Ich möchte eine Komponente simulieren, die ich in VHDL geschrieben habe.
Dafür habe ich folgende Testbench erstellt:
1 | library ieee;
2 | use ieee.std_logic_1164.all;
3 | use ieee.numeric_std.all;
4 |
5 | -- leere entity
6 | entity bfg_tb is
7 | end entity bfg_tb;
8 |
9 | architecture bhv of bfg_basic_tb is
10 |
11 | -- Moduldeklaration
12 | component bfg_basic is
13 | port (
14 | --Ports genau so deklariert wie im bfg_basic modul
15 | rx_clk : IN STD_LOGIC;
16 | reset : IN STD_LOGIC;
17 |
18 | stop_fifo_read: OUT STD_LOGIC; --0 fifo wird gelesen, 1 fifo wird nicht gelesen
19 |
20 | PHY_data_in : IN STD_LOGIC_VECTOR(3 downto 0);
21 | PHY_RX_DV_in : IN STD_LOGIC;
22 | PHY_data_out : OUT STD_LOGIC_VECTOR(3 downto 0);
23 | PHY_TX_EN_OUT : OUT STD_LOGIC;
24 |
25 | -- AVALON Slave Interface
26 | as_address : in std_logic_vector(7 downto 0);
27 | as_chipselect : in std_logic;
28 | as_write : in std_logic;
29 | as_writedata : in std_logic_vector(31 downto 0);
30 | bfg_output_msg : out std_logic_vector(31 downto 0)
31 | );
32 | end component;
33 |
34 | -- input
35 | signal rx_clk : std_logic := '0';
36 | signal reset : std_logic;
37 |
38 | -- output
39 | signal PHY_data_out : std_logic_vector(3 downto 0);
40 |
41 | begin
42 | clk <= not clk after 20 ns; -- 25 MHz Taktfrequenz
43 | reset <= '1', '0' after 100 ns; -- erzeugt Resetsignal: --__
44 | PHY_RX_DV_in = '1';
45 | PHY_data_in(0) = '0';
46 | PHY_data_in(1) = '1';
47 | PHY_data_in(2) = '0';
48 | PHY_data_in(3) = '1';
49 |
50 | as_address = b"00000000";
51 | as_writedata = x"00000001";
52 | as_chipselect = '1';
53 | as_write = '1';
54 |
55 | generate_data process (rx_clk)
56 | PHY_data_in(0) = not PHY_data_in(0);
57 | PHY_data_in(1) = not PHY_data_in(1);
58 | PHY_data_in(2) = not PHY_data_in(2);
59 | PHY_data_in(3) = not PHY_data_in(3);
60 | end process generate_data;
61 |
62 | -- Modulinstatziierung
63 | dut : bfg_basic
64 | port map (
65 | rx_clk => rx_clk,
66 | reset => reset
67 | );
68 |
69 | end architecture;
Leider kann ich das in ModelSim nicht kompilieren. Ich möchte an die
Eingänge meiner Entity PHY_data_in 4 Bit Daten anlegen. Zusätzlich muss
das DV Signal angelegt werden. Das alles muss synchron mit einem 25MHz
Takt geschehen. Wie mache ich das? Im Prinzip würde es mir reiche, wenn
eine vorher festgelegte Bitfolge von vllt 10 Nibble hintereinander an
den Port angelegt wird. Ich möchte mir dann das PHY_data_out anschauen.
Danke
