Hallo, ich habe den mySmartUSB Programmer. Mit dem kann ich erfolgreich ATmega8 brennen. Jetzt möchte ich einen ATmega168 brennen und es funktioniert nicht. "selected device is not supported by programmer: m168" Das mySmartUSB hat die neuste firmware (V2.5) und ich benutze das neuste WinAVR (03/2009). Woran kann das liegen? Gruß Stefan
Dazu muss ich noch sagen... beim Programmieren erscheint immer folgende Meldung: Programmer supports the following devices: Device code: 0x01 = (unknown) Device code: 0x02 = (unknown) Device code: 0x03 = (unknown) Device code: 0x04 = (unknown) Device code: 0x05 = (unknown) Device code: 0x06 = (unknown) Device code: 0x07 = (unknown) Device code: 0x08 = (unknown) Device code: 0x09 = (unknown) Device code: 0x0a = (unknown) Device code: 0x0b = (unknown) Device code: 0x0c = (unknown) Device code: 0x0d = (unknown) Device code: 0x0e = (unknown) Device code: 0x0f = (unknown) Device code: 0x10 = (unknown) Device code: 0x11 = (unknown) Device code: 0x12 = (unknown) Device code: 0x13 = AT90S1200 Device code: 0x14 = (unknown) Device code: 0x15 = (unknown) Device code: 0x16 = (unknown) Device code: 0x17 = (unknown) Device code: 0x18 = (unknown) Device code: 0x19 = (unknown) Device code: 0x1a = (unknown) Device code: 0x1b = (unknown) Device code: 0x1c = (unknown) Device code: 0x1d = (unknown) Device code: 0x1e = (unknown) Device code: 0x1f = (unknown) Device code: 0x20 = ATtiny84 Device code: 0x21 = (unknown) Device code: 0x22 = (unknown) Device code: 0x23 = (unknown) Device code: 0x24 = (unknown) Device code: 0x25 = (unknown) Device code: 0x26 = (unknown) Device code: 0x27 = (unknown) Device code: 0x28 = AT90S4414 Device code: 0x29 = (unknown) Device code: 0x2a = (unknown) Device code: 0x2b = (unknown) Device code: 0x2c = (unknown) Device code: 0x2d = (unknown) Device code: 0x2e = (unknown) Device code: 0x2f = (unknown) Device code: 0x30 = AT90S4433 Device code: 0x31 = (unknown) Device code: 0x32 = (unknown) Device code: 0x33 = (unknown) Device code: 0x34 = AT90S2333 Device code: 0x35 = (unknown) Device code: 0x36 = (unknown) Device code: 0x37 = (unknown) Device code: 0x38 = AT90S8515 Device code: 0x39 = (unknown) Device code: 0x3a = ATMEGA8515 Device code: 0x3b = (unknown) Device code: 0x3c = (unknown) Device code: 0x3d = (unknown) Device code: 0x3e = (unknown) Device code: 0x3f = (unknown) Device code: 0x40 = (unknown) Device code: 0x41 = ATMEGA103 Device code: 0x42 = (unknown) Device code: 0x43 = ATMEGA128 Device code: 0x44 = (unknown) Device code: 0x45 = ATMEGA64 Device code: 0x46 = (unknown) Device code: 0x47 = (unknown) Device code: 0x48 = (unknown) Device code: 0x49 = (unknown) Device code: 0x4a = (unknown) Device code: 0x4b = (unknown) Device code: 0x4c = AT90S2343 Device code: 0x4d = (unknown) Device code: 0x4e = (unknown) Device code: 0x4f = (unknown) Device code: 0x50 = (unknown) Device code: 0x51 = (unknown) Device code: 0x52 = (unknown) Device code: 0x53 = (unknown) Device code: 0x54 = (unknown) Device code: 0x55 = ATtiny12 Device code: 0x56 = ATtiny15 Device code: 0x57 = (unknown) Device code: 0x58 = (unknown) Device code: 0x59 = (unknown) Device code: 0x5a = (unknown) Device code: 0x5b = (unknown) Device code: 0x5c = (unknown) Device code: 0x5d = (unknown) Device code: 0x5e = ATtiny2313 Device code: 0x5f = (unknown) Device code: 0x60 = ATMEGA161 Device code: 0x61 = (unknown) Device code: 0x62 = (unknown) Device code: 0x63 = ATMEGA162 Device code: 0x64 = ATMEGA163 Device code: 0x65 = (unknown) Device code: 0x66 = (unknown) Device code: 0x67 = (unknown) Device code: 0x68 = AT90S8535 Device code: 0x69 = ATMEGA8535 Device code: 0x6a = (unknown) Device code: 0x6b = (unknown) Device code: 0x6c = AT90S4434 Device code: 0x6d = (unknown) Device code: 0x6e = (unknown) Device code: 0x6f = (unknown) Device code: 0x70 = (unknown) Device code: 0x71 = (unknown) Device code: 0x72 = ATMEGA32 Device code: 0x73 = (unknown) Device code: 0x74 = ATMEGA6450 Device code: 0x75 = ATMEGA6490 Device code: 0x76 = ATMEGA8 Device code: 0x77 = (unknown) Device code: 0x78 = ATMEGA169 Device code: 0x79 = (unknown) Device code: 0x7a = (unknown) Device code: 0x7b = (unknown) Device code: 0x7c = (unknown) Device code: 0x7d = (unknown) Device code: 0x7e = (unknown) Device code: 0x7f = (unknown) Hier sieht man, dass der ATmega168 nicht aufeglisted ist. Aus welcher Datei kommen diese Daten?
Der mySmartUSB sit ein AVR910 Programmer,bei diesen programmern muss jeder neue AVR separat in der Firmware nachgepflegt werden. Dem scheint der Hersteller hier nicht nachzukommen. Besser sind hier programmer die das AVRISPmkII oder STK500v2 protokoll unterstützen.
Hi und danke für deine Antwort. Mit dem "myAVR Workpad PLUS" kann ich den ATmega168 brennen, also an der Hardware kanns nicht liegen.
