1 | #include ".\flash.h"
2 | #include <stdlib.h>
3 |
4 | char test1 = 0x11;
5 | char test2 = 0x22;
6 | char test3 = 0x33;
7 |
8 | //* ====================================================================== */
9 | //* Funktion um Flash zu beschreiben */
10 | //* ====================================================================== */
11 |
12 | void write_SegA(char offset,char *buf, unsigned char length,bool longwrite) {
13 | unsigned short i;
14 | Flash_ptr = (char *) 0x1880; // Flash Pointer Initialsierung
15 | FCTL1 = FWKEY + ERASE; // Set Erase bit
16 | FCTL3 = FWKEY; // Clear Lock bit
17 | *Flash_ptr = 0; // Dummy write to erase Flash segment
18 | FCTL1 = FWKEY + WRT; // Set WRT bit for write operation
19 | for(i=0; i < length; i++) {
20 | *Flash_ptr++ = buf[i]; // buffer kopieren
21 | _NOP(); // SET BREAKPOINT HERE
22 | }
23 |
24 | FCTL1 = FWKEY; // Clear WRT bit
25 | FCTL3 = FWKEY + LOCK; // Set LOCK bit
26 | }
27 |
28 |
29 | //* ====================================================================== */
30 | //* Funktion um Flash zu lesen */
31 | //* ====================================================================== */
32 |
33 | void read_SegA(char offset,char *buffer, unsigned short laenge) {
34 |
35 | unsigned short i=0;
36 | Flash_ptr = (char *) 0x1880; // Reinitialisierung Flash Pointer
37 | Flash_ptr = Flash_ptr + offset; // Offset
38 | while(i < laenge) { // Flash lesen
39 | buffer[i] = *Flash_ptr++;
40 | i++;
41 | }
42 | _NOP();
43 | }
44 |
45 | void flash_laden(void) {
46 | read_SegA(ABS_P_OFFSET_OFFSET,(char*)test1,1);
47 | read_SegA(ABS_P_STEIGUNG_OFFSET_OFFSET,(char*)test2,1);
48 | read_SegA(DELTA_P0_OFFSET_OFFSET,(char*)test3,1);
49 | }
50 |
51 | void flash_speichern(void) {
52 | write_SegA(ABS_P_OFFSET_OFFSET,(char*)&test1,1,false);
53 | write_SegA(ABS_P_STEIGUNG_OFFSET_OFFSET,(char*)&test2,1,false);
54 | write_SegA(DELTA_P0_OFFSET_OFFSET,(char*)&test3,1,false);
55 | }
