Habe versucht den ICD 2 zu installieren. Bekomme den Selbstest nicht hin. Target Vdd ist auf Low MCLR Vdd ist auf Low der Rest Pass Jemand eien Tipp oder schon mal das gleiche Problem gehabt? Danke ung Gruess Running ICD Self Test ... Failed Self Test. See ICD2 Settings (Programmer->Settings) (status tab) for details. Connecting to MPLAB ICD 2 ...Connected Setting Vdd source to target ...Reading ICD Product ID Running ICD Self Test ... Failed Self Test. See ICD2 Settings (Programmer->Settings) (status tab) for details. MPLAB ICD 2 ready for next operation Programming Target... ICDWarn0021: No Vdd voltage detected at Target. Continue with operation? ICDWarn0052: MPLAB ICD 2 cannot validate a target device. Please make sure that the target device is connected and properly powered. Select "OK" to continue, or "CANCEL" to abort the operation ...Validating configuration fields ICDWarn0033: MPLAB ICD 2 does not support programming this device if both the internal oscillator and internal MCLR are selected. You may continue programming, but you are encouraged to cancel, reconfigure your device, and try again. ...Erasing Part ...Programming Program Memory (0x0 - 0x1A3) Verifying... ICDWarn0021: No Vdd voltage detected at Target. Continue with operation? ICDWarn0052: MPLAB ICD 2 cannot validate a target device. Please make sure that the target device is connected and properly powered. Select "OK" to continue, or "CANCEL" to abort the operation ...Program Memory ICD0161: Verify failed (MemType = Program, Address = 0x0, Expected Val = 0x28B4, Val Read = 0x0) ICD0275: Programming failed.
Ist doch ganz normal. Jedenfalls für einen ICD2, der nicht mit irgendeiner Zielhardware verbunden ist...
MPLAB ICD 2 ready for next operation Connecting to MPLAB ICD 2 ...Connected Setting Vdd source to target ...Reading ICD Product ID Running ICD Self Test ... Failed Self Test. See ICD2 Settings (Programmer->Settings) (status tab) for details. MPLAB ICD 2 ready for next operation Habe einen 16F628 dran... Target Vdd:0.00 Target Vpp:12.30 MPLAB ICD 2 Vpp:12.94 Power ist extern und nicht von USB und ist auch so angewählt... So denke ich ist etwas nicht mehr so "normal" ? Gruess
Das Problem steht doch da:
> Target Vdd:0.00
Prüfe also mal deine externe Spannung, ob die auch an der Vdd Leitung
vom ICD2 anliegt.
Am Netzsecker sind die 9 V vorhanden und richtig gepolt. Auf der Steckplatine ist Vdd 0V, also leider nichts vorhanden. Müsste hier auch im Normalzustand ohne dass ich am brennen bin 5VDC anliegen? Wenn ja,und es nicht das Kabel ist, wie wäre dann das weitere Vorgehen? Vielen Dank für die schnellen Antworten! Echt fasziniert bin...:-)
Excalibur schrieb: > Müsste hier auch im Normalzustand ohne dass ich am brennen bin 5VDC > anliegen? Wenn du die 5V bei den ICD2 Optionen deaktiviert hast, nicht. Allerdings benötigt der ICD2 eine Spannung. Du musst hier also die VDD aus deiner Schaltung, also deine 5V anschließen.
Danke schön, hast mir echt weitergeholfen. Nun ist sie aktiviert... Schaltung existiert keine. Meinte das £Microchip programming Modul mit der Steckplatine für die PIC's Wünsche noch einen Abend und nochmals vielen Dank
