Forum: FPGA, VHDL & Co. Fehlermeldungen ignorieren?
von Bastelboy (Gast)
kriege diese Fehlermeldungen/Warnungen.
Mein CPLD tut aber was es soll.
Started process "Fit".
Release 6.3i - CPLD Optimizer/Partitioner G.35
Copyright (c) 1995-2004 Xilinx, Inc.  All rights reserved.
Considering device XC9572-15-PC44.
Flattening design..
Multi-level logic optimization...
Timing
optimization............................................................
Timing driven global resource optimization
General global resource optimization........
Re-checking device resources ...
Mapping a total of 10 equations into 4 function
blocks......WARNING:Cpld:896 - Unable to map all desired signals into
function block, FB4,
   because too many function block product terms are required. Buffering
output
   signal Produckt<6> to allow all signals assigned to this function
block to be
   placed.
WARNING:Cpld:896 - Unable to map all desired signals into function
block, FB4,
output
   signal Produckt<5> to allow all signals assigned to this function
block to be
   placed.
block, FB4,
output
   signal Produckt<3> to allow all signals assigned to this function
block to be
   placed.
java.lang.RuntimeException: Attempting to format number '0.0' using
pattern ''.
  at
org.apache.xalan.xsltc.runtime.BasisLibrary.runTimeError(BasisLibrary.ja
va:1063)
  at
va:1071)
  at
org.apache.xalan.xsltc.runtime.BasisLibrary.formatNumber(BasisLibrary.ja
va:922)
  at
org.apache.xalan.xsltc.runtime.BasisLibrary.realToString(BasisLibrary.ja
va:870)
  at summary.PrintSummaryResources()
  at summary.PrintSummary()
  at summary.applyTemplates()
  at summary.transform()
  at
org.apache.xalan.xsltc.runtime.AbstractTranslet.transform(AbstractTransl
et.java:540)
  at com.xilinx.chipviewer.inout.xslt.XSLTProcess.doTransform(Unknown
Source)
  at com.xilinx.chipviewer.inout.xslt.XSLTProcess.ProcessXML(Unknown
Source)
  at com.xilinx.chipviewer.inout.xslt.XSLTProcess.main(Unknown Source)
java.lang.ClassCastException: org.apache.xalan.res.XSLTErrorResources_de
  at org.apache.xalan.xslt.Process.main(Unknown Source)
Exception in thread "main"
Design multiplier1 has been optimized and fit into device
XC9572-15-PC44.
Completed process "Fit".
Ja, einfach ignorieren  :-o
> Unable to map all desired signals into function block, FB4,
Dein CPLD ist zu klein. Einfach ignorieren :-o
Das ist aber seltsam...
EDIT:
> Design multiplier1 has been optimized and fit into device XC9572-15-PC44.
Ach der Multiplizerer...
Bei mir ging der ohne Fehler durch.
Mach mal "Cleanup Project Files".
von Grashalm (Gast)
Die Software ist so etwas von alt, das ist schon Museumsreif...
Ja, habe ich mir extra runtergeladen um mit dem Buch von Rainer Jost
kompatibel zu bleiben.   :-)
Werde natürlich wenn ich mehr Ahnung habe eine neue Software benutzen...
von Georg A. (Gast)
Die Fehlermeldung mit dem Java-Stack-Rotz ist wohl nur irgendein Bug bei
der Erzeugung des Reports. Naja, müssen ja alle Buzzword-Technologien
immer gleich verwendet werden. Java, XML, XSL, you name it...
Die Warnungen vorher kann man ignorieren, wenn man weiss, was sie
bedeuten ;-) Das sagt nur, dass du zuviel Produktterme brauchst für
EINEN Funktionsblock (=18 Makrozellen). Wenn das CPLD ein GAL wäre, wäre
jetzt Schluss. Da es beim 9572 aber 4 Funktionsblöcke gibt, werden ein
paar der Produktterme in die anderen FBs ausgelagert. Die sollten dann
auch als "burried Macrocells" auftauchen, ist aber schon lange her, dass
ich mit den 95xx was gemacht habe... Der einzige Nachteil an der Sache
ist, dass es damit etwas langsamer wird.
