Hallo, I have a problem with RS-232 communication between my microcontroller ATS902313 and a display. The LCD has RS232 connectors with theses pins: 1 VDD 2 TxD 3 RxD 4 DTR 5 GND 6 DSR 7 CTS 8 RTS 9 NC 1 and 9 no connected 6 and 4 connected together 8 and 7 connected together Betweens microcontroller and the LCD I put a Max202. T2out is connected to pin 3 of the LCD. Txd of microcontroller is connected to t2in. This is my program; d0 must be show on the LCD outi UBRR, _UBRR UART: sbi UCR,TXEN ;activate ldi w, d0 sbis USR,UDRE ; wait for UART Date Register Empty rjmp PC-1 ; loop back if not empty out UDR,w ; output character to UART Data Register WAIT_US 200 sbis USR,TXC rjmp PC-1 sbis USR,UDRE rjmp PC-1 cbi CR,TXEN ;desactivate WAIT_MS 200 WAIT_MS 100 After power on the microcontroller the LCd displays the right character but only one time and then there are others characters, and I'dont know from where they come. If I connect the PC to LCD with cable it wors perfect Whats the problem? Thanks Andrea
Hello Andrea, have you connected the uC to the PC ? Use a terminal programm to have a look at what it is sending via RS232. If it is what you expected you should have a closer look to the timing, a common display problem. Greets Martin
I try to connect my interface to PC and look with terminal. the result is the same. I think the max is making something wrong. Some one has new idea
