1 | File transfer via NFS from server 192.168.1.206; our IP address is 192.168.1.99
2 | Filename '/home/avr32/grasshopper_buildroot/project_build_avr32/grasshopper/root/boot/uImage'.
3 | Load address: 0x10400000
4 | Loading: #################################################################
5 | #################################################################
6 | #################################################################
7 | ######################################################
8 | done
9 | Bytes transferred = 1271320 (136618 hex)
10 | partition changed to nor0,2
11 | ## Booting image at 10400000 ...
12 | Image Name: Linux-2.6.27.6.atmel.1
13 | Image Type: AVR32 Linux Kernel Image (gzip compressed)
14 | Data Size: 1271256 Bytes = 1.2 MB
15 | Load Address: 10000000
16 | Entry Point: 90000000
17 | Verifying Checksum ... OK
18 | Uncompressing Kernel Image ... OK
19 |
20 | Starting kernel at 90000000 (params at 13fa5008)...
21 |
22 | Linux version 2.6.27.6.atmel.1 (avr32@avr32-desktop) (gcc version 4.2.2-atmel.1.1.3.buildroot.1) #1 Fri Jul 3 10:37:57 CEST 2009
23 | CPU: AT32AP700x chip revision C
24 | CPU: AP7 [01] core revision 0 (AVR32B arch revision 1)
25 | CPU: MMU configuration: Shared TLB
26 | CPU: features: dsp simd ocd perfctr java
27 | CPU: Running at 140.000 MHz
28 | Physical memory:
29 | 10000000-13ffffff
30 | Reserved memory:
31 | 10000000-10187c77: Kernel code
32 | 10187c78-10221707: Kernel data
33 | Exception vectors start at 90013000
34 | CPU: Paging enabled
35 | Node 0: start_pfn = 0x10000, low = 0x14000
36 | Node 0: mem_map starts at 90224000
37 | Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
38 | Kernel command line: nfsroot=$(serverip):/home/avr32/grasshopper_buildroot/project_build_avr32/grasshopper/::$(serverip)::255.255.255.0::eth0:dhcp
39 | PID hash table entries: 256 (order: 8, 1024 bytes)
40 | avr32_comparator: irq 0, 140.000 MHz
41 | console [ttyS0] enabled
42 | Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
43 | Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
44 | Memory: 62724k/62784k available (1491k kernel code, 2752k reserved, 111k data, 76k init)
45 | SLUB: Genslabs=10, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
46 | Calibrating delay using timer specific routine.. 281.76 BogoMIPS (lpj=563536)
47 | Mount-cache hash table entries: 512
48 | net_namespace: 756 bytes
49 | smc smc.0: Atmel Static Memory Controller at 0xfff03400
50 | NET: Registered protocol family 16
51 | Grasshopper: 2 PWMs
52 | Grasshopper: 6 Leds
53 | pdc pdc.0: Atmel Peripheral DMA Controller enabled
54 | at32_eic at32_eic.0: External Interrupt Controller at 0xfff00100, IRQ 19
55 | at32_eic at32_eic.0: Handling 4 external IRQs, starting with IRQ 64
56 | AVR32 AP Power Management enabled
57 | dw_dmac.0: DesignWare DMA Controller, 3 channels
58 | NET: Registered protocol family 2
59 | IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
60 | TCP established hash table entries: 2048 (order: 2, 16384 bytes)
61 | TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
62 | TCP: Hash tables configured (established 2048 bind 2048)
63 | TCP reno registered
64 | NET: Registered protocol family 1
65 | JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
66 | msgmni has been set to 122
67 | io scheduler noop registered
68 | io scheduler cfq registered (default)
69 | atmel_usart.0: ttyS0 at MMIO 0xffe01000 (irq = 7) is a ATMEL_SERIAL
70 | MACB_mii_bus: probed
71 | eth0: Atmel MACB at 0xfff01800 irq 25 (00:1f:e5:00:09:00)
72 | eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:00, irq=-1)
73 | physmap platform flash device: 00800000 at 00000000
74 | physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
75 | Amd/Fujitsu Extended Query Table at 0x0041
76 | number of CFI chips: 1
77 | cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
78 | RedBoot partition parsing not available
79 | Using physmap partition information
80 | Creating 3 MTD partitions on "physmap-flash.0":
81 | 0x00000000-0x00020000 : "u-boot"
82 | 0x00020000-0x00030000 : "env"
83 | 0x00030000-0x00800000 : "root"
84 | at32ap700x_rtc at32ap700x_rtc.0: rtc core: registered at32ap700x_rtc as rtc0
85 | at32ap700x_rtc at32ap700x_rtc.0: Atmel RTC for AT32AP700x at fff00080 irq 21
86 | at32_wdt at32_wdt.0: AT32 WDT at 0xfff000b0, timeout 2 sec (nowayout=0)
87 | atmel_mci atmel_mci.0: Atmel MCI controller at 0xfff02400 irq 28, 1 slots
88 | Registered led device: pwm0
89 | Registered led device: pwm1
90 | Registered led device: led1:green
91 | Registered led device: led2:green
92 | Registered led device: led3:green
93 | Registered led device: led4:green
94 | Registered led device: led5:green
95 | Registered led device: led8:green
96 | TCP cubic registered
97 | Initializing XFRM netlink socket
98 | NET: Registered protocol family 10
99 | IPv6 over IPv4 tunneling driver
100 | NET: Registered protocol family 17
101 | NET: Registered protocol family 15
102 | RPC: Registered udp transport module.
103 | RPC: Registered tcp transport module.
104 | cpufreq: AT32AP CPU frequency driver
105 | at32ap700x_rtc at32ap700x_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0)
106 | Root-NFS: No NFS server available, giving up.
107 | VFS: Unable to mount root fs via NFS, trying floppy.
108 | VFS: Cannot open root device "<NULL>" or unknown-block(2,0)
109 | Please append a correct "root=" boot option; here are the available partitions:
110 | 1f00 128 mtdblock0 (driver?)
111 | 1f01 64 mtdblock1 (driver?)
112 | 1f02 8000 mtdblock2 (driver?)
113 | Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
