1 | U-Boot 1.3.2-g02c22ce0-dirty (May 14 2008 - 13:13:06)
2 |
3 | U-Boot code: 00000000 -> 0000e820 data: 00014098 -> 0001a788
4 | SDRAM: 64 MB at address 0x10000000
5 | Testing SDRAM...OK
6 | malloc: Using memory from 0x13fa5000 to 0x13fe5000
7 | DMA: Using memory from 0x13fa1000 to 0x13fa5000
8 | Flash: 8 MB at address 0x00000000
9 | DRAM Configuration:
10 | Bank #0: 10000000 64 MB
11 | In: serial
12 | Out: serial
13 | Err: serial
14 | Net: macb0
15 | Press SPACE to abort autoboot in 3 seconds
16 | partition changed to nor0,2
17 | ### JFFS2 loading '/boot/uImage' to 0x10400000
18 | Scanning JFFS2 FS: ......... done.
19 | ### JFFS2 load complete: 1347187 bytes loaded to 0x10400000
20 | ## Booting image at 10400000 ...
21 | Image Name: Linux-2.6.28.4
22 | Image Type: AVR32 Linux Kernel Image (gzip compressed)
23 | Data Size: 1347123 Bytes = 1.3 MB
24 | Load Address: 10000000
25 | Entry Point: 90000000
26 | Verifying Checksum ... OK
27 | Uncompressing Kernel Image ... OK
28 |
29 | Starting kernel at 90000000 (params at 13fa5008)...
30 |
31 | Linux version 2.6.28.4 (aytac@ANT-PC5) (gcc version 4.2.2-atmel.1.1.3.avr32linux.1) #1 Mon Jun 15 17:38:07 CEST 2009
32 | CPU: AT32AP700x chip revision C
33 | CPU: AP7 [01] core revision 0 (AVR32B arch revision 1)
34 | CPU: MMU configuration: Shared TLB
35 | CPU: features: dsp simd ocd perfctr java
36 | CPU: Running at 140.000 MHz
37 | Physical memory:
38 | 10000000-13ffffff
39 | Reserved memory:
40 | 10000000-10186ed7: Kernel code
41 | 10186ed8-1023caff: Kernel data
42 | Exception vectors start at 90011000
43 | CPU: Paging enabled
44 | Node 0: start_pfn = 0x10000, low = 0x14000
45 | Node 0: mem_map starts at 9023f000
46 | Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
47 | Kernel command line: root=1F02 rootfstype=jffs2 mtdparts=physmap-flash.0:128k(boot)ro,64k(env)ro,-(root)
48 | PID hash table entries: 256 (order: 8, 1024 bytes)
49 | avr32_comparator: irq 0, 140.000 MHz
50 | Console: colour dummy device 80x25
51 | console [tty0] enabled
52 | console [ttyS0] enabled
53 | Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
54 | Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
55 | Memory: 62608k/62672k available (1495k kernel code, 2864k reserved, 142k data, 68k init)
56 | Calibrating delay using timer specific routine.. 282.69 BogoMIPS (lpj=469915)
57 | Mount-cache hash table entries: 512
58 | net_namespace: 716 bytes
59 | smc smc.0: Atmel Static Memory Controller at 0xfff03400
60 | NET: Registered protocol family 16
61 | pdc pdc.0: Atmel Peripheral DMA Controller enabled
62 | at32_eic at32_eic.0: External Interrupt Controller at 0xfff00100, IRQ 19
63 | at32_eic at32_eic.0: Handling 4 external IRQs, starting with IRQ 64
64 | AVR32 AP Power Management enabled
65 | ICnova: 9 Leds
66 | bio: create slab <bio-0> at 0
67 | NET: Registered protocol family 2
68 | IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
69 | TCP established hash table entries: 2048 (order: 2, 16384 bytes)
70 | TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
71 | TCP: Hash tables configured (established 2048 bind 2048)
72 | TCP reno registered
73 | NET: Registered protocol family 1
74 | audit: initializing netlink socket (disabled)
75 | type=2000 audit(1167609600.359:1): initialized
76 | JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
77 | msgmni has been set to 122
78 | alg: hash: Chunking test 1 failed for md5-generic
79 | 00000000: 24 e5 f6 e1 36 2e 67 bb a6 f6 2f 5f 81 ff bb a4
80 | alg: No test for stdrng (krng)
81 | io scheduler noop registered
82 | io scheduler cfq registered (default)
83 | atmel_usart.0: ttyS0 at MMIO 0xffe01000 (irq = 7) is a ATMEL_SERIAL
84 | atmel_usart.1: ttyS1 at MMIO 0xffe00c00 (irq = 6) is a ATMEL_SERIAL
85 | eth0 (macb): not using net_device_ops yet
86 | MACB_mii_bus: probed
87 | eth0: Atmel MACB at 0xfff01800 irq 25 (00:1f:e5:00:09:30)
88 | eth0: attached PHY driver [Davicom DM9161A] (mii_bus:phy_addr=0:00, irq=67)
89 | physmap platform flash device: 00800000 at 00000000
90 | physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
91 | Amd/Fujitsu Extended Query Table at 0x0041
92 | number of CFI chips: 1
93 | cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
94 | 3 cmdlinepart partitions found on MTD device physmap-flash.0
95 | Creating 3 MTD partitions on "physmap-flash.0":
96 | 0x00000000-0x00020000 : "boot"
97 | 0x00020000-0x00030000 : "env"
98 | 0x00030000-0x00800000 : "root"
99 | ------------[ cut here ]------------
100 | WARNING: at fs/sysfs/dir.c:462 sysfs_add_one+0x1c/0x2c()
101 | sysfs: duplicate filename 'physmap-flash.0' can not be created
102 | Modules linked in:
103 | Call trace:
104 | [<9001b756>] warn_slowpath+0x42/0x54
105 | [<9003a562>] __free_pages+0x22/0x24
106 | [<9001a12a>] free_task+0x1e/0x24
107 | [<9001b33c>] __put_task_struct+0x72/0x76
108 | [<9001c8da>] delayed_put_task_struct+0x1e/0x20
109 | [<90036800>] __rcu_process_callbacks+0xa0/0x168
110 | [<900368da>] rcu_process_callbacks+0x12/0x20
111 | [<900c9470>] ida_get_new_above+0x1c/0x10c
112 | [<90056a88>] ifind+0x8/0x3c
113 | [<90072a56>] sysfs_ilookup_test+0x0/0xa
114 | [<9000030c>] kernel_init+0x0/0x90
115 | [<90056ada>] ilookup5+0x1e/0x24
116 | [<90072f30>] sysfs_add_one+0x1c/0x2c
117 | [<9000030c>] kernel_init+0x0/0x90
118 | [<9007339a>] create_dir+0x32/0x5c
119 | [<900733e6>] sysfs_create_dir+0x22/0x30
120 | [<90008a58>] physmap_init+0x0/0x20
121 | [<9000030c>] kernel_init+0x0/0x90
122 | [<900c9c28>] kobject_add_internal+0x90/0x140
123 | [<900c9c36>] kobject_add_internal+0x9e/0x140
124 | [<90008a58>] physmap_init+0x0/0x20
125 | [<900c9d6c>] kobject_add_varg+0x20/0x2c
126 | [<90008a58>] physmap_init+0x0/0x20
127 | [<9000030c>] kernel_init+0x0/0x90
128 | [<900c9dcc>] kobject_add+0x30/0x3c
129 | [<90008a58>] physmap_init+0x0/0x20
130 | [<900eaca4>] device_add+0x64/0x38c
131 | [<900c9932>] kobject_init_internal+0xe/0x30
132 | [<9001bffc>] printk+0xc/0x10
133 | [<900ed380>] platform_device_add+0xc0/0x110
134 | [<90008a58>] physmap_init+0x0/0x20
135 | [<9000030c>] kernel_init+0x0/0x90
136 | [<900ed41a>] platform_device_register+0xe/0x10
137 | [<90008a58>] physmap_init+0x0/0x20
138 | [<90008a70>] physmap_init+0x18/0x20
139 | [<90008a58>] physmap_init+0x0/0x20
140 | [<900122f2>] do_one_initcall+0x32/0x104
141 | [<900100b4>] __early_initcall_end+0x288/0x30c
142 | [<9000fe2c>] __early_initcall_end+0x0/0x30c
143 | [<90008a58>] physmap_init+0x0/0x20
144 | [<900364a8>] register_irq_proc+0x48/0x6c
145 | [<900364f2>] init_irq_proc+0x26/0x48
146 | [<90000352>] kernel_init+0x46/0x90
147 | [<900100b4>] __early_initcall_end+0x288/0x30c
148 | [<9000fe2c>] __early_initcall_end+0x0/0x30c
149 | [<9001d9c4>] do_exit+0x0/0x460
150 | [<9000030c>] kernel_init+0x0/0x90
151 | [<9001d9c4>] do_exit+0x0/0x460
152 |
153 | ---[ end trace 1fd1bac2a4d434fe ]---
154 | kobject_add_internal failed for physmap-flash.0 with -EEXIST, don't try to register things with the same name in the same directory.
155 | Call trace:
156 | [<900ca05c>] kobject_rename+0xdc/0x11c
157 | [<900c9c94>] kobject_add_internal+0xfc/0x140
158 | [<900c9d6c>] kobject_add_varg+0x20/0x2c
159 | [<90008a58>] physmap_init+0x0/0x20
160 | [<9000030c>] kernel_init+0x0/0x90
161 | [<900c9dcc>] kobject_add+0x30/0x3c
162 | [<90008a58>] physmap_init+0x0/0x20
163 | [<900eaca4>] device_add+0x64/0x38c
164 | [<900c9932>] kobject_init_internal+0xe/0x30
165 | [<9001bffc>] printk+0xc/0x10
166 | [<900ed380>] platform_device_add+0xc0/0x110
167 | [<90008a58>] physmap_init+0x0/0x20
168 | [<9000030c>] kernel_init+0x0/0x90
169 | [<900ed41a>] platform_device_register+0xe/0x10
170 | [<90008a58>] physmap_init+0x0/0x20
171 | [<90008a70>] physmap_init+0x18/0x20
172 | [<90008a58>] physmap_init+0x0/0x20
173 | [<900122f2>] do_one_initcall+0x32/0x104
174 | [<900100b4>] __early_initcall_end+0x288/0x30c
175 | [<9000fe2c>] __early_initcall_end+0x0/0x30c
176 | [<90008a58>] physmap_init+0x0/0x20
177 | [<900364a8>] register_irq_proc+0x48/0x6c
178 | [<900364f2>] init_irq_proc+0x26/0x48
179 | [<90000352>] kernel_init+0x46/0x90
180 | [<900100b4>] __early_initcall_end+0x288/0x30c
181 | [<9000fe2c>] __early_initcall_end+0x0/0x30c
182 | [<9001d9c4>] do_exit+0x0/0x460
183 | [<9000030c>] kernel_init+0x0/0x90
184 | [<9001d9c4>] do_exit+0x0/0x460
185 |
186 | at32_wdt at32_wdt.0: AT32AP700X WDT at 0xfff000b0, timeout 2 sec (nowayout=0)
187 | Registered led device: led1:green
188 | Registered led device: led2:green
189 | Registered led device: led3:green
190 | Registered led device: led4:green
191 | Registered led device: led5:green
192 | Registered led device: led6:green
193 | Registered led device: led7:green
194 | Registered led device: led8:green
195 | Registered led device: pwrled:red
196 | dw_dmac.0: DesignWare DMA Controller, 3 channels
197 | TCP cubic registered
198 | NET: Registered protocol family 10
199 | IPv6 over IPv4 tunneling driver
200 | NET: Registered protocol family 17
201 | RPC: Registered udp transport module.
202 | RPC: Registered tcp transport module.
203 | cpufreq: AT32AP CPU frequency driver
204 | VFS: Mounted root (jffs2 filesystem) on device 31:2.
205 | Freeing init memory: 68K (90000000 - 90011000)
206 | init started: BusyBox v1.5.0 (2008-04-24 11:31:03 CEST) multi-call binary
207 | starting pid 842, tty '/dev/ttyS0': '/sbin/getty'
208 |
209 |
210 |
211 | Thank you for using In-Circuit ICNova
212 |
213 | icnova login: eth0: link up (100/Full)
