgang schalten int pins = (0x0F << LCD_DB) | // 4 Datenleitungen (1<
