Hallo, ich versuche grad folgendes Beispielprogramm aus einem Online VHDL Tutorial zum Laufen zu bekommen und habe dabei ein Problem. Das Comilieren funktiniert problemlos aber beim Simulieren erhalte ich 2 Warnungen und 2 Errormeldungen: Warning:Simulator:29 - at 0 ns: Warning: No entity is bound for inst Buzzer_Testbench/UUT/U0 of Component NOT1 WARNING:Simulator:29 - at 0 ns: Warning: No entity is bound for inst Buzzer_Testbench/UUT/U1 of Component NOT1 ERROR:Simulator:19 - Instance /Buzzer_Testbench/UUT/U2/ attempts to connect to a formal port named in1 which does not exist in the instantiated module AND2. ERROR:Simulator:34 - Elaboration failed. This is a Lite version of ISE Simulator. Die online-Hilfe von Xilinx hilft mir hier nicht weiter. Weiss jemand Rat?
1 | library ieee; |
2 | use ieee.std_logic_1164.all; |
3 | use ieee.std_logic_arith.all; |
4 | use ieee.std_logic_unsigned.all; |
5 | |
6 | |
7 | -- comments: example of the buzzer circuit of fig. 2
8 | |
9 | entity BUZZER is |
10 | port (DOOR, IGNITION, SBELT: in std_logic; |
11 | WARNING: out std_logic); |
12 | end BUZZER; |
13 | |
14 | |
15 | architecture structural of BUZZER is |
16 | -- Declarations
17 | |
18 | component AND2 |
19 | port (in1, in2: in std_logic; |
20 | out1: out std_logic); |
21 | end component; |
22 | |
23 | component OR2 |
24 | port (in1, in2: in std_logic; |
25 | out1: out std_logic); |
26 | end component; |
27 | |
28 | component NOT1 |
29 | port (in1: in std_logic; |
30 | out1: out std_logic); |
31 | end component; |
32 | |
33 | -- declaration of signals used to interconnect gates
34 | |
35 | signal DOOR_NOT, SBELT_NOT, B1, B2: std_logic; |
36 | begin
37 | -- Component instantiations statements
38 | U0: NOT1 port map (DOOR, DOOR_NOT); |
39 | U1: NOT1 port map (SBELT, SBELT_NOT); |
40 | U2: AND2 port map (IGNITION, DOOR_NOT, B1); |
41 | U3: AND2 port map (IGNITION, SBELT_NOT, B2); |
42 | U4: OR2 port map (B1, B2, WARNING); |
43 | end structural; |
