1 | #include <avr/io.h>
2 | #include <util/delay.h>
3 | #include <avr/eeprom.h>
4 | #include <avr/interrupt.h>
5 | #include <stdint.h>
6 |
7 | volatile int i = 0;
8 | volatile char MODE_VAL = 0;
9 | #define PWM_WS OCR1A //Pin Ausgang
10 | #define PWM_BL OCR1B
11 | #define LED_WS PB3
12 | #define LED_BL PB4
13 | #define DDR_IN DDRD
14 | #define PULLUP PORTD
15 | #define PIN_IN PIND
16 | #define MODE PD0
17 | #define UP PD1
18 | #define DOWN PD2
19 | #define PORT_IN PORTD
20 | #define DDR_OUT DDRB
21 | #define PORT_OUT PORTB
22 | #define LED_CHK PB7
23 |
24 | #ifndef EEMEM
25 | // alle Textstellen EEMEM im Quellcode durch __attribute__ ... ersetzen
26 | #define EEMEM __attribute__ ((section (".eeprom")))
27 | #endif
28 |
29 | uint16_t eeTOP_WS EEMEM;
30 | uint16_t eeTOP_BL EEMEM;
31 | uint16_t eePWM_WS EEMEM;
32 | uint16_t eePWM_BL EEMEM;
33 | uint16_t eeSPEED EEMEM;// = 1023; //eeTOP ist der Speicherbereich im EEPROM
34 | volatile uint16_t intTOP_WS;
35 | volatile uint16_t intTOP_BL;
36 | volatile uint16_t intPWM_WS;
37 | volatile uint16_t intPWM_BL;
38 | volatile uint16_t intSPEED;
39 |
40 |
41 | //------------ Taster entprellen ------------
42 | #define ALL_KEYS (1<<MODE | 1<<UP | 1<<DOWN)
43 |
44 | #define REPEAT_MASK (1<<UP | 1<<DOWN) // repeat: key1, key2
45 | #define REPEAT_START 50 // after 500ms
46 | #define REPEAT_NEXT 20 // every 200ms
47 | // every 200ms
48 |
49 | volatile uint8_t key_state; // debounced and inverted key state:
50 | // bit = 1: key pressed
51 | volatile uint8_t key_press; // key press detect
52 |
53 | volatile uint8_t key_rpt; // key long press and repeat
54 |
55 |
56 | ISR( TIMER0_OVF_vect ) // every 10ms
57 | {
58 | static uint8_t ct0, ct1, rpt;
59 | uint8_t i;
60 |
61 | TCNT0 = (uint8_t)(int16_t)-(F_CPU / 1024 * 10e-3 + 0.5); // preload for 10ms
62 |
63 | i = key_state ^ ~PIN_IN; // key changed ?
64 | ct0 = ~( ct0 & i ); // reset or count ct0
65 | ct1 = ct0 ^ (ct1 & i); // reset or count ct1
66 | i &= ct0 & ct1; // count until roll over ?
67 | key_state ^= i; // then toggle debounced state
68 | key_press |= key_state & i; // 0->1: key press detect
69 |
70 | if( (key_state & REPEAT_MASK) == 0 ) // check repeat function
71 | rpt = REPEAT_START; // start delay
72 | if( --rpt == 0 ){
73 | rpt = REPEAT_NEXT; // repeat delay
74 | key_rpt |= key_state & REPEAT_MASK;
75 | }
76 | }
77 |
78 | ///////////////////////////////////////////////////////////////////
79 | //
80 | // check if a key has been pressed. Each pressed key is reported
81 | // only once
82 | //
83 | uint8_t get_key_press( uint8_t key_mask )
84 | {
85 | cli(); // read and clear atomic !
86 | key_mask &= key_press; // read key(s)
87 | key_press ^= key_mask; // clear key(s)
88 | sei();
89 | return key_mask;
90 | }
91 |
92 | ///////////////////////////////////////////////////////////////////
93 | //
94 | // check if a key has been pressed long enough such that the
95 | // key repeat functionality kicks in. After a small setup delay
96 | // the key is reported beeing pressed in subsequent calls
97 | // to this function. This simulates the user repeatedly
98 | // pressing and releasing the key.
99 | //
100 | uint8_t get_key_rpt( uint8_t key_mask )
101 | {
102 | cli(); // read and clear atomic !
103 | key_mask &= key_rpt; // read key(s)
104 | key_rpt ^= key_mask; // clear key(s)
105 | sei();
106 | return key_mask;
107 | }
108 |
109 | ///////////////////////////////////////////////////////////////////
110 | //
111 | uint8_t get_key_short( uint8_t key_mask )
112 | {
113 | cli(); // read key state and key press atomic !
114 | return get_key_press( ~key_state & key_mask );
115 | }
116 |
117 | ///////////////////////////////////////////////////////////////////
118 | //
119 | uint8_t get_key_long( uint8_t key_mask )
120 | {
121 | return get_key_press( get_key_rpt( key_mask ));
122 | }
123 |
124 |
125 |
126 | void pwm_init(void)
127 | {
128 | //http://www.mikrocontroller.net/articles/AVR-GCC-Tutorial#PWM_.28Pulsweitenmodulation.29
129 | //fast-pwm; clear on compare match, set at top
130 | TCCR1A |= (1<<WGM10) | (1<<WGM11) | (1<<WGM12) | (1<<COM1A1) | (1<<COM1A0) | (1<<COM1B1) | (1<<COM1B0);
131 | TCCR1B |= (1<<CS10);
132 | //OCR1A = pwm; //compare match
133 | }
134 |
135 | void debounce_init(void)
136 | {
137 | TCCR0A = (1<<CS02)|(1<<CS00); // divide by 1024; timer for decouncing
138 | TIMSK = 1<<TOIE0;
139 | }
140 |
141 | void init_io(void)
142 | {
143 | DDR_OUT |= (1<<LED_WS) | (1<<LED_BL) | (1<<LED_CHK);
144 | PORT_OUT |= (1<<LED_WS) | (1<<LED_BL) | (1<<LED_CHK);
145 | DDR_IN &=~ (1<<MODE) | (1<<UP) | (1<<DOWN);
146 | PULLUP |= (1<<MODE) | (1<<UP) | (1<<DOWN);
147 |
148 |
149 |
150 | }
151 | void flush(void)
152 | {
153 | for (i = 0; i < intTOP_WS; i++)
154 | {
155 | PWM_WS++;
156 | PWM_BL--;
157 | _delay_ms(6);
158 |
159 | }
160 |
161 | for (i = 0; i < intTOP_BL; i++)
162 | {
163 | PWM_WS--;
164 | PWM_BL++;
165 | _delay_ms(6);
166 |
167 | }
168 |
169 | }
170 |
171 | void main(void)
172 | {
173 | init_io();
174 | debounce_init();
175 | pwm_init();
176 | intTOP_WS = eeprom_read_word(&eeTOP_WS);
177 | intTOP_BL = eeprom_read_word(&eeTOP_BL);
178 | PWM_BL = intTOP_BL;
179 | sei();
180 | while(1)
181 | {
182 | if( get_key_press( 1<<MODE ) || get_key_rpt( 1<<MODE ))
183 |
184 | {
185 | PORT_OUT &=~ (1<<LED_CHK);
186 | intTOP_WS = 250;
187 | eeprom_write_word(&eeTOP_WS, intTOP_WS); // schreiben
188 | intTOP_WS = eeprom_read_word(&eeTOP_WS);
189 |
190 |
191 | intTOP_BL = 250;
192 | eeprom_write_word(&eeTOP_BL, intTOP_BL); // schreiben
193 | intTOP_BL = eeprom_read_word(&eeTOP_BL);
194 | PWM_BL = intTOP_BL;
195 | }
196 |
197 | // - Pwm in eprom ablegen und auf ocxn schalten
198 | /*if ( !(PIN_IN & (1<<MODE)) )
199 | {
200 | PORT_OUT &=~ (1<<LED_CHK);
201 | intTOP_WS = 250;
202 | eeprom_write_word(&eeTOP_WS, intTOP_WS); // schreiben
203 | intTOP_WS = eeprom_read_word(&eeTOP_WS);
204 |
205 |
206 | intTOP_BL = 250;
207 | eeprom_write_word(&eeTOP_BL, intTOP_BL); // schreiben
208 | intTOP_BL = eeprom_read_word(&eeTOP_BL);
209 | PWM_BL = intTOP_BL;
210 | }*/
211 |
212 |
213 |
214 |
215 | flush();
216 |
217 |
218 | }
219 |
220 |
221 |
222 |
223 |
224 | }
