Forum: Platinen Probleme mit povray (Egalee 3D)
von Horst (Gast)
ich habe gerade Egale 3D und Povray installiert. (Ubuntu 8.10)
Nun habe ich erfolgreich die *.pov-Datei erzeugt und wollte sie mit
povray in ein Bild umwandeln. Das funktioniert allerdings nicht:
home@pc:~/eagle/povlinux/povray-3.6/include$ povray I<Head.pov>
bash: syntax error near unexpected token `newline'
Was mach ich da falsch??
von Εrnst B. (ernst)
Die spitzen Klammern müssen weg.
also:
povray +IHead.pov
von Horst (Gast)
povray: cannot open the user configuration file /home/christoph/.povray/3.6/povray.conf: No such file or directory
Persistence of Vision(tm) Ray Tracer Version 3.6.1 (g++ 3.4.1 @
 i686-pc-linux-gnu)
This is an official version prepared by the POV-Ray Team. See the
 documentation on how to contact the authors or visit us on the
 internet at http://www.povray.org/.
POV-Ray is based on DKBTrace 2.12 by David K. Buck & Aaron A. Collins
Copyright 1991-2003 Persistence of Vision Team
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd.
Primary POV-Ray 3.5/3.6 Developers: (Alphabetically)
  Chris Cason         Thorsten Froehlich  Nathan Kopp         Ron Parker
Contributing Authors: (Alphabetically)
  Steve Anger         Eric Barish         Dieter Bayer        Steve A. Bennett
  David K. Buck       Nicolas Calimet     Aaron A. Collins    Chris Dailey
  Steve Demlow        Andreas Dilger      Alexander Enzmann   Dan Farmer
  Mark Gordon         Christoph Hormann   Mike Hough          Chris Huff
  Kari Kivisalo       Lutz Kretzschmar    Jochen Lippert      Pascal Massimino
  Jim McElhiney       Douglas Muir        Juha Nieminen       Bill Pulver
  Eduard Schwan       Wlodzimierz Skiba   Robert Skinner      Yvo Smellenbergh
  Zsolt Szalavari     Scott Taylor        Massimo Valentini   Timothy Wegner
23
  Drew Wells          Chris Young
24
25
Other contributors are listed in the documentation.
26
27
Support libraries used by POV-Ray:
28
  ZLib 1.2.1, Copyright 1995-1998 Jean-loup Gailly and Mark Adler
29
  LibPNG 1.2.5, Copyright 1998-2002 Glenn Randers-Pehrson
30
  LibJPEG 6b, Copyright 1998 Thomas G. Lane
31
  LibTIFF 3.6.1, Copyright 1988-1997 Sam Leffler, 1991-1997 SGI
32
Redirecting Options
33
  All Streams to console..........On
34
  Debug Stream to console.........On
35
  Fatal Stream to console.........On
36
  Render Stream to console........On
37
  Statistics Stream to console....On
38
  Warning Stream to console.......On
39
Parsing Options
40
  Input file: Head.pov (compatible to version 3.61)
41
  Remove bounds........On
42
  Split unions.........Off
43
  Library paths:
44
    /usr/local/share/povray-3.6
45
    /usr/local/share/povray-3.6/ini
46
    /usr/local/share/povray-3.6/include
47
Output Options
48
  Image resolution 320 by 240 (rows 1 to 240, columns 1 to 320).
49
  Output file: /home/christoph/eagle/povlinux/povray-3.6/include/Head.png, 24
50
 bpp PNG
51
  Graphic display......On  (gamma: 2.2)
52
  Mosaic preview.......Off
53
  CPU usage histogram..Off
54
  Continued trace......Off
55
Tracing Options
56
  Quality:  9
57
  Bounding boxes.......On   Bounding threshold: 3
58
  Light Buffer.........On
59
  Vista Buffer.........On   Draw Vista Buffer....Off
60
  Antialiasing.........Off
61
  Clock value:    0.000  (Animation off)
62
63
  0:00:00 Parsing
64
File: Head.pov  Line: 117
65
Possible Parse Error: Could not find file 'tools.inc'
66
67
File Context (5 lines):
68
        1.535000,
69
70
#declare global_pcb_real_hole = 2.000000;
71
#include "tools.inc"
72
Parse Error: Cannot open include file tools.inc.
73
74
Parse Warning: Check that the file is in a directory specifed with a +L switch
75
 or 'Library_Path=' .INI item. Standard include files are in the include
76
 directory or folder. Please read your documentation carefully.
77
Total Scene Processing Times
78
  Parse Time:    0 hours  0 minutes  0 seconds (0 seconds)
79
  Photon Time:   0 hours  0 minutes  0 seconds (0 seconds)
80
  Render Time:   0 hours  0 minutes  1 seconds (1 seconds)
81
  Total Time:    0 hours  0 minutes  1 seconds (1 seconds)
Dann macht er aber immer noch kein Bild!!
von Horst (Gast)
jetzt kommt eine Fehlermeldung, dass eine Font-Datei nicht gefunden
werden kann. Wie kann ich die bei Ubuntu einbinden (glaub das geht mit
ner .ini-Datei)
MFG
von Horst (Gast)
es kommt immer wieder irgend eine andere Fehlermeldung.
Hat es jemand schon mal geschafft mit Linux und Povray ein Bild von
Eagle3D zu erzeugen??
Irgendwie komm ich nicht drauf wie das funktioniert!
MFG Horst
von Gerd (Gast)
Ja bei mir gehts ohne Probleme. Benutze Ubuntu 8.10.
Kopiere die Dateien aus den Eagle3D povray Verzeichnis nach
das +I beim Aufruf braucht man nicht.
von Horst (Gast)
habs grad mit nem Beispielboard ausgetestet - da gehts.
Bei meinem Board:
Parse Warning: Should have at least 2 objects in csg.
File: cap.inc  Line: 115
 //#local txt = text{ ttf besch_font,value,40,0 scale<diam/3,diam/3,diam/3> tran
slate<-diam/1.5,diam,-20>}
 #local leg = object{ cylinder {  <0,diam*0.2,0>,<0,-10.0>,0.25 texture{col_silv
er}}}
 #local ls2 = leadspc/2 ;
 union{
  object{ intersection{ object{txt
Parse Error: Expected 'object', undeclared identifier 'txt' found instead
Was kann man da falsch machen, dass es nicht geht??
Ausgabe von Egale 3D geht einwandfrei!
