1 | /*Header*/
2 | #ifdef USE_PIC18F4685
3 | #define __PICF4685
4 | #else
5 | #define __PICF4680
6 | #endif
7 |
8 | /*Includes*/
9 | #include "p18f4685.h" //definition for PIC18F
10 | #include "CAN18XX8.h" //definition for CAN
11 | #include "main.h" //global Defines
12 | #include "delays.h" //delay library
13 | #include "em4095.h" //RFID
14 |
15 |
16 |
17 |
18 |
19 | /**************************************************************/
20 | /* Function: High priority interrupt routine */
21 | /**************************************************************/
22 |
23 | #pragma code
24 | #pragma interrupt InterruptHandlerHigh
25 |
26 | void InterruptHandlerHigh ()
27 | {
28 | if(IRQ_INT1_FLAG)
29 | {
30 | IRQ_INT1_FLAG = CLEAR; //clear ext. interrupt 1 flag
31 | }
32 | if(TMR0_OVERFLOW_FLAG) //check for TMR0 overflow
33 | {
34 | TMR0_OVERFLOW_FLAG = CLEAR;
35 |
36 | }
37 | }
38 |
39 | /**************************************************************/
40 | /* Function: High priority interrupt Vector */
41 | /**************************************************************/
42 |
43 | #pragma code InterruptVectorHigh = 0x08
44 | void
45 | InterruptVectorHigh (void)
46 | {
47 | _asm
48 | goto InterruptHandlerHigh //jump to interrupt routine
49 | _endasm
50 | }
51 |
52 | /**************************************************************/
53 | /* Function: PIC Initializing */
54 | /**************************************************************/
55 | void PIC_Init(void)
56 | {
57 | /*Port init*/
58 | TRISB = 0b11001011; // Port-B definition: RB7=in / RB6=in / RB5=out / RB4=out / CANRX=in / CANTX=out / RB1=in / RB0=in
59 | TRISA = 0b11111111; // Bit 0 to 6 are not used
60 |
61 | /*interrupt init*/
62 | IRQ_PRIORITY = ENABLE;
63 | //IRQ_GLOBAL_LOWPRIO = DISABLE;
64 | //IRQ_GLOBAL_HIGHPRIO = 1; // only high priority IRQ
65 | IRQ_TMR0 = ENABLE;
66 | IRQ_INT0 = DISABLE;
67 | IRQ_PORTB_CHANGE = DISABLE;
68 | IRQ_INT1_EDGE_SELECT = RISING;
69 | IRQ_INT1_PRIORITY = HIGH;
70 | IRQ_INT1 = ENABLE;
71 | IRQ_INT1_FLAG = CLEAR;
72 | IRQ_TMR0_PRIORITY = HIGH;
73 |
74 | INTCONbits.GIE = 1;
75 | INTCONbits.PEIE = 0;
76 |
77 | /*Timer 0 init*/
78 | TMR0_CLK_SOURCE_SELECT = 0; // Internal instruction cycle clock (CLKO)
79 | TMR0_PRESCALER_notACTIV = 0; // Timer0 clock input comes from prescaler output. Prescaler activated
80 | TMR0_PRESCALER_T0PS0 = 1;
81 | TMR0_PRESCALER_T0PS1 = 0;
82 | TMR0_PRESCALER_T0PS2 = 0; // Set prescaler value 1:4 -> TIMER clock = 0.1us
83 | TMR0_OVERFLOW_FLAG = CLEAR;
84 | TMR0_8BIT = ENABLE;
85 |
86 | TMR0 = DISABLE; // Enable TIMER 0
87 |
88 | }
89 |
90 |
91 | /**************************************************************/
92 | /* Function: CAN Initializing */
93 | /**************************************************************/
94 | void CAN_Init(void)
95 | {
96 | /*Sets Baudrate of 125KB and goes back to normal mode*/
97 | CANInitialize(SJW_125K,BRP_125K,PHSEG1_125K,PHSEG2_125K,PROPSEG_125K, CAN_CONFIG_ALL_VALID_MSG);
98 |
99 | CANSetOperationMode(CAN_OP_MODE_CONFIG); // Set CAN module into configuration mode
100 | RXB0CONbits.RXBODBEN = ENABLE; // Double receive buffer if RXBuffer 0 full -> Message in RXBuffer 1
101 | CIOCONbits.ENDRHI = ENABLE; // CAN Tx PIN will drive VDD when recessive
102 | CANSetOperationMode(CAN_OP_MODE_NORMAL); // Set CAN module into normal mode
103 | }
104 |
105 | /**************************************************************/
106 | /* Function: MAIN */
107 | /**************************************************************/
108 | void main(void){
109 | /*temporary definition */
110 | BYTE MessageData[8];
111 | BYTE DataLen = 8;
112 | unsigned long ID = 0x11;
113 | MessageData[0]=0x08;
114 | MessageData[1]=0x80;
115 | MessageData[2]=0x11;
116 | MessageData[3]=0x01;
117 | MessageData[4]=0x02;
118 | MessageData[5]=0x04;
119 | MessageData[6]=0x12;
120 | MessageData[7]=0x14;
121 |
122 |
123 |
124 | /*Initializing of the moduls: CAN, RF and PIC*/
125 | RF_Init();
126 | CAN_Init();
127 | PIC_Init();
128 |
129 | while(1)
130 | {
131 |
132 |
133 | CANSendMessage(ID, MessageData, DataLen, CAN_TX_PRIORITY_0 & CAN_TX_STD_FRAME & CAN_TX_NO_RTR_FRAME);
134 |
135 | Delay10KTCYx(255);
136 | }
137 |
138 | }
